shonny
Joined: 1/26/2003 From: Armadale, WA,, AUSTRALIA Status: offline
[QUOTE]Originally posted by Ben Lanterman Maynard Hill has set records in altitude, endurance, closed course speed, and a host of others. Each one has had official witnesses according to the FAI codes governing world record attempts. He is the real deal. Do a look up and you might find some interesting information. It would be better than showing your lack of information in such great detail. In the time it took you to write your interesting message I found the following........... http://www.dc-rc.org/star.htm a quoted portion...... "The aeromodels used for this experiment will weigh about 11 pounds (5 kilograms) including fuel, and will have a wingspan of about 6.5 feet. The engine will be a four-stroke type of 10 cc. displaced volume. The effort will be carried out under the leadership of Maynard Hill, who has been responsible for the model design and engine development. During the past 3.5 decades, he has established 23 different world records under F.A.I. rules. His models currently hold records for altitude (26,990 ft), duration (33.67 hrs), closed course distance (1301 Km), and speed in a closed circuit (167 mph). The aerodynamic and propulsion aspects of the transatlantic model (TAM) are therefore based on much practical experience." [/QUOTE] I have some problems believing that you can fit about one gallon (the U.S. variety) of fuel in an 11 lbs plane (if the weight of fuel is in addition to the 11 lbs, it is still not plausible). That is a container about 4 by 4 by 15 inches. Where is the space for it? Then there are batteries that must last more than 40 hours. Then you have the satelite navigation equipment. The sum of this spells BULL****! But if someone can PROVE anything to the contrary, I'd be very interested.
