RE: [b]Flight Report!!![/b]
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Extra 300S - 60
  • 1 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Airplanes >> Kit Building >> RE: [b]Flight Report!!![/b]
    Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
    Login
    RE: [b]Flight Report!!![/b] - 5/6/2005 8:48 PM
    AdrianM
    Score: 100
    Last Login: 6/6/2009
    Status: offline
    quote:
    ORIGINAL: Ace.in.a.day
    Bought my OS 91 FX yesterday with the bisson muffler.
    Still thinking of doing the rudder and elevator mods, because i want a good knife edge performance, so i will probably need it.
    What advantages are there with a bigger elevator concernig the low speed habits. I don´t have a big field to land, so I have to fly quite slow on landing.
    What do you recommend...
    Moving the hinge line forward makes more of the stab's area control surface. The larger control surface is more effective at lower airspeeds. Think about the .40 size profile 3D planes. The fly super slow with 12.25x3.75 props. They have HUGE elevators with HUGE counterbalances to get more bite on the air at low speeds. This also helps vector thrust from the props thrust tube.
    The mods are really easy to do and have no negative effects so why not. I can pull full high rate up elevator at full throttle and it wont high speed stall. It will just do a small radius loop with a lot of tail porpoising.
    _____________________________
    Adrian Martinez
    Hide Signatures
    (in reply to Ace.in.a.day)
           Post #: 251
    RE: [b]Flight Report!!![/b] - 5/6/2005 9:09 PM
    Ace.in.a.day
    Score: 100
    Last Login: 6/19/2007
    Status: offline
    I saw your mods on page one.
    This looks really good for me with the aerod. counterbalances.
    Just for my right understandment.
    i don´t put the hinges on the place, like the plan tells, i put it forword, so the rudder surface remains withe the same size, but the effective part grows.....?
    Thanx vry much
    Hide Signatures
    (in reply to AdrianM)
           Post #: 252
    RE: [b]Flight Report!!![/b] - 5/7/2005 12:23 AM
    panicman
    Score: 100
    Last Login: 1/20/2009
    Status: offline
    Hear are some pics of my extra I finished it yesterday and flew it today what a great plane!!!!
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Hide Signatures
           Post #: 253
    RE: [b]Flight Report!!![/b] - 5/7/2005 12:29 AM
    zope_pope
    Score: 105
    Last Login: 3/9/2010
    Status: offline
    I like that color scheme a lot!!! Great job!
    If you choose not to make a decision, you have still made a decision.
    Hide Signatures
    (in reply to panicman)
           Post #: 254
    RE: [b]Flight Report!!![/b] - 5/7/2005 4:04 AM
    AdrianM
    Score: 100
    Status: offline
    Thanx vry much
    The sticks fore and aft of the elevator hinge line are 1/2 wide. I just moved everything forward one line (1/2"). Just look at the pics for how to do the counter balances. Note that I supplied my own spar (longer than stock) that went wing tip to wing tip.
    I didn't move the hinge line of the rudder. I made the counterbalance larger and added one inch to the tail of the rudder to increase its area. On the IMAC Extra 300's the rudder counter balance is 1/3 the span of the rudder when measured from the bottom of the fuse to the top of the rudder (yeah, thats big). The counterbalance is that big to reduce servo loading at high speed/extreme throws. The rudder mods are pretty straight forward. It will look weak when framed up bare but it is pretty stiff once covered.
    Modified or not this plane needs speed to fly knife-edge. You will also see a big yaw angle (AOA) when in knife edge. Its just a quirk of the plane.
    When you get to joining the wing halves have plenty of good clamps handy, use 2 hour epoxy if you can find it as 30min will be starting to kick and get thick before you have everything situated. You have to put the epoxy on A LOT of surfaces BEFORE putting in the wing joiners and 30min epoxy is just too fast. I probably have 2oz of extra epoxy in my wing that I could not wipe off in time.
    Save yourself a lot of trouble in the future and glue hard wood doublers over the landing gear rails (1/4x7/8 I think). Attach you gear with 1/4x20 nylon bolts. Tap threads in the rails. The kit screws are an absurd way of attaching the gear.
    Adrian Martinez
    Hide Signatures
           Post #: 255
    RE: [b]Flight Report!!![/b] - 5/7/2005 5:32 PM
    Ace.in.a.day
    Score: 100
    Status: offline
    Thank you very much for the detailed explanation.
    That helps me a lot......
    An other thing, is there a video of the extra on the net.?
    Hide Signatures
           Post #: 256
    RE: [b]Flight Report!!![/b] - 5/20/2005 1:28 PM
    Ace.in.a.day
    Score: 100
    Status: offline
    I have already started my kit, but i am confronted with some problems....
