edelbrook 600 bog    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Full Scale planes, cars, helis, boats >> Cars & Trucks - Full Scale >> edelbrook 600 bog Page: [1]
Login
edelbrook 600 bog - 6/18/2011 2:20 PM
WhiteRook
Score: 108
Last Login: 5/19/2013
Status: offline
i got this carb on a 440 , with 355 gears , why is it boging on hard acceleration? could it be the accelerater pump?
carb is almost new
Hide Signatures
       Post #: 1
RE: edelbrook 600 bog - 6/18/2011 9:40 PM
la.rc.doc
Score: 100
Last Login: 10/20/2012
Status: offline
Yes sir, if the car has been sitting for a while with no fuel being run threw the carb once in awhile, the acclerator pump drys up! If you have to keep pumping the gas to get it to run or move it the pump, now it is manual fuel pump right? in other words you don't have a helper fuel pump on it do you? anything under a the month of AUG. in 1985 should be manual fuel pump. the acclerrator pumps are easy to change, make sure to change the fuel filter as well make sure the fuel lines are not cracked and sucking air, but if you have never change a pump before I would let someone who has to it! It would not hurt to clean out the carb while the top plate it off! If you have anymore question feel free to ask I have been a mechanic for 30 years, and certified for 20yrs!
Hide Signatures
(in reply to WhiteRook)
       Post #: 2
RE: edelbrook 600 bog - 6/18/2011 9:43 PM
la.rc.doc
Score: 100
Status: offline
P.S. If it hasn't been sitting you may need to raise the level of the float, it may be thristing for fuel and not getting a enough fuel when you get into it!
Hide Signatures
(in reply to la.rc.doc)
       Post #: 3
RE: edelbrook 600 bog - 6/19/2011 2:17 PM
WhiteRook
Score: 108
Status: offline
there are 2 or 3 holes in the pump lever, i think the link arm is in the center hole, also one thing is that on initial start up. when i mash the throttle to engage the choke , i dont seem to be getting a good pump squirt.
Hide Signatures
       Post #: 4
RE: edelbrook 600 bog - 6/20/2011 7:01 PM
Tripower455
Score: 100
Last Login: 1/5/2013
Status: offline
If you're not getting a pump shot with minimal deflection, your pump is probably dried out or cracked. Also, if it's an older one, it might not be impervious to the ethanol in the fuel, causing it (and other stuff in your fuel system!) to deteriorate.
Is it the Quadrajet replacement, or the Carter type?
Hide Signatures
       Post #: 5
RE: edelbrook 600 bog - 6/21/2011 12:31 AM
WhiteRook
Score: 108
Status: offline
its the carter type .
Hide Signatures
(in reply to Tripower455)
       Post #: 6
RE: edelbrook 600 bog - 6/21/2011 1:01 AM
la.rc.doc
Score: 100
Status: offline
Well Whiterock those holes are adjustments the top one is for a deeper plunish, and the second is for a little less plunish, so yes the lower holes are for less squirt, is your choke electric or thermal, (has a thermal spring down in the intake with a little cover over it with a linkage arm going up to the butterfly flap)?
Hide Signatures
       Post #: 7
RE: edelbrook 600 bog - 6/21/2011 5:55 AM
WhiteRook
Score: 108
Status: offline
no its got the dang electric choke
Hide Signatures
       Post #: 8
RE: edelbrook 600 bog - 6/21/2011 8:09 PM
la.rc.doc
Score: 100
Status: offline
It should be adjustable, it should have 3 screws that hold a ring agaisnt it to hold it tight, loosen them and move it counter clock wise a little until you see the butterfly slap move down ward to choke it a little more, but don't close it all the way leave it about a 1/4 to 1/2 inch open.
Hide Signatures
       Post #: 9
RE: edelbrook 600 bog - 11/22/2012 12:17 AM
WhiteRook
Score: 108
Status: offline
one thing i did not do , is BEND THE CHOKE ROD , like it says to in the manual , so when you engage the choke
it opens only about 3/16ths . it was closing all the way. before
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
