RE: Top Flite Giant P-47 Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Top Flite Giant P-47 Build Page: <<   < prev  31 32 [33] 34 35 36 37 38 39 40   next >   >>
Login
RE: Top Flite Giant P-47 Build - 12/2/2012 5:48 PM
redbiscuits
Score: 130
Last Login: 5/26/2013
Status: offline
Little-by-little, I'm getting it knocked out. I pulled a late night last night and then finished off the top of the wing this morning. All that is left is the bottom of the wing and the cowl. Will upload some pics whenever RCU acts right.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by redbiscuits -- 12/2/2012 9:18 PM >
_____________________________
Gary-Waco Brother#171 If the build gets tough, always refrain from throwing things! ARCA, Austin Tx. www.austinrc.org
Hide Signatures
(in reply to redbiscuits)
       Post #: 801
RE: Top Flite Giant P-47 Build - 12/4/2012 2:51 AM
yates55
Score: 105
Last Login: 5/25/2013
Status: offline
Looking great Gary
Hide Signatures
       Post #: 802
RE: Top Flite Giant P-47 Build - 12/4/2012 5:04 PM
EJWash1
Score: 130
Status: offline
Caught-up with the thread. Very nice detail work in post #801.
Learning lots, thanks!
EJWash
Hide Signatures
(in reply to yates55)
       Post #: 803
RE: Top Flite Giant P-47 Build - 12/4/2012 6:23 PM
Mustangman40
Score: 181
Status: offline
Looks great Gary, very nice... So tell us, with all of us building ours, is it giving you the push to finish.. I know your detail work has me plugging along on mine....
Question about the filler you use.. Any problems with cracking or shrinking and what was the make again? I have to run to town and get my new glasses and had to stop at a Menards and was going to pic some up.. I have to get a longer 3/16" drill bit for the flap hinges and them suckers are done........
Jimbo
Ultra Sport Brotherhood #92
Hide Signatures
(in reply to EJWash1)
       Post #: 804
RE: Top Flite Giant P-47 Build - 12/4/2012 6:38 PM
redbiscuits
Score: 130
Status: offline
Yep Jimbo, It's keeping me motivated.
I use the Fast and Final Lightweight Spackling from Dap under the glass. I haven't had any cracking issues at all. I use that until I get the glass on and then I switch to good ol' Bondo for the final body work. I try to use the Bondo as sparingly as possible as that stuff is heavy.
Hide Signatures
(in reply to Mustangman40)
       Post #: 805
RE: Top Flite Giant P-47 Build - 12/4/2012 10:01 PM
Mustangman40
Score: 181
Status: offline
quote:
ORIGINAL: redbiscuits
10-4 on that. I went back in the thread and found what your using and picked some up, it feels pretty dang light and the price is a lot better then the stuff from the hobby shop...
Hide Signatures
       Post #: 806
RE: Top Flite Giant P-47 Build - 12/5/2012 3:01 AM
Mustangman40
Score: 181
Status: offline
I'm not sure as to why you guys thought the flaps were a PITA, I thought they were much worse then that, they sucked!!!!!!!  I even went and made it much worse by gluing the LE on wrong and had to glue on more wood.. I was in a hurry to glue them on before heading out with the family, a 50/50 shot at doing it right and I got them both wrong...lol Well done is done, glad they are done.. Here is a pic of what it looks like when you put them on wrong and have to remove a bunch of wood, only to glue on more on the other side... I really don't recommend doing it like I did!
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 807
RE: Top Flite Giant P-47 Build - 12/5/2012 3:04 AM
Ram360
Score: 100
Last Login: 5/24/2013
Status: offline
I am almost ready to start the flaps, not looking forward to it that's for sure.
Hide Signatures
       Post #: 808
RE: Top Flite Giant P-47 Build - 12/5/2012 3:15 AM
Mustangman40
Score: 181
Status: offline
I started doing a mod on the wing dowels, I didn't care for how the book shows and can see this being a weak point down the road.. I have a bunch of carbon fiber arrows and decided to beef them up.. I picked up some 3/8 poplar dowel rod from the home store and with a little sanding, got them to fit inside the tubes.. I drilled them into the stock rings but didn't go into the main spare, then I backed it up with some 1/4" ply.. I plan on filling the two bays with expanding foam tomorrow, that stuff really adds a lot of strength at little to no extra weight..  I will beef up the former on the fuse where the dowels go in when i mount the wing... I'm sure the stock set up is just fine, but I had the stuff and figured I would have some extra peace of mind...
