RE: [b]Flight Report!!![/b]
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Extra 300S - 60
  • 2 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> Kit Building >> RE: [b]Flight Report!!![/b]
    Page: <<   < prev  9 10 11 12 13 14 15 [16] 17 18   next >   >>
    Login
    RE: [b]Flight Report!!![/b] - 5/15/2006 1:08:14 AM
    Rate1
    Status: offline
    I flew my Extra for the first time for this season today. I liked it.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    < Message edited by Rate1 -- 5/17/2006 10:04:16 PM >
    _____________________________
    <--- This is my dog, Capt Morgan, and he has propably more flight hours than you.
    (in reply to prodigy467)
           Post #: 376
    RE: [b]Flight Report!!![/b] - 5/15/2006 2:31:27 PM
    a340
    Status: offline
    That looks great Rate1, nice colour scheme.
    Gonna have to carry on with mine, all built and has been for a couple of years now, just needs the covering. It will be powered by an OS91fx.
    Leigh.
    (in reply to Rate1)
           Post #: 377
    RE: [b]Flight Report!!![/b] - 5/15/2006 8:15:47 PM
    Rate1
    Status: offline
    ...well get cracking with it. You will not regret it as I am sure you are going to love this plane.
    You guys that have finished building and flown this kit, write your comments about it under Airplane Reviews.
    C.
    (in reply to a340)
           Post #: 378
    RE: [b]Flight Report!!![/b] - 6/2/2006 3:14:28 AM
    TheMachinist
    Status: offline
    This is a great thread! I have been a member here for a while but I was mainly involved with RC trucks. I ditched all that stuff and started flying. I am still learning with my 40 trainer. But I needed something to work on so I started building one of these 60 size extras. I don't plan on being able to fly it until next summer even if it was finished tommorow. I am building it completely stock except for some things that I read about here, but nothing involving the control surfaces.
    What do you guys build your wings on? I made a table for most of the work that is completely flat. For the wings though I wanted something that would let me push a pin into it.
    so I put a ceiling tile on top of my flat surface and started building the wing. The tile seems like it might flex a little bit and that worries me. Also what can be done about an assembly like the rear stab warping slightly after I built it? It went together straight and lined up with the drawing perfectly, after it sat for a week it had bowed a little. when I put a straightedge across it there was a 1/32 gap in the center. Is this normal?
    Sorry about the plethora of questions, maybe I will be able to help some one in another area!
    (in reply to Rate1)
           Post #: 379
    RE: [b]Flight Report!!![/b] - 6/4/2006 2:07:50 AM
    jb86
    Status: offline
    the "warped" horizontal; is it sheeted yet? if not, then glue the sheeting on w/ca on a flat surface, that will straighten it out. otherwise, if there is a small bow place it so the tips point up (not down).
    you have to know that a scale aerobat (extra, edge, ect) you have to be careful with take off, landing and slow flight. most important thing you can do to keep it tame is to keep the weight down, everything i've read on these threads is, try for 7 1/2-8 lb. saito 100 is about the best engine choice. there is a great thread called something like "great planes extra 300 build/mods." i think his name is adrian. the modifications are worthwhile and not dificult. there are lot's of great tips in his thread.
    my extra is almost done, covering complete, just assembling, but i can't touch it for a few months. i have an os 120 fs w/pump, very heavy, but i have it. comes in at 8 1/2 lb. and to get that i used lightweight equipment any where i could, saving about 7 oz. w/ the os 120, i put the two mini elev. servo and the mg rudder servo in the tail to balance.
    this probably isn't the best choice for a second plane. you should get something a bit more forgiving. i think a fun fly like the ucando .46 is a great choice, i fly w/a os 70. it gives you a chance to expand your flight envelope, definitely get some inverted practice.
    as far as a building surface, makes sure it's flat. i use a particle board (called hdo countertop substrate) about 2'x4', i lay it on top of the building table, check to be sure that this is perfectly flat and not warped, a 4 foot level placed criss cross to the opposite corners, and lengthwise.
    place the plans on this board. i never cared for pinning the spar down, it slides around. i use (4) or (5) 1/8" plywood pcs, about 3/4" wide and 1 1/2" long, drill two holes in them and use dry wall screws into the particle board, to clamp the spar down. keep them straight w/ the line on the plan, and adjust w/a screwdriver as needed. this way the spar is held tightly. be sure to put great planes plan protector over your plans.
    jon b
    saito club #235
    (in reply to TheMachinist)
           Post #: 380
    RE: [b]Flight Report!!![/b] - 6/4/2006 11:16:00 AM
    Rate1
    Status: offline
    Make sure you do increase rudder area. You will need it since original design does not have big enough for good knife edge. With my OS120 it came into 8,3 lbs and flew very nice. Landings were nice and slow never snaped on me. I used good std dual servos for elevator and for the ailerons. A mini servo för throttle and a strong digital on the rudder. Otherwise, as said, build it light and you will love it.
    (in reply to jb86)
           Post #: 381
    RE: [b]Flight Report!!![/b] - 6/5/2006 12:59:35 PM
    Captain Randy
    Status: offline
    I built mine with stock rudder and stab./elev. With an OS FS 1.20 it has more than enough rudder to knife edge. You just need a good servo. The mods for this plane are just for looks. I would not recommend this as a second airplane. Get a stick or a Four Star.
