Hitec digital servo noise    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> Hitec digital servo noise
Page: [1]
Login
Hitec digital servo noise - 6/26/2011 5:50 PM
Kaos
Score: 100
Last Login: 5/15/2013
Status: offline
I just installed a brand new set of Hitec digital servos (HS-6635HB) in my Killer Chaos to compliment my new Aurora 9 radio system. These are my first-ever digital servos. Everything seems to work fine, but I am concerned about the squeeling noise from each servo. The noise is not real loud, but there just same. By carefully moving the control sticks around center, I can get the noises to stop, but the noise returns the moment any new control inputs are made and then the control sticks released to center. The linkages move freely with no binding or drag. Is it normal for digital servos to squeel?
-kaos
_____________________________
May your landings equal your number of takeoffs
Hide Signatures
       Post #: 1
RE: Hitec digital servo noise - 6/26/2011 6:00 PM
speedracerntrixie
Score: 189
Last Login: 5/24/2013
Status: online
I have found that there are 3 things that can cause the digital servos to humm or squeel. The first is running a high voltage. If you are running 6V battery and a fresh charge you are actually pumping 7+ volts into them. The second is binding controls. I read that you said they move freely but check them again. One guys free is anothers bind if you know what I mean. The third and found mostly on the giant scale stuff where the servo/servos have to support the weight of a 200 sq in aileron.
Hide Signatures
(in reply to Kaos)
       Post #: 2
RE: Hitec digital servo noise - 6/27/2011 2:21 PM
EscapeFlyer
Score: 120
Status: offline
Digital servos are naturally noisy. There is nothing to worry about.
Also, there is not 7 volts going to each servo as there is a voltage regulator built into the receiver. You will be just fine. Enjoy your airplane!
Brian
N Central Regional Director
Classic Pattern Association
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
