RE: OS GT33 33cc gasser    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: OS GT33 33cc gasser
Page: <<   < prev  11 12 13 14 15 [16] 17 18 19 20   next >   >>
Login
RE: OS GT33 33cc gasser - 12/7/2012 8:50 PM
TimBle
Score: 162
Last Login: 5/25/2013
Status: offline
flies beautifully!
I'll start work on my Evolution with DLE 35 soon. going to be using a Min tor 38 pipe. Just need a header.
Hide Signatures
(in reply to wyo69cowboy)
       Post #: 376
RE: OS GT33 33cc gasser - 12/7/2012 10:20 PM
MTK
Score: 203
Status: offline
NO, no...not the flying. Was trying to convey the fact that gas engines in this displacement size up to 60cc give or take. don't have to sound like chain saws. There are off the shelf items one can use to knock out much of the noise and annoyance factors.
_____________________________
Regards,
MattK
Hide Signatures
(in reply to TimBle)
       Post #: 377
RE: OS GT33 33cc gasser - 12/13/2012 2:13 AM
Always flying
Score: 100
Last Login: 5/14/2013
Status: offline
has anyone run a header and pipe with this engine?...would like info on header length and prop combo...thx fellas'
Think i Won''t!...................
Hide Signatures
(in reply to MTK)
       Post #: 378
RE: OS GT33 33cc gasser - 12/26/2012 2:47 PM
rstekeur
Score: 100
Last Login: 4/25/2013
Status: offline
I'm building a Kangke 72" Waco bipe which should come in around 14lbs. I was thinking about a dle 35ra for the motor which is on back order till mid jan or the os 33. I'm not looking for 3d performance some areobatics. I like the single hole for the prop and OS has a good name. I just wonder if the OS33 is going to be enough for this plane.
Hide Signatures
(in reply to airborne2.4)
       Post #: 379
RE: OS GT33 33cc gasser - 12/26/2012 4:38 PM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: rstekeur
I have my 33 in an 11lb yak 54 and it has unlimited vertical at half stick ! At full throttle it just goes vertical much much quicker.
Hide Signatures
(in reply to rstekeur)
       Post #: 380
RE: OS GT33 33cc gasser - 12/26/2012 6:31 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: rstekeur
It will give your model all the power it needs plus quite a bit more
Regards,
MattK
Hide Signatures
       Post #: 381
RE: OS GT33 33cc gasser - 12/26/2012 6:53 PM
rstekeur
Score: 100
Status: offline
quote:
ORIGINAL: MTK
quote:
ORIGINAL: rstekeur
Thanks MTK, are you talking about the OS GT33?
Hide Signatures
(in reply to MTK)
       Post #: 382
RE: OS GT33 33cc gasser - 12/26/2012 7:58 PM
choihjin
Score: 105
Status: offline
Dear MattK
Nice to see you and your successful gas-powered F3A plane. I was very curious about you who is very talented in making all kind of hardwares, such as hand-made carbon props, exhaust pipe, soft-mount, plane itself...
I wondered who you are. I just met you in the you-tube. Thank a lot for your posting the video.
Wish you happy new year and all of you in this forum too.
Best Regards
Hide Signatures
(in reply to MTK)
       Post #: 383
RE: OS GT33 33cc gasser - 12/27/2012 2:55 AM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: choihjin
Dear MattK
Best Regards
 Choijin....My friend Auggie Scafidi posted the video since I haven't tried to figure out how to do that yet. The hobby gives me a great avenue for creation and release of ideas. I do what I do as matter of course. Then I post my findings, free of charge, for anyone to copy. So far, a few brave souls have tried some things successfully....Thank you for the ackowledgement !!
Regards,
MattK
Hide Signatures
(in reply to choihjin)
       Post #: 384
RE: OS GT33 33cc gasser - 1/6/2013 10:04 PM
seagull extra
Score: 100
Last Login: 5/13/2013
Status: offline
I just bought a 33 today. I am planning to use it in a 78" extra 300 that will likely weigh in at about 13.5 lbs. Does anybody have any prop no's for a 20"x8" prop?
Hide Signatures
(in reply to MTK)
       Post #: 385
RE: OS GT33 33cc gasser - 1/7/2013 12:50 AM
MTK
Score: 203
Status: offline
Somewhere around 7300 I'd guess, or a bit more on muffler. Let me put it this way, Mine is piped and turning a 20x10.5 APC at 7400 (Avgas mixed 50:1 with Bel Ray MC1), and around 7750 on premium autogas.
Engine is putting out over 24 lbs of thrust at full revs, so maybe that will be closer to 20-22 lbs on muffler.
I use a Dynatron to start it. It hand starts fine but takes a little more flipping than I want. Dynatron starts are simple, making this chore easy
Regards,
MattK
Hide Signatures
(in reply to seagull extra)
       Post #: 386
RE: OS GT33 33cc gasser - 1/7/2013 12:52 AM
ghoffman
Score: 163
Status: offline
What pipe Matt?
Hide Signatures
(in reply to MTK)
       Post #: 387
RE: OS GT33 33cc gasser - 1/7/2013 1:16 AM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: ghoffman
What pipe Matt?
Same as yours Gary, ESComposites 40G carbon. You wanna hear something sweet, take a look at my video...