    How can i glue the fuse sides to the fuse top. I have to flex the fuse sides using water, but it doesn´t work....
    Here is a pic how it looks right now
    < Message edited by Ace.in.a.day -- 5/20/2005 1:40 PM >
    Hide Signatures
           Post #: 257
    RE: [b]Flight Report!!![/b] - 5/20/2005 1:50 PM
    Rate1
    Score: 100
    Last Login: 3/16/2010
    Status: offline
    You have to soak the fuz sides where it bends, just little wet doesn't do it. I held my fuz sides under running water and only getting the side that is to be glued wet, then it worked better. After that I clamped the sides in place for the glue to cure.
    Others have soaked the whole side and then taped the fuz sides towards a can of proper sixe to dry over night. When dry the sides have taken the correct shape/form. Best of luck mate,
    Christian
    <--- This is my dog, Capt Morgan, and he has propably more flight hours than you.
    Hide Signatures
           Post #: 258
    RE: [b]Flight Report!!![/b] - 5/20/2005 2:19 PM
    AdrianM
    Score: 100
    Status: offline
    I soaked my fuse sides in a 5 gallon bucket so the water went up to the middle of the wing saddle for ~6 hours. I then wrapped the front of the fuse around a large coffee can secured with a lot of rubber bands and let it dry overnight. The next day fit perfectly to the formers.
    Adrian Martinez
    Hide Signatures
    (in reply to Rate1)
           Post #: 259
    RE: [b]Flight Report!!![/b] - 5/24/2005 11:23 AM
    Ace.in.a.day
    Score: 100
    Status: offline
    If you want to read my building report check this link Extra 300
    Sorry guys it is in german.
    From time to time i will post sime pics here, in English of course
    Hide Signatures
           Post #: 260
    RE: [b]Flight Report!!![/b] - 5/24/2005 6:52 PM
    FlyerBry
    Score: 100
    Last Login: 11/23/2009
    Status: offline
    Does the GP Extra 300 .60 lend itself to being lightened similar to the way the Funtana airframe is full of holes to save weight? Any options other than replacing the heavy wood in the kit?
    Hide Signatures
           Post #: 261
    RE: [b]Flight Report!!![/b] - 5/25/2005 1:24 AM
    KristianP
    Score: 100
    Last Login: 6/5/2007
    Status: offline
    Hello Guys...
    It has been very interesting to read about all your experience with the GP Extra 300S.
    I am especially lucky to find such a great resource for it because this has been my dream to build this plane since I startet RC-Flying one year back...
    My question is now if you would recommend a person to build this kit as the first one??
    Is it quite easy if you follow the instructions or is it still quite hard?
    Also I would like to now if some of you guys find this plane hard to fly.
    My first plane was a Bi-Plane but which flew sort of like a trainer. Right now I have my second plane and that is the Hirobo Skylimbo which is a .40 size Plane with full semitrical wing, so I guess a god plane to get into acrobatic planes.
    I am just wondering if I will be able to fly this lovely Extra 300S?
    Many Greetings from
    Kristian
    Hide Signatures
    (in reply to FlyerBry)
           Post #: 262
    RE: [b]Flight Report!!![/b] - 5/25/2005 7:04 AM
    Ace.in.a.day
    Score: 100
    Status: offline
    I also have not much flying experience ( Trainer , low wing trainer ) and it is my second kit, and the building seems not to hard, if you have a little experience with wood and glue
    Hide Signatures
    (in reply to KristianP)
           Post #: 263
    RE: [b]Flight Report!!![/b] - 5/25/2005 3:18 PM
    CAPtain232
    Score: 100
    Last Login: 4/25/2009
    Status: offline
    FlyerBry
    Read through this thread on how I reduced weight by an average of 1 1/4 pound. The AVERAGE GP EXTRA 300S .60 weigh 7.75 to 8 pounds....mine weighs 6.5........ GP EXTRA....TOTALLY 3D
    Weight reduction is not only in lightening the airframe, but by a better selection of the gear you use on the plane as well.
    Another link to the HATCH that I built into mine...... Even with the ADDITION of some items to the fuselage, I still ended up sooooo much lighter than stock........REVIVED
    CUSTOM GIANT SCALE BUILDER
    PROTOTYPE MODEL BUILDING for full scale aircraft
    current project can be seen at http://www.geversaircraft.com
    Hide Signatures
           Post #: 264
    RE: [b]Flight Report!!![/b] - 5/26/2005 12:53 AM
    KristianP
    Score: 100
    Status: offline
    Well I guess I am going for it then..
    Many Greetings from
    Kristian
    Hide Signatures
           Post #: 265
    RE: [b]Flight Report!!![/b] - 5/26/2005 1:00 AM
    KristianP
    Score: 100
    Status: offline
    Hey I looked a bit into some engines I would like to put on the plane.
