CARF F4U-1 Corsair build thread    Gallery
Logged in as Guest
Users viewing this topic: Avaiojet
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> CARF F4U-1 Corsair build thread
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
CARF F4U-1 Corsair build thread - 6/16/2011 6:40 AM
ram3500-RCU
Score: 145
Last Login: 5/21/2013
Status: offline
Here we will be preparing the ARF version for flight, flight testing this airframe with a Moki 250 and becoming familiar with the complex systems on this aircraft. This will be done with the plane still in it's silver gel coat. Then, we will apply the basic scheme we intend to model.
While we fly the ARF version, we will be building the kit version, adding all the scale detail we can muster. This second airframe we intend to be our competition aircraft. We are looking forward to the experience and to working with this fine aircraft and engine combination.
Here are some pictures to begin with.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Cheers,
Gary P. / use Steel Powder for ballast not lead. PM me for more information.
Hide Signatures
       Post #: 1
RE: CARF F4U-1 Corsair build thread - 6/16/2011 1:02 PM
rwright142
Score: 100
Last Login: 5/19/2013
Status: offline
Looks awesome!
In the works: 1/6 Scale F4U Corsair
CORSAIR Brotherhood # 39
Hide Signatures
(in reply to ram3500-RCU)
       Post #: 2
RE: CARF F4U-1 Corsair build thread - 6/16/2011 1:28 PM
Mustangman40
Score: 181
Last Login: 5/22/2013
Status: offline
Subscribed........
Good talking to you last night Gary, these projects will have my attention for sure...
Ultra Sport Brotherhood #92
Hide Signatures
(in reply to rwright142)
       Post #: 3
RE: CARF F4U-1 Corsair build thread - 6/16/2011 1:44 PM
scale only 4 me
Score: 319
Last Login: 5/24/2013
Status: offline
Can I come over and touch it?
Can't wait to see her go
Hide Signatures
(in reply to Mustangman40)
       Post #: 4
RE: CARF F4U-1 Corsair build thread - 6/16/2011 3:28 PM
uncljoe
Score: 160
Status: offline
FWIW there is an OUTSTANDING thread already here.. Comp ARF 110" Corsair..
Semper Fi
Look towards the Horizon......your death awaits you there
Hide Signatures
(in reply to scale only 4 me)
       Post #: 5
RE: CARF F4U-1 Corsair build thread - 6/16/2011 10:20 PM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: Mustangman40
Subscribed........
Same here. We are pumped about this project.
Cheers,
Hide Signatures
       Post #: 6
RE: CARF F4U-1 Corsair build thread - 6/16/2011 10:22 PM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: rwright142
Looks awesome!
Thanks. I'll be interested in any comments or suggestions you can add as a Corsair expert.
Cheers,
Hide Signatures
       Post #: 7
RE: CARF F4U-1 Corsair build thread - 6/16/2011 10:23 PM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: scale only 4 me
You WILL get to touch it my friend. We would like to bring itr to your field this year.
Cheers,
Hide Signatures
       Post #: 8
RE: CARF F4U-1 Corsair build thread - 6/16/2011 10:26 PM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: uncljoe
FWIW there is an OUTSTANDING thread already here.. Comp ARF 110'' Corsair..
Semper Fi
Thanks for the heads up. I have gone through it and some other information as well. I hope we can add to the knowledge base already available on this plane. Airframe #2 is to be a museum scale unit. I hope we have something to share.
Cheers,
Hide Signatures
(in reply to uncljoe)
       Post #: 9
RE: CARF F4U-1 Corsair build thread - 6/20/2011 6:49 PM
Mustangman40
Score: 181
Status: offline
Hey Gary,
you gaining any ground yet, a step by step on the Moki mounting would be great.. I plan on winning the lottery very soon and i will need to know things..
Hide Signatures
       Post #: 10
RE: CARF F4U-1 Corsair build thread - 6/20/2011 11:53 PM
ram3500-RCU
Score: 145
Status: offline
Hey Gary,
Picked up the RX over the week end. (JR 922) Now I can start to get things hooked up. I installed the Moki and then the cowl to make sure it was aligned properly. It looks good. I'll be taking it back off tonight and fuel proofing the firewall. Then I will re-install it and mount the pump. Brian is preparing the wings. I'll be posting more pictures later.
I'm also going to do a temporary install of the clear inside the canopy frame. I will need to be able to remove it later to paint it, but we will test fly it as is.
Cheers,
Hide Signatures
       Post #: 11
RE: CARF F4U-1 Corsair build thread - 6/23/2011 6:47 AM
ram3500-RCU
Score: 145
Status: offline
Some more pictures. The radial was too close to the cowl at a couple cylinders, so I plugged the holes in the firewall with dowel rod and Gorilla glue, and drilled new ones. It fits nicely at all five cylinders now.
Recommendations are to use grommets where any wiring goes through the firewall.
I also fuel proofed the fire wall and then painted it, before re-installing the Moki.
Some shots of the cockpit as well. This is airframe #1 and will not be as detailed as #2.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Cheers,
Hide Signatures
       Post #: 12
RE: CARF F4U-1 Corsair build thread - 6/26/2011 5:05 PM
ram3500-RCU
Score: 145
Status: offline
I mounted the fuel pump for the Moki 250. Here is what I did. It will prime in a second or two at the most.
Brian and I have been discussing the wing latching system and a way to verify it is totally locked. Given his electrical experience, he has come up with a very simple yet positive way to do this utilizing the each wing tip light. More on this later, after he has it designed.
