RE: Fly Eagle 1/6 scale F-16 Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Fly Eagle 1/6 scale F-16 Build Thread
Page: <<   < prev  23 24 25 26 27 28 29 30 [31] 32   next >   >>
Login
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/3/2012 4:49 PM
FenderBean
Score: 119
Last Login: 5/22/2013
Status: offline
Yeah my verzion has the old style servo mount so i didnt have that part but looks like james helped you. The f16 is almost a trainer in my opinion, i was having some issues this past weekend but i found my cg was off a bit just get it perfectly level at 220 and the landings are nice. Glad to help that was my goal of the build, where in south korea do u fly? I was stationed there for two years.
_____________________________
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to lookilook)
       Post #: 751
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/5/2012 3:15 PM
suhakkogi
Score: 100
Last Login: 5/18/2013
Status: offline
James,
Thanks for good picture.
If there is part list or manual, It will be good help to customer.
But I like building kit and also challenging.
Lookilook,
Mine is also 1/6 size and new honey comb material like you. This is my first kit really huge.
I think so too, light and detail kit additionally speed brake. Next item. I'm really exciting with it.
By the way what about your elevators? is it stiff too?
Hide Signatures
       Post #: 752
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/8/2012 2:09 PM
suhakkogi
Score: 100
Status: offline
I fly in Pyeongteak. But like this big bird I have to fine somewhere else. Where have you stayed? I used to go to pool in Pyeongteak air base on summer seasen because of my soldier buddies. Good to know you.
Hide Signatures
(in reply to FenderBean)
       Post #: 753
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/8/2012 8:53 PM
FenderBean
Score: 119
Status: offline
Camp Humphrey right next to Pyeongteak
Kingtech 170F
Hide Signatures
(in reply to suhakkogi)
       Post #: 754
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/11/2012 2:18 PM
suhakkogi
Score: 100
Status: offline
James,
Is FEJ working or not? Holiday?
I requested to send my valley tank which they missed when shipped. But no responding.
I checked several times to find out in the 3 boxes as they requested. Nothing.
Can you help me to push sending it to me?
This is my first time to have dealing with FEJ. But responding is too slow.
Regards,
Jake Ham
Hide Signatures
(in reply to EagleJC)
       Post #: 755
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/11/2012 3:25 PM
FenderBean
Score: 119
Status: offline
Well they were on holiday till after the 8th, who are you contacting?
Kingtech 170F
Hide Signatures
       Post #: 756
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/12/2012 6:04 AM
suhakkogi
Score: 100
Status: offline
That's why still pending. I got the answer today morning after I wrote message above last night. They will make it another one and ship after a few days.
I think they might send it to someone else.
Hide Signatures
       Post #: 757
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/27/2012 3:18 PM
suhakkogi
Score: 100
Status: offline
I have a question during the elevators installing.
There is no bearing on the elevators mounting point. Do you just install them with oil due to high torque servo? or choose another way to minimize friction?
What do you think?
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 758
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/27/2012 3:57 PM
FenderBean
Score: 119
Status: offline
No there is suppose to be a bearing inside, mine has a two I think, Mine has a brass tube with a place cut out for the flat spot on the elevator shaft. When you install mine I put the brass sleeve on the elevator shaft, slide a white plastic spacer ring on, and insert into the jet which slides through the bearings. Then on the inside you slide the elevator arm/clamp onto the shaft and push it on till it touches the inner race of the bearing. The prevents the elevator for moving in and out, your picture doesnt look right to me, my jet has a ply bulkhead and some aluminum in that area where the bearing and bearing holder mounts.
quote:
ORIGINAL: suhakkogi
What do you think?
Kingtech 170F
Hide Signatures
       Post #: 759
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/28/2012 2:31 PM
suhakkogi
Score: 100
Status: offline
I'm also really wondering why there is no bearing in it. Nothing at all. Only plastic sleeve like pipe. As you said there should be bearing on the moving parts with high load.
Guys! Do I have to modify like below picture which is skymaster's one or is there any great idea to solve it? Please advise me.
Click for fullsize
Hide Signatures
       Post #: 760
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/28/2012 5:03 PM
EagleJC
Score: 101
Last Login: 3/17/2013
Status: offline
Hi Suhak...
Your F16 should be new version with different set up. I have asked company to sent you some photos by email. You can check your email for set up.
James
FLY EAGLE JET/ US Distributor
Hide Signatures
(in reply to skunkworksrc)
       Post #: 761
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/29/2012 1:29 PM
suhakkogi
Score: 100
Status: offline
Hello James,
I got the picture from the factory. Thank you for supporting me.
They informed me my F16 is new version which have direct drive mechanism on the elevator.
But there was no bearing.
I'm still wondering it is reliable. due to that stiffness, I think it can be happen loosing jet due to over consumption voltage.
