Jet Legend 1/10 scale F-15 C Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
F-16 1/8 Advanced - ARF
Seller:  AndyAndrews
Details:   $2,800.00   |  6/17/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Jet Legend 1/10 scale F-15 C Build Thread
Page: [1]
Login
Jet Legend 1/10 scale F-15 C Build Thread - 8/2/2011 9:46 PM
lc_eiras
Score: 100
Last Login: 12/6/2012
Status: offline
The Kit finally arrives after 4 months waiting, the box had no damage and the jet was very well packed. After inspection I decide to reinforce all the critical areas with carbon fiber and change color scheme. I will try to built as “Scale” as possible so a lot of modifications will be done.
Be patient for the photos, I’m slow builder……..
Front landing gear modification, for these parts I used 10 mm aluminum, 6mm wood, 1 servo arm and J-B Weld glue.
I had to invert the front retract mechanism so I can get space for the gear, I’m happy with this modification because in the process I discover that all the screws were unscrewed and no Loctite applied in the factory.
This is the real one, which I’m trying to match. For some reason almost all mini torches in the market are now led technology, It’s being difficult to get two to duplicate the real thing.
< Message edited by lc_eiras -- 9/4/2011 2:07 PM >
Hide Signatures
       Post #: 1
RE: Jet Legend 1/10 scale F-15 C Build Thread - 9/4/2011 2:07 PM
lc_eiras
Score: 100
Status: offline
Landing Gear Installation....
Hide Signatures
(in reply to lc_eiras)
       Post #: 2
RE: Jet Legend 1/10 scale F-15 C Build Thread - 10/18/2011 5:29 PM
TURBOMC
Score: 100
Last Login: 5/26/2013
Status: offline
Are you still building the F15 kit?  I have one and am unable to idenitfy where some of the pieces go.  Thought maybe you caold help.
Hide Signatures
       Post #: 3
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/12/2011 7:58 PM
lc_eiras
Score: 100
Status: offline
Sorry for the delay in the answer. Send me some pictures of the parts and I will try to help.
Regards
LE
Hide Signatures
(in reply to TURBOMC)
       Post #: 4
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/12/2011 8:33 PM
TURBOMC
Score: 100
Status: offline
I will take some pics tonight and send them to you.  They are mostly small parts.  Here is one set.   These 3 all came in a bag by themselves.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 5
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/13/2011 12:52 AM
TURBOMC
Score: 100
Status: offline
Here are the rest of the parts that I can't figure out placement of;  Thanks for your help.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 6
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/13/2011 2:33 AM
mun_iz
Score: 100
Last Login: 6/3/2013
Status: offline
hi,
Question regarding the installation of your main gear. In the retracted position, will the wheel protrude out from the wheel well?
For mine, with the retacts mounted flat against the retract mounts, the wheels will protrude out about 1/8". I can't raise the mounts as the retract will foul the fuel tank.
Thanks.
Hide Signatures
       Post #: 7
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/13/2011 8:57 AM
jeff sewell
Score: 100
Last Login: 6/18/2013
Status: offline
Jl add an 1/8th ply spacer usually in the retract set to raise the main retract units. If not you can make your own...
I fitted the fuel tanks next to the intakes infront of the 1st main former. This relieves the area above the retracts and frees up space for turbine ancilliaries. This has no effect on CG during flight.
Jeff
_____________________________
Exclusive UK JetLegend Dealer
Wren Turbines Dealer
Hide Signatures
(in reply to mun_iz)
       Post #: 8
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/14/2011 12:34 AM
lc_eiras
Score: 100
Status: offline
Hello mun_iz,
I understand your problem, in my airplane the left retract is ok but the right one has a 3mm difference. So in this case is not a big problem.
I detected this issue when I was working on the gear doors and the left side as a small gap between the wheel and the door, the right one is almost touching. (With the gear retracted)
We all hope that the Chinese quality issues were solved, but I can tell you one history (or two) about my top F3A planes…….
Regards
Luis
Hide Signatures
       Post #: 9
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/14/2011 12:49 AM
lc_eiras
Score: 100
Status: offline
Hello TurboMC,
I have a pdf called F-15 photo installation which I download some years ago from the Global jet centre.
I checked the web page to give you the link but it’s not there anymore.
Send me your e-mail, and I will send this pdf to you.
The majority of the parts can be used on the tail pipe, servo mounts and front tray.
Regards
Luis
Hide Signatures
       Post #: 10
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/14/2011 12:56 AM
KC36330
Score: 328
Last Login: 6/17/2013
Status: offline
the laminated blocks are for servo mounting, i do NOT recommend using them, they delaminate very easily.
quote:
ORIGINAL: mun_iz
For mine, with the retacts mounted flat against the retract mounts, the wheels will protrude out about 1/8''. I can't raise the mounts as the retract will foul the fuel tank.
Thanks.
i added shims under the back of the retract unit to lift the wheels inside the fuselage and allow the doors to fully close.
quote:
ORIGINAL: lc_eiras
here's the pdf file mentioned above.
Click to see the file in new window.Attachment.pdf
JetCat USA Rep / KingTech Turbines Rep
Hide Signatures
       Post #: 11
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/14/2011 8:48 AM
mun_iz
Score: 100
Status: offline
Hi all,
Thanks for the tips on the main gear...
KC36330: how I wish I had the pdf file when i installed my F15... would had saved myself a lot of sleep...
