RE: Fuel mixing advice    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> RE: Fuel mixing advice
Page: <<   < prev  1 2 3 [4] 5 6   next >   >>
Login
RE: Fuel mixing advice - 6/25/2011 4:51 PM
RCER88
Score: 124
Last Login: 4/15/2013
Status: offline
I have Rossi's and they love FAI fuel. They also love that old junk fuel that has been sitting around for years. (the kind of stuff NOTHING else will run on). I run the fireball glow plugs at about $35.00 for a card of twelve. You can get different heat ranges so you can get something in the heat range you need.
I have never mixed my own fuel but have burned many different brands and ages of fuel. With the FAI in the Rossi's there is NO difference in performance and engine settings. If I use 10% nitro I have to change glow plug and retune. My old ST 40 runs fine on FAI. My Fox 40 runs but does not idle well. Fox's like nitro. So normally I carry two types of fuel. I add a capful of castor oil to EVERY gallon of fuel I open.
Some smoke and goop is a good exchange for burning up bearings and pistons.
Hide Signatures
(in reply to KeroPower)
       Post #: 76
RE: Fuel mixing advice - 6/25/2011 5:11 PM
KeroPower
Score: 100
Last Login: 5/21/2013
Status: offline
Cool, I do some Googling for fireball glow plugs.
I have a Fox .40 too. I run it on my Klean Strip brew and an OS #6. It idles ok. Top end is very good. Maybe the ethanol helps it idle?
_____________________________
Change is the only constant.
Hide Signatures
(in reply to RCER88)
       Post #: 77
RE: Fuel mixing advice - 6/25/2011 5:12 PM
KeroPower
Score: 100
Status: offline
Here is my only BIG glow engine:
Hide Signatures
       Post #: 78
RE: Fuel mixing advice - 6/25/2011 5:53 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: KeroPower
Did you mean spark ignition? Looks like a gasser run on alcohol to me. Sounds good, though.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 79
RE: Fuel mixing advice - 6/25/2011 6:32 PM
KeroPower
Score: 100
Status: offline
Yeah it still uses the stock ignition, but it runs on glow fuel, so I call it glow.
Thanks, I like the sound too.
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 80
RE: Fuel mixing advice - 6/25/2011 8:33 PM
TCraft Lover
Score: 100
Last Login: 5/19/2013
Status: offline
1Qwksport
  I have to go in to Plymouth or Brooklyn Park. I try to support them as much as possible. I got my plugs @ Hobbytown in Brooklyn Park this morning.
Ah nuts! I''m gonna need some glue.
Hide Signatures
       Post #: 81
RE: Fuel mixing advice - 6/25/2011 8:37 PM
TCraft Lover
Score: 100
Status: offline
quote:
ORIGINAL: 1QwkSport2.5r
quote:
ORIGINAL: TCraft Lover
Yeah I'm sure no engine guru but it seems to me that SOME older engines and euro. brands do very well on low -no nitro fuel. That's one reason I'm heading out for a #6 OS plug this morning. I'm itching to do my Meth./castor test.
ST Engines are known for being intolerant of nitro over 5%. Some run 10-15% nitro in them with no problems. I tested 5% and 15% on my TT .46 Pro engine and having a minimal effect on rpm made me go with strictly 5% nitro. My K&B overheats on 15%. The TT ran 250-300rpm less on 5%. I'm gonna test FAI in the ST .90 next week.
I like using long reach plugs in engines that are supposed to use long reach plugs. Most OS plugs are short or medium reach. There are long reach OS plugs, but I don't know what they are off-hand since I don't use them.
Do you have to come to the cities to hit the hobby shop or is there a shop up by you?
 My St .45 runs very nicely on 10% with 18% oil
Hide Signatures
       Post #: 82
RE: Fuel mixing advice - 6/25/2011 8:42 PM
KeroPower
Score: 100
Status: offline
TCraft, have you fired it up yet?
Hide Signatures
(in reply to TCraft Lover)
       Post #: 83
RE: Fuel mixing advice - 6/25/2011 9:17 PM
TCraft Lover
Score: 100
Status: offline
Not yet. I just got the new glow plug installed and then plumbed a new fuel tank pump for the special brew. Probably in about 2 hrs I'll have some kind of info.
Hide Signatures
       Post #: 84
RE: Fuel mixing advice - 6/25/2011 10:03 PM
KeroPower
Score: 100
Status: offline
Okay, good luck.
