VX Engine, in Earthquake 3.5?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> VX Engine, in Earthquake 3.5?
Page: [1]
Login
VX Engine, in Earthquake 3.5? - 7/24/2011 6:43 PM
slapohmama
Score: 100
Last Login: 8/23/2011
Status: offline
Hi All,
I bought this engine, http://www.hobbypartz.com/en18for1scni.html
Unfortunately I'm having some trouble putting it in the earthquake 3.5
If you take a look at that engine, you'll see the clutch assembly is a little different.
If I do a direct swap of the clutch drum, and flywheel- there is no room left on the threads to put a clutch nut on.
Any suggestions for making this work?
Hide Signatures
       Post #: 1
RE: VX Engine, in Earthquake 3.5? - 7/24/2011 8:07 PM
UrcHobby
Score: 100
Last Login: 3/30/2013
Status: offline
The motor you purchased has whats is called a SG Crank Shaft, Your Earthquake came with a Threaded Crank Shaft. You can make the SG crank work but you will need to get a few more items to make it work. You might want to see if you can get it swapped for the correct style (Thredded) crank shaft motor.
_____________________________
Urc Hobby Redcat Racing, HPI, Traxxas, XTM Racing, Venom, RC4WD, Integy, DDM Racing & PRP Dealer LI New York
Hide Signatures
(in reply to slapohmama)
       Post #: 2
RE: VX Engine, in Earthquake 3.5? - 8/18/2011 10:25 PM
slapohmama
Score: 100
Status: offline
Thanks for the reply. I've been quite busy so I haven't gotten around to this yet.
Unfortunately I can't swap out the engine, so I'm hoping you can advise me what parts I need? Do you have them?
Hide Signatures
       Post #: 3
RE: VX Engine, in Earthquake 3.5? - 8/19/2011 12:47 AM
jeffie8696
Score: 120
Last Login: 6/20/2013
Status: online
I am running into the same trouble installing the SH28 in an Earthquake 3.5. I think the clutch and bell from an HPI Savage might work but I am still working on it.
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
       Post #: 4
RE: VX Engine, in Earthquake 3.5? - 8/19/2011 10:21 PM
ehroof
Score: 105
Last Login: 6/6/2013
Status: offline
You need the clutch setup from either the avalanche, monsoon or hurricane, also the setup from a savage will work, the .21 that comes on the earthquake 3.5 uses a threaded crank, most .21 and larger engines use an sg crank, you will need a clutch nut to hold the flywheel on, not sure if the stock flywheel will fit the sg crank. If you get the collet (unless the engine comes with on, most do), flywheel, clutch/flywheel nut, shoes and springs, cluch bell, bearings/washer kit for the avalanche, monsoon or hurricane it will work.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to jeffie8696)
       Post #: 5
RE: VX Engine, in Earthquake 3.5? - 8/20/2011 6:57 AM
UrcHobby
Score: 100
Status: offline
If you use a SH .28 You will also need Shims for the motor mounts as the larger backing plate and pull start on the SH .28 is very big and it will not clear the chassis with out shimming.
Hide Signatures
(in reply to ehroof)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
