RE: Maj. Woody's X-Treme Jets F-4C Phantom    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Maj. Woody's X-Treme Jets F-4C Phantom
Page: <<   < prev  31 32 33 34 35 36 [37] 38 39 40   next >   >>
Login
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/15/2012 9:56 PM
MaJ. Woody
Score: 110
Last Login: 5/21/2013
Status: offline
The paint on the F-4 horns is latex house paint that I had matched at Home Depot. You think this will attack the Nylon/Plastic whatever Skymaster is using? I have painted all my linkages on all my jets with Hundreds of flights. Never a problem. Was I just lucky??
_____________________________
Maj. Woody Out!
Hide Signatures
(in reply to afterburner)
       Post #: 901
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/15/2012 10:24 PM
RCISFUN
Score: 105
Status: online
quote:
ORIGINAL: MaJ. Woody
Latex house paint should do anything to the plastic, however to be on the safe side I would still replace with CF horns
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
(in reply to MaJ. Woody)
       Post #: 902
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/17/2012 2:09 AM
MaJ. Woody
Score: 110
Status: offline
Here is the new aluminum servo arms I am using. I only had four on hand so I have to wait for the rest to show up in order to convert everything.
Click to see fullsize image.
Click for fullsize
Maj. Woody Out!
Hide Signatures
(in reply to RCISFUN)
       Post #: 903
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/17/2012 2:13 AM
MaJ. Woody
Score: 110
Status: offline
Here is the stock elevator setup vs the new setup with the aluminum arms. I had to remove 15 thousands from the arm in order for the Sullivan Golden Clevis to fit on and allow the retaining clip to be attached. I also had to realign the ball linkage location on the stab horn. The Dubro arms are offset and the new arms are not.
Click for fullsize
Click for fullsize
Maj. Woody Out!
Hide Signatures
       Post #: 904
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/17/2012 2:14 AM
jzuniga
Score: 105
Status: offline
Dom,
Where'd you get the Futaba alum arms? That's exactly what I'm looking for
Z
Hide Signatures
       Post #: 905
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/17/2012 2:18 AM
MaJ. Woody
Score: 110
Status: offline
Here is the stock rudder linkage with the Dubro horn vs the new setup with the Futaba aluminum horn and ball linkage. I don't like the bulky ball linkage out there but it is needed considering the bad geometry of the design. The ball linkage allows the rudder horn to swing without putting stress on it. By the way, the paint is water based and should not cause any problems for the plastic / nylon rudder horn.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Maj. Woody Out!
Hide Signatures
       Post #: 906
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/17/2012 2:19 AM
MaJ. Woody
Score: 110
Status: offline
quote:
ORIGINAL: jzuniga
Dom,
Z
Tower Hobbies:
http://www3.towerhobbies.com/cgi-bin/wti0091p?&P=SM&C=MGA&V=FUT
Maj. Woody Out!
Hide Signatures
(in reply to jzuniga)
       Post #: 907
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/17/2012 2:34 AM
jzuniga
Score: 105
Status: offline
Thanks Dom!...
Z
Hide Signatures
       Post #: 908
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/17/2012 2:47 AM
joeflyer
Score: 105
Status: offline
I finally got the long awaited pictures from Skymaster/X-treme today and gave the OK to ship.  I should have my F-4 in about a week.  In the meantime I'll anxiously wait for Woody's flight report and advice on CG and throws.  By the way thank you for the excellent build thread.  I'm sure it will help me a lot.
Joe
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 909
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/17/2012 2:52 AM
MaJ. Woody
Score: 110
Status: offline
Looks great. Thanks for liking my thread.
Dom
Maj. Woody Out!
Hide Signatures
(in reply to joeflyer)
       Post #: 910
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/18/2012 1:24 AM
mdeseve
Score: 100
Status: offline
Dom, when the maiden is schedule.
Jet Central Rabbit, Superbee, kingtech k-80, cheetah, kingtech k-170f...
Hide Signatures
       Post #: 911
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/18/2012 2:16 AM
MaJ. Woody
Score: 110
Status: offline
Not sure Mike. I am still converting the servo arms and working on some other details. I am yet again changing the elevator setup. I am going to ditch the Sullivan golden clevis and use another ball link. I'll post my results. I applied aluminum tape under my stab to minimize the effects of the heat. I just ran it up and it seems to help. Still loosing paint in some other areas. I may need to teak the pipe angle somehow.
Mike do you have any pictures that clearly show your pipe angle?
Dom
Maj. Woody Out!
Hide Signatures
(in reply to mdeseve)
       Post #: 912
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/18/2012 3:47 AM
Chris Balling
Score: 100
Last Login: 5/20/2013
Status: offline
Mine is ready to go, but we've entered the HEAT season (with humidity at 4%) and it's just too hot to do a maiden (106 today). We're also surrounded with our traditional wild fires and visibility is very low due to the smoke, so I'm going to sit on it a bit longer. I did drop my tail pipe angle down 1/4 of an inch as the tail feathers were warming up considerably. It helped a lot with the heat on the ground. Buck suggested it, as he did it on his big one. Staying tuned......
