RE: Top Flite Giant P-47 Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Top Flite Giant P-47 Build Page: <<   < prev  27 28 [29] 30 31 32 33 34 35 36   next >   >>
Login
RE: Top Flite Giant P-47 Build - 11/5/2012 4:29 AM
RWHorton
Score: 120
Last Login: 3/12/2013
Status: offline
Jimbo here a technique I use on my controls surfaces. It makes a really sharp corner and keeps the dings to a minimum. Glue a piece of 1/64 ply to each end of the control surface.
Makes a really sharp tough edge.
Ron
Hide Signatures
(in reply to Mustangman40)
       Post #: 701
RE: Top Flite Giant P-47 Build - 11/7/2012 1:02 AM
redbiscuits
Score: 130
Last Login: 5/23/2013
Status: online
I don't know what was worse, building the flaps or adjusting the linkages and the radio for the flaps. After 3 evenings of fiddling around with it I finally got the radio and the linkages all adjusted and working properly, the flaps coming down and going up evenly, all without any slop or servo buzz.
_____________________________
Gary-Waco Brother#171 If the build gets tough, always refrain from throwing things! ARCA, Austin Tx. www.austinrc.org
Hide Signatures
(in reply to RWHorton)
       Post #: 702
RE: Top Flite Giant P-47 Build - 11/7/2012 1:45 AM
Edwin
Score: 156
Status: offline
Lucky you. I'm still battling my flaps on the B-25.
Edwin
Hide Signatures
(in reply to redbiscuits)
       Post #: 703
RE: Top Flite Giant P-47 Build - 11/8/2012 2:52 PM
redbiscuits
Score: 130
Status: online
Doesn't look like any flying will be done here this weekend.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Edwin)
       Post #: 704
RE: Top Flite Giant P-47 Build - 11/8/2012 5:41 PM
Doomking
Score: 125
Status: offline
I hear a chant........Rivets!......Rivets!......Rivets!....
Hide Signatures
       Post #: 705
RE: Top Flite Giant P-47 Build - 11/8/2012 5:46 PM
redbiscuits
Score: 130
Status: online
I was thinking the same thing!
Hide Signatures
(in reply to Doomking)
       Post #: 706
RE: Top Flite Giant P-47 Build - 11/8/2012 10:19 PM
Doomking
Score: 125
Status: offline
Well thanks to my forever friend Gary, I can now proceed forward.
Ailerons are done and I am waiting for the filler to dry so that I can separate them and cut the hinge holes.
One question....actually two.
Is it sufficient for the flaps to be glued to the balsa LE just applying glue to the little ribs and the flap skins?
Seems to me that just a 3/32 " gluing surface is insufficient. But then again what do I know?
Also once you shape the flaps, is it possible to put enough glue around the flap horn or it's going to get squeezed out the slot you cut in the balsa once you insert it in?
How did you guy handle that?
Once again Gary.....thanks!!!
Click for fullsize
Hide Signatures
       Post #: 707
RE: Top Flite Giant P-47 Build - 11/8/2012 11:04 PM
redbiscuits
Score: 130
Status: online
Hey, no problem buddy. Glad it showed up so soon.
I followed the instructions but I used Titebond II wood glue for the leading edges of both. For the flap-horn, I used epoxy and then filled the rest of the gap with epoxy mixed with micro balloons once it set up.
Hide Signatures
       Post #: 708
RE: Top Flite Giant P-47 Build - 11/8/2012 11:08 PM
redbiscuits
Score: 130
Status: online
I can't remember if I glued in the flap-horn first and then glued the leading edge around it or not, but that kinda sticks out in my mind.
*edit*
It couldn't have been that way, the leading edge is already shaped by that time. Told you I had a bad memory!
Hide Signatures
       Post #: 709
RE: Top Flite Giant P-47 Build - 11/9/2012 5:01 PM
redbiscuits
Score: 130
Status: online
I think most of you guys are doing the razor back version. If ya'll need these files I can send them to you. I also have the P47D 3 views as well.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 710
RE: Top Flite Giant P-47 Build - 11/9/2012 6:08 PM
yates55
Score: 105
Status: offline
That would be awesome Gary
yates55@ec.rr.com
Yates
Hide Signatures
       Post #: 711
RE: Top Flite Giant P-47 Build - 11/9/2012 7:30 PM
yates55
Score: 105
Status: offline
Got em, going to print shop now to get blown up a bit
Thanks Gary
you are the man
yates
Hide Signatures
       Post #: 712
RE: Top Flite Giant P-47 Build - 11/10/2012 12:55 AM
Mustangman40
Score: 181
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: RWHorton
Ron
Ron,
that's a real good idea and one I think I will use, thanks for the tip..........
Hello gang,
been out of town working all week so not much progress on my bird.. Yard work in the morning, suppose to be 72 but 30mph winds, good day to send my neighbor his leafs back...lol
I'm looking forward to getting down in the shop over the weekend and getting the flaps knocked out.. Got good news at work, besides being busy which is always a good thing, the boss told me it was ok to build my plane rack for my shop.. I got full access to all the good stuff, gonna build a real nice mobile rolling rack with all the bells.....
