Total write off    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> JR Radio & Spektrum Radios >> Total write off
Page: [1]
Login
Total write off - 8/4/2011 10:14 PM
fudi50
Score: 100
Last Login: 1/12/2013
Status: offline
I have a JR 9303 with a new 2.4 modul with a new 9300 Spectrum Rx installed in a near new Ava Electric with a CAM
I had powered up to max motor height into a thermal every thing is fine. Disaster in error I turned off the Tx the Ava dove straight ddown to the ground the only parts salvagble the boom /rudder/fin/elevator Neu motor is Ok! ESC Ok! Rx case cracked.
When on the bench I believe that I have turned off the Tx and turnedd back on again with no problem. My questions is will the Tx seek the Rx and log on at altitude or not
A sad flyer
David
Hide Signatures
       Post #: 1
RE: Total write off - 8/5/2011 8:07 AM
electricpete
Score: 100
Last Login: 5/19/2013
Status: offline
why
Hide Signatures
(in reply to fudi50)
       Post #: 2
RE: Total write off - 8/5/2011 11:25 AM
P47Tbolt
Score: 110
Last Login: 5/14/2013
Status: offline
Are you saying you turned off the transmitter while flying???Why??You say it was an error.
How so?The on/off switch should never be touched while flying.
If so,why would you do that?no signal to receiver,so the aircraft will probably crash considering the
relink time.
I bet you will never do it again.you learn from your mistakes.Very hard lesson learned though
_____________________________
Today is the Tomorrow you worried
about Yesterday.
Hide Signatures
(in reply to electricpete)
       Post #: 3
RE: Total write off - 8/5/2011 1:05 PM
BuschBarber
Score: 104
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: fudi50
A sad flyer
David
I have had two JR XP9303 Tx's for 4 years. One has the Spektrum 2.4 module and one has the JR 72Mhz Synthesized RF Module. Never a problem with either.
If you get Interference and the Rx looses the signal from the Tx, the Rx goes into Failsafe and the Throttle goes to Idle until the Signal is restored. When the Signal comes back, you immediately have control. If you turn off the Tx, there is no signal to the Rx and it again goes into Failsafe, but the signal will not be restored until you turn on the Tx again.
There is no reason to turn off the Tx while flying.
If the Rx looses power or has a Brownout, there is no Failsafe.
Depending upon the Rx, you can set Failsafe to Hold all channels, except Throttle, or have each channel go to Preset conditions when a Failsafe Event happens.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 4
RE: Total write off - 8/5/2011 2:11 PM
Zeeb
Score: 111
Status: offline
Well if the OP turned off the tx, it's going to take 3 to 5 seconds for the rx to connect again when he turns the tx back on. That might be enough time to crunch the model. This was the original issue with power brownouts in that it took so long for the rx to re-connect after a power loss, this is what the Quick Connect firmware fixed.
DSMX will correct the 3 to 5 second initial connect time to almost instantly, but you loose the power brownout indication.
Zeeb
Hide Signatures
(in reply to BuschBarber)
       Post #: 5
RE: Total write off - 8/5/2011 2:12 PM
BarracudaHockey
Score: 280
Last Login: 5/17/2013
Status: offline
To the original question, if the transmitter is powered off and on it should connect instantly. There is no "relink" time with any Spektrum/JR system bought in the last couple of years but anything older I would perform a simple check to make sure you have the latest firmware.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 6
RE: Total write off - 8/5/2011 2:15 PM
Zeeb
Score: 111
Status: offline
quote:
ORIGINAL: BarracudaHockey
To the original question, if the transmitter is powered off and on it should connect instantly. There is no ''relink'' time with any Spektrum/JR system bought in the last couple of years but anything older I would perform a simple check to make sure you have the latest firmware.
Umm.... don't think so Andy....
If you turn off the DSM2 tx and then back on, it's got to scan the band and pick two frequencies and then the rx has to find the new frequencies. Takes time.
Zeeb
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 7
RE: Total write off - 8/5/2011 2:41 PM
BarracudaHockey
Score: 280
Status: offline
Oh duh! I haven't had my coffee yet! I was thinking reciever brown out.
www.JaxRC.com
Hide Signatures
(in reply to Zeeb)
       Post #: 8
RE: Total write off - 8/5/2011 5:13 PM
duworm
Score: 100
Last Login: 12/30/2012
Status: offline
Sounds like failsafe may have been with down elevator. Or, what so many do is to set it up on the bench, and then make a bunch of trim change once at the field. So far, so good. Once done trimming, YOU MUST REBIND THE AIRCRAFT to set the new falsafe.
Duworm
Hide Signatures
       Post #: 9
RE: Total write off - 8/5/2011 5:29 PM
fudi50
Score: 100
Status: offline
It would seem Zeeb is righ, about delay don't take long for a model to hit the ground.
But just to reply to the comment the Tx should never be turned off, Ok! but I am as they tell me older than dirt! and the feeling in my hands some what limited added to the link between action and mind alo limited. Na aint that bad but I do have numbness in my hands and that contributed to my error. So iff you see me flying perhaps it would be prudent to stand close to me, I will not hit me.
David AKA The Brit
Hide Signatures
(in reply to duworm)
       Post #: 10
RE: Total write off - 8/5/2011 6:23 PM
RonR214
Score: 100
Status: offline
quote:
ORIGINAL: fudi50
.,,,,,,,,,,,,, So iff you see me flying perhaps it would be prudent to stand close to me, I will not hit me.
David AKA The Brit
David, don't count on that. I have seen someone do it and it looked like it smarted.
Ron
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
