RE: Top Flite Giant P-47 Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Top Flite Giant P-47 Build Page: <<   < prev  19 20 [21] 22 23 24 25 26 27 28   next >   >>
Login
RE: Top Flite Giant P-47 Build - 10/5/2012 3:21 AM
Ram360
Score: 100
Last Login: 5/13/2013
Status: offline
As far as electronics go I am using a jr 9ch rx with a wolverine switch and am going to try savox servos all on HV. Motor is a DLE 55 I had laying around. This is my first build and had been fun so far.
Hide Signatures
(in reply to Ram360)
       Post #: 501
RE: Top Flite Giant P-47 Build - 10/5/2012 11:38 PM
Doomking
Score: 125
Last Login: 5/17/2013
Status: offline
Nick ...pictures didn't show.
Hide Signatures
       Post #: 502
RE: Top Flite Giant P-47 Build - 10/6/2012 12:12 AM
bigal126
Score: 120
Last Login: 5/15/2013
Status: offline
C'mon Nick.
Hide Signatures
(in reply to Doomking)
       Post #: 503
Ram360
Score: 100
Status: offline
Its been fixed
Hide Signatures
(in reply to bigal126)
       Post #: 504
RE: Top Flite Giant P-47 Build - 10/8/2012 1:16 PM
redbiscuits
Score: 130
Last Login: 5/19/2013
Status: offline
What is the consensus of gluing in pin hinges with Gorilla Glue? It foams and expands up to 3x when curing. Any thoughts would be appreciated.
_____________________________
Gary-Waco Brother#171 If the build gets tough, always refrain from throwing things! ARCA, Austin Tx. www.austinrc.org
Hide Signatures
       Post #: 505
RE: Top Flite Giant P-47 Build - 10/8/2012 1:32 PM
Ram360
Score: 100
Status: offline
It works great but can be messy. Take some Vaseline and put a thin coat around the hinge hole. If any glue expands out it will not stick and comes right off.  I have used gorilla glue on my last 2 35% planes.
Hide Signatures
(in reply to redbiscuits)
       Post #: 506
RE: Top Flite Giant P-47 Build - 10/8/2012 2:15 PM
redbiscuits
Score: 130
Status: offline
By messy, do you mean when it cures it gushes out or what? I guess if it works on a 35% air-frame it would more than do the job on this. Do you fly 3D Ram?
Hide Signatures
       Post #: 507
RE: Top Flite Giant P-47 Build - 10/8/2012 5:24 PM
yates55
Score: 105
Last Login: 5/18/2013
Status: offline
Just to let you guy's know Fiberglass Specialties have the "chin" for $14.00 plus shipping if you are looking for them
They are not listed yet but you can give Craig a call at 479-359-2429
yates
Hide Signatures
       Post #: 508
RE: Top Flite Giant P-47 Build - 10/8/2012 5:29 PM
redbiscuits
Score: 130
Status: offline
Awesome! I just got done posting in the ARF thread if anyone had one they were willing to part with.
Thanks Yates.
Hide Signatures
(in reply to yates55)
       Post #: 509
RE: Top Flite Giant P-47 Build - 10/8/2012 5:44 PM
maineflyer
Score: 105
Status: offline
Guys,
I am looking at this as my first scale project in a long time. Building a new workshop at the house and I am hoping this is going to be the first thing on the table. I wanted to ask some questions if you don't mind. I am looking at doing electric retracts and wanted to if anyone else is using them. I would also really like to fly with a scale prop on a DLE 55RE. Has anyone tried that? Thanks for the input... I have a bunch of reading to do
Jeff
Jeff
Hide Signatures
       Post #: 510
RE: Top Flite Giant P-47 Build - 10/8/2012 6:34 PM
bigal126
Score: 120
Status: offline
Redbiscuits,
I fly with Nick and consider him a friend. As far as does he fly 3D? I think it is safe to say "yes, you can call it that." As far as warbirds go, his last encounter with a P47 ended up with everyone at the field climbing the highest tree out there for the retrieval operation.
I have some experience with gorilla glue. The glue will look for the path of least resistance, which normally is out the back of the hinge hole. This is good in that a little ball of glue will form back there which locks the hinge in. It won't come out easily. With that being said, if you drill the proper hole diameter that allows the hinge to fit snug at the hinge line, very little if any glue will come out forward making a clean installation. But Nick is correct to suggest putting in some type of barrier "just in case". I took a piece of masking tape, punched a hole in the center with a standard hole punch, and placed the tape on both hinge lines before gluing. It was a little challenge to get the tape off after the glue sets, but made for a clean install. That is my experience at least, but I'm no prolific builder.
I've been following the thread and your plane and the others look awesome!
Hide Signatures
(in reply to maineflyer)
       Post #: 511
RE: Top Flite Giant P-47 Build - 10/8/2012 6:59 PM
redbiscuits
Score: 130
Status: offline
Thanks for sharing your experience bigal. I'm going to try it. I like how it foams up and expands. As many times as I have had the surfaces on and off the plane a couple of the holes aren't as tight as they used to be. I've read where guys swear by the stuff, I just don't like to believe everything I read sometimes.
