RE: CARF F4U-1 Corsair build thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CARF F4U-1 Corsair build thread
Page: <<   < prev  23 24 [25] 26 27 28 29 30 31 32   next >   >>
Login
RE: CARF F4U-1 Corsair build thread - 1/3/2012 3:01 PM
MANFRED
Score: 105
Last Login: 5/22/2013
Status: offline
Gary, the speakers are for your gun sounds I assume, can you mount them in the location of the oil cooler intakes or are the speakers too large?
< Message edited by MANFRED -- 1/5/2012 3:35 AM >
_____________________________
Time flies like a brick thru the window of life.
Hide Signatures
(in reply to ram3500-RCU)
       Post #: 601
RE: CARF F4U-1 Corsair build thread - 1/3/2012 4:37 PM
ram3500-RCU
Score: 145
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: MANFRED
Gary, the speakers are for you gun sounds I assume, can you mount them in the location of the oil cooler intakes or are the speakers too large?
Yes, and yes, we plan to mount them in that location. They are not too large, and they are housed in an acoustical box for better sound. They have a molded in stand of sorts that we will cut as needed.
The lights, smoke, and sound will all be synchronized together for affect. That is our goal. Brian has the lighting and sound figured out, we are still waiting on the smoke system. It will all be sized to fit in the compartments behind the wing intakes.
Because the front will be open, I want to make provision for exit air as well. The plan is to have the smoke exit the shell discharge chutes and trail off the wings behind each gun from there.
You can see in the picture, there is a fairly large compartment behind each intake. Under the center hatch will be all the switching and charging plugs and jacks.
Good question. Thanks.
Click to see fullsize image.
Click for fullsize
< Message edited by ram3500-RCU -- 1/3/2012 7:46 PM >
Cheers,
Gary P. / use Steel Powder for ballast not lead. PM me for more information.
Hide Signatures
(in reply to MANFRED)
       Post #: 602
RE: CARF F4U-1 Corsair build thread - 1/3/2012 7:53 PM
ram3500-RCU
Score: 145
Status: offline
Here is the tool Brian had made for the wing hinges, and how it is used. Worked like a charm. This keeps the wing hinge line perfectly parallel. Very important. You 'tack' the hinge mount in with this tool, then glue it good with Hysol.
Where the pivot winds up is a direct result of where the factory positioned the spar. In our case, I believe they got the spar a degree more tilted, the reason for the slight notch in the top skins at the hinge.
In the manual, they tell you you need something like this tool, but don't provide it.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Cheers,
Hide Signatures
       Post #: 603
RE: CARF F4U-1 Corsair build thread - 1/5/2012 4:21 AM
ram3500-RCU
Score: 145
Status: offline
Six Truths in Life
1. You cannot stick your tongue out and look up at the ceiling at the same time, a physical impossibility.
2. All idiots, after reading #1 will try it.
3. And discover #1 is a lie.
4. You are smiling now because you are an idiot.
5. You soon will forward this to another idiot.
6. There is still a stupid smile on your face ..
I sincerely apologize about this but I'm an idiot and I needed company. You now have 2 options...delete it, or send it along to put a smile on someone's face today
Sorry guys, I know this is off topic just a tad, but we all need to laugh once in awhile.
Building scale does this to you.
Cheers,
Hide Signatures
       Post #: 604
RE: CARF F4U-1 Corsair build thread - 1/5/2012 2:59 PM
glazier808
Score: 291
Status: offline
You just put a big ole idiot grin on my face!
You meanie lol...everyone knows to laugh and smile SUCKS...
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
       Post #: 605
RE: CARF F4U-1 Corsair build thread - 1/5/2012 3:02 PM
glazier808
Score: 291
Status: offline
Greatest thing was that my wife walked into the shop just as I tried LOL
should have seen the look I got LOL
Thanks Ram, know she's sure Im an idiot
Casey
Hide Signatures
(in reply to glazier808)
       Post #: 606
RE: CARF F4U-1 Corsair build thread - 1/5/2012 3:08 PM
Dwhart24
Score: 100
Last Login: 5/17/2013
Status: offline
Hey Gary, I sent you a pm. Did you get it.
Edit: I just got your email reply from Tuesday, but no pm yet. Not sure what's going on.
< Message edited by Dwhart24 -- 1/5/2012 4:11 PM >
David
www.warbirdandrcairplanephotography.com
Hide Signatures
       Post #: 607
RE: CARF F4U-1 Corsair build thread - 1/5/2012 4:41 PM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: Dwhart24
Yes I did Dave. and I sent a reply. I've had trouble a few times with this system. Not sure what gives. It may be that I replied in the email notice instead of using the link to RCU and replying directly in the site. That doesn't seem to work. I'll go back and take another look.
Thanks for the heads up buddy.
Gary
Cheers,
Hide Signatures
(in reply to Dwhart24)
       Post #: 608
RE: CARF F4U-1 Corsair build thread - 1/5/2012 4:44 PM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: glazier808
Casey
LOL!!!!!! Casey, you just made me laugh harder than I did when I fell for it myself.
My brother Bruce sent me this, and I couldn't resist sharing with you guys.
I took a break from working on this tail door linkage late at night, and had a good laugh over it.
fellow idiot,
Gary
Cheers,
Hide Signatures
       Post #: 609
RE: CARF F4U-1 Corsair build thread - 1/5/2012 4:55 PM
ram3500-RCU
Score: 145
Status: offline
I threw together a mock up gear door so I could reposition the linkage on it with out drilling unnecessary holes in the carbon fiber one, as I experiment with locations.