    "Servo screws vibrate loose!!!"
           Post #: 382
    RE: [b]Flight Report!!![/b] - 6/16/2006 3:37:57 PM
    rcapmd
    Status: offline
    Machinist:
    RE) Building Board - Relatively cheap and by far the most reliable I've had to date.
    Fortunately I have a glass company on my block - had them cut me approx. 1/4 inch thick, 24" x 48" glass slab - ($50.00) Slap a piece of sheet rock/drywall on it ($5.00) to pin into and your good to go - straight and flat as can be. Never a problem, no worries about eventual warping etc. After a couple builds, simply replace the sheet rock.
    regards -
           Post #: 383
    RE: [b]Flight Report!!![/b] - 7/2/2006 6:05:05 AM
    jamesflies
    Status: offline
    Hey guys im finishing up my extra, i am planning on using a super tigre G-2300. is that overkill? its only a couple ounces heavier than the o.s 1.20 without the pump. and there is always the throttle stick, so tell me what you guys think. i did mount two elevator and one rudder servo in aft end of the fuse, so balance shouldnt be too big of an issue.
    thanks,
    James
    (in reply to rcapmd)
           Post #: 384
    RE: [b]Flight Report!!![/b] - 7/3/2006 6:57:26 AM
    flapper
    Status: offline
    James,
    I would recommend beefing up the engine box. Probably look at using fibreglass and epoxy to ensure a stronger fixing of the box to the front former. Might need to make the actual firewall thicker to improve the joining surface area on all four sides. It is only light 3mm ply used for the engine box.
    (in reply to jamesflies)
           Post #: 385
    RE: [b]Flight Report!!![/b] - 7/4/2006 10:17:04 PM
    jb86
    Status: offline
    weight is a major concern, the os 120 fs is a bit heavy for the aircraft, it raises the auw to 8 lbs. read thru the thread "GP extra 300 build mods." he used a saito 100, best power/weight. too much weight and power w/a big prop makes it too easy to snap out of control. you have to keep the ailer and elev deflection really low at low speed. worth reading thru that thread, alot of good info.
    jon b
    saito club #235
           Post #: 386
    RE: [b]Flight Report!!![/b] - 7/26/2006 2:02:15 AM
    Rate1
    Status: offline
    Just to conclude my Extra.
    I have crashed it by misjudging the distance to the treeline while flying in the dusk. I am kicking myself for this as I am aware of the danger of lost perseption of distance while flying in such conditions (I am a full scale pilot). However, the plane is far beond repair but thankfully the engine and all the electronics made it.
    I used OS 120 Surpass III pumped and found it an excellent choise for this kit. Landings where nice and slow with no tip stalling tendencies, speed was good using a APC 16x6 prop that also offered good breaking during downlines. Stall was soft and straight, totally uneventfull with no tip stalling. Had made enlarged rudder and elevators which almost gave me knife edge loops (never had the guts to go all the way around). Had dual tail mounted elevator servos to counter the rather heavy swiss watch like ticking engine with an awesome sound. No lead was added to achive balance (used 0,5 oz at left wing tip for lateral balance to counter side mounted engine). For rudder I used a strong digital servo, micro servo for throttle, carbinote geared servos for aileron and elevator. All servos where Hitech. Knife edge to hover was posible. Further, I had nice selected hardware such as DP Ultimate tail wheel ect. Tank was c of g mounted = no triming throughout the flight.
    The total weight of the plane was 8,3 lbs. Hover was acomplished at approx 1/2- 3/5 throttle. Not knowing if power curve was linear but I would guess power to weight ration was parhaps 1:1,8 (that is almost twice as much power as models weight) when using 15% synthetic oil and 15% nitro (never got time to try 30% nitro). Vertical performance was not rocket but with authority and to out of sight. This was not, as many is aware of, a 3D plane but a VERY good traditional aerobat. I found this plane very stable and predictive hence very easy to fly as it did all I asked for and nothing I did not.
    Having all this said I should meantion that I used it as my trainer and it was my very fist model aircraft. (Beside being a pilot I cheated by taking training sessions on club trainer and flew rc sim for 6 months before flying this Extra). I loved that plane and are feeling a sence of pride that I manage to acomplish such a nice plane especially being my first rc plane ever and recived compliments from people that though is was a very nice ARF (I recived a lot of helpfull tips building it thru this RCU thread).
    The good part of this story is that apart of all the gained experience this have given me; learning to building, triming, flying, selecting hardware, and overall rc skills, I will now enjoy the next project.
    Regards,
    C.
    Click for fullsize
    < Message edited by Rate1 -- 7/26/2006 2:55:17 AM >
    (in reply to jb86)
           Post #: 387
    RE: [b]Flight Report!!![/b] - 7/26/2006 4:18:25 AM
    jb86
    Status: offline
    sorry to hear about your extra. i thank you for the discussions and listing your included equipment. i haven't touched my extra for about 4 months. i have it covered, all control surfaces are hinged, just finishing the equipment installation. i have the same os 120 pumped engine, and similar set up w/servos. i did a mock up before covering to check the approx cg, anticipating needing tail weight w/the 35 oz. engine. AUW comes in at 8 1/2 lb. i got to get it done soon, i'll post pic's. again sorry for you crash, however, your posts have been helpful. best of luck.
    jon b
    saito club #235
    (in reply to Rate1)