    I was thinking of a super tigre 90 or a Saito FA-100..
    I have a couple of questions though:
    First of all why is the Super Tigre 90 engine so cheap compared to OS and does it have good power.
    And what do you think of a Saito FA-100..read some have used it. Will it let the plane climb straight up from a hover or would it be better with a Saito FA-120 insead of the 100...
    I don´t know about you guys but 4 stroke engines just sound sweet so I kind of would like a 4 stroke on this beauty GP Extra 300.
    Maybe you can help me.
    Many Greetings from
    Kristian
    Hide Signatures
           Post #: 266
    RE: [b]Flight Report!!![/b] - 5/26/2005 5:16 AM
    zope_pope
    Score: 105
    Status: offline
    Get a ys 1.10 if you want all out power. Ys engines are the best fourstrokes available. My YS 140DZ has more punch than my Saito 180!! I am sure more than a few folks will back me up on the 1.10
    Hide Signatures
           Post #: 267
    RE: [b]Flight Report!!![/b] - 5/26/2005 6:27 AM
    Ace.in.a.day
    Score: 100
    Status: offline
    Hey Captain, is there also a re-revived thread, where we can see the finished model
    Hide Signatures
    (in reply to zope_pope)
           Post #: 268
    RE: [b]Flight Report!!![/b] - 5/26/2005 7:00 AM
    CAPtain232
    Score: 100
    Status: offline
    I do not have any pics of it finished and unfortunately, it is packed away in storage for a while...... I am building a new shop this year and almost everything I had in the old shop has been put in storage
    Hide Signatures
           Post #: 269
    RE: [b]Flight Report!!![/b] - 5/26/2005 11:46 AM
    Ace.in.a.day
    Score: 100
    Status: offline
    Where can i buy a light landing gear. I saw yours but the fiber lite one is out of stock....
    Hide Signatures
    (in reply to CAPtain232)
           Post #: 270
    RE: [b]Flight Report!!![/b] - 5/26/2005 8:29 PM
    Build-n-flyer-RCU
    Score: 100
    Last Login: 12/2/2007
    Status: offline
    I'll back up the YS-110 recommendation. My Extra is 2 years old now. I started with a Saito 100 which has more than adequate power for sport and pattern flying. Then I installed a YS-91 which gave the plane "super-hyperdrive" power. A few weeks ago I mounted up a YS-110 and now my buddies tell me that I've gone "plaid".
    At just a few more oz than a Saito 100, the YS-110 has power equivalent to a 120-150 size Saito. And it actually uses less fuel than the Saito 100.
    VQ P-61, H9 150 P-51, D-F Decathalon, NEA Twin Air, Duellist, Nobler, GP 60 Extra, Arrow racer, LT-40.. the hanger is full!!
    Hide Signatures
           Post #: 271
    RE: [b]Flight Report!!![/b] - 5/29/2005 9:17 AM
    FlyerBry
    Score: 100
    Status: offline
    Thanks CAPtain232,
    When trimming the formers, did you follow any rule of thumb as to how much to trim? How much is too much???
    quote:
    ORIGINAL: CAPtain232
    FlyerBry
    Hide Signatures
           Post #: 272
    RE: [b]Flight Report!!![/b] - 5/29/2005 5:28 PM
    Ace.in.a.day
    Score: 100
    Status: offline
    What big 3 bladed prop with small pitch do you recommend for the OS 91FX so that the Extra flies nice and slow, but with good vertical performance?
    @ FirstOfficer: Could you please make a pic of your tailwheel, looks good, where did you get it. Do you also have an new landing gear.
    Think of replacing that heavy stock on against a glassfiber one....
    < Message edited by Ace.in.a.day -- 5/30/2005 7:47 PM >
    Hide Signatures
           Post #: 273
    RE: [b]Flight Report!!![/b] - 5/31/2005 4:43 PM
    Navy18
    Score: 100
    Last Login: 3/15/2010
    Status: offline
    Question.... anyone ever think of adding thicker skin to the wings? Built one and didn't like the wing skins.... just curious.
    Hide Signatures
           Post #: 274
    RE: [b]Flight Report!!![/b] - 5/31/2005 5:03 PM
    zope_pope
    Score: 105
    Status: offline
    I believe first officer got his tailwheel from DPM www.davepatrickmodels.com . Its called the ultimate tailwheel. I have heard nothing but good things about it. As far as the wing skins go, I just used the stock ones and if you are real careful wit the wing, you won't have to worry about damaging them.
    Hide Signatures
    (in reply to Navy18)
           Post #: 275
    Extra 300S - 60
  • Read Full Review
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    1.594RCU1