Used 1/16 balsa and laminated 1/64 ply to it to hold the shape, and cut a couple hinges from 1/8 ply. 10 minutes. Should have this figured out and done today.
Click for fullsize
Click for fullsize
Cheers,
Hide Signatures
       Post #: 610
RE: CARF F4U-1 Corsair build thread - 1/5/2012 8:02 PM
Growler84
Score: 105
Status: offline
Nice work, I noticed in photo 1 you use the same scale building aid I use...TUMS!
From the Vegas CARF Corsair Crew,
Greg
Hide Signatures
       Post #: 611
RE: CARF F4U-1 Corsair build thread - 1/5/2012 8:15 PM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: Growler84
Standard issue, right?
Really, it is a wonderful kit to work with. Can't say enough about the condition of the molded parts. The appearance of the surface and the fit is outstanding. There are absolutely no significant defects, or even pin holes, to backtrack on, as with other composite I have worked with.
It is just a tedious plane to build because of the nature of it, and even more so if done with competition as a goal. Added to that, is the additional work in making the change from an F4U-4 (the kit), to an F4U-1A that we are modeling.
< Message edited by ram3500-RCU -- 1/5/2012 10:21 PM >
Cheers,
Hide Signatures
(in reply to Growler84)
       Post #: 612
RE: CARF F4U-1 Corsair build thread - 1/5/2012 10:52 PM
ram3500-RCU
Score: 145
Status: offline
panhandler, any news?
Cheers,
Hide Signatures
       Post #: 613
RE: CARF F4U-1 Corsair build thread - 1/5/2012 11:17 PM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: ram3500-RCU
Got what you sent but can't play it Dan. Looks interesting though.
Cheers,
Hide Signatures
       Post #: 614
RE: CARF F4U-1 Corsair build thread - 1/5/2012 11:31 PM
panhandler
Score: 100
Status: offline
quote:
ORIGINAL: ram3500-RCUpanhandler, any news?
Check your email Gary .I got this system to work , just had to think out of the box for this one .
Hide Signatures
       Post #: 615
RE: CARF F4U-1 Corsair build thread - 1/6/2012 12:08 AM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: panhandler
Got it Dan. Lookin good.
Cheers,
Hide Signatures
(in reply to panhandler)
       Post #: 616
RE: CARF F4U-1 Corsair build thread - 1/6/2012 3:04 AM
MANFRED
Score: 105
Status: offline
6 to 8 week lag time to get one of these... wow
Hide Signatures
       Post #: 617
RE: CARF F4U-1 Corsair build thread - 1/6/2012 6:59 AM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: MANFRED
Our Dealer is Andy Kane. Perhaps he could help.
Cheers,
Hide Signatures
       Post #: 618
RE: CARF F4U-1 Corsair build thread - 1/6/2012 7:26 AM
ram3500-RCU
Score: 145
Status: offline
We are talking about the pulsating smoke system for the guns. It will be coordinated with the sound and lights.
Cheers,
Hide Signatures
       Post #: 619
RE: CARF F4U-1 Corsair build thread - 1/6/2012 6:15 PM
tunakuts3d
Score: 105
Status: offline
Hey  Gary, Have you read the post today by Panhandle re interferance with his servos caused by D& L gear? Have you had any problems?
Paul
obsessed Stuka D3 nut
Hide Signatures
       Post #: 620
RE: CARF F4U-1 Corsair build thread - 1/6/2012 6:45 PM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: tunakuts3d
Hey  Gary, Have you read the post today by Panhandle re interference with his servos caused by D& L gear? Have you had any problems?
Paul
No, I didn't see that yet. I have had absolutely no problems or even so much as a glitch. Electronics are sometimes hard to diagnose. I'd be taking a hard look at every electrical component in the planes. Mitch has hundreds and hundreds of his gear conversions out there, and this is the first I have heard of anything like this.
Thanks for the heads up.
Gary
Cheers,
Hide Signatures
(in reply to tunakuts3d)
       Post #: 621
RE: CARF F4U-1 Corsair build thread - 1/6/2012 7:26 PM
wayne d
Score: 105
Status: offline
Paul
Could you post a link?
Best Regards,
Wayne Fussell Pres. Solo Propellers & RC Products
Hide Signatures
       Post #: 622
RE: CARF F4U-1 Corsair build thread - 1/6/2012 7:44 PM
glazier808
Score: 291
Status: offline
http://www.rcuniverse.com/forum/m_10894533/tm.htm
here you go Wayne.
Casey
Hide Signatures
(in reply to wayne d)
       Post #: 623
RE: CARF F4U-1 Corsair build thread - 1/7/2012 12:27 AM
ram3500-RCU
Score: 145
Status: offline
The servos in question are analog. He didn't say that I noticed, but he may still be on 72mhz as well. The 2.4G signal is virtually impervious to interference from within or otherwise. The 72mhz signal would pick up RF from ignitions and even metal to metal noise. Mitch can explain the forces at work here better than I. Perhaps he will chime in.
< Message edited by ram3500-RCU -- 1/7/2012 12:58 AM >
Cheers,
Hide Signatures
       Post #: 624
RE: CARF F4U-1 Corsair build thread - 1/8/2012 12:19 AM
tp777fo
Score: 103
Status: offline
I have been looking buying a CARF Corsair but I have some major reservations with the gear. It seems they dont work well and require an expensive mod to fix them. I emailed Down and Locked on the price of a mod and never received a reply. Sierra retracts are spotty at best with their customer service and I dont know of another solution. I hate to invest this much money on an airplane that might not work. Comments? Solutions?
Tom Perry
In Dog beers, I only had one!
Hide Signatures
       Post #: 625
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.704RCU1
