RE: [b]Flight Report!!![/b]
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Extra 300S - 60
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> Kit Building >> RE: [b]Flight Report!!![/b]
    Page: <<   < prev  9 10 11 12 13 14 [15] 16 17 18   next >   >>
    Login
    RE: [b]Flight Report!!![/b] - 2/14/2006 12:48:41 AM
    rcapmd
    Status: offline
    flyNoz - That's a great looking job you've done!
    A 90 size engine is perfect for this plane. I was a bit surprised the manual suggested it would handle up to a 1.20.....but hey, whatever works!
    Power Plant - OS 91 FX
    Exhaust - Bisson Pitts
    Guidance: JR XP652
    Servos - (5) 517's
    Skin - Monokote; Painted cowl
    IMHO only.
    I like:
    -Good Manual, quick building
    -Excellent Flight Characteristics: Snap Rolls are Unreal- don't blink!
    -Generally a tough plane, can take a bit of a beating
    -Looks great in the air
    Don't like:
    -Wheel Pants, cracked up after 2-3 flights
    -I found landing can be somewhat tricky in winds less than 5-7 mph.
    -Main gear support is weak
    -Very sensitive elevator response
    MODS:
    -Wheel Pants - tossed them out
    -Main Gear - Rebuilt entire under structure w/ reinforcements
    -Over sensitive elevator response- moved front incidence up approx. 1/4" inch from (front) factory mount holes; added 30% expo
    -Landing- Practice proper approach, subtle throttle management, lateral balance.
    -Rudder, Rebuilt top rear corner after it met my front door, DOH!
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    (in reply to harrier81)
           Post #: 351
    RE: [b]Flight Report!!![/b] - 2/14/2006 12:17:46 PM
    flapper
    Status: offline
    rcapmd,
    Nice looking plane. I replaced my Os 61 with a Supertiger 90 in last month. Good combination. Also running a Bisson in cowl muffler. I have had to strengthen the main gear attachment plate after ripping the two thin ply plates out when I landed and allowed the plane to run onto uncut grass at the end of the strip! Put in a thicker ply plate and secured well to fuselage former. No excuses if I land properly...
    I have a lot of cracking/splits in the ABS cowl and also removed the ABS wheel pants due to same. I might need to put an anti vibration type engine mounting in as I am sure it is the vibration causing this to the cowl. I have ordered a fiberglass cowl and pants from a US company called Fiberglass Specialties. Should be here (Aust) in 2 to 3 weeks. Not cheap but want the plane looking good.
    Regards
    Mark
    Click for fullsize
    (in reply to rcapmd)
           Post #: 352
    RE: [b]Flight Report!!![/b] - 2/14/2006 3:59:45 PM
    rcapmd
    Status: offline
    Thanks flapper!
    Ditto: same exact thing happened to me with the main gears - into the deep grass and off came the gear. Let me know how the new wheel pants and cowl work out - The wheel pants (for the little time I had them) really finished off the plane nicely.
    regards....
    (in reply to flapper)
           Post #: 353
    RE: [b]Flight Report!!![/b] - 3/6/2006 9:29:28 PM
    Antennaman
    Status: offline
    I've breifly scanned this thread but still have one question...
    Will this kit 3D? and if yes, will it do so with a ST G-90?
           Post #: 354
    RE: [b]Flight Report!!![/b] - 3/6/2006 11:28:56 PM
    jb86
    Status: offline
    never was designed as a 3d aircraft. it's a good scale aerobat. there's a thread w/build mod's, increase elevator, rudder and aileron area. mine's almost done (working on other projects right now), using an os 120 fs w/pump (i have it), i put the three servos (metal gear on rudder, 2.1 oz) in the tail to balance for the engine. comes in at a little over 8 pounds. everything i've read said that it's just not the right aircraft for all out 3d. no matter how much you lighten it, you can't get enough horsepower for all out 3d.
    jon b
    _____________________________
    saito club #235
    (in reply to Antennaman)
           Post #: 355
    RE: [b]Flight Report!!![/b] - 3/8/2006 6:40:05 PM
    rcapmd
    Status: offline
    Ditto - not really the right bird for full 3D capabilities.
           Post #: 356
    RE: [b]Flight Report!!![/b] - 3/10/2006 10:30:33 PM
    jb86
    Status: offline
    can anyone tell me; my extra 300 is almost done, and last night while handling the wing (it's covered) i made a small crack (about 2 inch circle) in the leading edge sheeting on the bottom of the wing, 1" behind the leading edge between r2 and r3. it really doesn't show, i'm concerned w/strength. i have considered cutting the covering and pull it back together and maybe lay a small pc of 2 oz glass over the crack. can i leave it alone, or do i have to repair it?
    jon b
    saito club #235
           Post #: 357
    RE: [b]Flight Report!!![/b] - 3/11/2006 5:57:24 AM
    flapper
    Status: offline
    Jon,
    It all depends on the finish you are after. You could peel back the covering carefully, repair the crack with zap and then re iron the covering back down. Another option is to put a series of small pin holes through the covering to let zap (or other glue) through to fix crack.
