RE: New H-9 Corsair 50    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Piper J-3 Cub 40 ARF / Saito 90 twin - RTF
Seller:  Hill202
Details:   $450.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: New H-9 Corsair 50
Page: <<   < prev  1 2 [3]
Login
RE: New H-9 Corsair 50 - 11/30/2011 9:08 PM
Burc
Score: 100
Last Login: 5/11/2013
Status: offline
Great, looking forward to it. Are you able to get the doors flush against the wing when the gears are up?
I think that the door mod you did really completes the look of this Corsair...
Hide Signatures
(in reply to aeroscale)
       Post #: 51
RE: New H-9 Corsair 50 - 12/5/2011 2:39 AM
aeroscale
Score: 100
Last Login: 5/8/2013
Status: offline
Fairly close but to get an better fit would require the molding of new doors as the area isn't perfectly flat, the doors are. It's fine for what it is.
AEROSCALE
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Burc)
       Post #: 52
RE: New H-9 Corsair 50 - 4/4/2012 10:06 PM
gungaslow
Score: 100
Last Login: 5/21/2013
Status: offline
Does anyone want to sell me there rtf hangar 9 50 nitro corsair? I just don't have the time to build one since we just had a baby...I barely have time to fly as it is ....I live in MA and if you are close or if you can ship that would be great...thank you
Hide Signatures
       Post #: 53
RE: New H-9 Corsair 50 - 4/7/2012 7:10 PM
ackroyd
Score: 105
Last Login: 4/7/2013
Status: offline
These can be scaled out quite a bit.
Here
_____________________________
Chris
Hide Signatures
(in reply to gungaslow)
       Post #: 54
RE: New H-9 Corsair 50 - 4/8/2012 1:49 AM
rgm762
Score: 120
Status: offline
anybody using the eflite retracts? mine wants to really climb when i retract them, balanced with the gear up
Ray
Hide Signatures
(in reply to ackroyd)
       Post #: 55
RE: New H-9 Corsair 50 - 4/8/2012 4:45 AM
monkeygutz69
Score: 100
Last Login: 11/22/2012
Status: offline
rgm762, go to post 10 on page one and read from there.. TJ
Old School Power..If a little bit is good.. a whole bunch is better..and to much still ain''t enough!
Hide Signatures
(in reply to rgm762)
       Post #: 56
RE: New H-9 Corsair 50 - 11/21/2012 7:09 AM
PlaneKrazy214
Score: 100
Last Login: 3/20/2013
Status: offline
It was my understanding that H9 discontinued the 60 corsair. Was considering getting a 50 but if I had the choice...I prefer the 60. I will have to call Horizon and see if they are going to reissue the 60. Anyone have any feedback on it?
CHECK YOUR SIX!
Hide Signatures
       Post #: 57
RE: New H-9 Corsair 50 - 11/21/2012 8:42 AM
Tman
Score: 100
Last Login: 5/18/2013
Status: offline
PlaneKrazy, check out RC Groups there is a Corsair 60 for sale (NIB) for $215.00 plus shipping just posted. If that one is sold check Google to find one or any of the auction sites, one will show up.
Tony
Hide Signatures
(in reply to PlaneKrazy214)
       Post #: 58
RE: New H-9 Corsair 50 - 11/21/2012 11:11 AM
da Rock
Score: 265
Status: offline
quote:
ORIGINAL: rgm762
I have them on mine. The model is trimmed for flight with the gear up, as are all my warbirds. All of them have retracts, and only a couple have enough pitch response to notice. I've not even bothered to do a mix on any of those.
On my retract gear models, I've always taken the extra minute after everything is said and done, to check the CG locations with the gear up and the gear down. It's no effort and takes no time at all, and worth knowing. Setting the CG with the gear up for a Corsair, P40 or F6F is the safer choice since that puts the weight of the struts and wheels aft and biases the CG location a touch aft. It is only a touch, since the mass is almost dead on the CG as it is. When the gear is down on those aircraft, the CG is barely shifted a touch forward, which is more stable after all.
