RE: CDI gr8flyer55    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Page: <<   < prev  18 19 [20] 21 22 23 24 25 26 27   next >   >>
Login
RE: CDI gr8flyer55 - 10/7/2012 11:22 PM
COM
Score: 100
Last Login: 3/13/2013
Status: offline
Thanks John. Can you ask Jake if he wold make that curve the "default curve"?
_____________________________
Regards
Charlie M.
Hide Signatures
(in reply to gr8flyer55)
       Post #: 476
RE: CDI gr8flyer55 - 10/7/2012 11:58 PM
jakestew
Score: 180
Last Login: 5/18/2013
Status: offline
Done. I should probably be incrementing the version, but I think only people from this thread are using it at the moment, so everyone should be on the same page.
-Jake
http://www.electrofunnel.com/CDI-2012/index.htm
Hide Signatures
(in reply to COM)
       Post #: 477
RE: CDI gr8flyer55 - 10/8/2012 2:13 AM
gr8flyer55
Score: 600
Last Login: 5/22/2013
Status: offline
Thanks Jake for adding my curves to the program. I've been running that engine all afternoon and found no problems with the curves or tracking. Charlie seems to have problems with running it in his engine sim. I'm wondering what would cause that. Runs fine, video was proof of that.
John
Hide Signatures
(in reply to jakestew)
       Post #: 478
RE: CDI gr8flyer55 - 10/8/2012 4:45 AM
jakestew
Score: 180
Status: offline
No problem. I'd like to have as many curves as possible to make it easier on people. They can try them two at a time until they find the best one, then tune from there.
If we need more save slots it should be no problem to add more.
The data is also in an easy format to exchange. You just copy the yellow cells from the saved curve page and they can be posted here. Anyone can then just copy and paste them back into a save slot and load them up.
The data for your curve looks like this...
0,500,1000,1400,2000,2500,3000,3500,4000,4500,5000,5500,6000,6500,7000,7500,8000,8500,9000,9500,10000,10500,11000,12000,13000,14000,15000,16000
4,4,4,5,7.5,9.5,12,14,16,18,20,22,28,28,28,28,28,27,26,26,26,25,25,24,24,24,24,24
Pretty simple to share the data this way. It's just a list of the RPM points and a list of the advance settings separated by commas.
-Jake
Hide Signatures
       Post #: 479
RE: CDI gr8flyer55 - 10/8/2012 12:08 PM
nyemi
Score: 210
Last Login: 5/21/2013
Status: offline
Hi, everyone
Sorry, but work does not leave me time.
Specifically I'm sorry you: Gompy
Printer circuit board is still experimental:docs.google.com/file/d/0BxQHqG9HPIj3bV9HZnRWbXdHUDQ/edit
I use Sprint Layout 5.0
I see Jake's success.
Congratulate him.
Great work.
If you have a little time, and then look through C code.
Now a lot of work, busy.
It is difficult for them to life.
I welcome all ignition constructor.
Large sparks. Easy-starting engines.
Good luck.
Regards nyemi.
Hide Signatures
(in reply to Gompy)
       Post #: 480
RE: CDI gr8flyer55 - 10/8/2012 12:31 PM
Gompy
Score: 460
Status: offline
quote:
ORIGINAL: gr8flyer55
Rob,
What sparkplug size does your Aprilia use? 5/8 hex or 3/4 hex? I'm building another ignition for you to try..finished the whole ignition for your homelite engine complete with plug wire and a case..just like I sell. If you'd rather I left the sparkplug cap and boot off, I can do that also, but tell me the wire length you'll need..
Hi John,
For the Aprilia I need a hour to see how long the lead must be.
The ignition and candle are behinde the airfilter and other bodywork.
It's a crime to replace the candle, you can't doit if you are on the runway.
I think / hope 10 or 15" will be enough, otherwise I replace the ignition.
For the Homy I think I have enough of normal lenght.
The flashlight.
The flashlight wil be triggert at the same time the SCR is triggert.
But why want you change it, the LED do the job very well (I think ?)
If you want a "tool" for it, put a LED into a (alu) tube, and you have a real strobe.
........or have you make a board change on the pin output of the flashlight ?
Click to see fullsize image.
Click for fullsize
CU, Rob
http://www.electronics.gompy.net
Hide Signatures
       Post #: 481
RE: CDI gr8flyer55 - 10/8/2012 12:43 PM
Gompy
Score: 460
Status: offline
Rob, I too have experimented with different ways to connect it for a good strong positive signal. This is what I am trying to figure out. We need an interface connection to directly plug in for the signal, full strength to make it bright and reliable. A cheap led flashlight is a good light source which I have tried and it works perfectly.
I have many ways to do what need but involve complicated hookups. We just need a simple, easy to use, foolproof, system that anyone can have success with. A users tool, not an experimenters nightmare.
