DLE 111 ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> DLE 111 ?
Page: [1]
Login
DLE 111 ? - 5/19/2011 1:46 PM
Hothead
Score: 100
Last Login: 5/18/2013
Status: offline
What is the differance between the new and old DLE 111. Is there a ser# series to stay away from?
Thanks,Ken
Hide Signatures
       Post #: 1
RE: DLE 111 ? - 5/19/2011 2:13 PM
mpascual
Score: 115
Last Login: 12/27/2012
Status: offline
quote:
ORIGINAL: Hothead
Thanks,Ken
Crankshaft, crankcase, rear bearing, propeller hub and woodruff key.
Regards
Hide Signatures
(in reply to Hothead)
       Post #: 2
RE: DLE 111 ? - 5/19/2011 2:19 PM
Tired Old Man
Score: 662
Last Login: 1/16/2012
Status: offline
Add in cylinder head design. Everything new from the dealers is a "buy" engine.
_____________________________
Never lie, and never minimize or gloss. Tell it like it is and let the pieces fall where they may. The truth always wins.
Hide Signatures
(in reply to mpascual)
       Post #: 3
RE: DLE 111 ? - 5/19/2011 3:05 PM
mpascual
Score: 115
Status: offline
quote:
ORIGINAL: Tired Old Man
Add in cylinder head design. Everything new from the dealers is a ''buy'' engine.
In the newest version, i think the cylinder head is not changed.
Regards
Hide Signatures
(in reply to Tired Old Man)
       Post #: 4
RE: DLE 111 ? - 5/19/2011 3:23 PM
jedijody
Score: 309
Last Login: 1/15/2013
Status: offline
DLE has constantly made improvements and changes to their engines over the years, there are no official version 1, 2, or 3, etc. engines. About the only thing on a current production 111 thats's the same as the original ones are the bolts that hold it all together. They are all excellent and strong running engines but unless you know the crankshaft has been replaced by someone that knows how to do it, steer clear of low time engines with serial numbers below 650.
Now go outside and play
Hide Signatures
       Post #: 5
RE: DLE 111 ? - 5/19/2011 3:37 PM
mpascual
Score: 115
Status: offline
quote:
ORIGINAL: jedijody
I agree with all your words, i was talking about last improvement.
Regards
Hide Signatures
(in reply to jedijody)
       Post #: 6
RE: DLE 111 ? - 5/19/2011 8:37 PM
Hothead
Score: 100
Status: offline
Is there a way of telling new from old design by looking at the engine . if so what do I look for?
Hide Signatures
       Post #: 7
RE: DLE 111 ? - 5/19/2011 9:47 PM
Tired Old Man
Score: 662
Status: offline
Ahhh, serial number was mentioned above.... Just buy an engine with a higher number. If you're getting a new engine from a dealer I find it highly unlikely you'll get one with a serial number under 2,000, probably a lot higher.
Hide Signatures
       Post #: 8
RE: DLE 111 ? - 5/19/2011 10:29 PM
jedijody
Score: 309
Status: offline
Current production DLE111 engines have serial numbers near 5000.
Hide Signatures
       Post #: 9
RE: DLE 111 ? - 5/19/2011 10:45 PM
Tired Old Man
Score: 662
Status: offline
People worry too damn much.
Once again I'll suggest people run a couple of searches, even in this forum, on the desired subject matter. All this stuff is well over a year dead and gone, wasting the time and effort of people again answering the same questions.
Hide Signatures
       Post #: 10
RE: DLE 111 ? - 5/19/2011 10:53 PM
jedijody
Score: 309
Status: offline
quote:
ORIGINAL: Hothead
Yes, 3 round dots from the casting mold on the front of the front cylinder and rear of the rear cylinder is the newest cylinder design. A rear crankshaft bearing housing (where the serial number is engraved) of about 1-1/2" is the latest crankcase and crankshaft design and has only been out for a few months, the older version bottom end had a rear bearing housing of only 1-1/4", this is measuring the the outside of the casting where the rear crankshaft bearing is located. There are several other changes that have been made over the years but these are the major ones. Bottom line, if you want to guaranty you get the latest version you have to buy it from a distributor that buys directly from the faactory, not a local hobby shop or online swapshop.
Hide Signatures
       Post #: 11
RE: DLE 111 ? - 5/20/2011 2:11 AM
Hothead
Score: 100
Status: offline
jedijody ,Thanks for that reply. My LHS was going to give me a super good deal, I checked it out and it is indeed the old model.
Tired Old Man, I did a search and could not get the info I wanted. I thought that is what these forum's are for.
Hothead
Hide Signatures
       Post #: 12
RE: DLE 111 ? - 5/20/2011 4:34 AM
jedijody
Score: 309
Status: offline
Any of them NIB above the serial number I mentioned are excellent engines, you would be very happy with it.
Hide Signatures
       Post #: 13
RE: DLE 111 ? - 5/20/2011 8:08 PM
JOHNS3D
Score: 108
Last Login: 10/28/2011
Status: offline
mine is 3209 and works amazing.
OMP Extra 300 100cc - DLE111
AW Extra 300 50cc - DLE55
Hide Signatures
       Post #: 14
RE: DLE 111 ? - 5/22/2011 2:54 AM
lou1947
Score: 105
Last Login: 3/7/2013
Status: offline
Are the changes seen on the 111 also go for the DLE 55?If so what serial number are thew new ones?
Hide Signatures
(in reply to JOHNS3D)
       Post #: 15
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> DLE 111 ?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.640RCU1
