RE: *** AMR Trainer 20 build thread. Beginner's Build***    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: *** AMR Trainer 20 build thread. Beginner's Build***
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9   next >   >>
Login
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/27/2011 10:36 PM
heritageman
Score: 110
Last Login: 5/12/2013
Status: offline
Ken, here a picture. Hope you can tell what the problem is.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to RCKen)
       Post #: 101
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/27/2011 11:20 PM
RCKen
Score: 416
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: heritageman
Your problem is that you have to cut the side of the cowl to fit around the muffler. You can't mount a DLE 20 in this plane without doing this.
Ken
Click for fullsize
Click for fullsize
_____________________________
The take off is optional, but the landing is MANDATORY!!
RCU Forum Manager
Ultra Sport Brother #1
www.gettingairborne.com
Hide Signatures
(in reply to heritageman)
       Post #: 102
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/27/2011 11:22 PM
heritageman
Score: 110
Status: offline
Ken, could you measure the width from inside motor compartment side to side.
Hide Signatures
       Post #: 103
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/27/2011 11:44 PM
heritageman
Score: 110
Status: offline
Here's a couple more pictures.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 104
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/28/2011 2:28 AM
RCKen
Score: 416
Status: offline
It measures just a hair over 4".
Ken
RCU Forum Manager
Hide Signatures
       Post #: 105
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/28/2011 2:58 AM
heritageman
Score: 110
Status: offline
Ken, thanks for the help. Forgot that it needed cut out. Now I'm having a time finding a allen wrench small enough to fit set screw on collars of the tail wheel. What size?
Hide Signatures
(in reply to RCKen)
       Post #: 106
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/28/2011 3:17 AM
RCKen
Score: 416
Status: offline
.05"
Ken
RCU Forum Manager
Hide Signatures
       Post #: 107
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 1:10 AM
Cherokee Flyer
Score: 100
Status: offline
I am using a pitts muffler and it fits fine. Picture to follow.
L.
Cherokee Flyer
Club SAITO #696
Hide Signatures
(in reply to RCKen)
       Post #: 108
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 1:29 AM
Cherokee Flyer
Score: 100
Status: offline
Picture:
Click for fullsize
Cherokee Flyer
Club SAITO #696
Hide Signatures
(in reply to Cherokee Flyer)
       Post #: 109
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 1:31 AM
Cherokee Flyer
Score: 100
Status: offline
one more:
Click for fullsize
Cherokee Flyer
Club SAITO #696
Hide Signatures
       Post #: 110
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 3:22 AM
RCKen
Score: 416
Status: offline
Nice. I like the looks of that with the Pitts muffler. What manufacturer is that muffler from??
Ken
RCU Forum Manager
Hide Signatures
       Post #: 111
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 1:36 PM
Cherokee Flyer
Score: 100
Status: offline
http://www.jtecrc.com/dlengineswraparound.htm
It does require you be able to remove and replace the mount with the engine installed on the mount, but that is not a big issue.
L.
Cherokee Flyer
Club SAITO #696
Hide Signatures
(in reply to RCKen)
       Post #: 112
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 1:44 PM
weezle
Score: 101
Last Login: 9/20/2012
Status: offline
you could make 2 holes in the cheek for the muffler bolts.
Hide Signatures
       Post #: 113
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 2:23 PM
RCKen
Score: 416
Status: offline
quote:
ORIGINAL: weezle
No, that still won't work. There just isn't enough room inside the cowl for the muffler to fit without making a cutout.
Ken
RCU Forum Manager
Hide Signatures
(in reply to weezle)
       Post #: 114
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 3:53 PM
weezle
Score: 101
Status: offline
i was referring to the jtec wrap around pitts muffler
Hide Signatures
(in reply to RCKen)
       Post #: 115
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 4:57 PM
RCKen
Score: 416
Status: offline
quote:
ORIGINAL: weezle
My mistake, I'm sorry. I thought you were referring to the stock muffler from the post earlier in this tread.
