REPEATEDLY STRIPPING SPUR GEAR HELP!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> REPEATEDLY STRIPPING SPUR GEAR HELP!
Page: [1]
Login
REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/13/2011 5:48 PM
tinosasso
Score: 100
Last Login: 3/19/2013
Status: offline
hello all, need some quick suggestions for my redcat volcano epx brushless pro. i had previously replaced the spur with the new steel replacement since i kept stripping the plastic ones with the lipo battery. The issue is, i cant drive the truck more than a few minutes b4 it strips loose from the pinion. Both are steel, but somehow, they just separate. I meshed them properly and tightened the bolts b4 using it, but it happens nonetheless. any suggestions out there??????
Hide Signatures
       Post #: 1
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/13/2011 6:59 PM
xerxes
Score: 209
Last Login: 11/22/2012
Status: offline
so da 2 steel 1s arnt strippn, der un-meshing?
try a dab of blu loktite or thik ca glue on each screw b4 u tightn it.
Hide Signatures
(in reply to tinosasso)
       Post #: 2
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/13/2011 8:06 PM
cumquat
Score: 210
Last Login: 5/23/2013
Status: offline
you should look for the reason the plastic spurs where striping. gears shouldnt strip very often, only when they are worn out. my guess is there is some binding in the drive-line, possibly a pin that is coming out. as for the motor moving, check all screws to see if they are tight and if it still comes loose, do as xerxes said, blue loctite on the motor mount screws.
_____________________________
HELP! IM STUCK ON AN ESCALATOR!
Hide Signatures
(in reply to xerxes)
       Post #: 3
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/14/2011 4:35 AM
Link119
Score: 128
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: xerxes
So the tow steel ones arent stripping, they are unmeshing?
Try a dab of blue locktite or thick ca glue on each screw before you tighten it.
Or get new motor screws if the current ones are stripped.
And you dont want ca glue on your screws. That would destroy the point of screws and they would become rivets.
I Ca glued a heatsink over my existing esc heatsink and the overheatsink just wont come off. Its like welded.
Gws Slow Stick Brushless
Hide Signatures
       Post #: 4
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/14/2011 4:40 AM
xerxes
Score: 209
Status: offline
quote:
ORIGINAL: Link119
Hide Signatures
(in reply to Link119)
       Post #: 5
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/14/2011 11:48 AM
Haddi Taha
Score: 183
Last Login: 5/11/2013
Status: offline
Follow these rules:
use a good screw driver set for setting the screws
replace worn screws ASAP
always try to use steel hex headed screws where possible
don't use the crappy L shaped wrenches included
push down on the screw with the driver to stop the screw head from stripping and this enables maximum tightening
purchase appropriate threadlock and use on the screws
replace any worn gears asap
always get high quality gears
make sure you use gears of the same pitch (people do make this mistake)
Also, the pinion screws on the redcats are crap, get some higher quality ones from another brand
Thunder Tiger MT4- Hobbywing 4274sd 2200kv motor- Savox 1256tg Servo
Hide Signatures
       Post #: 6
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/14/2011 12:42 PM
cumquat
Score: 210
Status: offline
robinson racing makes some of the best hears and set screws out there and have been for upward 30 years.
Hide Signatures
(in reply to Haddi Taha)
       Post #: 7
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/14/2011 11:13 PM
hindupimp2384
Score: 106
Last Login: 11/8/2012
Status: offline
yea i was stripping my spur too and found out i was using the 0.5 pitch Pinion gear instead of 48 ptich
- CUSTOMIZED RUSTLER SV2 1406 Neu-Castle 4Pole 5700KV
Hide Signatures
(in reply to cumquat)
       Post #: 8
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/15/2011 12:46 AM
Haddi Taha
Score: 183
Status: offline
quote:
ORIGINAL: hindupimp2384
its happened to nearly every rc hobbyist at one stage. When I was a noob, I thought my tt01e had 48pitch (because they looked the same, bought some and stripped 3 spur gears in a row (they costed $2 each) Then I realised that 0.6 pitch existed so I bought some Yeah Racing hard coated 0.6 gears, problem solved
Hide Signatures
(in reply to hindupimp2384)
       Post #: 9
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/15/2011 8:03 PM
tinosasso
Score: 100
Status: offline
thanks for the help, i think i'll be starting with the screws, the gears are rather new and i had already upgraded from the plastic spur gear that was getting chewed up constantly. Probalby a dumb question, but the screws you guys are referring to are the ones that old the pinion gear onto the motor and the screws that hold the spur gear down right?
Hide Signatures
       Post #: 10
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/15/2011 8:31 PM
cumquat
Score: 210
Status: offline
no, the screws that hold the motor. yes to the pinion set screw.
Hide Signatures
       Post #: 11
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/16/2011 1:19 AM
The Mad Modder
Score: 341
Status: offline
quote:
ORIGINAL: cumquat
robinson racing makes some of the best gears and set screws out there and have been for upward 30 years.
+1 I love their pinion gears. They're very high quality.
God bless America
Hide Signatures
       Post #: 12
RE: REPEATEDLY STRIPPING SPUR GEAR HELP! - 7/25/2011 3:53 AM
Steve.
Score: 123
Last Login: 9/19/2012
Status: offline
quote:
ORIGINAL: xerxes
Yeah, CA on a steel screw into aluminum... nice suggestion donkey.
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.395RCU1
