Polyester resin and Blue foam process??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Polyester resin and Blue foam process??
Page: [1]
Login
Polyester resin and Blue foam process?? - 8/14/2003 9:17:56 PM
gjs
Status: offline
Does anyone know of a good sealer for S T Y R E N E foam (Urethane foam sanding dust is Fine and Nasty to breath) that will allow a good bond of polyester resin to the foam. Or what glues, paints,resines will Polyester resin bond to?
My intent is to add Glass rod to Foam . Foam to resist buckleing in longerons and Glass caps on two sides of foam to stiffen. ect. ect. My own custom building method aimed at the lightness at the end of the tunnel.
< Message edited by gjs -- Aug 22 2003 2:08AM >
       Post #: 1
styrene - 8/15/2003 9:47:41 PM
TGoodwin
Status: offline
If you plan on using polyester resin on your plug then dont use styrene foam. There is a yellow foam that is polyester safe and easy to shape. I forget the name of the product though. Can anybody else help out here with the name?
Ted
(in reply to gjs)
       Post #: 2
Polyester resin and Blue foam process?? - 8/16/2003 8:40:09 AM
Newflee
Status: offline
I would have liked to know the answer to this question a couple years ago, but since I started using west system epoxy, I will never use P resins again. I know the epoxy seems expensive but trust me it goes a long way and has so many advantages.
Just my .02.
I'll stay tuned for an answer though, just in case I want to get high of of P resin fumes some day.
Lee
(in reply to gjs)
       Post #: 3
Foam - 8/16/2003 11:56:43 AM
Mike James
Status: offline
If you use polyester resin, urethane foam can take it, but styrofoam (white, blue, or pink) will melt.
Epoxy will work over any of the above.
_____________________________
Mike James
RC Design and Building - www.nextcraft.com
(in reply to gjs)
       Post #: 4
foam barrier - 8/16/2003 7:07:56 PM
rcalfred
Status: offline
In his book "Fiberglass & Composite Materials", Forbes Aird says...there is a material which is cheap, generally available, and effective. The secret is ordinary exterior latex house paint. It must say "alkyd" somewhere on the label--interior latex is unsuitable. He suggests thinning it and spraying, but I'm not sure that is necessary. Experiment on a separate piece and try it out. Won't cost much and it will prove itself one way or the other. Regards.
Al Sortwell
AMA 15663
(in reply to gjs)
       Post #: 5
Polyester resin and Blue foam process?? - 8/17/2003 8:12:28 AM
gjs
Status: offline
I painted polystyrene with vinyl acetate (a product for bonding concrete to substrates, I think similar to Tite Bond) after drying I put Polyester resin and glass down on it, used some heat to expedite cure ( sometimes heat causes solvents to break seals) but it cured, bonded to vinylacetate and did not attack foam.
WELDBOND works also, it is a white glue, HomeDepot, Lowes?
thanks for your info guys! GJS
< Message edited by gjs -- Aug 22 2003 1:56AM >
(in reply to gjs)
       Post #: 6
Polyester resin and Blue foam process?? - 8/17/2003 10:47:53 PM
winship
Status: offline
Here is a link to foam that is compatable with polyester resins. The 6# weight is great for making plugs. Sands and shapes extremely well. This product will also take dope and auto primer. Sometimes I prefer to build up a finish with dope and silkspan finished with auto primer. The dope and silkspan method ensures that you will not any fiberglass print through on your plug.
Freeman supply also sells this type of foam I believe.
http://www.elliottfoam.com/
(in reply to gjs)
       Post #: 7
Re: foam barrier - 8/18/2003 7:04:23 PM
gjs
Status: offline
[QUOTE]Originally posted by rcalfred
In his book "Fiberglass & Composite Materials", Forbes Aird says...there is a material which is cheap, generally available, and effective. The secret is ordinary exterior latex house paint. It must say "alkyd" somewhere on the label--interior latex is unsuitable. He suggests thinning it and spraying, but I'm not sure that is necessary. Experiment on a separate piece and try it out. Won't cost much and it will prove itself one way or the other. Regards. [/QUOTE]
rcAlfred,
I've got that book, it's a great resource and I'll check it out.
thanks everybody , GJS
< Message edited by gjs -- Aug 20 2003 7:33PM >
(in reply to gjs)
       Post #: 8
smaller WLoading - 8/21/2003 12:49:19 AM
gjs
Status: offline
My intent is to add Glass rod to Foam or balsa sheet. Foam to resist buckleing in longerons and Glass caps on two sides of foam to stiffen. ect. ect. My own custom building method aimed at the lightness at the end of the tunnel.
(in reply to gjs)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU4