Hide Signatures
(in reply to KC36330)
       Post #: 12
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/14/2011 1:15 PM
TURBOMC
Score: 100
Status: offline
Thank you for the PDF.  Should help a lot.  A couple more questions.
- How far your flaps go down and how much elevator (up or down) you've dialed in to compensate for the flap deployment?
- Any special tips for flying the plane (I'm flying on grass), take off, landing, etc.
Thank you!
Hide Signatures
       Post #: 13
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/14/2011 1:44 PM
KC36330
Score: 328
Status: offline
my flaps drop 1 3/4", i use crow so the ailerons go up 1/4" and i have no pitch change at all with flap deployment.
i have a Titan SE in mine and only fly from concrete so take off is a non event most of the time, it doesn't do well in strong cross wind due to the small rudder size so expect it to drift after lift off. balanced on the center of the forward spar it takes minimum effort to rotate.
landings are almost automatic, pull power back and pull the nose up, add just enough power to control rate of decent, chop it full just before touchdown and flare. only landing issue i've had was the nose gear hanging up on the opening and not dropping out but the stabs kept the weight off the nose and it only suffered paint damage, didn't even rub though the gel coat.
here's the flight where the nose wheel hung up, it was a 10-15mph 90 deg cross wind so you can see the drift after rotating as well.
http://youtu.be/fxhHLsKXNDc
Hide Signatures
       Post #: 14
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/14/2011 2:04 PM
TURBOMC
Score: 100
Status: offline
Thank you for the info.  The info I got for the throws was 1" up/down ailerons, 1" left/right on rudder and 2" up/down on stabs.  Do those sound right to you?  BTW looking flight.   You make it look easy.
Hide Signatures
       Post #: 15
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/14/2011 2:17 PM
KC36330
Score: 328
Status: offline
those are about what i've got with the exception of the stabs, i've got 2.5" of up and down, full flying stabs take a lot of throw in hard turns and on high AOA landings.
Hide Signatures
       Post #: 16
RE: Jet Legend 1/10 scale F-15 C Build Thread - 2/10/2012 3:19 PM
TURBOMC
Score: 100
Status: offline
Hate to keep being a pest but I have  few more questions
-  can you tell me what your F15s weight was (all 3 main tanks empty, UAT full)?
-  by CG on the forward spar do you mean the forward carbon fiber dowel that mounts the wing to the plane?
-  my exhaust pipe is touching the rear recessed lip that the main hatch seats down into, I have ceramic matting covered with tin foil in that area.  Did yours do that?
Hide Signatures
       Post #: 17
RE: Jet Legend 1/10 scale F-15 C Build Thread - 2/10/2012 7:07 PM
KC36330
Score: 328
Status: offline
quote:
ORIGINAL: TURBOMC
33.4lbs.....
Yes.......
See Pic Below..
Click for fullsize
Hide Signatures
       Post #: 18
RE: Jet Legend 1/10 scale F-15 C Build Thread - 2/10/2012 7:30 PM
TURBOMC
Score: 100
Status: offline
Thank you!  You've been a ton of help.
Hide Signatures
       Post #: 19
RE: Jet Legend 1/10 scale F-15 C Build Thread - 2/10/2012 8:14 PM
KC36330
Score: 328
Status: offline
You're welcome.
Hide Signatures
       Post #: 20
RE: Jet Legend 1/10 scale F-15 C Build Thread - 2/13/2012 11:14 AM
lc_eiras
Score: 100
Status: offline
Front gear almost ready for painting.
Start working on the rudders….
The hinges (changed for Graupner hinges) are glued to the white rudder parts, but not glued to the fixed part.
The all structure is very fragile (Chinese construction……L), I’m still thinking in a way to secure the servos and I have to correct and reinforce the holes in the rudder (not align).
For servos I have two choices:
Hitec 5125 MG – 3.5 kg of torque
Graupner DES 448 BB, MG – 4.5 kg
Any thoughts/options for rudder installation.....?
Hide Signatures
       Post #: 21
RE: Jet Legend 1/10 scale F-15 C Build Thread - 2/13/2012 12:42 PM
TURBOMC
Score: 100
Status: offline
For what it's worth I used JR DS378.  It ash 4.5 kg @ 4.8v and 5.4 kg @ 6v.
http://www.horizonhobby.com/products/ds378-wing-servo-JRPS378
Hide Signatures
       Post #: 22
RE: Jet Legend 1/10 scale F-15 C Build Thread - 2/13/2012 3:26 PM
funflyerf4
Score: 100
Last Login: 6/19/2013
Status: offline
Hi Kc is the cg at the front removable spar brace?
Frank
Hide Signatures
       Post #: 23
RE: Jet Legend 1/10 scale F-15 C Build Thread - 2/13/2012 5:34 PM
KC36330
Score: 328
Status: offline
quote:
ORIGINAL: funflyerf4
Frank
No, as mentioned above, it's the center of the forward carbon tube in the wing.
Hide Signatures
(in reply to funflyerf4)
       Post #: 24
RE: Jet Legend 1/10 scale F-15 C Build Thread - 12/6/2012 12:01 AM
lc_eiras
Score: 100
Status: offline
Hello,
I need help on this ......
There are some differences between the left and right estabilizardor in the JetLegend F-15?
They are completely symmetrical and can be used on both sides?
Hide Signatures
       Post #: 25
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.889RCU1
