NGH 17cc gasoline engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> NGH 17cc gasoline engine
Page: [1] 2 3 4 5 6 7   next >   >>
Login
NGH 17cc gasoline engine - 5/26/2011 2:13 PM
limbodancer
Score: 100
Last Login: 6/21/2012
Status: offline
Hi .. any experience with the NGH 17 cc gasoline engine ? Cheers!
Hide Signatures
       Post #: 1
RE: NGH 17cc gasoline engine - 5/26/2011 2:55 PM
captinjohn
Score: 247
Last Login: 5/25/2013
Status: offline
If you want more data...just google the name of the engine.
http://www.facebook.com/video/video.php?v=150833578314365&oid=110836435655891&comments
This is a new generation of small gas quality engine, it combines the advantages of both Nitro and gasoline engines, compact in size, light weight, fuel economy, reliable and powerful.
  Specifications:
  Engine Type: Gasoline Two-stroke, Air Cooled, Rotary Valve
Cylinder Type: Precision Steel Sleeve
Cylinders: Single
Crank Type-Forged: Dual Ball Bearing Support
Mounting Type: Beam or Rail Mount
Carburetor Type : Walbro WT Series
Carburetor Mounting: Front
Crankshaft Threads: 5/16" X 24 TPI
Mounting Dimensions: Owners Manual or Website
Plug Type: 1/4 X 32
Displacement: 1.02 cu in.(16.91cc)
Bore: 1.14 in. (29mm)
Stroke: 1.01 in (25.6mm)
Engine (Only) Weight: 730g
Ignition Weight: 120g
Prop Range: 14*8,15*8,16*8
RPM Range:L 2100-9000
Fuel: Unleaded Gasoline With High-Quality Two-Cycle Oil, Pre- Mixed
compression ratio: 10
Pre-Mix Oil Ratio and Type : Break-in with 25:1, General 35:1, For Air Cooled Engines
_____________________________
I never met a engine I did not like !
Hide Signatures
(in reply to limbodancer)
       Post #: 2
RE: NGH 17cc gasoline engine - 5/26/2011 4:51 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
The NGH-17 is a revised/improved version of the JBA-15g.
Michael Chow (formerly of JBA) started up NGH.
The NGH line initially showed Valley View RC as one of 2 USA distributors, but
now only Agape Racing and Hobbies is listed on the NGH web site (for USA sales).
http://www.nghengine.com/parter.asp
http://agaperacingandhobby.com/
There's already a thread here on NGH Gas Engines.....
http://www.rcuniverse.com/forum/m_10436663/anchors_10436663/mpage_1/key_/anchor/tm.htm#10436663
Another tells all on the JBA-15g (New .90 gas engine (15cc))
http://www.rcuniverse.com/forum/m_9609247/mpage_1/key_/tm.htm
Any "issues" the JBA-15g had, are supposed to be fixed in the NGH-17.
You'll need to read that msg thread for details.
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
       Post #: 3
RE: NGH 17cc gasoline engine - 5/26/2011 5:34 PM
captinjohn
Score: 247
Status: offline
My personal opinion...you would be better off to find a good deal on a new or used SuperTiger 2300 and send it to Ken Lambert.  He can make it a fine engine with needle bearings on the rod.  The NBH-17 and the JBA-15 would both sell better with needle bearing rods also.    Capt,n
Hide Signatures
(in reply to a1pcfixer)
       Post #: 4
RE: NGH 17cc gasoline engine - 5/26/2011 11:17 PM
mpascual
Score: 115
Last Login: 12/27/2012
Status: offline
I'm testing one GT17 from a couple of weeks, and all i can say is : i like it.
Not much more powerful than J15G but some issues solved, user friendly and easy adjust of needles.
Steel cylinder sleeve , pressure nipple for carb pulses on crankcase, at opposite side of exhaust, Walbro carb specially adjusted for the engine after many test with many carbs, exhaust with internal plate, no carb adapter now, included in the cast now .......
Almost all parts are new .
About brass bushing , if oil content is as recommended, NO problem.
Small gas engines does not need small needle bearings on the crankshaft side of con-rod. Small needle bearings have less and small needles.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to captinjohn)
       Post #: 5
RE: NGH 17cc gasoline engine - 5/26/2011 11:36 PM
jedijody
Score: 309
Last Login: 1/15/2013
Status: offline
That scale you have there looks like it should weigh really fast!
Now go outside and play
Hide Signatures
(in reply to mpascual)
       Post #: 6
RE: NGH 17cc gasoline engine - 5/27/2011 2:00 AM
mpascual
Score: 115
Status: offline
quote:
ORIGINAL: jedijody
Thath's only the engine , without muffler, muffler bolts, ignition, spark plug .....
Regards
Hide Signatures
(in reply to jedijody)
       Post #: 7
RE: NGH 17cc gasoline engine - 5/27/2011 3:18 AM
captinjohn
Score: 247
Status: offline
Mpascual,
 I got to take your word that the 17 & 15cc engine do not need a needle bearing.  I guess with very high quality bearing & high quality oil the engine should work out like you say.  I know that you indeed have a lot of experience with the engines.   If a film of oil is in the bushing,  does provide more of a surface to say "glide" on that surface rather than a small surface of very few needles...the bushing may indeed work good.    Also if the oil hole is done right ...that helps too...I guess.  So buyers dis-regard my post #4 ...Mpascual most likely is right.   Best Regards    Capt,n
Hide Signatures
       Post #: 8
RE: NGH 17cc gasoline engine - 5/27/2011 2:33 PM
karolh
Score: 310
Last Login: 5/26/2013
Status: offline
Capt,n I must admit, that it one of the nicest worded retractions I have ever seen
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
       Post #: 9
RE: NGH 17cc gasoline engine - 5/27/2011 2:55 PM
Andika
Score: 130
Last Login: 4/14/2013
Status: offline
quote:
ORIGINAL: mpascual
VIDEO soon please....