    If you have an actual hole in the sheeting the only option would be to remove a portion of the covering and re glue another piece of balsa shaped for the hole and then use a light filler to smooth edges. Will need sanding but you will have to be careful not to damage surrounding covering. It is a shame it didn't happen before covering. Nothing more frustrating than finishing a plane and then having to repair before it has actually flown!!!!!
    Wouldn't recommend the glass cloth as you will have a high spot which will show after covering.
    Regards
    Mark
    (in reply to jb86)
           Post #: 358
    RE: [b]Flight Report!!![/b] - 3/11/2006 11:39:41 AM
    waagbuck
    Status: offline
    If it makes you feel any better, I cracked the leading edging sheeting on mine pulling it out of the car after attending my club's building contest. Just pull the covering back, fix the crack with thin CA, repair covering. No one has ever noticed my repair, and I'm sure no one will notice yours.
    (in reply to jb86)
           Post #: 359
    RE: [b]Flight Report!!![/b] - 3/19/2006 6:14:46 PM
    Captain Randy
    Status: offline
    This may be too late, but I encountered the same thing. I drilled a small hole from the bottom directly under the cracked area. Then I squirted some thin ca in the hole, rotated the wing around a bit to spread the ca, then stuck a small "L" shaped allen wrench threw the hole and pushed the area back up. Covered the small hole, and no one can tell.
    "Servo screws vibrate loose!!!"
    (in reply to jb86)
           Post #: 360
    RE: [b]Flight Report!!![/b] - 3/19/2006 8:18:05 PM
    jb86
    Status: offline
    i cut open the covering, pulled the pieces back and put some thin ca over it. seemed fine, it was only about a 1 1/2" circular area that was damaged. i sanded it and laid about a 3" patch of 3/4 oz glass over it w/thin ca, feathered it out, after covering you can't see it. i wanted some glass to reinforce it since i can't reach behind for a patch of balsa.
    jon b
    saito club #235
    (in reply to Captain Randy)
           Post #: 361
    RE: [b]Flight Report!!![/b] - 4/14/2006 11:12:15 AM
    hitcttd
    Status: offline
    Nice planes guys... I actually finished mine a while back and haven't had time to get it flight ready until now.
    plane will have the following setup
    Futaba 9 channel receiver
    All Hitec servos -
    x2 5625 for ailerons
    x2 5645 for elevators
    x1 5925 for rudder
    x1 225BB for throttle
    may be a bit of an overkill but all of this stuff comes off of a funtana... 90
    Saito 1.25 fueled by a 16oz fuel tank...
    Here are some pictures...
    I do have a question. I will be using a 5 cell 6 volt pack, where did you all place it to get the CG? could it fit right in the middle of the fuse or would i need to move it back to the tail to compensate for the engine? Let me know guys, i want to get this thing flying in about two weeks
    has anyone flown this plane with a 120?
    OH! if you guys want you can use U-Can-DO 60 wheel pants... they're a little big, but they're cheap and are nice
    as for the cowl, i dont know what i'm going to do yet
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    ... when is the fedex guy gonna come?
           Post #: 362
    RE: [b]Flight Report!!![/b] - 4/15/2006 11:24:50 PM
    Captain Randy
    Status: offline
    xX911gt2Xx,
    Your plane looks awesome!
    Ive got an OS 120 w/ pump
    16x6 prop
    Carl Goldberg plastic spinner
    2 Futaba S3010 for elevators (mounted externally in rear)
    2 Futaba S3010 for ailerons
    1 Hitec HS-645MG for rudder
    1 Futaba S3004 for throttle
    1 5 cell 6v battery pack
    Stans Fiber Tech cowl and pants
    Great plane lite wheels
    Sullivan tail wheel
    The only modification I made was externally mounting the elevator servos in the rear.
    Came out just under 8lbs.
    Be sure and use bonded washers to mount the cowl!
    I mounted the battery pack to the bottom of the pilot platform. I put it as far back as possible, yet still easily accessible. I originally had a tru Turn spinner, but it balanced perfectly with a plastic one .........
    The plane flies as good as it looks:
    Click for fullsize
    Click for fullsize
    (in reply to hitcttd)
           Post #: 363
    RE: [b]Flight Report!!![/b] - 4/15/2006 11:34:28 PM
    hitcttd
    Status: offline
    Oh man nice plane. It's too late for me to mount my servos in the rear, i thought about doing that. i might have to make a hatch for the battery so i can mount in the back. My saito i think is a lot lighter than your OS but i will be using a tru turn spinner. this is going to be really interesting when CG balancing time comes. I am going to use the stock cowl and reinforce it with fiber glass resin. for cowl mounting i use nylon screws and O rings to protect the cowl. maybe down the road i will order a cowl from stan but for now i just want to