Jimbo
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 809
RE: Top Flite Giant P-47 Build - 12/5/2012 3:22 AM
Mustangman40
Score: 181
Status: offline
quote:
ORIGINAL: Ram360
Ram,
they really aren't that bad, just a lot of sanding to get the fit you want... I'm not real fond of the hinging, but they seam much more solid now that they are done.. I am putting a 90cc motor in mine and was thinking with this set up that they would be shaking real bad from vibration, but now I don't think it will be a problem.....
Jimbo
Hide Signatures
(in reply to Ram360)
       Post #: 810
RE: Top Flite Giant P-47 Build - 12/5/2012 4:02 AM
thebeave
Score: 100
Last Login: 5/8/2013
Status: offline
What diameter and width are the wheels you guys are going to use ? I was test fitting mine today and it looks as if the wheels are going to stick up above the sheeting near the leading edge. I would really like to use more of a scale looking wheel, but all the ones i come across are out of my price range right now. Help..........
Hide Signatures
       Post #: 811
RE: Top Flite Giant P-47 Build - 12/5/2012 12:56 PM
redbiscuits
Score: 130
Status: offline
I'm using the Dubro 5" Large scale inflatable wheel, I don't know the width.
Believe me, it's a tight fit, but it fits as long as it's not over inflated.
Hide Signatures
(in reply to thebeave)
       Post #: 812
RE: Top Flite Giant P-47 Build - 12/5/2012 7:16 PM
Mustangman40
Score: 181
Status: offline
I finished up the dowel bays and filled with the spray foam.. I added some 1/4" ply to the front 1/8" stock part that the dowels go through where they have you make little balsa gussets. I also covered up the lightning holes to keep the spray foam from going into the retract bays... The foam really expands, first pic is right after, second one is five minutes later, wait till you see it when it's cured...  I will let it cure for a day and then cut off the extra and sand it down to the ribs... I won't ever have to worry about the dowels letting go, my flying will break before they do...
Question.
I looked in the manual and found nothing about glassing the center section as was wondering what your thoughts are on this... I am glassing the whole plane, but that's with 3/4oz cloth.. Has anyone glassed the center section? The wing joiner is pretty dang beefy, not sure glass would improve the strength much and it would make for some trimming on the belly pan formers....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Mustangman40 -- 12/5/2012 7:46 PM >
Hide Signatures
       Post #: 813
RE: Top Flite Giant P-47 Build - 12/5/2012 7:33 PM
Edwin
Score: 156
Status: offline
What engine you running? Mine will be a G-62 and I'm not planning on strength glassing the center section. Just a standard glass job for a paint base. I've seen a lot of these jugs running 85cc and real screamin demons. Makes the hair on the back of my next rise up as they go by, love it. I know two of the guys personally and they didnt beef it up. My spar joiner was replaced and made beefier and I figure that will be enough for my flying style.
Edwin
Hide Signatures
       Post #: 814
RE: Top Flite Giant P-47 Build - 12/5/2012 7:52 PM
Mustangman40
Score: 181
Status: offline
quote:
ORIGINAL: Edwin
Edwin
Edwin,
I am putting in a GP88 EVO, I have been told that it has the same power as a DA100 and very low vibration for being a single cyl.  It should scoot mine real good and that's why I am beefing up a few things... With the extra motor, I will also try swinging a 4 blade............
Jimbo
Hide Signatures
(in reply to Edwin)
       Post #: 815
RE: Top Flite Giant P-47 Build - 12/5/2012 7:59 PM
Edwin
Score: 156
Status: offline
You dont really loose anything by beefing it up at this stage. That will probably pull some stout G's. I've only folded one wing. It was on a smaller electric spitfire with a pretty big electric motor in it. It folded in a high G turn trying to loose a FW190 that was on my tail during a dog fight. He claimed the kill, but seconds later his esc smoked and in he went so I claimed a latent kill. Still argued to this day.
