RE: Repairing a Jetcat ECU    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Skygate CARF, Viperjet - RTF
Seller:  snobird
Details:   $9,600.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Repairing a Jetcat ECU
Page: <<   < prev  1 2 3 [4]
Login
RE: Repairing a Jetcat ECU - 11/19/2011 3:59 AM
sortegon
Score: 100
Last Login: 5/30/2013
Status: offline
quote:
ORIGINAL: Xairflyer
What components did you replace
Replaced the fet and drivers for the starter
(N06HD,Ndt456,fmmt4401)
Hide Signatures
(in reply to Xairflyer)
       Post #: 76
RE: Repairing a Jetcat ECU - 11/19/2011 11:31 AM
Xairflyer
Score: 105
Last Login: 6/19/2013
Status: offline
was that all the five main components on the fet side of the board?
Was about the other side?
_____________________________
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to sortegon)
       Post #: 77
RE: Repairing a Jetcat ECU - 11/20/2011 4:16 AM
sortegon
Score: 100
Status: offline
The fmmt is on the back side. Its a tiny surface controler.
Hide Signatures
       Post #: 78
RE: Repairing a Jetcat ECU - 1/27/2012 6:04 AM
kalischek
Score: 100
Last Login: 12/17/2012
Status: offline
Hello
I'm facing thae same problem all is working on the ECU except the pump. I have changed all the param (voltage to make sure even with higher voltage it doesn't work) so I have tested the transistor that are ok does someone have a schematic of the ECU version 6 ?
I think the problem can't be a big one but without schematic I have to spend few day's just to build up a schematic trying to understand the connexions on the board and we have 3
One with the CPU memory and eeprom
the second is the high current output stage
and the last is all the sensors and i/O needed for that ECU
Or if someone has a last test to propose I'm ready to do before jumping in the transistor and AOP storry
Thanks in advance
Hide Signatures
(in reply to basimpsn)
       Post #: 79
RE: Repairing a Jetcat ECU - 1/27/2012 10:46 AM
BaldEagel
Score: 118
Last Login: 6/18/2013
Status: offline
Silly question I know, but have you tested the pump to see if it runs off a 6 volt battery?
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to kalischek)
       Post #: 80
RE: Repairing a Jetcat ECU - 1/27/2012 1:06 PM
basimpsn
Score: 120
Status: offline
quote:
ORIGINAL: kalischek
Hello
Thanks in advance
If you already tried Baldeagel pump test , then go back to post # 33 and try my test. Its the same for ,Pump,Glow& Starter
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
       Post #: 81
RE: Repairing a Jetcat ECU - 1/27/2012 7:29 PM
kalischek
Score: 100
Status: offline
Hello
Thanks for your responses the pump run fine I have tested with 1.2V and turn fine
The transistors are ok I but i think there is a process that doesn't drive the transistor (a protection or ...)
I have done a mesurement with the scope and can see pulse coming 2 or 3 of few ms and than finish
I think there is a loop that control the current or ... I think i should have the schematic of the board because there is a pwm controler that will have in charge to control the voltage of the pump and I don't see anything when I try to make a test when I am in the test menu that is normaly used to purge the kero
If someone has some idea they are welcome I am electronic eng so i can understand and do a lot but if you don't know the state machine behaviour it is a little difficult
Thanks in advance
Regards
Hide Signatures
       Post #: 82
RE: Repairing a Jetcat ECU - 1/27/2012 9:51 PM
KC36330
Score: 328
Last Login: 6/17/2013
Status: offline
the processor has to see RPM and EGT before it energizes the pump, might be worth while to check those too.
JetCat USA Rep / KingTech Turbines Rep
Hide Signatures
       Post #: 83
RE: Repairing a Jetcat ECU - 1/28/2012 3:49 AM
basimpsn
Score: 120
Status: offline
Looks like you did your home work . I don't think there is a loop or fail safe circuit that could stop the PUMP TEST FUNCTION from working. The driving (pulse width) sometime comes directly from the Micro Processor. I once found a open circuit from the CPU to my glow plug TRN.