Jimbo
Ultra Sport Brotherhood #92
Hide Signatures
       Post #: 713
RE: Top Flite Giant P-47 Build - 11/10/2012 12:57 AM
Mustangman40
Score: 181
Status: offline
quote:
ORIGINAL: redbiscuits
Oh yeah baby, that will help a bunch when I do my P.L. and hatches..........
nwood10@yahoo.com
Thanks Gary.....
Hide Signatures
       Post #: 714
RE: Top Flite Giant P-47 Build - 11/10/2012 4:43 PM
redbiscuits
Score: 130
Status: online
Let the riveting begin!
There is a little bit of a learning curve to using the finish set that I bought. The transfer tape that is provided is good for one row of rivets, "maybe" two. I found it best just to use it once. I use a fresh piece, as it looses its tack quickly and fails to pick-up every rivet or screw. No big deal, as Mirce provided a lot of the tape.
I also found it best to use a tongue depressor to help in the transfer to the tape and to peel the tape back on itself while applying them, using the stick to help them release from the tape as well.
As I said, there is a little bit of a learning curve, but it's getting better as I go.
It's starting to look pretty sweet!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 715
RE: Top Flite Giant P-47 Build - 11/10/2012 9:07 PM
redbiscuits
Score: 130
Status: online
Few more...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 716
RE: Top Flite Giant P-47 Build - 11/10/2012 9:30 PM
cannonball200
Score: 105
Last Login: 5/18/2013
Status: offline
Wow!!!!!!!!!!!!!!!!!!!!!!! GaryThat is awesome!! I have followed your build with intent to build one for myself soon. The rivet detail is a necessity I think.
Good luck on the final finish, we will be watching...
Eddie of OKC
cannonball200
Waco" Brother #191 @ Cub Brother #122
Hide Signatures
       Post #: 717
RE: Top Flite Giant P-47 Build - 11/10/2012 9:34 PM
Mustangman40
Score: 181
Status: offline
Gary,
they look great, very nice.. i was thinking about buying them from him and you really got me thinking I will now, awesome... Thank you for the 3 views as well, got them this morning.
Jimbo
Hide Signatures
       Post #: 718
RE: Top Flite Giant P-47 Build - 11/10/2012 10:33 PM
Doomking
Score: 125
Status: offline
Gary looks great.
Compared to the iron method, would you say it's a bit faster and easier?
Are the rivets going to stick permanently or lift under the paint eventually?
I am seriously considering it as well if the application time vs my iron is cut down considerably.
On another note, Gary you were right about the flaps......what a pain in the &@"$@$;:.
I am having an issue with mine since they both developed a slight twist on the TE and it's very difficult to align both sides to the fuse and aileron at the same time.
I might have to just split the difference unless you guys have a solution to the twist.
Maybe soacking the flap TE in water and let them dry on a flat surface with some wight on?
Pictures to follow.
Hide Signatures
       Post #: 719
RE: Top Flite Giant P-47 Build - 11/10/2012 10:41 PM
Ram360
Score: 100
Last Login: 5/13/2013
Status: offline
Looks great Gary. I haven't done much on mine in the last few weeks I got a new 100cc bird I been working on.
Hide Signatures
       Post #: 720
RE: Top Flite Giant P-47 Build - 11/10/2012 11:13 PM
redbiscuits
Score: 130
Status: online
Thanks for the kind words guys!
Fabio, I think it is faster. It was kind of slow going at first, but once I developed a method that works for me I'm moving right along. It definitely isn't as monotonous as ironing 15,000 rivets, been there done that! I would say once I have paint and clear coat over it they aren't going anywhere, but right now I have to be kind of careful.
I had the same problem with one of my flaps. What I did is soak it with Windex and then weighted it down with sand bags for a couple days. That took most of the twist out of it and it's not noticeable now.
Hide Signatures
(in reply to Ram360)
       Post #: 721
RE: Top Flite Giant P-47 Build - 11/11/2012 1:07 PM
redbiscuits
Score: 130
Status: online
At this point I think it would be easy to "overdue" things. The P47 has flush rivets and I think if I just keep adding rivets it might take away from the look rather than enhance it. I don't like the overdone look, so I think I will try and find a happy medium while capturing the most noticeable details. Some of the panels are a little mis-placed, too late to change it now, I'm done doing bodywork.
What do you guys think?
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 722
RE: Top Flite Giant P-47 Build - 11/11/2012 4:23 PM
Mustangman40
Score: 181
Status: offline
I think your a very talented builder and it's coming out great, that's what me thinks...
I haven't had any warping problems in my flaps, but I haven't glued on the LE yet..  I am going to use a slow dry wood glue and weight them down flat on the bench while it sets.. I'm wondering if the LE being glued on in two pieces is causing this, there is not much to keep it from happening.. I think I might keep a scrap in the control horn gap while it all dries....
Hide Signatures
       Post #: 723
RE: Top Flite Giant P-47 Build - 11/11/2012 4:32 PM
redbiscuits
Score: 130
Status: online
quote:
ORIGINAL: Mustangman40
That's probably what is happening.
Heading to the hobby shop to see if I can pickup some stuff to simulate the sliding mechanism.
Click for fullsize
Hide Signatures
       Post #: 724
RE: Top Flite Giant P-47 Build - 11/11/2012 4:39 PM
Mustangman40
Score: 181
Status: offline
Gary,
do you remember who's Fiberglass cloth you used and how much you ended up using? I was going to get mine ordered today at my LHS...
Hide Signatures
       Post #: 725
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.781RCU1
