94141 servo connectors    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Airtronics Support Forum >> 94141 servo connectors
Page: [1]
Login
94141 servo connectors - 7/28/2011 12:33 AM
kloz
Last Login: 2/5/2013
Status: offline
I am converting to 2.4 wih a RDS8000 and an 8 channel receiver. I am trying to hook up 94141 servos but the connectors will not go into the receiver - too large. They are the non-z connectors, but I have reversed the wires and have used them with a Futaba system. What is the fix??
_____________________________
Ken
Hide Signatures
       Post #: 1
RE: 94141 servo connectors - 7/28/2011 1:42 AM
mschulz531
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: kloz
I had this problem too when I went to the RDS 8000 and the Airtronics Z connector RX's....I bought some converters that converted from the old Airtronics to the Z connector.
http://www.hobbypeople.net/index.php/airtronics-adaptor-atx-servo-older-to-z-receiver.html
< Message edited by mschulz531 -- 7/28/2011 1:43 AM >
Gold Wing Su-26m/DLE-30, Twist 60/Saito 1.15, Airtronics 2.4 Ghz SD-10G.
Hide Signatures
(in reply to kloz)
       Post #: 2
RE: 94141 servo connectors - 7/28/2011 3:31 AM
kloz
Status: offline
OK, I'm brain dead. Just got a Z connector and it fits fine. Just need to find some old A to Az adapters.
Thanks!
Ken
Hide Signatures
(in reply to mschulz531)
       Post #: 3
RE: 94141 servo connectors - 7/28/2011 3:12 PM
ToddNicholson
Last Login: 5/23/2013
Status: online
We make ATX (OLD) to Z (New) adapters (See the link provided above). Be aware though that if you changed the polarity in your old ATX connectors, you should change it back to the original ATX polarity before using these adapters. The adapters not only change the connector, but also the polarity to be compatible with the new receivers.
-Todd
Hide Signatures
(in reply to kloz)
       Post #: 4
RE: 94141 servo connectors - 7/28/2011 3:14 PM
mschulz531
Status: offline
quote:
ORIGINAL: ToddNicholson
-Todd
Todd,
Your link did not come through; please update your post; thanks, Mike
Hide Signatures
(in reply to ToddNicholson)
       Post #: 5
RE: 94141 servo connectors - 7/28/2011 7:07 PM
ToddNicholson
Status: online
Here is a link:
http://www.airtronics.net/index.php/airborne-accessories/adapters-and-leads/airtronics-adaptor-atx-servo-older-to-z-receiver.html
-Todd
Hide Signatures
       Post #: 6
RE: 94141 servo connectors - 7/28/2011 7:12 PM
mschulz531
Status: offline
Here is a link:
-Todd
Yep - that's the one I was referring to earlier; I have some of these and they work just fine.
Hide Signatures
       Post #: 7
RE: 94141 servo connectors - 7/28/2011 8:50 PM
flybyjohn
Status: online
I have had good results just using a hobby knife and shaving off the ridges on the old connectors and then putting a bevel on the top two edges of the connector, rerouting the pos. and neg. wires and they plug in just fine. Just make sure all the wires are in the right location before pluging in and don't go back to the old rx's without reversing the wires again.
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