P.S Diagram not for JETCAT but use the same type TRN.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to KC36330)
       Post #: 84
RE: Repairing a Jetcat ECU - 3/9/2012 3:18 AM
coolt5
Score: 100
Last Login: 5/17/2013
Status: offline
Hi all
i have the same ecu 5.0v and i was trying to start my engine when i notice a smok coming from the ECU so i take it a part and notice the no1 in the Picture was burn so i take it to my frinde to check it for me and he ask me to git another one so he can replace it . also hey find the no2 in Picture its short also. hey ask me to replace it too.
is that mine it have to do somthing togither .
also what is the part no for no1 in Picture .
and from wher i can order them pls.
thanks in advans
SAM
Click for fullsize
Hide Signatures
       Post #: 85
RE: Repairing a Jetcat ECU - 3/9/2012 11:24 AM
coolt5
Score: 100
Status: offline
just for your info:
also the story start like this 1st:
My p80 that I have for a 1 year’s already
I tried to run it and its propene start so when the sequence start after the ignition and engine go to 5000 rpm there is a fire in the Combustion chamber the engine dos not spoall up and I think it’s the fuel dos not go to the engine so I take the fuel bomb out and tray it its work only when the volte go’s 0.600 and up but lees than that it’s not working when u tray to test it from GSU ….. Is that normal or it should work from a lower voltage
last time engine run was alomst 8 mintes.
and i didnt get over temp alarm. or the preheating
also i get acceleration delay
also its just run with propan only no fuel go to the engine
Thanks in advance
Hide Signatures
(in reply to coolt5)
       Post #: 86
RE: Repairing a Jetcat ECU - 3/9/2012 2:40 PM
basimpsn
Score: 120
Status: offline
We try to fix this problem sometime ago by looking at pictures but got no where. As for #2 looks like a 5v regulator try this web site. #1 could be anything,(JETCAT PART#) its up to your tech to determined if its a npn, pnp, two diode together or Fet. Good Luck
http://www.utsource.net/ic-datasheet/431AC-436378.html
Hide Signatures
       Post #: 87
RE: Repairing a Jetcat ECU - 12/8/2012 2:09 PM
coolt5
Score: 100
Status: offline
this picture from a jetcat p80 and i need to replace the small cheeps insaid the jet board so if anyone ever open his jet before or know the part no# of this pls let me know
or post a picture hear
thanks in advance
Hide Signatures
       Post #: 88
RE: Repairing a Jetcat ECU - 12/8/2012 7:34 PM
DrScoles
Score: 105
Status: offline
Cool thread. Bunch of guys from around the world trying to help each other out! This is way beyond me, but fun to watch and find out if things get fixed.
Hide Signatures
       Post #: 89
RE: Repairing a Jetcat ECU - 12/9/2012 6:55 AM
basimpsn
Score: 120
Status: offline
First are you having a start motor or a RPM problem?
Hide Signatures
       Post #: 90
RE: Repairing a Jetcat ECU - 12/9/2012 8:47 AM
coolt5
Score: 100
Status: offline
No sr
The only problem is I solder the lipo battery in reverse of + and - so when I connect the battery to the ecu it smoked and I open it there was a small voltage filter cheap burn so I replace it with the same no on the cheap and test everything is ok
So when I try to rotate the motor by the ground unite it rotate for 5 seconds and the smoke come from this bord in the engine as u can see in pic.
that the hole story.
And the engine was working fine before that
Hide Signatures
       Post #: 91
RE: Repairing a Jetcat ECU - 12/9/2012 2:03 PM
basimpsn
Score: 120
Status: offline
Need a better picture of the burn component. could be a protective diode or a EMF blocker to the FET transistor. Remove the bad part and re-test the ECU, and go from there.
Hide Signatures
       Post #: 92
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
