RE: 21 Tunnel Talk    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: 21 Tunnel Talk
Page: <<   < prev  4 5 6 7 8 9 10 [11] 12 13   next >   >>
Login
RE: 21 Tunnel Talk - 12/18/2011 10:53 PM
amrharrymac
Score: 100
Last Login: 6/6/2013
Status: offline
Maybe check out the Cricket vinyl cutter website and do your own? Just an idea; I don't know that much about it, just saw the infomercials on TV. If it works let us know...
Hide Signatures
(in reply to kiteboarder)
       Post #: 251
RE: 21 Tunnel Talk - 12/18/2011 11:47 PM
racer504
Score: 100
Last Login: 6/13/2013
Status: offline
Try monojeff over on the OSE forum. Look under unique products and services
_____________________________
Black Cat Racing
Hide Signatures
(in reply to amrharrymac)
       Post #: 252
RE: 21 Tunnel Talk - 12/19/2011 1:54 AM
kiteboarder
Score: 100
Last Login: 10/15/2012
Status: offline
Thanks guys, I'll look them up.
By the way... The RC article I was creating for FloatWays is done. Check it out here:
http://floatways.com/1522/absolute-rc-boats-guide-for-speed-loving-racers/
I'll likely set up a proper thread for it tomorrow. I'm tired.
FloatWays.com - A Million Ways to Float!
Hide Signatures
(in reply to racer504)
       Post #: 253
RE: 21 Tunnel Talk - 12/20/2011 12:48 AM
Slideblues
Score: 100
Status: offline
I've seen the Cricket ads too, wonder if it cuts the thicker 3M auto grade stuff with program fonts,
Dunno.....Good idea thou,
Gene
Hide Signatures
       Post #: 254
RE: 21 Tunnel Talk - 12/20/2011 1:21 AM
kiteboarder
Score: 100
Status: offline
Well, I need to send in EPS files, cause it's all custom graphics. But... I found a guy locally that'll do them all for $40! So I'm going for that.
I'll keep you posted on the results...
Hide Signatures
(in reply to Slideblues)
       Post #: 255
RE: 21 Tunnel Talk - 1/2/2012 3:11 AM
Slideblues
Score: 100
Status: offline
Yea, That sounds fair ta me.........
One of my locals quoted me 50 buck custom font fee and then 25 for one set of graphics,
I said thanks and left LOL!
Gene
Hide Signatures
       Post #: 256
RE: 21 Tunnel Talk - 1/4/2012 6:00 PM
kiteboarder
Score: 100
Status: offline
So I finished my FloatWays VS1 this last weekend and ran it for the very first time on Sunday! I was impressed. I took my time to build the thing and it's obvious it paid off. The boat ran perfectly straight and the initial trim wasn't that bad. I ran 6 tanks, not a single problem! Plus, I had set the servo turning end points and the turning speed and all felt spot on.
The engine I bought used, but I'm not sure how much it had been run, so I'm treating it like a new engine and breaking it in. Plus, I'm not good at setting these engines yet, so running rich is a good idea as to not break it.
I think I'm running the carb at tad leaner than the OS recommended setting for break-in. So instead of 2.5 turns open, I'm running the needle at 2.75 turns open.
I've got some pictures and video coming soon. I just don't have them here. In the meantime, there's a photo of it on the wall of the FloatWays facebook page here.
Hide Signatures
       Post #: 257
RE: 21 Tunnel Talk - 1/7/2012 10:57 PM
Slideblues
Score: 100
Status: offline
Dang Dude!
Tha boat looks great, Hope ya have a ball running it......
Gene
Hide Signatures
       Post #: 258
RE: 21 Tunnel Talk - 1/24/2012 11:27 PM
Slideblues
Score: 100
Status: offline
From your roving reporter.........
It seems Rod G bought a Lynx (Or lynx copy unsure)
Might just be me, Anyone else wondering what his plans are ?