Oh yeah I forgot to mention that the denatured alcohol is perfectly safe on glow fuel pumps, lines, stoppers, etc.
Hide Signatures
       Post #: 85
RE: Fuel mixing advice - 6/26/2011 12:09 AM
TCraft Lover
Score: 100
Status: offline
OK, Just got done with the test run. I give the overall performance an "A". Here's the dope bearing in mind I only had 10oz of fuel.
Temp.  70 Degr.
Humidity  67%
Dew Point 58Degr.
Klean Strip S-L-X 8oz.  2oz human ingestible castor. (or 20% oil)
First time running this prop so no benchmark RPM.
WITH OS#6 PLUG:
Peak RPM - 7700
90 Sec. Idle RPM - 1700-1800
WITH OS "F" PLUG
Same peak RPM
Idle RPM 2300 died after about 20 sec.
Notes:
-Seemed to be a little harder to start than with nitro blend.
-Very smokey
-Ran Great
-Dang it now I gotta get a big Cub for this bad boy.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by TCraft Lover -- 6/26/2011 12:52 AM >
Hide Signatures
       Post #: 86
RE: Fuel mixing advice - 6/26/2011 2:07 AM
Jim Dross
Score: 100
Last Login: 4/17/2013
Status: offline
I have used this mix for well over 30 years;
In a clean 5 gallon can add 2 qts. Nitro Methane, 1 qt. Castor Oil, 3 qts. Klotz KL-200 Oil and 3-1/2 gallons Methanol. This will give you 10% Nitro 20% Oil blend. Add 5 drops per gallon Armoral to avoid foaming.
I use this mix in all of my glow engines both 2 and 4 stroke and have yet to have any corrosion issues or bearing problems plus my glow plugs last for years.
Hide Signatures
(in reply to DashRiprock)
       Post #: 87
RE: Fuel mixing advice - 6/26/2011 2:09 AM
KeroPower
Score: 100
Status: offline
Great job! Excellent photos too. Very clear.
Yes this fuel for some reason is very smokey. You can see in my video that mine smokes a lot. Looks like an RC helicopter. I'm not sure why it is so smokey. Probably because of the higher oil content. Possibly the ethanol in the S-L-X. But hey at least you went "green" with the ethanol.
How about the carb? Did you have to lean the needles a wee bit? When you switch to all methanol FAI fuel the settings should be the same. Possibly on;y need to richen it a click or two.
Yeah the OS #6 is the plug to use with this fuel and with FAI fuel.
Did you notice that the exhaust kind of smells like rotten eggs/sulfur?
I wish it was 70 hear in Maryland. It was 80 and a bit humid. Maryland is always humid.
Hide Signatures
(in reply to Jim Dross)
       Post #: 88
RE: Fuel mixing advice - 6/26/2011 2:11 AM
KeroPower
Score: 100
Status: offline
quote:
ORIGINAL: Jim Dross
Yeah this mix is the way to go. It works great.
Hide Signatures
       Post #: 89
RE: Fuel mixing advice - 6/26/2011 2:56 AM
TCraft Lover
Score: 100
Status: offline
Yes I forgot to mention that I did indeed lean the HS needle. I looked up my original tach checks using a 16-8 MAS with 10/18 Byrons two years ago. My peak than was 8500 rpm. I've learned two things this evening with my 10 oz test. 1-This motor loves no nitro fuel. 2- It will turn a very large prop with authority. I bought his engine in 2009 for $133 out the door new. I had (still don't) no model  to use it on. But I'm really glad I bought it. It is a real powerhouse for not much money and it runs great  (thanks to you guys) on cheap fuel.
Hide Signatures
       Post #: 90
RE: Fuel mixing advice - 6/26/2011 3:27 AM
1QwkSport2.5r
Score: 155
Status: offline
Glad to hear the SLX mix worked, albeit a performance hit. Nonetheless, it's good to know one can use hardware store/drug store materials and make a model engine run. I look forward to running my ST S90K on FAI. I don't think my TT .46Pro will take to it as well, but that's my speed engine so I'll keep it on a nitro diet. I love the fact all castor keeps the inside of the engine looking so nice, and it doesn't get that foul smell in the crankcase like low castor fuel often produces. ( I equate that smell with something similar to skunky beer. )
When I'm back in town I'll do some testing with videos to post. My Airboats are dying to "go fast".
