Engines for Hangar 9 Twin Otter    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> Engines for Hangar 9 Twin Otter
Page: [1] 2   next >   >>
Login
Engines for Hangar 9 Twin Otter - 6/25/2011 4:31 PM
cwasik
Score: 100
Last Login: 4/7/2013
Status: offline
I purchased a Hangar Twin Otter last year and I am finally at the stage of selecting power. I thought about getting the OS 35 AX's but the price is steep. I know that will probably be my best bet but they are a little steep in price for me. I have two 46 FX's that I was thinking about but I am not sure if they will be to heavy for the model. Does anyone have any suggestions? Any advice would be greatly appreciated.
Hide Signatures
       Post #: 1
RE: Engines for Hangar 9 Twin Otter - 6/27/2011 4:22 PM
slopoke
Score: 105
Last Login: 5/19/2013
Status: offline
I have Saito .40's in mine. It flys very well and sounds great.
_____________________________
Saito #254
Life is too short to fly helicopters.
Hide Signatures
(in reply to cwasik)
       Post #: 2
RE: Engines for Hangar 9 Twin Otter - 7/3/2011 2:56 AM
cwasik
Score: 100
Status: offline
I wonder if two Saito 56's would work well or if weight would be a big issue. I already have one 56 so this would be a good alternative to the O.S. 35's if I can make it work.
Hide Signatures
(in reply to slopoke)
       Post #: 3
RE: Engines for Hangar 9 Twin Otter - 7/3/2011 11:46 AM
Lifer
Score: 148
Last Login: 5/21/2013
Status: offline
Thunder Tiger Pro .36's might be an affordable option. I have had good luck with these engines.
Hide Signatures
       Post #: 4
RE: Engines for Hangar 9 Twin Otter - 7/3/2011 12:45 PM
cwasik
Score: 100
Status: offline
I use two of the TT 40's for Pylon Racing and they both run really well. They seem very reliable and they are quite a bit chreaper than the O.S. 35's. Great suggestion.
Hide Signatures
(in reply to Lifer)
       Post #: 5
RE: Engines for Hangar 9 Twin Otter - 7/3/2011 7:08 PM
bigstew60
Score: 100
Status: offline
I am putting os 70 4 strokes on mine.
carl h stewart jr
Hide Signatures
       Post #: 6
RE: Engines for Hangar 9 Twin Otter - 11/11/2011 6:54 PM
speedbrake
Score: 100
Last Login: 5/12/2013
Status: offline
Used two Saito 40 four strokes. Flies great.
Keith
Click to see fullsize image.
Click for fullsize
Speedbrake
Hide Signatures
       Post #: 7
RE: Engines for Hangar 9 Twin Otter - 11/12/2011 11:38 PM
bigstew60
Score: 100
Status: offline
I ran into a snag with my twin otter. The os 70 four strokes wont fit without me cutting into the firewall to recess the engine back. I am trying to decide if i should do it or find some smaller 4 strokes.
carl h stewart jr
Hide Signatures
(in reply to speedbrake)
       Post #: 8
RE: Engines for Hangar 9 Twin Otter - 12/12/2011 2:18 AM
kthmarks
Score: 100
Last Login: 5/9/2013
Status: offline
I'm in the process of doing a makeover to the H9 Twotter. I am making a DHC6-100 instead of the -300. I did quite a bit of research on engines so hopefully you can benefit. Since I am recovering/glassing/painting, I was not confident the Saitos 40's would perform with the increased weight. The FA-40 appears to be the only 4 stroke engine that will fit without modification.
Below is what I found. I elected to go with the Saito FA62A's since they are in the same case as the FA56, and I already own one of the required 2. I also extend the cowl instead of cutting into the firewall as I also increased tank size from the standard 8oz tank to 10oz. The line of the prop still appears to be in line with the fuse in a scale location. I'll post pics when I get some.
Disclaimer.... the dims for the Magnum below is the best I could determine. Info for that engine is hard to find.
Below is my target model
Click for fullsize
Keith Marks
AMA 49064
Hide Signatures
(in reply to bigstew60)
       Post #: 9
RE: Engines for Hangar 9 Twin Otter - 12/12/2011 6:44 AM
Chuck54sd
Score: 100
Last Login: 5/17/2013
Status: offline
Just installed 2 OS Max .46 AX's in mine.... have not flown it yet. Balance came out great (no weights needed). It's a tight fit.... but came out great. I kept the regular mufflers on it. Just tweaking out the controls right now. Used the mix function in my Futaba 8FG for the elevators (you will need to reverse one side & mix gear with elevator or buy a servo reversor). This will be my test bed for the Twin sync since the cowls are easy to get to. The reason I selected the OS 46's..... is I have had a history of solid performance with them.... a very stable and dependable engine.... with great power for this size bird. For a twin..... stable is good. The OS Max 55AX.... not so much. (great power for size.... but finicky).