Click for fullsize
Click for fullsize
Click for fullsize
Cheers,
Hide Signatures
       Post #: 13
RE: CARF F4U-1 Corsair build thread - 6/27/2011 12:38 AM
ram3500-RCU
Score: 145
Status: offline
We have made another decision for airframe #2. We will be covering it with Aerofoil from Meister, and then doing the paint scheme. Chipped and damaged paint looks so much better over aluminum.
We will also equip both airframes except for the engine, fuel system (all on the one board including the pump, which is held in by 8 screws), and the ignition system. That way, we can switch to a second airframe in maybe as little as 1/2 hr in the case of an accident (not involving the engine.
Cheers,
Hide Signatures
       Post #: 14
RE: CARF F4U-1 Corsair build thread - 6/27/2011 1:31 AM
Whistling Death
Score: 150
Last Login: 5/23/2013
Status: offline
Subscribed!
Blake
CORSAIR Brotherhood Lucky #13
Hide Signatures
       Post #: 15
RE: CARF F4U-1 Corsair build thread - 6/27/2011 5:15 AM
ram3500-RCU
Score: 145
Status: offline
Some more of our plans for #2.
- new D&L air system
- brakes
- Graeme Mears detail parts (this is a nice set of parts if you haven't seen them yet)
- full lighting system (including the scale cockpit)
- paint over aluminum foil finish
- sliding canopy
- scale hand holds
- operational cowl flaps with automatic thermal control and attached to the fuselage not the cowl (we think this will make it easier to remove the cowl for servicing the Moki)
- gun flashing (lights)
- our own design for wings down and fully locked verification (we will experiment with this on airframe #1)
- and a few more things in the works
We hope to have #2 completed by March 2012.
We hope to maiden #1 sometime next month, July. We will fly it in July and August, then, if all goes well, we will break it down and paint it in September, and have it ready to fly again by the Monster Planes event in October. We will fly it to the end of the season, then pull the engine, ignition, and fuel system to install in #2.
Should be fun.
< Message edited by ram3500-RCU -- 6/28/2011 1:08 PM >
Cheers,
Hide Signatures
(in reply to Whistling Death)
       Post #: 16
RE: CARF F4U-1 Corsair build thread - 6/30/2011 12:42 AM
Mustangman40
Score: 181
Status: offline
quote:
ORIGINAL: ram3500-RCU
- brakes
- sliding canopy
- scale hand holds
Should be fun.
Boy Gary,
you and your brother have your hands full with that list. looking forward to following this build...
I know it's going to be a looker when you two get done with it!
Jimbo
Hide Signatures
       Post #: 17
RE: CARF F4U-1 Corsair build thread - 6/30/2011 2:07 AM
ram3500-RCU
Score: 145
Status: offline
Yes, I'm sure the next few months are going to go by very fast, as it always does when you are heavy into a build. I'm hoping we can get it far enough along before next winter so I have some time to build another P-38 to replace the one I lost at WOG. We'll see.
Cheers,
Hide Signatures
       Post #: 18
RE: CARF F4U-1 Corsair build thread - 6/30/2011 8:49 PM
turboratt89
Score: 100
Last Login: 10/23/2011
Status: offline
got 2 quistions for you guys
why are you all using the moki 250 and not the 215
plus why do you need the fuel pump added
may sound stupid but i would like to know thanks
Hide Signatures
       Post #: 19
RE: CARF F4U-1 Corsair build thread - 6/30/2011 11:46 PM
ram3500-RCU
Score: 145
Status: offline
quote:
ORIGINAL: turboratt89
got 2 questions for you guys
Well, I'm new to the Moki engines, but as I understand it, this plane was designed (scaled) around the moki 250. I also did some asking around of guys I know have years of experience with these engines, and they are in agreement that, for the money, it is worth going a couple hundred more for the 250, if not for now, for future projects. You can always throttle back, and it swings a more realistic size prop.
As for the pump, once again, I asked those moki experts. Answer: is it necessary - no, but, here are some benefits to using it. Easier starting, 200 or more RPM on the high end, and lower more reliable idle on the low end. This from guys who have run them both ways. I chose to install the pump for these reasons.
Cheers,
Hide Signatures
(in reply to turboratt89)
       Post #: 20
RE: CARF F4U-1 Corsair build thread - 7/1/2011 2:44 AM
turboratt89
Score: 100
Status: offline
thank you ram i was just very interested in the reasons why
Hide Signatures
       Post #: 21
RE: CARF F4U-1 Corsair build thread - 7/1/2011 3:06 AM
ram3500-RCU
Score: 145
Status: offline
You are very welcome.
Airframe #1 came equipped with the Moki 250 and pump. I still did some research before installing it. I like keeping things as simple as possible. But the reasons for going ahead with the pump were compelling to me. It will have it's own battery and switch. That means that turning the fuel pump on will be part of the check list as with full scale.
Cheers,
Hide Signatures
       Post #: 22
RE: CARF F4U-1 Corsair build thread - 7/1/2011 3:51 PM
turboratt89
Score: 100
Status: offline
sweet thanks again
Hide Signatures
       Post #: 23
RE: CARF F4U-1 Corsair build thread - 7/9/2011 3:03 AM
ram3500-RCU
Score: 145
Status: offline
Made some air tank fixtures and installed them. I used sign board (very light, very strong) and balsa. They are installed under the cockpit. Installed with Gorilla glue.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Cheers,
Hide Signatures
       Post #: 24
RE: CARF F4U-1 Corsair build thread - 7/9/2011 5:13 AM
Whistling Death
Score: 150
Status: offline
For those of us who don't know, what is "sign board" and what is it made of?
Blake
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
