RE: The dreaded step!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: The dreaded step! Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: The dreaded step! - 6/2/2011 2:19 PM
joebahl
Score: 132
Last Login: 5/24/2013
Status: offline
I cant stand sanding, because iam not to good at it and have to take more time to do. Covering is next on my cant stand to do list. joe
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to MinnFlyer)
       Post #: 76
RE: The dreaded step! - 6/2/2011 3:54 PM
EscapeFlyer
Score: 120
Status: online
You may hate sanding, but you're an amazing craftsman... What a cool project!
Brian
_____________________________
N Central Regional Director
Classic Pattern Association
Hide Signatures
(in reply to joebahl)
       Post #: 77
RE: The dreaded step! - 6/2/2011 3:57 PM
TBONE6
Score: 115
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: AmishWarlord
Oh forgot about this one. I haven't built a plane from a kit "That I didn't bash into something unrecognizable" in a long time but when your kit building and on a step then they tell you to do something that should have been mentioned three steps before.
"Quickly reads directions before building, 1... 2... 3 cut out hatch,4 glue in rails,5 install servo,6 put on control horn, 7 put cover back on. Got it"
Step 3 Cut out hatch cover
Step 4 Glue in servo rails.
Step 5 Install servo
Step 6 Align servo horn with push rod then screw in place
Step 7 Install hatch cover. Screw hatch cover into blind nuts mounted on back of servo rails.
What!? I glued in those rails in step 4 and now in step 7 you tell me I needed to install blind nuts in the back side of those rails!
HAWKS
Hide Signatures
(in reply to AmishWarlord)
       Post #: 78
RE: The dreaded step! - 6/2/2011 4:50 PM
joebahl
Score: 132
Status: offline
quote:
ORIGINAL: Ilikebipes
Brian
Any one could build one in a year,thats how slow iam . lol I have her painted and graffics are going on,thanks callie, plan to maiden her real soon. joe
Hide Signatures
(in reply to EscapeFlyer)
       Post #: 79
RE: The dreaded step! - 6/2/2011 7:01 PM
jessiej
Score: 144
Status: offline
quote:
ORIGINAL: joebahl
After looking at the photos I'd have to say that if you are no good at sanding, I would love to see something you are good at! That is a beautiful project.
BTW I learned to overcome my own fear and loathing of carving, shaping, and sanding by carving the big props for the larger rubber powered free flight models. At one time I traveled a lot and would carve props in mt hotel room at night. I suspect the maids wondered at the wood shavings in the trash, not to mention the occasional bloodstain.
jess
Hide Signatures
       Post #: 80
RE: The dreaded step! - 6/2/2011 8:36 PM
daven
Score: 100
Last Login: 5/16/2013
Status: offline
People that detest sanding are probably trying to get every last grits worth out of their blocks.
Change that paper often and it will go much easier
Dave Norman
29w
Hide Signatures
(in reply to jessiej)
       Post #: 81
RE: The dreaded step! - 6/2/2011 8:54 PM
junkjet
Score: 100
Last Login: 5/19/2013
Status: offline
glassing
AMA427952
Freddy Schneider
Hide Signatures
(in reply to mistermnkim)
       Post #: 82
RE: The dreaded step! - 6/3/2011 1:48 AM
edh13
Score: 115
Last Login: 5/22/2013
Status: offline
Running back and forth to the hobby shop 42 times because out of the 1000's of nuts, bolts, screws, pins, hinges, horns, wires, tubes, tanks, wheels, mounts, clevises, tapes, glues, covering rolls, drill bits, fuel fittings, spinners, props etc that I've managed to accumulate over the years NOTHING I have in stock will work with the plane I'm building.
P.S. Replace 'hobby shop' with 'Home Depot' if I'm working a home project...
Hide Signatures
(in reply to junkjet)
       Post #: 83
RE: The dreaded step! - 6/3/2011 2:05 AM
jessiej
Score: 144
Status: offline
quote:
ORIGINAL: edh13
You have a hobby shop? Within less than a day's travel?!
