RE: 72    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> RE: 72
Page: <<   < prev  1 2 3 4 5 6 7 [8]
Login
RE: 72 - 4/6/2012 10:53 PM
The Ghost
Score: 110
Last Login: 5/21/2013
Status: offline
Mick, Good luck today, off to Mogo with the daughter and her boyfriend.
Cheers
_____________________________
Remember, Always look after the ORGANIC part of the model
Hide Signatures
(in reply to Pat Kinney)
       Post #: 176
RE: 72 - 4/7/2012 12:53 AM
F1Rodman
Score: 105
Status: offline
Sounds good buddy, hope it goes well today. Might inspire Dazza to get that big hydrolift happening.
Cheers
Mate
Hide Signatures
(in reply to mickieb49)
       Post #: 177
RE: 72 - 4/7/2012 6:27 AM
bentley marshall
Score: 105
Last Login: 5/20/2013
Status: offline
HOW DID IT GO MICK ???
owner www.rcinnovations.co.nz
Hide Signatures
(in reply to F1Rodman)
       Post #: 178
RE: 72 - 4/7/2012 8:47 AM
mickieb49
Score: 100
Status: offline
Well the engines are easy to start now, but the maiden voyage didn't go as good as i had hoped,  i think i had chopped too much off the driveshafts, so there wasn't enough shaft into the coupler, as such it went loose and lost the first shaft and prop in the shallow water, no harm done, found the shaft , reinstalled it, and gave it another try, but then because i had to loosen the drive dog, i think i rounded off the hex in the grub screw and so it then came loose.
 Bottom line i found out how it all floated,  and now i have purchased new drive shafts (longer ones) and some stainless grub screws, and a new set of allen key's.
 I will try to get the footage of it tomorrow uploaded, even though it may not be all that exciting.
 Hoping to be giving it another try once i get the new shafts.
Cheers Mick
Hide Signatures
(in reply to bentley marshall)
       Post #: 179
RE: 72 - 4/7/2012 8:53 AM
F1Rodman
Score: 105
Status: offline
Hey!! Upload it now ya big girl!!!! .... hehehe
Oh...... shafts all greased now, Ahhh!!!!
Cheers
Chris
Hide Signatures
       Post #: 180
RE: 72 - 4/7/2012 9:58 PM
The Ghost
Score: 110
Status: offline
Mick, sorry to here that, but at least you have a couple of spare drive shafts for other projects. Pics?
Cheers
Hide Signatures
       Post #: 181
RE: 72 - 4/7/2012 10:08 PM
mickieb49
Score: 100
Status: offline
Here you go then Chris,
http://www.youtube.com/watch?v=zz-G1gl5tbc
 It is only a short one as the rest of the footage was dicky !
 From the brief moment there it may nearly look promising.
Hide Signatures
(in reply to The Ghost)
       Post #: 182
RE: 72 - 4/8/2012 1:48 AM
The Ghost
Score: 110
Status: offline
Mick, it sits nice in the water, with the nose up a little it wont bow dive when you hit the power
Cheers
Hide Signatures
       Post #: 183
RE: 72 - 4/15/2012 1:06 AM
Pat Kinney
Score: 100
Last Login: 4/22/2013
Status: offline
Hi Mickie
Any progress on re-running your boat.
Pat
Hide Signatures
       Post #: 184
RE: 72 - 4/15/2012 10:45 PM
mickieb49
Score: 100
Status: offline
Hi Pat, i am intending on running it again this comming weekend, only just got the replacement drive shafts.  Don't worry i will be getting some footage of it as it happens.
regards Mick
Hide Signatures
       Post #: 185
RE: 72 - 4/16/2012 10:38 AM
wetsleeves
Score: 100
Last Login: 5/7/2013
Status: offline
hey Mick, remember measure twice cut once, even if you cut them a little longer and trim them up. Hope all is well your way.
Hide Signatures
       Post #: 186
RE: 72 - 4/20/2012 2:59 AM
The Ghost
Score: 110
Status: offline
Mick, we still on for tomorrow.
Cheers
Hide Signatures
(in reply to wetsleeves)
       Post #: 187
RE: 72 - 4/20/2012 8:13 AM
mickieb49
Score: 100
Status: offline
Hi Andrew yep we are, just as long as the weather holds up, give me a ring and i can give you the directions.  Hoping to be giving the cat it's second try....
Cheers Mick
Hide Signatures
       Post #: 188
RE: 72 - 4/21/2012 11:24 AM
wetsleeves
Score: 100
Status: offline
So Mick, how did the boat go?
Hide Signatures
       Post #: 189
RE: 72 - 4/21/2012 11:17 PM
mickieb49
Score: 100
Status: offline
Hi Pete,
 Boat went alot better than before, has plenty of promise, turns real nice and doesn't seem to have any bad tendencies ,  could only get it to half throttle due to carby tunning and some heat build up under the cowl.  Going to put some more air vents in to better the airflow and some more tweeks on the carby's should do it.
  Found out after the last run that the grub screw holding the strut at height was missing, so pretty sure what i thought was a carby problem may also be due to that.
  Here is the Vid:
http://www.youtube.com/watch?v=gM27-eWU5uA
 Don't have the heart to sell it now, just going to be too much fun.
 Any one elso have any idea's on getting it run better i am open to any coments.
Cheers all
Mick
Hide Signatures
       Post #: 190
RE: 72 - 4/21/2012 11:33 PM
mickieb49
Score: 100
Status: offline
Here is another vid taken by Andrew (Ghost), thanks Andrew for posting it, seems to have better footage.
http://www.youtube.com/watch?v=iL8v6Gh8gIY&feature=youtu.be
Regards Mick
Hide Signatures
       Post #: 191
RE: 72 - 4/21/2012 11:55 PM
wetsleeves
Score: 100
Status: offline
Good to see that shes finaly on the water. I didnt think you were going to sell her after she was running..... Why dont you make another hatch and cut the sreen out and mesh it. If that works then you can cut the painted one.
Now your just going to have to play around with the setting and try and get those 2 motors to run in sync.
Oh and we need a much larger pond so we can really stretch that girl out once shes dial in and of corse broken in..
Hide Signatures
       Post #: 192
RE: 72 - 4/22/2012 2:42 AM
The Ghost
Score: 110
Status: offline
Mick, Once you fix that pesky grub screw it won't take long to get the engines dialed in, almost there on the last run. Should have a new RX this week. Building the stand today.
Cheers
Hide Signatures
       Post #: 193
RE: 72 - 5/29/2012 10:30 AM
mickieb49
Score: 100
Status: offline
Hey guy's, just thought i would let you know that i will have to get back to this project after i have moved house and have a shed built to put all the boats in,  haven't given up yet.....
Mick
Hide Signatures
       Post #: 194
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.467RCU1
