RE: Top Flite Giant P-47 Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Top Flite Giant P-47 Build
Page: <<   < prev  41 42 [43] 44 45 46 47 48 49 50   next >   >>
Login
RE: Top Flite Giant P-47 Build - 1/25/2013 6:20 PM
redbiscuits
Score: 130
Last Login: 5/26/2013
Status: offline
Thanks Tony, will it mount to the standoffs for a DLE55 without much modification?
I have the final coat of primer on the cowl, I just need to wet sand it back and peel off the tape. I'm going to start prepping the bottom of the wing and maybe if the wind lays down a bit this evening, I can get some color on it.
I borrowed an oil separator and drier from my work so I can get the best air that I can from my compressor. When I was priming, I would get fish-eyes from oil/water droplets, no big deal as I was sanding them out at the time. Now that it's time to shoot color, I don't want that happening.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Gary-Waco Brother#171 If the build gets tough, always refrain from throwing things! ARCA, Austin Tx. www.austinrc.org
Hide Signatures
(in reply to TonyBuilder)
       Post #: 1051
RE: Top Flite Giant P-47 Build - 1/25/2013 8:08 PM
TonyBuilder
Score: 143
Status: offline
Yes, just take a piece of 3/4 ply and drill the stand off pattern in it with a single hole in the center for a 1/2 carage bolt. The one that is on there is for a DLE 30 but just rotate and drill new holes for the DLE 55, that's what I am planing on doing!
TB
Fly, fly, fly!!!!
Hide Signatures
(in reply to redbiscuits)
       Post #: 1052
RE: Top Flite Giant P-47 Build - 1/25/2013 8:45 PM
Mustangman40
Score: 181
Last Login: 5/25/2013
Status: offline
I bet your excited Gary, cant wait to see it............
Ultra Sport Brotherhood #92
Hide Signatures
       Post #: 1053
RE: Top Flite Giant P-47 Build - 1/25/2013 10:26 PM
redbiscuits
Score: 130
Status: offline
Alright, here we go! I'm wondering if I bought a professional HVLP gun if it would orange peel like this one does? The primer went down fairly smooth, but everything I tried with the paint still gave me the orange peel look. Anyone out there have any suggestions?
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Mustangman40)
       Post #: 1054
RE: Top Flite Giant P-47 Build - 1/25/2013 10:42 PM
Zor
Score: 181
Status: offline
I do not spray model airplanes but painting an automobile I started on the inside of the trunk lid and noticed an orange peel effect. I cured it using more thinner and lower air pressure on the spray gone.
Zor
Hide Signatures
       Post #: 1055
RE: Top Flite Giant P-47 Build - 1/25/2013 11:09 PM
TonyBuilder
Score: 143
Status: offline
Ok so here are some better pics of my painting jig. The bracket is from my drum kit, just a Tama cymbal stand bracket. You can also just make it out of ply and 2x4s that is what I am planning for my jug. All you need is a plate to mount to the stand offs then have a 10” threaded bolt that can go into a ½ hole on your jig at a 90 degree or maybe even a 45 degree. All you want is a rotating pivot point so you can easily rotate as you paint.
TB
P.S. Looks like your kneed deep in the paint Gary
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Fly, fly, fly!!!!
Hide Signatures
(in reply to Zor)
       Post #: 1056
RE: Top Flite Giant P-47 Build - 1/25/2013 11:20 PM
redbiscuits
Score: 130
Status: offline
quote:
ORIGINAL: Zor
Zor
I may try more thinner on a test piece, Klass Kote says not to over thin and max is 1-1-1.
one part A, one part B, and one part thinner, that is what I did.
Hide Signatures
(in reply to Zor)
       Post #: 1057
RE: Top Flite Giant P-47 Build - 1/25/2013 11:22 PM  1 votes
Mustangman40
Score: 181
Status: offline
quote:
ORIGINAL: redbiscuits
In my opinion Gary it looks sweet, it really looks like military painted metal to me from the picture.. I never did care for the warbird that looked like a modern car paint job.. Back in the 40's when this plane was made as well as painted, we didn't have all the modern gadgets as well as time. They were banged out as fast as they could do it.... Just another point of view for ya buddy......
