Falcon 120 "wingmod" *video*    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Falcon 120 "wingmod" *video*
Page: [1]
Login
Falcon 120 "wingmod" *video* - 7/20/2011 6:56 PM
Henke Torphammar
Score: 100
Last Login: 5/22/2013
Status: offline
I bought a Falcon 120 kit some years ago. Due to the low quality of the kit I put it away for some years to dig it out this summer. My plan was to use it as a flying wing which needed relocation of the landinggear... opening the wing I saw the disaster and the amount of work needed to make it durable enough for grass field operation... so I jumped the gear and decided SOG (slide of ground) would be good enough :-)
For power I use the Haoye 5" EDF with a Scorpion 4035-800 motor, the setup uses 159A from a 10S pack and provides enough thrust for unlimited verticals. Topspeed seem to be around 125mph due to my Android app which dopplers the plane in the air, flight times about 4min on my 5000mAh packs with power to spare for a couple of aborted landings.
I was surprised of the amount of power the fan put out, even with a turbine setup very fiew planes have the oumpf to go straight up from the start.
I'm not saying this is better then anything else, just that I with inspiration from the guys at rcgroups.com came up with a pretty cheap way of flying a pretty large jet model with an EDF setup.
_____________________________
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
       Post #: 1
RE: Falcon 120 - 7/20/2011 9:03 PM
John Casey
Score: 100
Last Login: 11/12/2007
Status: offline
Well done modification.....great flight....
Hide Signatures
(in reply to Henke Torphammar)
       Post #: 2
RE: Falcon 120 - 7/20/2011 9:29 PM
RAPPTOR
Score: 104
Last Login: 5/21/2013
Status: offline
KOOL..C/G STILL 13 INCHES?? STOCK??
Hide Signatures
       Post #: 3
RE: Falcon 120 - 7/20/2011 10:15 PM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: RAPPTOR
About 10,5" CG, you also need to cut away the flaps part of the wing and align it with the motormount, or rather cut 4/5 and crack it up, then fill the gap with balsa and the glue of your choice. :-)
/Henke
Hide Signatures
(in reply to RAPPTOR)
       Post #: 4
RE: Falcon 120 - 7/20/2011 11:14 PM
BaldEagel
Score: 118
Status: offline
Now that is impressive, I don't mean the Falcon, but how flat your grass patch is. LOL I would kill for a grass patch that flat even the sheep poo forms bumps bigger than the wheels at our site. and if you ever run out of epoxy use sheep poo, its impossible to get off once its dried.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 5
RE: Falcon 120 - 7/21/2011 2:01 AM
rocketman-RCU
Score: 100
Last Login: 5/14/2013
Status: offline
I'm not sure what you meant regarding the flaps. So you are flying with elevons and no flaps? And the wing inside the stabs are inline with the motor mount? Looks like rudders, but I can't see the servos.
Hide Signatures
(in reply to BaldEagel)
       Post #: 6
RE: Falcon 120 - 7/21/2011 3:02 AM
erbroens
Score: 105
Status: offline
It´s a smart and quick Idea... nice! As a bonus you can fly it easily on snow too.
Enrique
Hide Signatures
(in reply to rocketman-RCU)
       Post #: 7
RE: Falcon 120 - 7/21/2011 9:21 AM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: rocketman-RCU
The upper surface of the trailing edge needs to be level with the motor mounting platform. Flying it with only two servos.
/Henke
Hide Signatures
       Post #: 8
RE: Falcon 120 - 11/3/2012 5:50 PM
mvivona
Score: 100
Last Login: 5/7/2013
Status: offline
Anyone building the Falcon 120 needs to see the 6 part instructional video on Youtube.
It is the BEST one out there. Covers every aspect of the build. Sure wish I would have know about this before I built my first one.
http://www.youtube.com/watch?v=OYYo4o1r5ho&feature=youtu.be
Hide Signatures
       Post #: 9
RE: Falcon 120 - 11/3/2012 7:40 PM
Xairflyer
Score: 105
Status: offline
Love it (the wing mod not the edf )
So who is going to be first with a turbine version?
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to mvivona)
       Post #: 10
RE: Falcon 120 - 11/6/2012 1:01 PM
i3dm
Score: 100
Status: offline
Cool wing mod ! how bad would it be on the stock gear location ? perhaps adding trailing link struts could help ?
www.liorzahavi.com
www.youtube.com/i3dm
Hide Signatures
(in reply to Xairflyer)
       Post #: 11
RE: Falcon 120 - 11/6/2012 1:18 PM
Dr Honda
Score: 100
Status: online
quote:
ORIGINAL: Henke Torphammar
About 10,5'' CG, you also need to cut away the flaps part of the wing and align it with the motormount, or rather cut 4/5 and crack it up, then fill the gap with balsa and the glue of your choice. :-)
Is this to ad reflex to the design?
quote:
ORIGINAL: Xairflyer
I have a falcon that's stripped to be "Beefed-up" a little. Maybe this is what I need to do to it. If I added canards... it would be a Jr Rookie.
< Message edited by Dr Honda -- 11/6/2012 3:53 PM >
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 12
RE: Falcon 120 - 11/6/2012 2:29 PM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: i3dm
As the CG moves forward by about 3" you need to follow with the landing gear, trailing links would make it worse. A quite easy fix if you got materials and a proper jigsaw and a good rectract system to use. I didn't at the moment.
/Henke
Hide Signatures
(in reply to i3dm)
       Post #: 13
RE: Falcon 120 - 11/6/2012 2:30 PM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: Henke
quote:
ORIGINAL: Dr Honda
Yep!
/Henke
Hide Signatures
(in reply to Dr Honda)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