Regards,
MattK
Hide Signatures
(in reply to ghoffman)
       Post #: 388
RE: OS GT33 33cc gasser - 1/7/2013 1:15 PM
seagull extra
Score: 100
Status: offline
Thanks for the reply Matt. I did notice that you were getting some good prop no's with your pipe. I was hoping to get some first hand prop no's with the stock muffler as that is what I will be using. If it can do 7000rpm with say a 20x8 xroar prop I should be okay. Like I said my plane will be at least 13.5 lbs possibly 14lbs so I know I'm getting to the upper limit for weight for this motor.
Hide Signatures
(in reply to MTK)
       Post #: 389
RE: OS GT33 33cc gasser - 1/7/2013 1:34 PM
ghoffman
Score: 163
Status: offline
Nice!  How is the sound without the exhaust exit device?
Hide Signatures
(in reply to MTK)
       Post #: 390
RE: OS GT33 33cc gasser - 1/7/2013 2:49 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: ghoffman
It's the same as far as dB go. But to the ear, the sound is very slightly different, mellower with the gizmo on.
An earlier experiment, before the diffuser, accomplished the same thing as the diffuser by reducing the stinger cross section to 5/16", so I think it has more to do with the exhaust stinger cross section than it does with diffusing the exhaust.
Final word on that hasn't been written yet as the R&D continues. I've come up with something different for the exhaust but that will have to wait til Spring...
I should have a different plane by then too to try the piped OS in.
Regards,
MattK
Hide Signatures
       Post #: 391
RE: OS GT33 33cc gasser - 1/7/2013 2:51 PM
ghoffman
Score: 163
Status: offline
What dB at 20 feet is it?
Hide Signatures
(in reply to MTK)
       Post #: 392
RE: OS GT33 33cc gasser - 1/7/2013 2:56 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: seagull extra
The XOAR props are a little more load than APC's because of the wider and thicker blades. If you aren't happy with the results, don't fret it. Get an APC prop from Central Hobbies. They are heavier props than the wood but are more efficient and work exceptionally well in suppressing noise. Remember, if you can hear the prop it means power is taken from thrust and being converted to noise
I think you said a 78" Extra. I know of the Extreme Flight 78" Extra. That model is very light and the OS is perfectly suited to it
Regards,
MattK
Hide Signatures
       Post #: 393
RE: OS GT33 33cc gasser - 1/7/2013 2:59 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: ghoffman
Hmmmmm... Dunno! It's around 92-93 at 10 feet over grass.
I would guess around 88-89 at 20 feet over grass. Probably 90 over asphalt
Who sez you can't quiet a gassie??
Regards,
MattK
Hide Signatures
       Post #: 394
RE: OS GT33 33cc gasser - 1/7/2013 4:10 PM
BarracudaHockey
Score: 280
Status: offline
I think that engine would be perfect on the EF 78" Extra.
I just got one to review thats going on a 70 Fokker DVII but when I'm done with the review I'll be looking for an aerobat for it and may get another Extra (I had one before that I used to test a couple of the MLD engines on)
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to MTK)
       Post #: 395
RE: OS GT33 33cc gasser - 1/7/2013 4:23 PM
ghoffman
Score: 163
Status: offline
Yes, that is what I am thinking, and since I have the pipe, all I would need is the header.  However, I am going to try the M38 we got back from service and try it since I have it, the header and the ES40G pipe. By then, the WRAM show will have happened and I will have an idea if the DA-35 will ever come out.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 396
RE: OS GT33 33cc gasser - 1/7/2013 4:37 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: ghoffman
I had the M38 and tried it with the Mintor pipe and the ESC 40G. It isn't in the same league as the OS, powerwise.
But it is a nice sport engine with very good field manners. I sold mine to a sport flier
Regards,
MattK
Hide Signatures
       Post #: 397
RE: OS GT33 33cc gasser - 1/13/2013 11:30 PM
Broken Wings
Score: 141
Status: offline
I "saved up" and bought one of these engines. It looks pretty nice. I have a Macs Products #1096 Quiet Tuned Pipe that is 25" long. I ordered the header pipe for this engine from Macs as well.
Does anyone know what the length from the spark plug to the first baffle in the pipe should be?
Club Saito member #715
Club Jett member #12
Hide Signatures
(in reply to MTK)
       Post #: 398
RE: OS GT33 33cc gasser - 1/19/2013 2:48 AM
coronabob
Score: 110
Status: offline
Flew my GT33 for the first time today. Started easily and I knew how to avoid the backward running thanks to this post. No break in on the ground, Xoar 20x8 on a Great Planes Yak with factory settings I got 6,400. The plane went vertical at a constant speed at less than WOT. It was very quiet in the air as I could barely hear it with someone running their engine on the ground. It idled very well below 1800, accelerated w/no burble. I am very very pleased with it.
Hide Signatures
(in reply to Broken Wings)
       Post #: 399
RE: OS GT33 33cc gasser - 1/19/2013 4:28 AM
seagull extra
Score: 100
Status: offline
Thanx for posting your prop no's Bob. I am planing on using the 20x8 xroar as well. I just recieved mine a couple af days ago and it looks great. I comapred it to a new DL 20 and DL 50 that I have and it is very easy to see that the OS is made to a much higher standard just by looking at them. I will be putting mine in a Great Planes Patty Wagstaff so I will probably be on the upper limit for good performance with the 33cc. I have another Patty with a 50cc that I did a lot to keep the weight down to 15.0lbs. I should come in at 13.5 to 14 lbs with this one. Do you know how much your Yak weighs Bob?
Hide Signatures
(in reply to coronabob)
       Post #: 400
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: OS GT33 33cc gasser
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
