Futaba GV-1 governor set up    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> RC Helicopter General Discussions >> Futaba GV-1 governor set up
Page: [1]
Login
Futaba GV-1 governor set up - 6/16/2011 10:19 PM
Kaos
Score: 100
Last Login: 6/3/2013
Status: offline
I just put the first 3 flights on my low-time X-cell 60 and I'm having a little problem with my new Futaba GV-1 governor. It works fine as far as holding any of the 3 switchable RPM's I've set, but the governor will not shut off when I reduce the throttle stick to idle. The heli just sits there, whirring away at 1500 RPM. I thought I set up the throttle stick limits and idle cut off properly, but maybe I'm missing something. To review, I set the throttle stick to low then hit the data button; throttle to high and again hit the data button. Last, I set to idle cutoff and hit the button again.
I'm using a 3-position switch to select RPM's (in this case, 1500, 1550, 1600) and also a separate switch to turn the governor on and off.
If I instead set the throttle stick to one notch above idle (fast idle) and then pushed the data button, would that solve the problem with the governor not disengaging?
-Kaos
X-cell 60 Custom
OS.61 SF
JR 550T gyro w/servo
Aurora 9 radio system
_____________________________
Align T-Rex 450 Pro DFC, iKON, Hitec Aurora 9
Hide Signatures
       Post #: 1
RE: Futaba GV-1 governor set up - 6/16/2011 10:36 PM
tadawson
Score: 100
Last Login: 4/24/2013
Status: offline
Enable StSw in the GV-1 . . . that is what is required to have the GV-1 drop offline based on stick position (StickSwitch)
Without that (which is the default) it ignores stick position once engaged.
- Tim
Hide Signatures
(in reply to Kaos)
       Post #: 2
RE: Futaba GV-1 governor set up - 6/17/2011 4:09 PM
Kaos
Score: 100
Status: offline
quote:
ORIGINAL: tadawson
- Tim
You were exactly correct Tim. I brought up the StSw menu and sure enough, it was INH. I punched the data button
once and then it indicated OFF. Advancing the throttle stick past about 25% it shows ON. ON, OFF, ON, OFF :-)
Thanks!
-Kaos
Hide Signatures
(in reply to tadawson)
       Post #: 3
RE: Futaba GV-1 governor set up - 6/17/2011 5:23 PM
tadawson
Score: 100
Status: offline
No problem! Enjoy!
- Tim
Hide Signatures
(in reply to Kaos)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