Hide Signatures
(in reply to kthmarks)
       Post #: 10
RE: Engines for Hangar 9 Twin Otter - 12/13/2011 5:47 PM
fledermaus
Score: 105
Last Login: 3/4/2013
Status: offline
The Evolution 36s that H9 "recommends" work just fine in my Twotter. They fit nicely, and the price is excellent. Plane flies in a very scale fashion using the 11x6 prop that H9 recommends (slightly "over propped" for the engine but it works much better than the 10x6 you might otherwise use).
Hide Signatures
(in reply to Chuck54sd)
       Post #: 11
RE: Engines for Hangar 9 Twin Otter - 1/3/2012 1:12 AM
Thomas B
Score: 111
Last Login: 5/10/2013
Status: offline
I went with E-Flite Power 32s, 4s4000 lipos and 60 amp Detrum ESCs for my Twotter.... Total power system cost including batteries was $270. (motors were $70, ESCs were $20 and the lipo was $45, per side.
Hard to beat electric power for the H9 Twin Otter....no cylinder head or muffler cutouts, improved reliability and they give a very nice simulation of scale turbine power!
I got mine together over the Christmas break and maidened it on 12/30/11. A really great flying model!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Electric Coolhunter
Hide Signatures
(in reply to fledermaus)
       Post #: 12
RE: Engines for Hangar 9 Twin Otter - 1/4/2012 2:45 AM
SIMCO
Score: 100
Last Login: 5/20/2013
Status: offline
Love the last picture on final. Looks like Woody is dressed for the Artic!!!
Hide Signatures
(in reply to Thomas B)
       Post #: 13
RE: Engines for Hangar 9 Twin Otter - 3/6/2012 6:12 PM
jetpassion
Score: 100
Status: offline
About how many minutes you can fly with this setting ?
Hide Signatures
       Post #: 14
RE: Engines for Hangar 9 Twin Otter - 4/8/2012 3:48 PM
kthmarks
Score: 100
Status: offline
Hey guys......below is a link to my second outing with the Otter. GREAT flying plane. Could not be happier.
http://youtu.be/kdffK5v5fJM
Click for fullsize
Click for fullsize
Keith Marks
AMA 49064
Hide Signatures
(in reply to jetpassion)
       Post #: 15
RE: Engines for Hangar 9 Twin Otter - 4/8/2012 9:54 PM
korvette
Score: 100
Status: offline
 Hey Keith,
You have saito .62 engines on board....do the fit in?...and the exhaust ? Please, a few close up foto's. :-)
Or did you have to rebuild the plane?
Kor
Hide Signatures
       Post #: 16
RE: Engines for Hangar 9 Twin Otter - 4/9/2012 12:23 AM
kthmarks
Score: 100
Status: offline
Below are a few photos.
I had to rework the nacelles to get the 62's to fit. I extended the cowls appx 1/2" by adding blocks to the existing firewall and then filled in recessed space that the nacelles originally mounted to with 1/32 ply and filler. In addition, I removed the tank floor of each nacelle and made a new one appx 3/4" lower to achieve the correct center-line relationship of the tank to the carb. I used a combination of maple, basswood and light 1/4" plywood to reinforce the construction after cutting out the floor.
I bumped the tanks from 8oz to 10oz and I'm glad I did. My last flight was 8.5 minutes and I used appx 5oz of fuel. With regard to the exhaust, I used a 90 degree adapter (tapped for pressure) with a straight pipe out the bottom of the nacelle. Unfortunately it doesn't sound like a turbine.....more like a hot rod!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Keith Marks
AMA 49064
Hide Signatures
(in reply to korvette)
       Post #: 17
RE: Engines for Hangar 9 Twin Otter - 4/9/2012 8:22 PM
korvette
Score: 100
Status: offline
 Hi Keith,
Great looking plane...and those army colors are awsome....
Mabay are a couple of turbo header mufflers the solution for your sound problem ? ( http://www.rcspecialties.net/ )
What do you think...are those muffles fit insite the cowls ?
Greatings,
Kor
Hide Signatures
       Post #: 18
RE: Engines for Hangar 9 Twin Otter - 4/10/2012 3:04 AM
kthmarks
Score: 100
Status: offline
Those mufflers may be a good solution. I'll look into it. After so much building over the winter, I think I'm going to enjoy this bird a little before I make any changes.