Hide Signatures
       Post #: 512
RE: Top Flite Giant P-47 Build - 10/8/2012 8:15 PM
Mustangman40
Score: 181
Status: online
quote:
ORIGINAL: maineflyer
Guys,
Jeff
Jeff,
I am building one right now as well and been waiting for Robart to come out with the Electric retracts, they came out and it will run my $630.00 for the mains and tailwheel.. I about choked when i seen the price so I am rethinking what way I will go with gear... As far as the scale prop, everyone I seen running them have went with a DA 85 to help turn the monster, haven't seen a DLE 55 turning one yet...
Jimbo
Ultra Sport Brotherhood #92
Hide Signatures
       Post #: 513
RE: Top Flite Giant P-47 Build - 10/8/2012 10:17 PM
maineflyer
Score: 105
Status: offline
Jimbo,
I think there is a company that will convert gear to electric also... I was hoping to find something for under 500.
Jeff
Hide Signatures
(in reply to Mustangman40)
       Post #: 514
RE: Top Flite Giant P-47 Build - 10/8/2012 10:46 PM
Ram360
Score: 100
Status: offline
quote:
ORIGINAL: redbiscuits
Yes it will start to bubble out of the hole if its to large, but Al already commented on all of that.  And I am by no means easy on my planes, Fabio can comment on that to lol.  And it wasnt the tallest tree, it was only 20ft up.
Hide Signatures
       Post #: 515
RE: Top Flite Giant P-47 Build - 10/9/2012 2:57 AM
Doomking
Score: 125
Status: offline
For those of you along with Gary, that are considering using Gorilla Glue for Robart hinge point, years ago I found here on RCU an awesome video demonstrating the proper procedure to how to install Robart hinge point with gorilla glue.
I tried it years ago and I never looked back. I think by far is the easiest and strongest installation method out there.
To find the video click on the link listed below.
It's the review for the Top Flite GS p-51 ARF.
Scroll just a bit down, and on the second row of pictures he talks about installing hinge points and gives a link to a very informative video.
Enjoy!!!
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=273
Fabio
Hide Signatures
       Post #: 516
RE: Top Flite Giant P-47 Build - 10/9/2012 12:13 PM
redbiscuits
Score: 130
Status: offline
Well, I'm sold on that method now. Thanks Fabio!
Hide Signatures
       Post #: 517
RE: Top Flite Giant P-47 Build - 10/10/2012 3:52 PM
Mustangman40
Score: 181
Status: online
Man, evryone is so craby in the warbird forum......................
Gary,
I been using just regular Tite bond wood glue for ahwile now on all my hinges and it's worked awesome, use to use epoxy...
I like the fact that the GG expands and will be trying it on my next hinge job....
I am also going to glass mine with a new product I came across called EzeKote, after using it to glass a screwed up cowl on my 50cc pitts. I don't think I will ever use epoxy resin to glass with again, it was that good....
Jimbo
Hide Signatures
       Post #: 518
RE: Top Flite Giant P-47 Build - 10/10/2012 4:00 PM
redbiscuits
Score: 130
Status: offline
Yeah Jimbo, congrats on the #1 thread on RCU right now, only seconded by another **** stirring thread in the jet forum, no surprise there!
I'd like to see some pics how that resin turns out, I'm always looking for a better way to do things with good results.
Hide Signatures
       Post #: 519
RE: Top Flite Giant P-47 Build - 10/10/2012 4:17 PM
Mustangman40
Score: 181
Status: online
LOL it's funny how crazy they get trying to tell you how wrong your opinion is, but try and cram their opinion on ya.....
Any way..
here is a short vid of the stuff and a few of the really cool things..
http://www.youtube.com/watch?v=XQJ-mkoYQIo&feature=related
No smell, water base so clean up is great.. You can start a wing in the morning and be ready for primer in as little as 2 hours and that's no joke.. I found it to blend and sand awesome when i used it and that was on a glass cowl, can only imagine how well it works on wood... My shop is in the basement, so the no odor thing is a big plus...  I will do a vid on the stuff when I do my P-47 and keep you posted..
Jimbo
Hide Signatures
       Post #: 520
RE: Top Flite Giant P-47 Build - 10/10/2012 6:41 PM
redbiscuits
Score: 130
Status: offline
Oh well, you know Jimbo, one good thing about those ARF's is it frees up a lot of time to play on the internets.
Hide Signatures
       Post #: 521
RE: Top Flite Giant P-47 Build - 10/10/2012 10:34 PM
Doomking
Score: 125
Status: offline
Kinda looks like the poly method.
Milky substance, water based and done with 3 to 4 coats.
Keep us posted.
I would like to hear your impression if that water based product will not effect the wood with warping and all.
Thanks for sharing.
Hide Signatures
       Post #: 522
RE: Top Flite Giant P-47 Build - 10/10/2012 10:42 PM
shrek514
Score: 100
Status: offline
You can perchase it at great hobbies. Who apparrently purchased ontario adhesives company. So you can only by it from great hobbies. I will buy some  and test this product out for sure. Thanks for the tip on this great product.
Hide Signatures
       Post #: 523
RE: Top Flite Giant P-47 Build - 10/10/2012 10:57 PM
redbiscuits
Score: 130
Status: offline
Horizon has it http://www.horizonhobby.com/products/eze-kote-DLMBD37
Hide Signatures
(in reply to shrek514)
       Post #: 524
RE: Top Flite Giant P-47 Build - 10/11/2012 3:09 PM
shrek514
Score: 100
Status: offline
Sorry i was talking in canada
Hide Signatures
       Post #: 525
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
