cleaning car    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> cleaning car Page: [1]
Login
cleaning car - 5/19/2011 4:18 PM
demonic_crow
Score: 100
Last Login: 6/4/2011
Status: offline
Would this be something good to clean up my electric buggy?
http://www.crcindustries.com/hd/content/prod_detail.aspx?PN=05103&S=N
I'm planning on cleaning out my shocks and everything and want to make sure if anyone else every use this before I do so.  Thanks
Hide Signatures
       Post #: 1
RE: cleaning car - 5/19/2011 4:33 PM
kaiser01
Score: 186
Last Login: 7/6/2012
Status: offline
you might be over thinking cleaning.
what do you want to use that spray on?
how deep are you cleaning the car?
here's what i do:
during a race i blow it off with air after each heat.
i clean the tires with simple green and a brush.
i go over the shocks with a tooth brush for anything that the air didn't get.
after a race weekend i do the same thing except i also take out the diff, clean and rebuild.
take apart shocks, drain them, blast them with a little cleaner, dry and refill.
i take apart my bl motors and blow them out and oil the bearings.
i'll take apart the entire car from time to time, to get dirt out from every where.
_____________________________
RC8BE/B4/BBT/JRX2/RC10/RC10T/DF-01/ABC GENETIC/M-03/ KRANZEL TERMINATOR/CPE PRO MOD CLOD/BLADE 120SR & CX3/TROJAN T-28/CHAMP
Hide Signatures
(in reply to demonic_crow)
       Post #: 2
RE: cleaning car - 5/19/2011 4:53 PM
demonic_crow
Score: 100
Status: offline
I need to clean my entire buggy.  I picked it up at a yard sale and it is pretty nasty.  I know I need to clean and refill the shocks cause they are way to loose.
Hide Signatures
(in reply to kaiser01)
       Post #: 3
RE: cleaning car - 5/19/2011 5:38 PM
tsan
Score: 100
Last Login: 7/13/2011
Status: offline
Very nice, I love the Ultima.
I did the same thing with one of mine last year. I disassembled it into smaller sections to clean with soap and water. You can see the pics here:
Ultima Tear Down part 1
I filled a large container with warm dish soap, and cleaned all the bits and pieces with various things. (tooth brushes, q-tips etc)
Make sure you dry it really well... especially bits like hinge pins etc. Compressed air works best to get water out of nooks and crannies. If you plan on running it later, you'll want to re-grease things like your bushings. Seeing as mine was getting shelved, I didn't bother with the re-greasing.
Tim Sanderson
http://tsanrc.com/
Hide Signatures
       Post #: 4
RE: cleaning car - 5/19/2011 5:41 PM
kaiser01
Score: 186
Status: offline
just tear it down and was in soapy warm water. no need for sprays/solvents.
i like simple green.
Hide Signatures
(in reply to tsan)
       Post #: 5
RE: cleaning car - 5/19/2011 6:04 PM
SyCo_VeNoM
Score: 621
Last Login: 5/23/2013
Status: offline
the metal pieces I would clean with rubbing alcohol or automotive brake cleaner (that stuff strips the dirt, just make sure none gets on lexan)
Platic pieces you can let soak in soapy water for awhile or a mild degreaser to get the caked on dirt off, and let them air dry.
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
       Post #: 6
RE: cleaning car - 5/19/2011 6:16 PM
FahrtAutoRC
Score: 409
Last Login: 5/17/2013
Status: offline
When we do a tear down of one of our racers we strip front assembly, rear assembly and remove all electrinics from the chassis. I then pull my diffs, rebuild them, pull my shocks, and re-do them, pull all my bearings and replace them with new and shoot the rest down with Simple Green, rinse, repeat. I do this three times, then hit every nook and cranny with compressed air, then WD-40 and/or Jig-A-Loo everything and wipe the excess witha  clean dry rag. The end result will look like these pics, and while it is only a shot of the rear section of my truck, it should give ya an idea! Takes me about one evening to do
Click to see fullsize image.
Click for fullsize
Click for fullsize
The Midnight Chef
Hide Signatures
       Post #: 7
RE: cleaning car - 5/19/2011 7:00 PM
ThunderbirdJunkie
Score: 1040
Last Login: 6/25/2012
Status: offline
ThunderbirdJunkei usually goes to the track with last week's dirt still on his truck. It's just gonna get dirty again anyway right?
"Some people can mess up an anvil with a rubber hammer" -46u
If you don''t allow yourself to fail, you''ll never allow yourself to succeed-ThunderbirdJunkie
Hide Signatures
(in reply to FahrtAutoRC)
       Post #: 8
RE: cleaning car - 5/19/2011 7:35 PM
FahrtAutoRC
Score: 409
Status: offline
Try a full rebuild just once, TBJ! You'd eb amazed how much better the vehicle goes and works all freshened up!
quote:
ORIGINAL: ThunderbirdJunkie
The Midnight Chef
Hide Signatures
(in reply to ThunderbirdJunkie)
       Post #: 9
RE: cleaning car - 5/19/2011 7:47 PM
ThunderbirdJunkie
Score: 1040
Status: offline
quote:
ORIGINAL: HimmlerHimself
ThunderbirdJunkie's got new bearings, shock o-rings and such that will probably be used after this Saturday's points race. The truck has seen better days
Hide Signatures
       Post #: 10
RE: cleaning car - 5/19/2011 8:52 PM
SyCo_VeNoM
Score: 621
Status: offline
only do it when I get a used truck
My X1 CRT I swear I probably removed half a pund of clay from it. The guy got it literally everywhere (including in the diffs )
Other than that I only will clean a a RC is if I do a bad nitro spill and the oils everywhere on it, or if an electric RC needs a chassis replaced. Might as well take 5 more minutes out to make the rest look all pretty.
