RE: Top Flite Giant P-47 Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Top Flite Giant P-47 Build Page: <<   < prev  20 21 [22] 23 24 25 26 27 28 29   next >   >>
Login
RE: Top Flite Giant P-47 Build - 10/12/2012 12:24 PM
redbiscuits
Score: 130
Last Login: 5/22/2013
Status: offline
I've been working on installing the servos and push rods. I opted to use couplers on all the push rods so I have adjustment on both ends. This also allows me to use ball links on the servos, I like the solid connection they provide. I'm not a big fan of the solder links that the kit provides, but it's really just a personal preference.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Gary-Waco Brother#171 If the build gets tough, always refrain from throwing things! ARCA, Austin Tx. www.austinrc.org
Hide Signatures
(in reply to shrek514)
       Post #: 526
RE: Top Flite Giant P-47 Build - 10/12/2012 1:06 PM
Ram360
Score: 100
Last Login: 5/13/2013
Status: offline
Looks good, I am planing on using ball links also and turnbuckles for the ailerons.
Hide Signatures
(in reply to redbiscuits)
       Post #: 527
RE: Top Flite Giant P-47 Build - 10/12/2012 3:09 PM
maineflyer
Score: 105
Status: offline
How would you rate the TF P-47 compared to the Yellow A/C or Meister??? I am looking forward to starting a build soon and am leaning toward the TF...
Jeff
Hide Signatures
(in reply to Ram360)
       Post #: 528
RE: Top Flite Giant P-47 Build - 10/12/2012 3:14 PM
Mustangman40
Score: 181
Status: offline
Gary,
looks good, I do the same with my stuff.. I like having the ball link on both sides, makes for a very solid connection....
Jimbo
Ultra Sport Brotherhood #92
Hide Signatures
(in reply to maineflyer)
       Post #: 529
RE: Top Flite Giant P-47 Build - 10/12/2012 4:31 PM
redbiscuits
Score: 130
Status: offline
Thanks Jimbo, I have the Dubro heavy duty locking clevises on the other end. Been using them a long time and never had one fail or get sloppy, plus I scrounged up enough around the shop to do the job. That's always a bonus!
I would like to do a Meister Scale or go all overboard and build a Don Smith 1/4 scale someday (dreaming) The Yellow A/C is a tad too small for me personally, but I don't think you will be disappointed in the TF kit, and it is pretty complete right out of the box. I'm glad I chose to build both the small and the large TF Jugs, it's given me the skills I will need to not make a plans built warbird not so daunting.
Hide Signatures
(in reply to Mustangman40)
       Post #: 530
RE: Top Flite Giant P-47 Build - 10/12/2012 5:05 PM
maineflyer
Score: 105
Status: offline
Gary,
Thanks for the info... There was a Yellow kit in the market... I am looking at a Ziroli one also but am leaning toward the topflite. I will most likely go with the TF. I want to play at scaling it out some so later on I can really do high detail scale project.
Thanks again for all the info.
Jeff
Jeff
Hide Signatures
       Post #: 531
RE: Top Flite Giant P-47 Build - 10/12/2012 5:27 PM
redbiscuits
Score: 130
Status: offline
No problem Jeff, Keep us updated when you get started.
I've been playing with the air system this morning. I picked up a couple of these T's from Grainger thinking that they would look nice mounted in the fuse and make the connections look a little more tidy. My only concern was they might leak, but that isn't a concern anymore, they have been holding solid pressure for over three hours now and I've cycled the tail wheel a dozen times. I think I'm going to pick up a couple more to finish off the install.
Click for fullsize
Hide Signatures
       Post #: 532
RE: Top Flite Giant P-47 Build - 10/13/2012 12:50 AM
SitNFly
Score: 100
Status: offline
Hey guys,
I've been installing the retracts in mine. I'm using the Robarts that are designed for this plane. It looks like I'm going to have to remove a lot of rib area for the leg to retract fully into the locked position. This is with a Dubro 5" treaded lite wheel. Is this normal or do you pivot the leg slightly to get the required clearance? Some of the photos on this thread show the wheels much deeper in the wing than I think mine are going to end up.