He did say he would modify it if the needs be........
News at 11:00
Gene
Added a pic:
Click to see fullsize image.
Click for fullsize
< Message edited by Slideblues -- 1/24/2012 11:48 PM >
Hide Signatures
       Post #: 259
RE: 21 Tunnel Talk - 2/11/2012 1:43 AM
Slideblues
Score: 100
Status: offline
Testing 123, Had a weird timeout message there.....
Just checked Tower and was amazed at the latest TS3 pricing......
All colors but yellow $114.96
But if ya want YELLOW $149.97........$35.01 difference for a color?
Makes me dizzy!
Gene
Hey JD if ya read this send a lil birdy over to Rod's house and see what he doin
Hide Signatures
       Post #: 260
RE: 21 Tunnel Talk - 3/8/2012 11:26 PM
kiteboarder
Score: 100
Status: offline
Hey guys,
Is there a trick to soldering the pull-pull cables into the threaded soldering couplers ?
I have soldering experience and have done tons of electronics... But this is DIFFERENT.
I apply heat to both parts and use soldering flux. I fill the hole in the coupler with melt solder and stick the hot cable in there. Then I apply more heat before letting it cool with zero movement to avoid a weak cold solder.
I've ran the boat a couple of times with no problems.
However, last night one of them came undone while I was working on the engine.
What am I doing wrong. I'm using standard rosin core solder. Am I supposed to use something else?
Hide Signatures
       Post #: 261
RE: 21 Tunnel Talk - 3/8/2012 11:43 PM
Slideblues
Score: 100
Status: offline
Danny, I use stay brite silver solder, no failures in a long time.
Local electronic supply should have some.
Here's a pic.......
Gene
Click for fullsize
Hide Signatures
       Post #: 262
RE: 21 Tunnel Talk - 3/9/2012 12:01 AM
kiteboarder
Score: 100
Status: offline
Hi Gene,
Hmmm, I'll give that a try.
I had the idea of soldering, then crimping the sleeve where the sable is soldered into. My guess is it should make the whole thing stronger, but I might be wrong. Unfortunately, I used the wrong tool to crimp and nearly cut through the sleeve and cable itself! But that doesn't mean it won't work if done right.
I'm fine tuning my boat with help from Rodney P. So far I've made some adjustments to the engine height and tilt, but I'm also replacing the throttle cable - I originally made at a bit too short. It works but fine tuning is a PITA and I can't get the boat to idle without having my hand on the radio. (too open).
I'm also adjusting the COG with a couple of stick-on lead weights. Currently the COG on my VS1 is at 7.5" from the further riding surface of the sponsons. I want to try and bring that up to 8"
Hide Signatures
       Post #: 263
RE: 21 Tunnel Talk - 3/9/2012 12:55 AM
Slideblues
Score: 100
Status: offline
Hi Danny,
Well I dont know bout crimp after solder.....
I tin the end of the cable and put a drop of flux in the coupler,
Add even heat and let the silver solder flow in till the coupler is full.
The silver content in stay brite is WAY stronger than the std 60/40 rosin core solder.
Glad to hear your getting the boat dialed in,
Sounds like your close,
Gene
Hide Signatures
       Post #: 264
RE: 21 Tunnel Talk - 3/9/2012 1:09 AM
kiteboarder
Score: 100
Status: offline
Yeah, I'm going to run by Frys and see if I can find that stuff. I'm sure they must have it. I find that rosin core doesn't mix well with the brass and/or stainless steel these things are plated with. No matter how much heat I apply the rosin core acts like oil, it sort slips all over the place and doesn't quite "blend" with the material.
Hide Signatures
       Post #: 265
RE: 21 Tunnel Talk - 3/9/2012 1:27 AM
Slideblues
Score: 100
Status: offline
Yup, know what ya mean, I use DuBro couplers, not as bad as some others.