Edwin
Hide Signatures
       Post #: 816
RE: Top Flite Giant P-47 Build - 12/5/2012 8:06 PM
redbiscuits
Score: 130
Status: offline
I glassed the center section and belly pan with what I think is 6oz. The top of the wing was done more for cosmetic reasons, the belly pan was done in heavier cloth in case of a gear up situation.
Hide Signatures
(in reply to Edwin)
       Post #: 817
RE: Top Flite Giant P-47 Build - 12/5/2012 8:10 PM
Edwin
Score: 156
Status: offline
On yeah, My belly pan has hardwood stringers and will get the same glass treatment as Gary's.
Edwin
Hide Signatures
       Post #: 818
RE: Top Flite Giant P-47 Build - 12/5/2012 8:32 PM
Mustangman40
Score: 181
Status: offline
That's a real good idea Gary, I would rather have it and not need it, then need it and not have it...
The hardwood stringers are also a great touch and will be used on mine as well........
I have to give my LHS a call and see what the status is on my Retracts, I'm really starting to run out of things to do with out them...
I think I also need to order my servos, all 8 of them...  Gonna use the Hyperions that I used in my 50cc pitts, but will upgrade the ailerons and elevators to the next ones up that they have. They are a little slower then the DS 20fmd, but you pic up another 100+ oz . Full metal gear dual BB digital totally programmable..
I am also adding a Smart-Fly Power Expander, it makes hooking up twin elv and flaps a breeze and the dual battery share is awesome.. With the pin style switch and electric retracts, I won't have to make any hidden hatches, just one up front for a fuel dot and ignition...
Hide Signatures
       Post #: 819
RE: Top Flite Giant P-47 Build - 12/5/2012 8:56 PM
redbiscuits
Score: 130
Status: offline
Well Jimbo, You got those "Fancy Schmancy" gear that are supposed to work everytime. Hopefully you won't need it.
Hide Signatures
       Post #: 820
RE: Top Flite Giant P-47 Build - 12/5/2012 10:21 PM
Mustangman40
Score: 181
Status: offline
I'm glassing the belly and might even fill the whole thing with spray foam....
The bread is rising.........  The goldfish crackers are all gone, but the new chips are yummy......
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 821
RE: Top Flite Giant P-47 Build - 12/5/2012 10:50 PM
redbiscuits
Score: 130
Status: offline
quote:
ORIGINAL: Mustangman40
Sounds like you have post traumatic stress disorder from past pneumatic experiences! LOL
Wish I would have thought of the foam dang-it. I should pump some in the belly-pan of mine.
*edit* No disrespect intended for anyone suffering from PTSD...
Hide Signatures
       Post #: 822
RE: Top Flite Giant P-47 Build - 12/6/2012 12:04 AM
RWHorton
Score: 120
Last Login: 3/12/2013
Status: offline
Just a note, it's not the bottom of the wing that fails it's the top, when a wing folds the top compresses, the bottom tries to streach.
Ron
Hide Signatures
       Post #: 823
RE: Top Flite Giant P-47 Build - 12/6/2012 12:52 AM
Mustangman40
Score: 181
Status: offline
quote:
ORIGINAL: RWHorton
Ron
10-4 on that Ron......  The whole belly pan thing is incase of a gear up landing, easier to fix the paint and not the pan....
Hide Signatures
(in reply to RWHorton)
       Post #: 824
RE: Top Flite Giant P-47 Build - 12/6/2012 1:02 AM
Mustangman40
Score: 181
Status: offline
Well Gary, lets just say that a guy from a particular Magazine was going to take some pics, but I had already took off the static stuff.. he said he would get some pics later on once i was done flying and put all the static stuff back on.. Well, the static stuff never did make it back on that day and the pics never happened..
A word of caution on the spray foam... Trying to fill something that is all covered up with just an access hole, is suicide..  It will blow the sheeting right off and don't ask how i know this, just trust me, it will blow it right off......  They do make a low expanding foam for around windows, if you used it and are careful it should work fine, but don't quote me on that.......
Hide Signatures
       Post #: 825
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