WALBRO Carburetors - Info for Dummies.
http://www.rcuniverse.com/forum/m_10654463/tm.htm
Hide Signatures
       Post #: 10
RE: NGH 17cc gasoline engine - 5/28/2011 12:28 AM
mpascual
Score: 115
Status: offline
This time , the manufacturer wants to release a heli version of this engine.
On the JBA15G i've tested a prototype head with bigger air cool fins.
I dont't have any helicopter to test now, and maybe the development must be done by a person who knows helis requirements.
Regards
< Message edited by mpascual -- 5/28/2011 2:26 AM >
Hide Signatures
(in reply to Andika)
       Post #: 11
RE: NGH 17cc gasoline engine - 5/28/2011 3:50 AM
Andika
Score: 130
Status: offline
he left JBA when he was testing the heli version, I wish the best for him.
the GT17 will replace a small .50 so he need at least 3HP and high rpm, over 10.000 would be correct.
don't know how he will fit a 17cc engine in all standard 50 size helis. it fits perfect on 90 helis but this engine is not enough for 3D.
1- What's about the smaller CDI from RCexl, anything new ?
Click for fullsize
Hide Signatures
       Post #: 12
RE: NGH 17cc gasoline engine - 5/28/2011 12:37 PM
optech
Score: 105
Status: offline
I've got a Century Radikal 20 heli. It does 3D fine so if they can stuff a Zenoah G20 into a .50 size airframe there is no reason NGH couldn't stuff their 17 in one as well.
The guys that make the Pantera .50 also offer a "BigBlock" kit to stuff a .90 into the Pantera. Maybe he could start with that for development.
Mike
Hide Signatures
       Post #: 13
RE: NGH 17cc gasoline engine - 5/28/2011 12:39 PM
Lifer
Score: 148
Status: offline
Have they reinforced the muffler so it doesn't distort/leak when tightened? If so, is it a bolt-on replacement for the 15cc version?
Hide Signatures
       Post #: 14
RE: NGH 17cc gasoline engine - 5/28/2011 2:23 PM
a1pcfixer
Score: 168
Status: offline
All the improvements are listed in post #5.
Manuel stated "exhaust with internal plate" which most likely is sleeves/tubes for the bolts to pass through.
Jim L.
Hide Signatures
(in reply to Lifer)
       Post #: 15
RE: NGH 17cc gasoline engine - 5/28/2011 10:58 PM
Lifer
Score: 148
Status: offline
Does anybody have a price list for a replacement muffler?
Hide Signatures
       Post #: 16
RE: NGH 17cc gasoline engine - 5/28/2011 11:14 PM
a1pcfixer
Score: 168
Status: offline
quote:
ORIGINAL: Lifer
Try contacting Jim, Susan, or Ben at ARH.
Second link in post #3 above.
Jim L.
Hide Signatures
(in reply to Lifer)
       Post #: 17
RE: NGH 17cc gasoline engine - 5/28/2011 11:50 PM
Lifer
Score: 148
Status: offline
a1pcfixer,
Thanks for the assist!
Hide Signatures
       Post #: 18
RE: NGH 17cc gasoline engine - 5/30/2011 7:28 PM
Andika
Score: 130
Status: offline
quote:
ORIGINAL: optech
Mike
You have got one but you dont have it now... why did you sell it ?
maybe because it's a stone in the air, 2.5D it's not hard 3D as you can do with any OS engine or so...
they cannot stuff the ZG20 into ANY .50 size airframe, they (Century) have their OWN BAD carbon frames, you make me laught.
As I said above the GT17 is too big for the Trex 600, Raptor 50, Outrage 50..etc you need the .90 size airframes to install the GT17..
thanks
Hide Signatures
(in reply to optech)
       Post #: 19
RE: NGH 17cc gasoline engine - 6/5/2011 10:38 PM
bdcoaster
Score: 105
Last Login: 10/30/2012
Status: offline
Hello everyone! This is Ben Willis from Agape Racing and Hobby and I would be happy to answer any questions about the NGH GT17!
Hide Signatures
       Post #: 20
RE: NGH 17cc gasoline engine - 6/6/2011 2:17 AM
skip1320
Score: 105
Status: offline
Hey Ben,what carb does it use?
Hide Signatures
(in reply to bdcoaster)
       Post #: 21
RE: NGH 17cc gasoline engine - 6/6/2011 3:53 AM
bdcoaster
Score: 105
Status: offline
It uses the Walbro WT-962 carb that has been modified and jetted from the factory to run well with the GT17.
Hide Signatures
(in reply to skip1320)
       Post #: 22
RE: NGH 17cc gasoline engine - 6/6/2011 4:03 AM
skip1320
Score: 105
Status: offline
Can you sell just a carb for 17? Send PM if so,thanks
Hide Signatures
       Post #: 23
RE: NGH 17cc gasoline engine - 6/6/2011 4:12 AM
bdcoaster
Score: 105
Status: offline
I have posted some more pictures of the motor on my Facebook page. I will be updating and using the Facebook page to display sales and new products! The link to the page is:  http://www.facebook.com/pages/Agape-Racing-and-Hobby/#!/pages/Agape-Racing-and-Hobby/147747955296322?sk=wall or just look up Agape Racing and Hobby!
Hide Signatures
       Post #: 24
RE: NGH 17cc gasoline engine - 6/6/2011 3:33 PM
bdcoaster
Score: 105
Status: offline
Hey Skip I dont think your PM is working correctly....
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> NGH 17cc gasoline engine
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