With regard to the finish, it is actually modeled after the Norwegian Special Forces aircraft used from 1967-2001! The plane later got around some and unfortunately met it's demise not far from where I live here in Georgia, US. I found that out after I was well into the project. Good thing I am not superstitious.
http://www.719skvadron.no/dhc6/dhc6-news.htm
If you're thinking about going with 4 stroke glow, I'd seriously look at the OS FS56 or better yet, the YS FZ70-S. Both have a smaller footprint than the Saitos and deliver more power. The YS has a crazy amount of HP. I went with the Saitos because I already had one of the required two and did not want to incur the added cost.
Keith
Keith Marks
AMA 49064
Hide Signatures
       Post #: 19
RE: Engines for Hangar 9 Twin Otter - 4/10/2012 8:01 AM
korvette
Score: 100
Status: offline
I have those saito's already in my possession :-)....one is in use already...the other one is new.
The intention was that they come in the Marutaka Cessna 337 Skymaster.... but I have to finish this plane...and thats gonna take a while.
Thats why I am looking for a RTF twin plane where I can use those engines...and this twin Otter looks great.
I think I am gonna order one.....I see in your pics that the engine fits with some modifications....the mufflers....whell...perhaps the original saito's or also those turbo mufflers...if they are not too noisy.
Kor
Hide Signatures
       Post #: 20
RE: Engines for Hangar 9 Twin Otter - 4/10/2012 2:35 PM
kthmarks
Score: 100
Status: offline
See attached for the modifications I did to accommodate the Saito 62's. Your experience may vary.
Click for fullsize
Keith Marks
AMA 49064
Hide Signatures
       Post #: 21
RE: Engines for Hangar 9 Twin Otter - 6/17/2012 2:34 PM
jbettinelli
Score: 100
Last Login: 8/13/2012
Status: offline
Hello all, I took my otter to the feild yesterday and had trouble synching the engines. One was running faster than the otther, I dicsonneceted the throttel servo pushrod to get it to run in sequnce with the other engine, but I still couldnt get them close enough. When I taxied the runway, I had to keep constant rudder to track straight.
I am considerign buying a servo synchronizer, I dont have anotehr channel on my radio to program.
So, couple questions, how close in RPM's do you get, or do you do it by ear, and do you think the synchronizer is a solid solution?
This is my first twin, so trying to learn as |I go along.
have a great day, thanks,
Joe
Hide Signatures
       Post #: 22
RE: Engines for Hangar 9 Twin Otter - 6/17/2012 4:40 PM
JPMacG
Score: 123
Last Login: 5/16/2013
Status: offline
My experience (with 2-stroke twins) is that you should adjust the linkages so that the throttles track mechanically as closely as possible. When you get to the field you run each engine independently and tune the high and low needles the normal way. And then fly.
No attempt should be made to adjust the needles so that the engines run at the same rpm. That is a recipe for having an engine quit in flight, which can be ugly. And by the way, for someone new to twins, I recommend that if you lose an engine in flight you immediately throttle down the other engine and perform a dead stick landing like on a single engine model.
You may need to run your newer Saito more before marrying it with the older Saito. Maybe for several gallons of fuel so that it is fully broken in.
Hide Signatures
(in reply to jbettinelli)
       Post #: 23
RE: Engines for Hangar 9 Twin Otter - 6/17/2012 4:57 PM
JPMacG
Score: 123
Status: offline
I'll add another comment... I find that I do need to sometimes use a lot of rudder on takeoff. I think it is because one engine is not coming up to power as quickly as the other. But having to use a lot of rudder is also a clue that one engine may be having a problem.
Hide Signatures
(in reply to JPMacG)
       Post #: 24
RE: Engines for Hangar 9 Twin Otter - 6/17/2012 9:20 PM
kthmarks
Score: 100
Status: offline
I went with a Twin-sync setup on mine. LOVE IT and the installation was pretty straight forward. The biggest issue is getting the servo end points set up correctly so you get maximum sensitivity from the unit. I elected to put the sensor magnets in the spinner hubs. I am quite pleased with the operation and the engines are within 100-200 rpm of each other. One other HUGE advantage is that if you have an engine out, the active engine immediately goes to idle. Already saved my bacon on a touch and go.
http://www.troybuiltmodels.com/items/WRCTWINSYNC.html
< Message edited by kthmarks -- 6/17/2012 9:50 PM >
Keith Marks
AMA 49064
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.015RCU1
