Tornado S30: Cant start the bloody thing!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Tornado BB
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Tornado S30: Cant start the bloody thing!
    Page: [1]
    Login
    Tornado S30: Cant start the bloody thing! - 5/17/2011 9:03 PM
    u4iia
    Score: 100
    Last Login: 1/10/2013
    Status: offline
    Hey guys,
    I have been running my buggy (S30) since Nov last year.  I am still consider my self a nitro newb.   Anyways,  I could not get the dang thing started.  Basically was frustrated and gave up for a few months.   So, im back, im ready and i am going to get the dam thing started one way or another.  Here is what I have done....
    1.  Replaced Glow plug several times (Hot type)
    2.  Fully Charge ignitor
    3.  I use my drill w/backplate
    4.  I took the glow plug out and added cpl drops of fuel
    5. closed HSN and LSN and backed them both out 3 turns
    6.  I use Sidewinder 20% (red stuff)
    7. Sometimes I will remove the glowplug and turn upside down to get any excess fuel out
    It hates me, bad.  It sputtered a couple of times and also ran a couple times until i removed the ignitor.  I cant seem to get the magic number of turns on the LSN or HSN.  I have spent hours trying to start.  Either im really doing something incorrect or something is not working.  How should I attack this? Thank you in advance!
    Hide Signatures
           Post #: 1
    RE: Tornado S30: Cant start the bloody thing! - 5/17/2011 9:27 PM
    NewRageRC
    Score: 100
    Last Login: 4/8/2013
    Status: offline
    I've been going through the same thing with my Backdraft, so take what I say with a grain of salt. I'm waiting on a new one way bearing now so I haven't been able to do much else.
    If it's running with the glow plug igniter on and dying when you take it off, it's probably not getting hot enough. Sounds like you know this (and added the hot glow plug), so there's your sanity check. Leaning it out should make it run hotter. Double check the stock settings for the HSN and LSN before you do anything I know I read half a dozen wrong "factory settings" before Redcat told me what was right. Then lean the HSN out until it will idle correctly. If you have to lean it out too much, you might want to turn it back a bit and lean the LSN.
    Like I said, I haven't gotten mine running, but what I thought was the factory setting when I was trying was VERY rich. Now that I know I'm pretty confident I'll be able to get it when my parts get here Friday.
    Hide Signatures
    (in reply to u4iia)
           Post #: 2
    RE: Tornado S30: Cant start the bloody thing! - 5/18/2011 8:19 PM
    ehroof
    Score: 105
    Last Login: 5/16/2013
    Status: offline
    try 2 out on the 2 needles, also if you let it sit for a while its possible the needles have gotten gummed up, i had this happen to an sh carb on one of my rc's, i took the carb off, took the needles out, sprayed it all down with some mooter cleaner from cow rc but regular carb cleaner will work also, try to get one without any bleach/chlorine. Mine would run a few seconds then turn off...... I would go with leaner needle settings first. Also check your needles by taking them out and making sure there is a point on them, i have seen them break at the end when they are put in too tightly, this will make for either a very lean running engine or a rich one depending on where the point of the broken needle is.
    _____________________________
    125 characters and 2 lines is not enough to list my RC obsession!!!
    Hide Signatures
    (in reply to NewRageRC)
           Post #: 3
    RE: Tornado S30: Cant start the bloody thing! - 5/18/2011 11:58 PM
    u4iia
    Score: 100
    Status: offline
    Ok guys.  I removed and cleaned the carb per the redcat videos.  Needles looked good.  Backed the HSN and LSN 2 1/4 turns.  I took the glowplug out and had to put several drops of full directly in cylinder to start it.  Got it started.  Ran without the igniter, open the throtlle a couple times, no smoke, maybe to lean?   Adjusted the idle so wheels stop spinning, opened throttle again and it died.  What do I adjust?
    Hide Signatures
    (in reply to ehroof)
           Post #: 4
    RE: Tornado S30: Cant start the bloody thing! - 5/19/2011 2:10 AM
    NewRageRC
    Score: 100
    Status: offline
    If there's no smoke with the throttle open its too lean
    Hide Signatures
    (in reply to u4iia)
           Post #: 5
    RE: Tornado S30: Cant start the bloody thing! - 5/19/2011 2:19 AM
    ehroof
    Score: 105
    Status: offline
    you want to richen (turn counter clockwise) the high and low needles, try a 1/2 turn on each. this should get your mix closer
    Hide Signatures
           Post #: 6
    RE: Tornado S30: Cant start the bloody thing! - 5/19/2011 2:28 AM
    u4iia
    Score: 100
    Status: offline
    Ok I got her running good.  Man, i tinkered with that thing for 4 hours non stop finding thr magic mixture.  It was gratifying though, im glad I didnt give up.  I can see where someone new could get frustrated and shelf it.  I bought a temp gun for it.  What should my temp range be for that motor?
    Hide Signatures
           Post #: 7
    RE: Tornado S30: Cant start the bloody thing! - 5/19/2011 2:51 AM
    ehroof
    Score: 105
    Status: offline
    between 200 and 270 depending on how your running it and the outside temps, 270 would be running on a hot day and alot of high speed running.
    Hide Signatures
    (in reply to u4iia)
           Post #: 8
    Page:   [1]
    Page: [1]
    Tornado BB
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.969RCU1