I've gone through a number of those EFlites but the latest pair is still working. However, in spite of the model being a bit under 7.5lbs and well within the advertised weight range for those EFlites, simply flying off a grass field has resulted in one strut bending every outing.
If there were an alternative available, those things would be swapped out right now.
Good flying wit ya today
Hide Signatures
       Post #: 59
RE: New H-9 Corsair 50 - 11/21/2012 11:23 AM
da Rock
Score: 265
Status: offline
quote:
ORIGINAL: PlaneKrazy214
Tower has just now dropped the price on their TF 60 Gold Box ARF $100.00 dollars. I'm picking up one at the LHS this morning when they open the doors in a couple of hours. It is the size of the H9 Corsair. Doesn't have the ugly H9 wing messup where they misfit the wing to the fuselage and it sticks out on either side before starting the gull dip. I've flown my H9 60-size since April '08 and that ugly isn't visible when it's flying. In fact, it flies like a dream and is fast as well, but it looks terrible no matter how it flies.
The 50 flies just as good as the H9 60. They are basically the same weight. The 50 is only a touch smaller. When I get the TF in the air, I figure to get rid of the H9.... maybe.... it is a Corsair after all, at least in the air.... and it flies so good. It's ground handling on grass is lame of course. Oh for some reliable 100s.
The 50 handles on the ground excellently. However, the EFlite gear really leaves a lot to be desired for dependability. Unfortunately, I'm not sure the 50 would handle anywhere as nicely with 90degree gear, and I'm not about to put fixed gear in any retract gear plane.
Hide Signatures
       Post #: 60
RE: New H-9 Corsair 50 - 11/21/2012 11:56 AM
Tman
Score: 100
Status: offline
That is a good deal on the TF corsair. I wish Robart would put out an electric gear for the 50 sized plane. The E-Flite gear doesn't hold up at all. I went back to fixed gear.
Tony
Hide Signatures
(in reply to da Rock)
       Post #: 61
RE: New H-9 Corsair 50 - 11/21/2012 12:48 PM
w1nd6urfa
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: da Rock
Some paint and a little weathering can transform it in the best looking ARF in the field!
A designer knows he has achieved perfection when there is nothing left to take away (Antoine de Saint-Exupery)
Hide Signatures
       Post #: 62
RE: New H-9 Corsair 50 - 11/21/2012 5:09 PM
PlaneKrazy214
Score: 100
Status: offline
Thanks Rock for the input. I looked at the TF corsair, its a nice machine. It would cost a bit more to get it airworthy, but it would probably be woth it in the long run.
CHECK YOUR SIX!
Hide Signatures
       Post #: 63
RE: New H-9 Corsair 50 - 11/21/2012 5:10 PM
PlaneKrazy214
Score: 100
Status: offline
That my friend is a nice looking Corsair.
CHECK YOUR SIX!
Hide Signatures
(in reply to w1nd6urfa)
       Post #: 64
RE: New H-9 Corsair 50 - 11/22/2012 4:05 AM
monkeygutz69
Score: 100
Status: offline
DaRock, I feel Ya, man. I sent 3 sets back to Horizon. I talked with their tech guys and explained everything that was going on and that the screw shaft that moves the gear out was way to small. They never questioned My sending the retracts back, they just sent a new set each time with a note that read, "shaft broken- replaced with new retract set".
 What really irked Me was the fact that the retracts would allow me to take-off and would not cycle properly once the Corsair was in the air. I would then have to belly land it with the one gear hanging down... refer to previous post in the forum. The forth set, I didn't even put in the plane. I took the back to the LHS and hung the plane from the ceiling.
 Like You, Rock, I will not fly a warbird with fixed gear. Looks tacky. I have tried to find and alternative that would work but all I came up with was a set of 40size mechanicals but I will have to open the bottom of the wing and make all new base for it.. Way to much trouble for now. Other than the retracts, this bird was a great flier. I hope I can afford one soon that flies as good as it did. TJ
Hide Signatures
       Post #: 65
RE: New H-9 Corsair 50 - 12/1/2012 1:58 AM
PlaneKrazy214
Score: 100
Status: offline
da rock,
I decided on the TF Corsair ARF. Just got it yesterday. I believe I made a good decision.