Hide Signatures
       Post #: 1058
RE: Top Flite Giant P-47 Build - 1/25/2013 11:36 PM  1 votes
TonyBuilder
Score: 143
Status: offline
 I totally agree, my chippy had the same orenge peal and it looked great. You don't need a glass finish IMHO. Looks great so far, keep going with that.
Fly, fly, fly!!!!
Hide Signatures
       Post #: 1059
RE: Top Flite Giant P-47 Build - 1/25/2013 11:42 PM  1 votes
heritageman
Score: 110
Last Login: 5/12/2013
Status: offline
Redbiscuits, your paint needs thinning, and it will flow out more even.
Hide Signatures
       Post #: 1060
RE: Top Flite Giant P-47 Build - 1/26/2013 12:43 AM
Zor
Score: 181
Status: offline
You also have to consider the paint gun conditons. Orange peel is due to some dropplets being too big. In different words the atomization of the paint mixture is not fine (small) enough. You may need a different head on your spray gun.
Zor
Edited 26 Jan 2013 to correct "dopplets" to "dropplets".
< Message edited by Zor -- 1/26/2013 1:32 PM >
Hide Signatures
(in reply to heritageman)
       Post #: 1061
RE: Top Flite Giant P-47 Build - 1/26/2013 1:04 PM  1 votes
Edwin
Score: 156
Status: offline
Many thin coats. It usually takes me about 4 passes before I see a complete covering with the color. Then a last wet coat. Whats your air pressure? I'm usually about 30psi. I also use a smooth sanded scrap piece of finish ply (I get it from Lowes) to test my spray before going to the plane. If thats the harbor freight gun, keep an eye on the adjustments. Mine tended to move a little. Mine is the 5oz hvlp.
Edwin
Hide Signatures
(in reply to Zor)
       Post #: 1062
RE: Top Flite Giant P-47 Build - 1/26/2013 1:41 PM
redbiscuits
Score: 130
Status: offline
I have 70 psi constant coming out of the tank and then I have the gun turned down somewhere near 40-50 I would guess. It's not a huge deal and really doesn't look too bad. It's just me being a perfectionist. I really want to get it spraying better before I continue though, I don't want to have to go back and sand the orange peel out, that would suck!
Edwin, you going out to the club today for the "Freeze Fly"?
Hide Signatures
(in reply to Edwin)
       Post #: 1063
RE: Top Flite Giant P-47 Build - 1/26/2013 1:49 PM  1 votes
WacoNut
Score: 175
Status: offline
Hi Gary,
I am watching with special interest as I plan on painting my 1/3 Waco with KK paint. I have sprayed alot of latex thru my HVLP gun but I have not used this paint yet. Same as you I do not want the orange peel finish.
With latex I normally spray around 30 psi. I would try dropping the pressure and turning the needle in to reduce the paint flow into the gun.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 1064
RE: Top Flite Giant P-47 Build - 1/26/2013 2:06 PM
redbiscuits
Score: 130
Status: offline
Good advise Anthony, I'm following along on your Waco rebuild as I want to do my 1/5 scale Pica with cloth too.
Glad I started on the bottom of the wing, that will get invasion stripes and stars and bars so by the time I get that on and cleared it won't be noticeable. I'm just going to get this figured out before I shoot the OD.
Hide Signatures
(in reply to WacoNut)
       Post #: 1065
RE: Top Flite Giant P-47 Build - 1/26/2013 2:06 PM  1 votes
TonyBuilder
Score: 143
Status: offline
Are you guys using finishing guns? My painter uses a low pressure finishing gun to finish my cabinets with, very little to no overspray and a perfect finish with no orenge peal. I think he is at 30 or lower psi
TB
Fly, fly, fly!!!!
Hide Signatures
       Post #: 1066
RE: Top Flite Giant P-47 Build - 1/26/2013 2:30 PM
redbiscuits
Score: 130
Status: offline
This one in particular is a regular gun, although I do have a small one too. Both from Harbor Freight.
Hide Signatures
       Post #: 1067
RE: Top Flite Giant P-47 Build - 1/26/2013 2:43 PM  1 votes
Edwin
Score: 156
Status: offline
Yeah, your pressure is way too high. I adjust the pressure at the tank. I dont trust the regulator on this harbor freight gun.
