RE: Fly Eagle 1/6 scale F-16 Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Fly Eagle 1/6 scale F-16 Build Thread
Page: <<   < prev  23 24 25 26 [27] 28 29 30 31 32   next >   >>
Login
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/2/2012 1:32 AM
FalconWings
Score: 121
Last Login: 6/19/2013
Status: online
......Combat F-16? Probably more difficult to set one up properly than your FEJ!!
_____________________________
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
(in reply to FenderBean)
       Post #: 651
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/2/2012 2:17 AM
FenderBean
Score: 124
Last Login: 6/10/2013
Status: offline
Only hard part was the nose gear and the gear door
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to FalconWings)
       Post #: 652
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/2/2012 3:03 AM
VF84sluggo
Score: 345
Last Login: 6/18/2013
Status: online
FB, looks like you got that F-16 dialed in! Very nice.
Hide Signatures
       Post #: 653
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/2/2012 7:15 AM
FenderBean
Score: 124
Status: offline
thanks sluggo yeah she is going great, time to hook up the afterburner ring and scale lights
quote:
ORIGINAL: VF84sluggo
Kingtech 170F
Hide Signatures
(in reply to VF84sluggo)
       Post #: 654
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/2/2012 1:02 PM
VF84sluggo
Score: 345
Status: online
Now you're talkin'! I look forward to seeing that.
BTW, what jets are you looking at getting this year? I'm wanting a Flash real bad.
Hide Signatures
       Post #: 655
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/2/2012 3:38 PM
KC36330
Score: 328
Last Login: 6/17/2013
Status: offline
Randy, fix that L39 and fly it till the wheels fall off..........oh sorry they already have
JetCat USA Rep / KingTech Turbines Rep
Hide Signatures
       Post #: 656
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/2/2012 4:23 PM
VF84sluggo
Score: 345
Status: online
LOL...that's good. Yeah, Skymaster 'quality' helps that happen, can't take all the credit.
This L-39 can't take half the 'firmness' of some of the landings that other planes handle with no trouble. I'm working with a buddy on beefing up the gear mount area. The Skymaster design is not well braced to handle the torsion applied by trailing link gear...especially when it's only half-glued, and with Chinese 'hysol' to boot.
Hide Signatures
(in reply to KC36330)
       Post #: 657
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/2/2012 5:40 PM
KC36330
Score: 328
Status: offline
I've flown their L39 and liked it so at least you'll have a good flier when you get it all fixed up. That has a way of making all the problems leave your mind.
Hide Signatures
       Post #: 658
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/5/2012 3:58 PM
lookilook
Score: 100
Status: online
Well i finished my F16 today , put everything together and worked flawless. One major thing left and that is to prime engine valves and start the engine and hopefully all goes well.
It will take a while to recover from my injury so maiden flight will be delayed for a couple of months.
A small video of functions that was filmed at 1080p and got knows why youtube edit it on 360p!!!!   http://www.youtube.com/user/northnik
regards
Nicos
OWNER OF
F16 1/8 K80E
Hide Signatures
       Post #: 659
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/13/2012 3:56 PM
GCA-NavAids
Score: 100
Last Login: 5/26/2013
Status: offline
As a Chopper instructor and Helicopter/Jet modler I was wondering if you had seen this one yet?
The new Eurocopter.  No tail rotor so it looks like the torque pedals may control the thrust of the 2 propellers independently.
  http://www.youtube.com/embed/8ljxyDtCsaM
 Imagine this machine loaded down with ordanence.
You are below the Glidepath. Decrease your rate of decent.
Increase power and pull up. damnit ... I said ... PULL UP!!
Hide Signatures
       Post #: 660
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/13/2012 4:08 PM
KC36330
Score: 328
Status: offline
quote:
ORIGINAL: GCA-NavAids
doesn't look like a very good combat design setup but i bet the props are a real treat during a retreating blade stall.
Hide Signatures
(in reply to GCA-NavAids)
       Post #: 661
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/20/2012 6:23 AM
lookilook
Score: 100
Status: online
hi to all readers of this  thread, i am using fenders thread as mine is also FEJ F16 1/6 but with honeycomb material and i post here just for information to all who are interested.
yesterday i weighted the plane after i installed everything and had the header tank full and gears extended. what i have extra on this is a triple ring afterburner and controller plus 7.2v 1000mah , D4S light system and controller plus lifepo 6.6v 2500mah, animatronic pilot with 6v nimh 2000mah,powerbox smoke pump,2 digital screens for cockpit and the detail package from D4S. To have the plane balanced at recommended 220mm i needed to move 3 batteries behind the cockpit area and then just lifted it up and showed 16.1kg= 35.4lbs
i have installed a K170 on this baby and i think i will be ok. i quess if i could avoid some of  the extras the plane could weigh from  about  an average 15kg=33lbs maybe less.