Hide Signatures
       Post #: 533
RE: Top Flite Giant P-47 Build - 10/13/2012 3:54 AM
Doomking
Score: 125
Status: online
I know that some people put 1/4" hardwood shims under the retracts mount just to lift the wheel off the wing.
The extra 1/4" will not show when the gear is up.
Hope this helps
Fabio
Hide Signatures
(in reply to SitNFly)
       Post #: 534
RE: Top Flite Giant P-47 Build - 10/13/2012 1:05 PM
redbiscuits
Score: 130
Status: offline
quote:
ORIGINAL: SitNFly
Hey guys,
I've been installing the retracts in mine. I'm using the Robarts that are designed for this plane. It looks like I'm going to have to remove a lot of rib area for the leg to retract fully into the locked position. This is with a Dubro 5'' treaded lite wheel. Is this normal or do you pivot the leg slightly to get the required clearance? Some of the photos on this thread show the wheels much deeper in the wing than I think mine are going to end up.
Go here to post #107-#109 http://www.rcuniverse.com/forum/fb.asp?m=10829988
You will need to shave those two ribs down quite a bit so they don't interfere with the wheel. You may have to shim it a little too if that doesn't give you enough room, as Fabio said.
I also added stringers on the inside for scale effect, but also they really gave the sheeting some extra support.
If you try and pivot the strut too much to allow clearance, when you open the gear the wheel will have too much toe out, not a good thing either.
I finally found a happy medium where everything worked, gear extended with the wheels straight and the locks functioned easily. That is why I sheeted the bottom of the wing with the gear in the plane so I could lay up the gear doors to account for shimming the gear. Does that make sense?
Hide Signatures
       Post #: 535
RE: Top Flite Giant P-47 Build - 10/13/2012 9:45 PM
SitNFly
Score: 100
Status: offline
Thanks for the link to the pictures and the shim tip. Looking at mine, I've still got a ways to go on the ribs, but the shim may be a must-have also. Thanks.
Hide Signatures
       Post #: 536
RE: Top Flite Giant P-47 Build - 10/14/2012 4:19 AM
Doomking
Score: 125
Status: online
Glad we could help.
I am running into some issue with the fuel tank.
The stock set up with a couple of balsa stringer running across F1 and F2 do not offer a good way to anchor the tank and make it removable at the same time.
How did you guys set yours up?
I am thinking of building a tray like in my top flite p51 that rest in a slot behind the firewall and attaches with two screws on F2 for easy removal for inspection and such.
Am I missing something on page 28 of the tank installation instruction?
Fabio
Hide Signatures
       Post #: 537
RE: Top Flite Giant P-47 Build - 10/14/2012 1:29 PM
redbiscuits
Score: 130
Status: offline
I did mine stock Fabio. The piece of balsa you see along the tank side is not glued in yet as I still need to run a choke setup through that area. After I get that buttoned up, I will glue it in to keep any sideways movement from happening. I have the batteries under the tank (or on top depending on the way your looking at it) between the balsa tank rails and I used some heavy chipboard as the battery floor. Foam is jammed up in there to keep everything from rattling around. Worked out pretty good.
I spent the biggest part of yesterday hardening up all the holes with CA and applying Locktite to everything. I also got the elevators glued in, and the Gorilla Glue seems to be doing the job after I tugged on them pretty hard.
I'm thinking I will make another tray that will mount over the servo tray. I would like to mount the receiver to that tray and it will also keep any of the wing wiring and air-tubing from getting tangled up in the servos.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Doomking)
       Post #: 538
RE: Top Flite Giant P-47 Build - 10/14/2012 8:50 PM
redbiscuits
Score: 130
Status: offline
I finished up the choke servo and hooking up the linkage. Not a moment too soon either, as the shop is a wreck!