Also I may need more high torque servos.
Hide Signatures
       Post #: 762
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/29/2012 4:02 PM
EagleJC
Score: 101
Status: offline
Hi
here are couple photos to show the new set up on elevators.
James
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 763
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/29/2012 5:25 PM
powerjets
Score: 110
Status: offline
I get the idea behind it, but it does not look good to me....I might be wrong though.
does anybody have experience with this system being used on a regular basis ?
Is there any loss in torque this way?
OUfly12
Hide Signatures
       Post #: 764
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/29/2012 9:58 PM
FenderBean
Score: 119
Status: offline
Im not a fan of this type design, I personally will not buy any that has this design(not saying its bad or good just saying I like bearings) if the wear out you can replace them. I would bet the FEJ can do it with or without per buyers request.
Kingtech 170F
Hide Signatures
(in reply to powerjets)
       Post #: 765
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/30/2012 12:58 AM
FalconWings
Score: 121
Status: online
I had a small Yellow F-16 with a similar setup on the ailerons, to ease wing removal. It worked great but I would never trust it to an elevator of such size. It is though, a good concept for LE Flaps. I may be doing something similar on my future F16 project.
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
       Post #: 766
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/30/2012 3:02 AM
EagleJC
Score: 101
Status: offline
Fender:
I have one J10 (canard set up is simiar to this). It has around 150 flights on. Never has a single issue or wear out on this part.
Mr. Liu flew his J10 more than 200 flights on, no issue on this part.
One customer has F16 1/5.5 scale, he got his model 5 or 6 months ago. He got more than 300 flights (fly almost every day) and never has an issue on this part.
Anyway, I will suggest this part  to company if can be an option with bearing.
James
Hide Signatures
(in reply to FalconWings)
       Post #: 767
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/30/2012 4:27 AM
FenderBean
Score: 119
Status: offline
I just dont see how a shaft rotating inside something without a bearing is the best design, if you say it works then I guess it does. I like the idea of continued improvements but it is impossible for two materials to rub/rotate without some wear. Just to be clear im not talking about the part that attaches to the servo and goes into the control surface, I am just talking about the shaft going into the jet from the control surface.
Does the hole have something special like teflon or something?
Just my thoughts and personal liking, man 300 flights on the F-16 is out standing I need his landing gear for sure.
quote:
ORIGINAL: EagleJC
Fender:
James
Kingtech 170F
Hide Signatures
       Post #: 768
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/30/2012 4:31 AM
FenderBean
Score: 119
Status: offline
That is my opinion, I think its great design for the wings, slats and ailerons, would be great and like you said ease of removal would be fantastico!! I just think the larger/heavy jet elevators need something. The flight load on a elevator is crazy, plus you have forces twisting, pushing and rotating all at the same time.
quote:
ORIGINAL: FalconWings
Kingtech 170F
Hide Signatures
       Post #: 769
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/30/2012 4:48 AM
dubd
Score: 135
Status: online
I agree. The elevator should have bearings.
Hide Signatures
       Post #: 770
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/30/2012 5:26 AM
EagleJC
Score: 101
Status: offline
hi Fender:
there is ABS material tube inside the hole. So, the titanium rod go throught the hole to work with the ABS tube together perfectly. after intall, there is no play at all on stabs. fly many times, still work perfectly and no play either.
his landing gear is same as the new one you have.
James
Hide Signatures
(in reply to dubd)
       Post #: 771
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/30/2012 7:19 AM
FenderBean
Score: 119
Status: offline
Thanks for the info
quote:
ORIGINAL: EagleJC
hi Fender:
James
Kingtech 170F
Hide Signatures
       Post #: 772
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/30/2012 7:22 AM
dubd
Score: 135
Status: online
James, seems to me that a plastic tube (ABS) is more prone to wear, especially on planes that are flown hard. Do you feel that the ABS is superior over bearings?
Hide Signatures
       Post #: 773
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/30/2012 3:29 PM
suhakkogi
Score: 100
Status: offline
Fender,
You said all what I want to say. I really really agree that elevator should be bearing.
Whatever material used for this elevator support, at the moment this elevator is very stiff without any modify.
I'm wondering what Mr,Liu did do his jet, and configuration.
James,
That's very good approach. The buyer definetly want bearing on the elevator even it is option.
By the way James, can I also buy elevator support parts with bearing to modify it like old version style same as Fenders's one?
I need whole related parts.
Hide Signatures
       Post #: 774
RE: Fly Eagle 1/6 scale F-16 Build Thread - 10/30/2012 3:37 PM
suhakkogi
Score: 100
Status: offline
Thanks, I'll do.
But I'm still thinking what is the best solution to clear this issue.
I'm expecting FEJ supporting.
Hide Signatures
       Post #: 775
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.781RCU1