Try sloshing your parts in isopropyl alcohol before soldering helps too,
Gene
Hide Signatures
       Post #: 266
RE: 21 Tunnel Talk - 10/14/2012 10:41 PM
Slideblues
Score: 100
Status: offline
Been almost a year, So what ya got on tha tunnel burner for 2013 ?
Carl V has some new models, Havent heard a release date yet.
Gene
Im still runnin VS1 and collecting outboard parts.......
Current pics below
Added note:
Mike Z has shelved the Nemesis (first pic) And running VS1/TS3 next year.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Slideblues -- 10/29/2012 12:37 AM >
Hide Signatures
       Post #: 267
RE: 21 Tunnel Talk - 10/15/2012 4:25 PM
Jerry Dunlap
Score: 105
Last Login: 6/16/2013
Status: offline
I plan to continue running my VS1/O.S. Ver. 2 for 2013. The boat/engine combination has won the NAMBA District 8 20 Stock Tunnel Class the past two years.
JD
Hide Signatures
       Post #: 268
RE: 21 Tunnel Talk - 10/15/2012 6:27 PM
kiteboarder
Score: 100
Status: offline
I've cut expenses (building any new boats) - I don't race (cause there's no racing around here)… But I'm happily enjoying my VS1 / OS21 at least once a month. For me it really is a hobby
Hide Signatures
(in reply to Jerry Dunlap)
       Post #: 269
RE: 21 Tunnel Talk - 10/15/2012 10:18 PM
Slideblues
Score: 100
Status: offline
Hey Guy's
The PSRP Villain series that became the VS1 has winning rep for sure.
TS2/TS3 is a mover too, The FE guy's are knockin all over 70 mph.
Gene
Added pics of orig series:
Click for fullsize
Click for fullsize
< Message edited by Slideblues -- 10/16/2012 4:42 PM >
Hide Signatures
       Post #: 270
RE: 21 Tunnel Talk - 10/16/2012 12:34 AM
Slideblues
Score: 100
Status: offline
Also a couple more in wood (my fav)
Gen 2 ML295 with a new cowl and a few changes (on the right)
And Breakthru 4 or 5 from David Moyle in Oz
Nice work guy's
Gene
Recent update: ML has stoped tunnel hull production,
Info in screenshot........
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Slideblues -- 11/1/2012 6:53 PM >
Hide Signatures
       Post #: 271
RE: 21 Tunnel Talk - 11/10/2012 6:49 PM
Slideblues
Score: 100
Status: offline
Some Euro vibe, Hydro & Marine Skater in glass,
Seems like Bob K. sold one not to long ago at IW.......
Gene
Click for fullsize
Hide Signatures
       Post #: 272
RE: 21 Tunnel Talk - 11/13/2012 12:54 AM
Blackout
Score: 100
Last Login: 6/18/2013
Status: offline
Tunnels are so much fun to race! I'll probably put the NR in my Vision next year. I've had the parts for a year now....
Craig Mapstone, IMPBA #20305S, Stony Pond Model Boat Club
2012 D1 20 Hydro Champion
Hide Signatures
       Post #: 273
RE: 21 Tunnel Talk - 11/13/2012 4:06 AM
Slideblues
Score: 100
Status: offline
Heck yeah Man,
With your recent pond expansion you got enough room to really wind it out.
Nice work by the way, Looking good!
Gene
Added pics:
A 28" Woodstuff by Mike Crawford
And my retro KaBoom /Oz pipe
Click for fullsize
Click for fullsize
< Message edited by Slideblues -- 11/14/2012 6:43 PM >
Hide Signatures
(in reply to Blackout)
       Post #: 274
RE: 21 Tunnel Talk - 1/24/2013 9:06 PM
Slideblues
Score: 100
Status: offline
Something new from Mike at ML Boatworks.....
The 300 series Nitro or FE, as a frame up kit or WOF,
Check his post at IW for details and release dates.
Gene
Click for fullsize
Hide Signatures
       Post #: 275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