Now I remember my only dreaded task in building.
jess
Hide Signatures
(in reply to edh13)
       Post #: 84
RE: The dreaded step! - 6/3/2011 10:31 AM
genisis300
Score: 100
Last Login: 7/22/2012
Status: offline
i hate working with plastic parts like wheel spats and nose cowls
i'm only on my 1st plan build but the wings where the scary part for me,
got to say nothing beats sanding a block down to the exact shape
Hide Signatures
       Post #: 85
RE: The dreaded step! - 6/3/2011 2:32 PM
richardgerardi
Score: 124
Last Login: 3/25/2013
Status: offline
I absolutely hate cutting cowls it makes me cringe.
Hide Signatures
       Post #: 86
RE: The dreaded step! - 6/4/2011 10:08 PM
DUCO
Score: 105
Last Login: 3/24/2012
Status: offline
Dupilcate: Wing tips and anyother item that requires 2 of , you can bet the farm, I will not get them the same!!!!!!!!!!!!!!
Where ever I be, there I am........
AMA 968496
Hide Signatures
(in reply to richardgerardi)
       Post #: 87
RE: The dreaded step! - 9/20/2011 5:34 AM
balsabuff
Score: 100
Status: offline
DISLIKE : hinging, radio install, tank install when there is a space/centerline issue, re-doing anything, and worst of all...engineering retract placement and functional landing gear doors.
THINGS I LIKE THAT MANY OTHERS HATE : making a kit from plans, planking, sanding, glassing, painting. ABSOLUTE FAVORITES : Framing-up, adding decals/dry transfers, peeling masking tape off. 'buff
Hide Signatures
(in reply to DUCO)
       Post #: 88
RE: The dreaded step! - 9/20/2011 5:56 AM
Gray Beard
Score: 314
Status: online
I didn't go back and see what I said but it was probably sanding, now it's sanding and painting. I never have been able to paint but it hasn't gotten any better over time.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to balsabuff)
       Post #: 89
RE: The dreaded step! - 9/20/2011 8:50 AM
AmishWarlord
Score: 121
Status: offline
Wife and I picked up some old end tables that someone had thrown out. We where going to use them outside on the front porch until we get some better ones later.
The tops where trashed and had some sticky stuff on them. She washed off the sticky stuff. I took off the top layers of what didn't come off with a gun cleaner spray. Then sanded the top with 60 grit sand paper on the sander. Wiped it down with a damp rag. That's it. We did this in ten minutes. Now the wood is still kind of wet from where it was washed and still had gun cleaner residue on it also. I went in the shop and grabbed some 3 years old blue spray paint. And just sprayed it on without care. and just left it out in the yard that night to dry or get rained on.
Things I did wrong
1 Just sanded with 60 grit rough sandpaper.
2 Painted in low light at sunset.
3 Just used paint, no filler or primer coats.
4 Painted still damp surface with oil based paint.
5 Used spray paint that was 3 years old
6 Painted over and un-known cleaning residue.
7 Didn't paint in overlapping patterns. Just blasted it on without care.
8 Sprayed more paint on top of wet paint. This will cause a run or sag every time!
9 Went back and just spayed more paint into holes or scratches that looked like they needed it without care of runs or flash.
10 Painted in the late evening with high humidity.
11 Left wet painted items out in the yard under a tree over night with a chance of rain.
The next morning. It hadn't rained over night. The table where absolutely flawless. The paint had laid down and dried to a glossy defect free shine. No bugs, leaves, sticks, or dust had fallen on the wet paint despite it being out all night under a tree. There was no runs, sags, orange peel, or flash anywhere. There was no thin spots in the paint or anywhere showing that there was only a 60 grit sanding job under the paint. The paint looked like it was sprayed on top of a 2,000 grit polished primer coat.
I was pissed. I swear you make just one of any of those mistakes and it will ruin the paint job on a model. Heck even if you spray it perfect some damn bug will fly into it before it dries.