I'm planning on being there, a couple of students want to get some stick time in. They're going into withdrawals. Its a little wet at my place this morning but should dry out enough by noon. Wind forecast is right down the runway peaking at 12mph around 3pm, perfect.
Edwin
Hide Signatures
       Post #: 1068
RE: Top Flite Giant P-47 Build - 1/26/2013 2:44 PM  1 votes
TonyBuilder
Score: 143
Status: offline
 Ok so my painter said first you need to thin down your paint and do 4-6 coats, he is using a pro painting airless setup and will do 8-10 coats for aouto paints. if your using epoxy paints you cant use lacker thiner but if you are using an oil-bsse the lacker thiner mixed with paint thiner will streach the pain and eliminate the orenge peal, but for you guy going the harbor fright way you just need to thin it down and do more costs. You can't get it in one or two coats.
Fly, fly, fly!!!!
Hide Signatures
       Post #: 1069
RE: Top Flite Giant P-47 Build - 1/26/2013 2:49 PM
redbiscuits
Score: 130
Status: offline
Are you tipeing on yuor phone agin Tony?
Hide Signatures
       Post #: 1070
RE: Top Flite Giant P-47 Build - 1/26/2013 2:53 PM  1 votes
TonyBuilder
Score: 143
Status: offline
yes, my dumb phone, I will never let it fly one of my planes!
Fly, fly, fly!!!!
Hide Signatures
       Post #: 1071
RE: Top Flite Giant P-47 Build - 1/26/2013 8:20 PM  1 votes
yates55
Score: 105
Status: offline
It Looks great to me, hope mine turns out half that nice
So Gary it looks like you have servo's all hooked up and hinged did you paint over them are they protected with something?
oh yea got my joe also
yates
Hide Signatures
       Post #: 1072
RE: Top Flite Giant P-47 Build - 1/26/2013 9:24 PM
HoundDog
Score: 178
Status: offline
Remember ... Every one of these Things we fly has a Termination date, The more expensive The bigger the tears.
Hide Signatures
(in reply to yates55)
       Post #: 1073
RE: Top Flite Giant P-47 Build - 1/26/2013 10:16 PM  1 votes
SunDevilPilot
Score: 147
Status: offline
Someting is wrong with your setup.  Looks like it is throwing chunks of paint at the wing instead of atomizing it into a mist which hits the wing.
Check the manual for your paint gun, specifically the air pressure.
Also, most paint guns work best when run wide open.  Set the air to the correct pressure per the manual and needle for the nozzle wide open.
Most guns are compatable with water, fill that thing with water...  make your adjustments...  and see if it sprays it like a mist.
When the paint is atomized at the nozzle the thinner evaporates on the way to the painted surface.  Thinner, for the most part, doesnt even reach the wing when done right.
I can duplicate what I am seeing on your wing by choking down the air at the gun and running too much paint at one time.  Spits it over.  The over pressure should have corrected this but maybe it is really pulling the paint out of the gun too fast.
The mixture of 1:1:1 is fine with Klass Kote, that is what I use.
Here is my cowl painted with Klass Kote.  Paint gun, a Sata Minijet 4, has a nozzle size of 1.2.
Click for fullsize
Click for fullsize
SunDevilPilot
Cub Brotherhood # 47
Hide Signatures
(in reply to HoundDog)
       Post #: 1074
RE: Top Flite Giant P-47 Build - 1/27/2013 2:41 PM
redbiscuits
Score: 130
Status: offline
Thank you all for your advise, it really helped me out and I have it figured out. First, my gun was out of wack! not enough flow and the air was to high. Second, I completely took the gun apart and gave everything a bath. It had some gunked up primer in it and was causing problems with the flow. Live and learn right, I never claimed to be a painter.
So what have I learned, you can NEVER be too clean or too cautious when it comes to painting.
So with that figured out, this morning I got the bottom of the fuse in grey. What a relief, it went on with no problems, no orange peel and no fish eyes. Yea!!!
I'm not doing a lot of coats, I'm just trying to cover it with color. Epoxy paint doesn't flash off the solvents (other than the reducer) from what I understand. So the weight could really add up if I get carried away.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to SunDevilPilot)
       Post #: 1075
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.625RCU1