Hide Signatures
       Post #: 913
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/18/2012 4:19 PM
Chris Balling
Score: 100
Status: offline
Dom,
I've made a couple of changes to Phantom since we last communicated. I decided to go with a new P-100 rather than my 120SX. The airplane only weighs 18 pounds and as you know the new Jetcat series of turbines is very east to rig. They are also very small. Our entire State has just been given a Red Flag Warning, so I probably won't be able to do the maiden until our monsoonal winds bring some rain; usually July. Our density altitude is now over 6.7K with our very warm temps. Keep you posted.
Hide Signatures
(in reply to Chris Balling)
       Post #: 914
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/19/2012 12:33 AM
joeflyer
Score: 105
Status: offline
Chris,
What's included in the 18 pounds?  Is that the complete airframe with everything ready to fly except the engine?
I've been debating between using a 100 or a 140.  My preference is to keep it as light as possible and use a 100.  Mine should be here next week and one of the first things I'll do is weigh everything to help decide which engine to buy.
Joe
Hide Signatures
       Post #: 915
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/19/2012 1:21 AM
mdeseve
Score: 100
Status: offline
Hi Dom, no picture but it is pointing down, i never had any heat problem on the elevetor, i ran the turbine about 12 times, and made 5 flight, with no heat damage.
Hide Signatures
       Post #: 916
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/19/2012 3:28 AM
Chris Balling
Score: 100
Status: offline
That is complete but totally dry. I've used JR DS3421 servo's throughout; except for one 8711 on the flying stab, and a UP3 valve to help keep the weight down. Batteries are in the nose with just a few BB's to balance slightly ahead of the forward wing rod. I've also put three small air tanks in, vice two large, one in the nose with Batts and one each aside the turbine. Can't wait to fly this machine, but no relief in sight with respect to the heat and fire situation here in Arizona.
Hide Signatures
       Post #: 917
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/19/2012 4:46 AM
smaze17
Score: 105
Status: offline
Hi Dom. So you never did the maiden? I was anxiously awaiting a flight report for this plane. I have yet to see anyone actually do a flight report for the smaller Skymaster F-4
Oh well. You did a masterful build on her.
S
Hide Signatures
       Post #: 918
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/19/2012 3:17 PM
rhklenke
Score: 129
Status: online
quote:
ORIGINAL: smaze17
S
Go back a few pages - he's making a few modifications based on the problems he had with the Hawk. With any luck, he's out flying it now...
Bob
Hide Signatures
(in reply to smaze17)
       Post #: 919
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/19/2012 3:26 PM
smchale
Score: 115
Status: online
http://www.rcuniverse.com/market/item.cfm?itemId=844923
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
(in reply to rhklenke)
       Post #: 920
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/19/2012 10:04 PM
afterburner
Score: 110
Status: online
Sorry to see that Dom. This is one frustrating hobby that's for sure.
Marty
Hide Signatures
(in reply to smchale)
       Post #: 921
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/20/2012 2:50 AM
smaze17
Score: 105
Status: offline
quote:
ORIGINAL: rhklenke
quote:
ORIGINAL: smaze17
S
Bob
I had seen his ad and was bummed for him regarding the sale but I totally understand why. I really hope we see you back in the game very soon Dom!!
S
Hide Signatures
       Post #: 922
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 5/20/2012 3:02 AM
MaJ. Woody
Score: 110
Status: offline
Thanks Guys!
Maj. Woody Out!
Hide Signatures
       Post #: 923
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 6/1/2012 5:05 PM
joeflyer
Score: 105
Status: offline
My F-4 finally arrived.  After weighing all the parts plus the radio and other equipment I'm planning on using it comes to about 20 pounds without an engine.  It should come out about 23 pounds dry with engine.  I can't imagine Chris's being only 18 pounds, perhaps you should double check your scale.   With 6 pounds of fuel the take off weight will be about 29 pounds, so I've decided to go with a 140.
I have the long (E nose) version and it looked bigger than expected so I measured it.  I was suprised to find that it's 83" long and 55" ws.  That's larger than the advertised 79" long and 53" ws.  I hope to get going on it soon.
Joe
Hide Signatures
       Post #: 924
RE: Maj. Woody's X-Treme Jets F-4C Phantom - 6/3/2012 3:58 AM
mistermnkim
Score: 100
Last Login: 5/8/2013
Status: offline
I started fitting the gear to mine tonight! My F-4 is the original prototype from Xtreme.
Click for fullsize
club saito #625 CG Ultimate brotherhood #19 SPITFIRE brotherhood #91
Hide Signatures
       Post #: 925
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.655RCU1
