RE: [b]Flight Report!!![/b]
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Extra 300S - 60
  • 2 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> Kit Building >> RE: [b]Flight Report!!![/b]
    Page: <<   < prev  9 10 11 12 13 14 15 16 [17] 18   next >   >>
    Login
    RE: [b]Flight Report!!![/b] - 2/9/2007 8:11:35 PM
    AllTheGoodNamesAreTaken
    Status: offline
    FYI
    Mine flies great @ 8 pounds and a Saito .91 in the nose. Very very smooth flying airplane.
    _____________________________
    Jeff Walker
    (in reply to Captain Randy)
           Post #: 401
    RE: [b]Flight Report!!![/b] - 2/12/2007 11:46:10 AM
    a340
    Status: offline
    LOL I have Just realised that I have the wrong version of extra on mine should be 300S and I have put 300L on it........DOHHH!! Ahh well it'll have to do coz I aint changing it now. Just goes to show how observant every one is in here lol
           Post #: 402
    RE: Great Planes Extra 300 .60 Build/Mods - 3/29/2007 7:36:30 PM
    alfredbmor
    Status: offline
    Adrian: Did the overall size remained the same?
    When you placed the pieces on the plan they fitted on the overall size?
    As I am starting to build this plane I'd like to know about it.
    Thanks.
    quote:
    ORIGINAL: AdrianM
    Moving the elevators forward 1/2" make the elevators ~50% of the stab area. The counter balances make the elevators a bit more than 50%.
    So...The scale outline is still there, there will be less load on the servos and I will have more pitch authority.
    Thats it for today. Vertical stab and rudder tomorrow.
    Saito Club Member
    (in reply to AdrianM)
           Post #: 403
    RE: [b]Flight Report!!![/b] - 5/17/2007 6:24:07 AM
    gauravag
    Status: offline
    Hi all,
    I am building the same plane ( GP extra 300 .60 ) , and have a question about the wheel pants.
    THe wheels are very tight inside the pants and literally not being able to rotate . THere is no part of the pants touching the wheel and the tightness is because of the nut, that goes through the wheel and tightens at the axle . If i loosen it then the whole wheel pant assembly becomes loose.
    Any help would be much appreciated ..
    Thanks to all !
    Gaurav
    (in reply to alfredbmor)
           Post #: 404
    RE: [b]Flight Report!!![/b] - 5/17/2007 12:34:48 PM
    Captain Randy
    Status: offline
    Sounds like you need to put a spacer (washer or collar) between the nut and the wheel.
    "Servo screws vibrate loose!!!"
    (in reply to gauravag)
           Post #: 405
    RE: Great Planes Extra 300 .60 Build/Mods - 5/24/2007 4:47:17 AM
    gauravag
    Status: offline
    Nice Thread.
    I have just completed this plan, and using an OS .91 FX . Anyone has any ideas on using a smoke system with this engine ?
    Recommended equipment for this ?
    Would love to see smoke with this plane.
    Thanks to all
    -Gaurav
           Post #: 406
    RE: Great Planes Extra 300 .60 Build/Mods - 5/24/2007 6:38:54 PM
    alfredbmor
    Status: offline
    Take a look at here:
    www.tmenet.com/smktips.htm
    I already have the simple smoke pump from TME and is great, I hope this will help.
    Saito Club Member
           Post #: 407
    RE: Great Planes Extra 300 .60 Build/Mods - 6/2/2007 9:13:38 AM
    gauravag
    Status: offline
    Thanks. I am getting the TME Simple smoker as well. Do you think it will work good with a OS .60 2 stroke ?
           Post #: 408
    RE: Great Planes Extra 300 .60 Build/Mods - 6/2/2007 6:04:54 PM
    alfredbmor
    Status: offline
    The real secret here is to preheat the oil, on 4 strokers this is a simple task but in 2 strokers this is a bit more difficult to accomplish, you will need to coil a brass tubing around the muffler or manifold to preheat the oil before it gets in the exhaust and becomes smoke.
    Here is a picture of my set up in a Carl Goldberg Ultimate, using the TME simple smoke pump
    Click to see fullsize image.
    Click for fullsize
    Saito Club Member
           Post #: 409
    RE: Great Planes Extra 300 .60 Build/Mods - 8/23/2007 9:08:59 PM
    Hughes500E
    Status: offline
    Pweeeew, long thread but worth the read. I am just finishing up my kit. I did the tail mods and I bolted a YS 110 to the front of it.
    Should be interesting! Anyone still enjoying their Extra 300s? Anyone still building ?
           Post #: 410
    RE: Great Planes Extra 300 .60 Build/Mods - 8/24/2007 3:29:03 PM
    rc-fly
    Status: offline
    Good luck with the kit, Hughes500E
    Yeah, I enjoyed my Extra so much that is has become RIP . I think, I had a failing x-tal during flight. Must be ones in a life time that happens? Oh well, I have already promised myself that I will build another one - it's simply that good .
    GP Extra 300 .60 (RIP), YT Freestyle Rush (flying), Avistar (flying) ,Midwest AT-6 (awaits building), TP Contender (sold)
    (in reply to Hughes500E)
           Post #: 411
    RE: [b]Flight Report!!![/b] - 9/22/2007 6:00:23 PM
    matzri
    Status: offline
    hi, i'm going to put on ,ine OS91 FX,
    did u think that i stil have to move to some servos to the rear of the fuse?
    if so, relocate the elevatore (2 servos) or the Rudder (1 servo)?
    THX
    tal
    (in reply to rc-fly)
           Post #: 412
    RE: [b]Flight Report!!![/b] - 9/22/2007 6:07:20 PM
    jb86
    Status: offline
    i would build the frame and leave the option open to mount servos in the tail. mine i built for os 120 surpass II w/pump, have mounts for the - (2) hobbico cs35MG (1 ounce each) for the elevators, and a hitec hs 5965mg for the rudder. i balanced it before covering w/enigne mounted and placed the servos anearby held w/tape, placed the fiberglass cowl on the engine; everything as close to the prper place to get a rough balance. then i covered it. now i have a saito 100, about 8 ounces less. now i'll put the 2 ounce rudder servo in the fuse w/a pull/pull.
    jon
    saito club #235
    (in reply to matzri)
           Post #: 413
    RE: [b]Flight Report!!![/b] - 9/22/2007 7:11:14 PM
    matzri
    Status: offline
    THX,
    but i'm hoping that somone hwo had installd an 90 2 C engine (OS) can give me an answer...
    < Message edited by matzri -- 9/22/2007 11:36:58 PM >
    (in reply to jb86)
           Post #: 414
    RE: [b]Flight Report!!![/b] - 9/23/2007 2:31:05 AM
