RE: How to get max rpm out of a tt 40    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-500 Racing >> RE: How to get max rpm out of a tt 40 Page: <<   < prev  1 [2]
Login
RE: How to get max rpm out of a tt 40 - 6/22/2011 11:32 AM
airwebb
Score: 104
Last Login: 1/19/2013
Status: offline
ok.  great thanks for the info to everybody.
Hide Signatures
(in reply to djlyon)
       Post #: 26
RE: How to get max rpm out of a tt 40 - 6/23/2011 12:44 PM
blindfaithnogod
Score: 100
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: GSJames
quote:
ORIGINAL: blindfaithnogod
the rod to the crank. it needs lapped in.
Mike: What do you use for lapping compound these days? In my CL Combat days, on the G21-35's we used automotive rubbing and/or polishing compound.
Mike says he uses fox lapping compound.
Hide Signatures
(in reply to GSJames)
       Post #: 27
RE: How to get max rpm out of a tt 40 - 6/23/2011 5:09 PM
jaka
Score: 158
Last Login: 5/21/2013
Status: offline
Hi!
Head shims are head gaskets!
Just different words for exact the same thing.
The TT .40 SE comes with a head gasket (shim) that is 0,4mm thick but that is too thick if you want to run on lower nitro contents or no nitro at all.
For 15% nitro or more it might be perfeckt.
I haven't tried my new TT yet but I have made my own 0,1mm alumium gaskets and put two in so well see what happens when I run my engine on 80/20 fuel.
_____________________________
Jan Karlsson - Supplier MVVS Products
Hide Signatures
(in reply to airwebb)
       Post #: 28
RE: How to get max rpm out of a tt 40 - 6/23/2011 6:38 PM
GSJames
Score: 100
Last Login: 5/23/2013
Status: offline
Thanks!
Gary James
AMA CD 68845, NMPRA 15I, RCCA #908
Hide Signatures
(in reply to blindfaithnogod)
       Post #: 29
RE: How to get max rpm out of a tt 40 - 6/23/2011 8:05 PM
fizzwater2
Score: 124
Status: offline
There's a guy on e-bid.com that has a couple of bags of the Fox Lustrox lapping compound left.. not me, I just ran across it in a google search.
No matter where you go, there you are!
Hide Signatures
       Post #: 30
RE: How to get max rpm out of a tt 40 - 6/23/2011 9:55 PM
PAINLESS
Score: 100
Last Login: 4/9/2013
Status: offline
I did some bench testing with a TT40 some years ago and found .012 to .014" HEAD to PISTON clearance worked best (highest rpm) with a 9x6 prop and 15% fuel. I think I ended up with two .004" shims in there.
Hide Signatures
(in reply to fizzwater2)
       Post #: 31
RE: How to get max rpm out of a tt 40 - 9/1/2011 8:23 PM
Kevin Matney
Score: 105
Status: offline
What Merlin glow plug do you run???
Kevin Matney 2 wrongs don''t make a right But 2 Wrights make an Airplane
www.Matneymodels.com
Hide Signatures
(in reply to PAINLESS)
       Post #: 32
RE: How to get max rpm out of a tt 40 - 9/1/2011 8:43 PM
BarryReade
Score: 100
Last Login: 5/22/2013
Status: offline
I don't understand Please explain .004 + .004 = .008  how does this fit between .012 and .014.  I am having trouble connecting the dots so to speak.  Unless the the other .004 to .006 clearance was without any shims at all.  Is that what you were saying??
quote:
ORIGINAL: PAINLESS
Barry...
http://www.RCPRO.org
Hide Signatures
       Post #: 33
RE: How to get max rpm out of a tt 40 - 9/1/2011 9:38 PM
fizzwater2
Score: 124
Status: offline
Barry - yep, the rest of the clearance is in the stock fit with NO shim. It varies from engine to engine by a few thousandths of an inch, from what I can see.
I've had engines that would just about have zero clearance with no shims in place, others with several thousandths of clearance between the squish band on the head and the piston at TDC.
I've been running mine at .015 head to piston or thereabouts, might have to go down a little bit lower. That is, if I feel like messing with it. They all run pretty well at .015, I've been getting decent consistent runs there. It takes a whale of a lot of RPM difference to make up for flying, so practicing is probably time better spent instead of fooling with engines.
