Xtm 24.7 pull start eliminator
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Xtm 24.7 pull start eliminator
Page: [1]
Login
Xtm 24.7 pull start eliminator - 8/15/2003 8:53:01 AM
Maxxer
Status: offline
Hey, my pull start on my xtm 24.7 some times turns over the engine and some times not at all!!!! So I found this [URL=http://www.neweramodels.com/cgi-bin/item.cgi?session_id=mlbuhtgjycjoieqlobqmbqxvllkbngdn&part_id=359]pull start eliminator[/URL]. Does anyone have any experience with this problem? Are there any other electric starts that work with my engine? [IMG]xtm 24.7[/IMG]
Click to see fullsize image.
Click for fullsize
_____________________________
[______]
       Post #: 1
Xtm 24.7 pull start eliminator - 8/15/2003 8:55:24 AM
badboy2
Status: offline
dude just buy a rotostart its much easier
SAVAGE QUARK125/8XL,MGT W/lc32,LSP W/REX28, inferno gt,REVO,E-PEDE,MP777 SP2
(in reply to Maxxer)
       Post #: 2
Xtm 24.7 pull start eliminator - 8/15/2003 10:00:09 AM
Turn&Burn
Status: offline
I found my 247 6 port doing the samething, but then again this is not the first one to do it and probley wont be the last.....What is happening is the start shaft that slides into the 1 way is slipping in the bearing due to it being very very smooth, which is not a very good thing but it can be fixed with spending less that 5 bucks at walmart.....You can take a small piece of 1000 grit sand paper to sand some very lite grooves in the shaft to give the roller's inside the 1 way to grip on....When sanding on it sand it the length fo the shaft (longways) not around the shaft.....Just 3-4 time's back and forth is all that's needed....BTW to be on the safe side do not use an thing lower that 800 grit paper...... Works like a charm.....
Gon' buy it........Modify it.........
       Post #: 3
Xtm 24.7 pull start eliminator - 8/15/2003 10:22:02 AM
badboy2
Status: offline
http://www.meganitro.com/1-jump%20start.htm check this it says its for different engines ..i just followed what they said
       Post #: 4
Xtm 24.7 pull start eliminator - 8/15/2003 10:24:48 AM
Maxxer
Status: offline
Hey thanks guys I will be purchasing a jump start soon!!
[______]
       Post #: 5
Xtm 24.7 pull start eliminator - 8/15/2003 6:47:49 PM
Turn&Burn
Status: offline
Jumpstart, pullstart...They both use the same one-way......Take a look @ it because it will STILL slip........I have the rotostart for mine and have experenced that.......
       Post #: 6
Xtm 24.7 pull start eliminator - 8/15/2003 8:03:38 PM
Kuma
Status: offline
Seems the 24.7 uses the same one-way the XTM .18 does, and might not be strong enough for the compression the 24.7 produces. Try picking up a GS 21B01 one-way, it's identical and might be stronger, give it a shot. I've never had a prob with the GS 21B01's pullstart.
- OFNA Hyper 7 / Hyper 21 8P (soon RB WS7-II)
- HPI RS4 Nitro MT / Sirio SP12TRP (2-speed)
       Post #: 7
Xtm 24.7 pull start eliminator - 8/15/2003 9:09:19 PM
Maxxer
Status: offline
i think im just gonna use sand paper, with the jump start.
[______]
       Post #: 8
Xtm 24.7 pull start eliminator - 8/15/2003 9:54:16 PM
bubbafien
Status: offline
the gs,.247, xtm .15 .18 .21etc, mach .15, mach .26 are all made by the same company.
i think that it is called ECB but am not sure. kinda like ofna picco, these places just slap their lable on it.
bubbafien
mp 7.5
full hardcore kanai
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.594RCU4