OWNER OF
F16 1/8 K80E
Hide Signatures
       Post #: 662
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/20/2012 11:58 AM
mdeseve
Score: 100
Status: offline
Hi, i did fit details4scale speedbrake on my fej f-16, lots of work cause they were made for skymaster. But with modification, it fit, and i'm happy i did it , i could solidify the glue joint inside the elevator support. If interest i can post pics later.
Mike
Jet Central Rabbit, Superbee, kingtech k-80, cheetah, kingtech k-170f...
Hide Signatures
(in reply to lookilook)
       Post #: 663
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/20/2012 12:36 PM
lookilook
Score: 100
Status: online
hi, i am interested, i thought there was no way to fit those on an FEJ, is it honeycomb you have? post the pictures
OWNER OF
F16 1/8 K80E
Hide Signatures
(in reply to mdeseve)
       Post #: 664
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/20/2012 1:45 PM
mdeseve
Score: 100
Status: offline
I don't have the honeycomb, here some pics:
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 665
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/20/2012 1:47 PM
mdeseve
Score: 100
Status: offline
More...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 666
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/20/2012 1:57 PM
mdeseve
Score: 100
Status: offline
I have to redo the right side
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 667
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/20/2012 2:17 PM
FenderBean
Score: 124
Status: offline
Weight is pretty good for all the bling! I will eventually sale this one and get the new version so can fly it with wing ordinance. Maybe even go with the larger one.
Looking good
Kingtech 170F
Hide Signatures
       Post #: 668
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/20/2012 4:31 PM
lookilook
Score: 100
Status: online
fender , can you please tell me how many liters are the 3 fuel tanks we have in our f16?
OWNER OF
F16 1/8 K80E
Hide Signatures
       Post #: 669
RE: Fly Eagle 1/6 scale F-16 Build Thread - 1/20/2012 5:07 PM
FenderBean
Score: 124
Status: offline
I believe I posted the exact weight in my build but if i remember its like almost a full gallon
quote:
ORIGINAL: lookilook
Kingtech 170F
Hide Signatures
       Post #: 670
RE: Fly Eagle 1/6 scale F-16 Build Thread - 2/4/2012 3:47 AM
GCA-NavAids
Score: 100
Status: offline
Fender... any further progress with the armament or flights that you care to share with those of us who have been following this thread? Thanks and be well.
Hide Signatures
       Post #: 671
RE: Fly Eagle 1/6 scale F-16 Build Thread - 2/4/2012 4:47 AM
Wap4life
Score: 110
Status: offline
hey fender
here they go
Click for fullsize
Click for fullsize
Click for fullsize
Wap
FEJ F14, Mig 29 & F15; Tam F16
Hide Signatures
       Post #: 672
RE: Fly Eagle 1/6 scale F-16 Build Thread - 2/4/2012 5:45 AM
FenderBean
Score: 124
Status: offline
dude that just looks like a blast to arrange, im a super freak on routing wires and air lines I would have a field day with that! I mean will have !
Kingtech 170F
Hide Signatures
(in reply to Wap4life)
       Post #: 673
RE: Fly Eagle 1/6 scale F-16 Build Thread - 2/24/2012 1:37 AM
essyou35
Score: 100
Status: offline
Fenderbean:  I read this whole thread today after KC mentioned in another thread you were getting guff for getting an f-16 as your first jet.  After reading all this, you and I are very similar in our thinking.  You are an inspiration for sure!
Let me ask you this, in retrospect, do you think the f-16 was a good jet to start with?  I watched your 11th landing, that lands slower than my HET a-10!  If you could do it over, would you of got a shock (not) jet?
I'm in the same spot now you were last year.  I have a FEJ f-16  except mine is 1/8th scale.
I wonder if the 1/8th scale lands faster perhaps?  On this page:
http://wigen.net/hobby/f-16/
Watch flight #7's landing around the 3:24 mark.  I bounces like yours except it actually stops in the air about 5 feet up,  and the pilot pulls out of that...  I dont know about you about that doesnt look like a jet that lands "Fast".
Hide Signatures
       Post #: 674
RE: Fly Eagle 1/6 scale F-16 Build Thread - 2/24/2012 1:54 AM
FenderBean
Score: 124
Status: offline
Well even what I know today I still would have done everything the same, the only thing I would have done different would be not let people suck me into to childish banter and just used the block feature more . I know my abilities and so I had no worries about being able to fly my Jet, I was nervous for sure but when you have this much money in something its just the way it is. I think a lot of people land a lot faster than they have to. Good luck
Kingtech 170F
Hide Signatures
(in reply to essyou35)
       Post #: 675
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