Break them in well, don't abuse them, and fly fly fly.
Hide Signatures
(in reply to BarryReade)
       Post #: 34
RE: How to get max rpm out of a tt 40 - 9/1/2011 10:55 PM
BarryReade
Score: 100
Status: offline
Yes, I treat my Pro 40's just like I did my F1 engines.  The fastest ones are only used on race day.  I never do aerobatics with them and the slowest ones are my practice mule engines.  And as you know it does make a difference.  I have been accused of doing something illegal as my motors run so well.  And not all 9x6 props are the same.  I buy a dozen, balance them and them run them on a test motor.  The ones that turn the fastest are used on race day the rest are practice and whatever.  And as you said practice,practice, and more practice.  One blown turn can cost 5 sec. or more on your time for that heat.
Barry...
Hide Signatures
       Post #: 35
RE: How to get max rpm out of a tt 40 - 9/1/2011 11:02 PM
fizzwater2
Score: 124
Status: offline
Barry - around here, we provide propellers with registration at the races, and they're dyed different colors, so we can tell if folks are using the provided props. You are correct, there are differences, but this way everyone has the luck of the draw.
We also fly some 426, for those who want to do like you're suggesting - buy lots of props, sort through them, test run/test fly, etc. 424 is our low-key fun event, and it's been working out pretty well. This year attendance is a little down due to the economy, but last year we got as many as 28 people to a 424 race. So far this year it's been 14-16 people. The two-day race that KCRC throws is October 1-2, that one usually draws a few more long-distance folks because they can race for two days!
Hide Signatures
       Post #: 36
RE: How to get max rpm out of a tt 40 - 9/2/2011 12:18 AM
sahartman21
Score: 110
Status: offline
I've been running a Merlin 2016 Globee style plug for the Thunder Tiger Pro 40.
It seems to be good for an additional 100 to 200 rpms when compared to a conventional plug.
Hide Signatures
       Post #: 37
RE: How to get max rpm out of a tt 40 - 9/2/2011 12:47 AM
BarryReade
Score: 100
Status: offline
Yes, the 216 takes up, more room in the combustion chamber.  It is like removing .004 worth of shims.  If you have shimmed the engine already then a 216 will slow the motor down. If you haven't and are running where head shimming is not allowed the 216 is a great plug
Barry...
Hide Signatures
(in reply to sahartman21)
       Post #: 38
RE: How to get max rpm out of a tt 40 - 9/2/2011 2:47 AM
airwebb
Score: 104
Status: offline
where do i get the merlin 216 plugs
Hide Signatures
       Post #: 39
RE: How to get max rpm out of a tt 40 - 9/2/2011 3:26 AM
Kevin Matney
Score: 105
Status: offline
http://merlinglowplugs.com/Aircraft.html
Hide Signatures
       Post #: 40
RE: How to get max rpm out of a tt 40 - 9/2/2011 4:38 AM
DHULEN
Score: 100
Status: offline
I have never had a new tt 40 all my engines have come from % Bay used but when i get them i check first for end play they must have it then I run them rich with a 9x4 and fly them rich I dive the plane so it realy turns up and i dont weld the muffler i use the 6/32 rod with a spring so it has room to grow so it can be taken apart to see its stock And never race them at peak leave room to unload
I think my engines run great thats all i do and they keep getting faster
Duane
12V
MOKAN
< Message edited by DHULEN -- 9/2/2011 8:09 AM >
Hide Signatures
(in reply to Kevin Matney)
       Post #: 41
RE: How to get max rpm out of a tt 40 - 9/2/2011 6:31 PM
GSJames
Score: 100
Status: offline
But be sure to change out the main bearing if it isn't one of the newer ones with the non-metal retainer. Don't learn the hard way...like I did...
Gary James
Hide Signatures
(in reply to DHULEN)
       Post #: 42
RE: How to get max rpm out of a tt 40 - 9/2/2011 7:04 PM
BarryReade
Score: 100
Status: offline
I hear you Gary.  I have been fortunate to learn that before I had the chance to mess one up.
Barry...
Hide Signatures
       Post #: 43
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.687RCU1