How come every time I do electronics stuff it looks like a bomb went of in the garage?
How many of you guys solder that little hole in the choke butterfly closed? I'm thinking of doing that, any problem with doing that? My DLE 30, next time I have the engine off the firewall I was going to do the same thing.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 539
RE: Top Flite Giant P-47 Build - 10/14/2012 8:52 PM
Ram360
Score: 100
Status: offline
Some people say it will draw fuel faster. I never did it and both my dle 30 and 55 started pretty quick.
Hide Signatures
       Post #: 540
RE: Top Flite Giant P-47 Build - 10/15/2012 3:53 AM
SitNFly
Score: 100
Status: offline
quote:
ORIGINAL: Doomking
Glad we could help.
Fabio
I built a mount that slides in on the existing tank floor. It fits in a small hardwood "wicket" I glued on the front of the floor and then I put a lip on the back of the mount with a couple screws to hold it in place. Works fine as I wanted to be able to get to the tank a little easier also. By the way, I ground off most of the ribs and used the shim idea on my retracts. Works great. Back to work for me and I'll stay out of redbiscuits thread as much as I can......
Click for fullsize
Hide Signatures
       Post #: 541
RE: Top Flite Giant P-47 Build - 10/15/2012 11:33 PM
redbiscuits
Score: 130
Status: offline
The brown truck came today.
Click for fullsize
Hide Signatures
       Post #: 542
RE: Top Flite Giant P-47 Build - 10/15/2012 11:43 PM
Ram360
Score: 100
Status: offline
How many times did they drop the box?
Hide Signatures
       Post #: 543
RE: Top Flite Giant P-47 Build - 10/16/2012 12:06 AM
redbiscuits
Score: 130
Status: offline
UPS=United Parcel Smashers
Hide Signatures
       Post #: 544
RE: Top Flite Giant P-47 Build - 10/16/2012 12:14 AM
redbiscuits
Score: 130
Status: offline
I asked my wife if they brought it to the door or just drove by and kicked it out in the ditch. LOL
Hide Signatures
       Post #: 545
RE: Top Flite Giant P-47 Build - 10/16/2012 12:28 AM
Edwin
Score: 156
Status: online
About $1000 in paint?
Edwin
Hide Signatures
       Post #: 546
RE: Top Flite Giant P-47 Build - 10/16/2012 2:24 AM
Doomking
Score: 125
Status: online
One question.
Doesn't it get labor intensive to spray a color, clean everything up then spray another color and so on?
I would love to use my spray gun equipment, but I always dreaded the clean up part.
Any tips that you guys can share to alleviate the pain?
Fabio
Hide Signatures
(in reply to Edwin)
       Post #: 547
RE: Top Flite Giant P-47 Build - 10/16/2012 2:31 AM
Edwin
Score: 156
Status: online
I use the water base warbird colors or nelsons paint. Changing colors is pretty easy, flush it with water and spray it through the gun till its clean. Warbird colors has been having problems with his supplier but he's about to get it solved pretty soon.
Edwin
Hide Signatures
       Post #: 548
RE: Top Flite Giant P-47 Build - 10/16/2012 12:36 PM
redbiscuits
Score: 130
Status: offline
After all the priming I have done Fabio, I only had to clean my gun once. After I spray, I pour a little lacquer thinner in my cup and spray it out into a rag, wipe the cup out, go over the gun, and I'm done. The thing that has been more bothersome than anything is wearing a breathing mask. I have one of those filtered masks so I'm not inhaling the fumes. It's an instant headache if I don't wear it, so I deal with it.
Hide Signatures
       Post #: 549
RE: Top Flite Giant P-47 Build - 10/16/2012 12:44 PM
redbiscuits
Score: 130
Status: offline
Some of you may have seen this, Frank T's huge P47 "Wicked Wabbit"
Hide Signatures
       Post #: 550
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.125RCU1