On a side note, I might be going looking for my first trainer to learn to fly planes. My TT .46 is the powerplant of choice. I get 16,800 on a 9x7 APC, and 15,800 on a 10x5 APC on my 5% nitro 20% castor brew. I'm motivated to do more experimentation though I need another gallon of castor pretty soon.
TCraft - where do you fly? I need to find a club to come hang with so I can learn to fly. Any suggestions?
Hide Signatures
       Post #: 91
RE: Fuel mixing advice - 6/26/2011 3:44 AM
TCraft Lover
Score: 100
Status: offline
I fly in Monticello at Wright flyers Club. I think that really there is no performance loss using this Faux FAI blend. My 8500 rpm was achieved with a 16-8. The 7700 rpm was with an 18-6 which is a hugh hunch of lumber compared to a 16" I think I should now test the brew using my 16-8 to really compare apples to apples. Good luck finding a club. Check out Texas Rc Planes for a cheap trainer that's very agile. Would be perfect for your TT .46.
Hide Signatures
       Post #: 92
RE: Fuel mixing advice - 6/26/2011 3:02 PM
1QwkSport2.5r
Score: 155
Status: offline
I fly in Monticello at Wright flyers Club. I think that really there is no performance loss using this Faux FAI blend. My 8500 rpm was achieved with a 16-8. The 7700 rpm was with an 18-6 which is a hugh hunch of lumber compared to a 16'' I think I should now test the brew using my 16-8 to really compare apples to apples. Good luck finding a club. Check out Texas Rc Planes for a cheap trainer that's very agile. Would be perfect for your TT .46.
Monticello is up there; I've done work up there in the past. I'll see if there is anything local to me.
I would definitely swing the 16x8 on the same fuel and compare numbers. Something you might also want to try is adding acetone to your FAI mix. This will add a little more volatility to the fuel for faster starts and better ignition. I don't think it would add much extra power but it should start better and maybe be a little less smokey. Seems the going rate is 1-3% Acetone.
Hide Signatures
       Post #: 93
RE: Fuel mixing advice - 6/26/2011 3:14 PM
Iflyglow
Score: 122
Status: offline
Don't you guys have any dirt oval racers around. I have 99.9% methanol available at the pump at several places within 10 miles of my house. Late Model dirt oval cars, Sprint Cars & Midgets, Go Karts and IMCA Mods all burn methanol. It runs about $2.50 a gallon currently. I bought a Methanol race jug, and just refill when I need some.
Hide Signatures
       Post #: 94
RE: Fuel mixing advice - 6/26/2011 3:57 PM
TCraft Lover
Score: 100
Status: offline
Yeah I've been reading about the use of acetone and there seems to be some confusion as to what dose is correct. There seems to be agreement though that it enhances idle and starting. You might check the AMA site for flying clubs near you.
Hide Signatures
       Post #: 95
RE: Fuel mixing advice - 6/26/2011 4:24 PM
KeroPower
Score: 100
Status: offline
Perhaps some gasoline might help too? 5%?
Hide Signatures
       Post #: 96
RE: Fuel mixing advice - 6/26/2011 4:51 PM
TCraft Lover
Score: 100
Status: offline
Kero,
  Do you mean that gasoline may be an aid to starting and idling?
Hide Signatures
       Post #: 97
RE: Fuel mixing advice - 6/26/2011 5:36 PM
KeroPower
Score: 100
Status: offline
Yes. It would make the fuel more volitile. This will definately help make cold starts easier since gasoline vaporizes much more easily than alcohol. Idling...not sure if it would help.
I think I'll try the acetone first though which will also make the fuel more volitile.
Hide Signatures
       Post #: 98
RE: Fuel mixing advice - 6/26/2011 5:43 PM
TCraft Lover
Score: 100
Status: offline
I don't know squat about it except that I've read some people don't even say gasoline and glow engines in the same breath!
Hide Signatures
       Post #: 99
RE: Fuel mixing advice - 6/26/2011 6:39 PM
KeroPower
Score: 100
Status: offline
Ok I just flew my .25LA with some acetone added to the Klean Strip brew. It started up no problems. Idle was definately better. I mean before the acetone I could hear the engine drop a few RPM at idle when the igniter was removed. Not anymore though. Also I think it was a little less smokey.
Hide Signatures
       Post #: 100
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> RC Fuels >> RE: Fuel mixing advice
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