< Message edited by AmishWarlord -- 9/20/2011 9:12 AM >
Hide Signatures
(in reply to Gray Beard)
       Post #: 90
RE: The dreaded step! - 9/20/2011 8:53 AM
thailazer
Score: 110
Status: offline
Amish... That is pretty good! Like I always say, If you can't be good, be lucky!
Tiger Flyer #49
Hide Signatures
       Post #: 91
RE: The dreaded step! - 9/20/2011 7:35 PM
stevenmax50
Score: 121
Status: offline
I havent even read any of the postings in this thread, just the title.  And I will betcha that the majority of responses are just like mine.  SANDING!!!  I hate it.
Well I went back and read the thread.  Seems as if I am in the minority.  I think I will try the sanding outside with the air hose nearby idea.
ROLL TIDE!!!
Hide Signatures
(in reply to thailazer)
       Post #: 92
RE: The dreaded step! - 9/20/2011 7:52 PM
ARUP
Score: 134
Status: offline
Installing radio stuff.
Hide Signatures
(in reply to stevenmax50)
       Post #: 93
RE: The dreaded step! - 9/20/2011 7:58 PM
rafeeki
Score: 101
Status: offline
Instead of air hose I use a shop vac with a sizable paper funnel close up to where I am sanding.
sanding is not my dreaded last step, it is one of the better ones as the shape of the wing tips, nose etc.. start taking shape, yepeee a precurser for covering..
Hide Signatures
       Post #: 94
RE: The dreaded step! - 9/20/2011 8:02 PM
rafeeki
Score: 101
Status: offline
Hey Joe,
Last I saw u at St John early summer. Did u get her up and running?
Did u get the other one that was perched up in the tree at Lake Hills? I have had worse
rafeek
Hide Signatures
       Post #: 95
RE: The dreaded step! - 9/20/2011 8:55 PM
wilde
Score: 100
Status: online
Gary,the answer to your second hate is to grab a large cup of coffee. Now, lay the kit down on the table FACE DOWN. lift the inner box from the kit and place beside the kit. carefully note the orientation and spacial position of the contents as each piece[ pieces] is/are removed for inspection . note that the piece has to be replaced in the box in a mirror image.[ ie. rotated 180 Degrees ] the manufacturer achieved this , so now it is up to you
forgive the pun,we are constantly reminded to "think outside the box" in this case we do have a box to "think outside of"
roll plans up with the print outside. they will then lay flat on the table,and not roll up
Hide Signatures
(in reply to GaryHarris)
       Post #: 96
RE: The dreaded step! - 9/21/2011 1:05 AM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
One word "CANOPIES" - arrrggggggggggggg ....
Hide Signatures
(in reply to wilde)
       Post #: 97
RE: The dreaded step! - 9/21/2011 10:56 AM
robc57
Score: 100
Status: offline
Cutting ribs - it's just plain boring.
Film covering - I can never seem to get a straight line to stay straight, then two days after I finally think I've got everything looking reasonable I come back to find the beast covered in bubbles.
Carving and sanding - now that's the bit I enjoy, as ugly square blocks transform into graceful curves.
Hide Signatures
(in reply to SeamusG)
       Post #: 98
RE: The dreaded step! - 9/29/2011 3:01 AM
tcraftpo
Score: 105
Last Login: 5/21/2013
Status: offline
Covering...can't stand it. I have three unfinished planes that just need covering, even the radio and engine stuff have been fit and finished then removed for covering. The covering is your signature and I think that's why I can't stand it. I admit that once I do cover a plane it turns out pretty decently so I don't know why I can't stand it. Did I mention that I can't stand covering?
One day, I stopped to think then forgot to start again!
Hide Signatures
(in reply to robc57)
       Post #: 99
RE: The dreaded step! - 9/29/2011 3:23 AM
foodstick
Score: 182
Status: offline
I have another one to add.
just about the time I get one done, and flying decent..I am only interested in the next project I don't even need ! I have one plane now that gave me enough trouble I WISH it had broke more on the last crash so I could.. MOVE ON and give up on it !
its an addiction ....
Hide Signatures
(in reply to tcraftpo)
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