CHECK YOUR SIX!
Hide Signatures
       Post #: 66
RE: New H-9 Corsair 50 - 12/27/2012 10:22 PM
ForeverHero
Score: 100
Last Login: 1/2/2013
Status: offline
I just received this plane and the electric retracts as a Christmas present and i have a few questions. First, I have a new Saito 14B gas engine w/ inverted Slimeline Pitts style muffler that I would like to use in this plane. The mounting template included only allow for the engine to be mounted at an angle, does anyone have a recommendation or template on how i can install this engine inverted?
Also, I'd really like to change the markings to another aircraft using aftermarket decals but I'd like to know the best way to safely remove the stock decals/stickers without damaging the covering. Any thoughts or recommendations on how to do this?
Cheers,
Mark
Hide Signatures
       Post #: 67
RE: New H-9 Corsair 50 - 12/27/2012 10:43 PM
mobyal
Score: 110
Status: offline
Mark
No problem removing the markings. Just pick at a corner 'til it's raised, then peel from there. If it tears the marking you're peeling, or is really hard to remove, hit it w/ a little heat. They'll come off fine and you can clean off any residue w/ rubbing alcohol. If the residue won't come off w/ rubbing alcohol, use a little Monokote Trim Solvent on it. That stuff'll take off anything!
And don't worry about damaging the underlying surface. I do this all the time and have never had a problem w/ damaging the surface. Just don't plan on reusing the ones you peel off, tho! That ain't gonna work.
Callie at CallieGraphics can make up anything you want.
Good luck.
Al
(I'd post a pic or two of mine, but RCU is having one of its periodic hissy fits and won't allow it....)
MobyAl
Hide Signatures
(in reply to ForeverHero)
       Post #: 68
RE: New H-9 Corsair 50 - 12/27/2012 10:46 PM
mobyal
Score: 110
Status: offline
Take a look at Post #8 on p.1. Those are Callie;s markings.
MobyAl
Hide Signatures
(in reply to mobyal)
       Post #: 69
RE: New H-9 Corsair 50 - 3/5/2013 1:14 PM
Alessandro 78
Score: 100
Status: online
Hi all!
i want share with you my effort to improve the look of this nice ship.
i was very impressed by the job Aeroscale did on his mustang and texan, so i focused myself on the cockpit.
the pics here below show my progress; at this point few parts are still to be made, but next time pics will show everything.
still missing are the gun sight, and a couple of box.
the pilot cames from CJM, with some improvements, cause the poor quality (it should be the 1/7 scale)
the consolles and the main panel cames from a HQ pic of a real one used on FSX
material used are balsa & plasticard painted with humbrol enamel
the plan is cut the canopy and fix it open .... i have to fix really well everything!!!!
sorry for the poor quality of these pics, taken with a BB
this small warbird is set up as follow.
- os71FS
- futaba 2.4ghx 617 rx
- futaba gear all around
- e-flite rotating retracts & stock wheels
everything but the cockpit is out of the box, but probably i'll paint the airframe with 2k matt
Alessandro
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Check your six!
Hide Signatures
       Post #: 70
RE: New H-9 Corsair 50 - 3/17/2013 5:43 PM
Alessandro 78
Score: 100
Status: online
Hi!
just a little progres: the engine replica
Alessandro
Click for fullsize
Click for fullsize
Check your six!
Hide Signatures
(in reply to Alessandro 78)
       Post #: 71
RE: New H-9 Corsair 50 - 3/24/2013 1:17 PM
BountyHunter51
Score: 105
Last Login: 5/19/2013
Status: offline
The extra detail on the radial looks great
Cheers!
AMA #872535 Club Saito Member #570
www.skysharksrc.org
Hide Signatures
       Post #: 72
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