Ken
RCU Forum Manager
Hide Signatures
       Post #: 116
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 5:45 PM
heritageman
Score: 110
Status: offline
Ken , it's me again.Just wondering if the tank is to be mounted in the cockpit floor,and the elect. ignition between the forword two servo's. Then the receiver could go right in front of the rudder servo. Does this sound right for no interference from the ignition.
Hide Signatures
(in reply to RCKen)
       Post #: 117
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 9:01 PM
RCKen
Score: 416
Status: offline
I've always set up gas engines to keep the radio components as far away from the ignition system as possible. I moved the throttle servo back to rudder servo tray. Put the fuel tank right over the CG between the rudder servo tray and former F2. And then I put the ignition system on the tray right behind the firewall.
Ken
RCU Forum Manager
Hide Signatures
       Post #: 118
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/29/2011 10:54 PM
Cherokee Flyer
Score: 100
Status: offline
I am doing prett much the same thing; except I am using one of these instead of a ignition battery. I am using a 2300 mil A-123 battery pack.
42-Percent-Products Is Proud to Introduce:
The Mini Thor Ignition Power Expander
This is the world’s smallest ignition power expander!
•33mmx21mmx6mm Footprint
•Output of Up to 3.9A @ a User Selectable 5 or 6VDC
•Output Voltage Regulated to a Tolerance of +-100mV
•Absolutely No Operational Time Limit or Additional Cooling Required
•Input Voltage Range of 6 to 20VDC
•22ga Twisted Noise Canceling Wires on Both Input and Output Leads
•Made in U.S.A
Cherokee Flyer
Club SAITO #696
Hide Signatures
(in reply to RCKen)
       Post #: 119
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/30/2011 4:21 AM
Nitro-Tom
Score: 120
Last Login: 5/15/2013
Status: online
quote:
ORIGINAL: Cherokee Flyer
L.
Is that the "Compact" version (1.25" diameter can) or the regular version (1.5" diameter can)???
I want to get the correct pitts muffler (Especially for $80)
But it is well worth the price to not have to cut the side of the cowl.....
Nitro - Tom
General R/C Addict
Hide Signatures
       Post #: 120
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/30/2011 4:25 AM
Nitro-Tom
Score: 120
Status: online
•Made in U.S.A
I am always nervious about these......after all they connect the power for the Radio to the Ignition.....if interference makes it to the radio, it can be bad.....
that being said, they are in use everywhere and gaining in popularity (For obvious reasons)........
so if I am still paranoid about this, what is the smallest Ignition Battery I can get away with, and still fly 8 - 10 flights without recharge?
I will use NiMH 4.8v or 6v....whatever is best......
Nitro - Tom
General R/C Addict
Hide Signatures
       Post #: 121
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/30/2011 4:58 AM
RCKen
Score: 416
Status: offline
Tom,
 I have a 4 cell 2000 Mah Enerloop Nimh in for the ignition in this plane. I have yet to test how long it can go. I know that there are products like the one listed above, but I still prefer to have a seperate battery for the ignition.
Ken
RCU Forum Manager
Hide Signatures
(in reply to Nitro-Tom)
       Post #: 122
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/30/2011 12:43 PM
Nitro-Tom
Score: 120
Status: online
quote:
ORIGINAL: RCKen
Tom,
Ken
Here here.....This plane is not the lightest in it's class, for sure.
I would rather have a seperate switch and battery as well....guess I would not save that much weight going with a 4 Cell 1100 or something....and with the 2000 you do not have to worry about charging the IGN battery, that's for sure.
Thanks, and I am taking notes for our build
Nitro - Tom
General R/C Addict
Hide Signatures
(in reply to RCKen)
       Post #: 123
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 6/30/2011 1:25 PM
Cherokee Flyer
Score: 100
Status: offline
Tom;
It is the compact version.
L.
Cherokee Flyer
Club SAITO #696
Hide Signatures
       Post #: 124
RE: *** AMR Trainer 20 build thread. Beginner's Build*** - 7/1/2011 7:41 PM
heritageman
Score: 110
Status: offline
Where is the best location for the receiver battery swich?
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