Hide Signatures
       Post #: 11
RE: cleaning car - 5/19/2011 10:33 PM
demonic_crow
Score: 100
Status: offline
quote:
ORIGINAL: tsan
Actually I have an Outrage MKII.  I guess the Ultima and it are pretty close those.  Read I could use Ultima body style and stuff on it.  Here my pic:
Hide Signatures
(in reply to tsan)
       Post #: 12
RE: cleaning car - 5/19/2011 10:39 PM
demonic_crow
Score: 100
Status: offline
Thanks everyone for the tips.  I will be cleaning everything tonight.  I'm going to clean out the shock and hope I don't have to rebuild them.  Good thing I have a shop near by that have a rebuild kit.  Just hoping the rebuild kit will work out most shock since I wouldn't know what to do about mine since they are old.
Hide Signatures
       Post #: 13
RE: cleaning car - 5/20/2011 3:22 AM
ThunderbirdJunkie
Score: 1040
Status: offline
Hide Signatures
       Post #: 14
RE: cleaning car - 5/20/2011 3:53 AM
gPlayer234
Score: 105
Last Login: 4/20/2013
Status: offline
if you're palnning to do a complete thorough cleaning to a like-new condition (if you plan to sell it or something) I usually take apart the car and clean each plastic piece individually with some soap water and toothbrush.  For the shocks I usually just take the springs off and wipe everything down with a paper towel and toothbrush, again with some warm water (but I don't fully submerge the shocks).  I dry everything with an air hose.
Another way I do a quick cleaning without disassembling anything that works really well is to get everything wet and use an air compressor to spray everything off, I do it after every run and it keeps it looking like new, and it only takes a few minutes.
Hide Signatures
       Post #: 15
RE: cleaning car - 5/20/2011 3:55 AM
gPlayer234
Score: 105
Status: offline
haha junkie, do you actually do that?  Don't you get water in the gearbox or something?  Not a bad Idea
Hide Signatures
       Post #: 16
RE: cleaning car - 5/20/2011 5:04 AM
Ttam Says Blarg
Score: 186
Status: offline
Some dishwashers get hot enough to melt plastic. Keep it away from the heating element.
Aint nothin but a thang
Slash 1/16 - DB-01 - TT-01 - RC18B and a Super Cub!
Hide Signatures
(in reply to gPlayer234)
       Post #: 17
RE: cleaning car - 5/20/2011 9:28 AM
demonic_crow
Score: 100
Status: offline
LOL, thats great.  The wife would murder me if I done that, let alone with dishes in there.
Hide Signatures
       Post #: 18
RE: cleaning car - 5/20/2011 11:20 AM
demonic_crow
Score: 100
Status: offline
Well I came across just a bit of a problem.  As you can see above the previous owner had duct tape on the shock for some reason.  It left a really sticky mess and wondering how you can get that all clean up.  Right now I have the parts soaking in some dawn soap water hoping it will help.  Anyone else have any other tips.
Hide Signatures
       Post #: 19
RE: cleaning car - 5/20/2011 5:10 PM
tsan
Score: 100
Status: offline
Ah yes, the Outrage is based on the Ultima.
If soaking it doesn't help remove the tape glue, you can try a little alcohol or nail polish remover. that should do it no problem.
Tim Sanderson
http://tsanrc.com/
Hide Signatures
       Post #: 20
RE: cleaning car - 5/20/2011 6:28 PM
demonic_crow
Score: 100
Status: offline
Since this is my first RC I went nuts on the cleaning lol.  Since the shocks are nice and clean I decided everything else should be also.  Plus its still storming here so I'm not going to get to run it until it stop raining one of these days.
Hide Signatures
(in reply to tsan)
       Post #: 21
RE: cleaning car - 5/24/2011 9:34 PM
demonic_crow
Score: 100
Status: offline
It took me all saturday night to get it rebuild but it was a blast.  First time every doing this and I loved alot.  The shocks took the most time since I was trying to fix them which had no luck. I planning on modifying my buggy to aloud other parts upgrade unless I find a rc car for cheap.
Hide Signatures
       Post #: 22
RE: cleaning car - 5/24/2011 10:01 PM
tsan
Score: 100
Status: offline
Good job, that looks great! All you have to do now is try to tame that bird's nest of wires.
I'm sure you could find some 3racing shocks (or something similar) that will fit that car. Just measure the front and rear shocks, and try to find something that will fit.
Tim Sanderson
http://tsanrc.com/
Hide Signatures
       Post #: 23
RE: cleaning car - 5/24/2011 10:54 PM
demonic_crow
Score: 100
Status: offline
quote:
ORIGINAL: tsan
Yea I need to get rid of the MSC and put a ESC in it.  I notice the EZRUN 60a looks good but you cant find them in stock anywhere.  I measure the shock shaft being 35mm so kinda hard to find something to match it when some sites don't tell you the length.  I might just get some slightly bigger shocks and just slowly convert it to another kind of a buggy.  Kinda hate doing that since this is a Vintage buggy.
Hide Signatures
(in reply to tsan)
       Post #: 24
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.736RCU1