We could make it an accessory item. That is the add-on approach which will work.
One more item we need is the direct rpm readout to accurately check rpm with respect to timing. I have my own way of doing this with an optical tach pointed at the prop. Also had worked by pointing it at the timer's led and reading it, multiplying the reading by 2 (my tach is set for a 2 blade prop- 2 interuptions per revolution). This would be fine except now with the led on the board being so dim, doesn't work at all. Maybe using the RCExl inline tach is the solution there too. Just a thought.
If you use my standalone strobelight you can simple modify it with some resistors and a capacitor to isolate the HV of the spark.
Put a simple spring between the candle and sparkcap, and isolate the !!!!! metal from crocodilclip !!!!! you can pickup the spark for 100%
Some old strobelights use this kind of pickup the spark.
http://www.electronics.gompy.net/strobelight/index.htm
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Gompy -- 10/8/2012 2:27 PM >
CU, Rob
Hide Signatures
       Post #: 482
RE: CDI gr8flyer55 - 10/8/2012 12:52 PM
Gompy
Score: 460
Status: offline
quote:
ORIGINAL: nyemi
Hi, everyone
Hi Nyemi,
I got allready the layout, but I'm missing the componentnames / types on the layout.
There are also more components on the layout the schematic will show.
The schematic is not complete or on the PCB there are to much components.
I hope you have some time to complete the schematic or PCB for me.
CU, Rob
Hide Signatures
(in reply to nyemi)
       Post #: 483
RE: CDI gr8flyer55 - 10/8/2012 4:28 PM
Gompy
Score: 460
Status: offline
Engine makes 4514 rpm with a 20x8 prop, I don't have (can get) a 16x8 prop at the moment.
I can't start the engine by hand, I need a startrope.
BTW, the tool on the picture is a TDC-tool and also a compression checker.
If you turn the prop / shaft, the pin wil be in and out if the comprssion is OK.
If you turn the prop / shaft you can also see and mark with the ring the TDC.
If the pistion goes up and down, you can read the distance and calculated back to degrees.
Nice to use if you don't want or can't use a degree disk.
The distance between TDC and UDC of my Homy is 28.41 mm
1 degree will be 28.41 / 360 = 0.07892 mm
If the ignition must be 30 degrees BTDC, the calculation wil be 0.07892 x 30 = 2.36 mm BTDC
With a caliper it's easy to do.
Click for fullsize
< Message edited by Gompy -- 10/8/2012 6:01 PM >
CU, Rob
Hide Signatures
(in reply to Gompy)
       Post #: 484
RE: CDI gr8flyer55 - 10/8/2012 8:07 PM
jakestew
Score: 180
Status: offline
I just uploaded v0.99b7 to the website.
There are no code changes, but I hid some sheets and locked some cells. Also tweaked the views a bit.
Only cells that should be edited are available to change now. I hid the 3 sheets that don't need to be messed with. Added some code to minimize the ribbon, hide the formula bar and headings.
There is no password on the file. All you have to do is go to...
- "Home -> Format -> UnProtect Sheet" to unprotect the sheet. You have to do this to each sheet you want to change.
- "Home -> Format -> Hide & Unhide -> Unhide Sheet" will let you unhide the hidden sheets.
- Ctrl-F1 will switch the ribbon between normal and auto-hide modes.
- Click "View -> Headings/Formula bar" to make headings and formula bar show back up.
AFAIK these changes will only apply to this spreadsheet and not mess with your default Excel settings. Hopefully these changes make it a little easier and less stressful to edit the settings and curves. The view changes should make it easier to see everything without extra foolery cluttering the screen. If there are any problems let me know.
You can now quickly get to all the settings by hitting the Tab key, which will take you right to each unlocked cell. I also changed the colors a little. The informational settings that are just for checking things are in a olive drab green and the actual settings that affect things are in a slightly different green color.
-Jake
< Message edited by jakestew -- 10/8/2012 8:30 PM >
Hide Signatures
(in reply to Gompy)
       Post #: 485
RE: CDI gr8flyer55 - 10/8/2012 10:37 PM
COM
Score: 100
Status: offline
Hi Jake,
Well I adjusted my hall on my engine sim and now everything looks good. I am going to test it on my engine in a day or so. I bet everything is going to work great. Thanks and Great Job.
Regards
Charlie M.
Hide Signatures
       Post #: 486
RE: CDI gr8flyer55 - 10/8/2012 11:15 PM
COM
Score: 100
Status: offline
OK I played with making a few different curves and tested everything on my engine sim. everything works spot on. Now I am ready to test the software on a engine.
Jake you really did a great job. Thank you for all the hard work .
Regards
Charlie M.
Hide Signatures
(in reply to COM)
       Post #: 487
RE: CDI gr8flyer55 - 10/9/2012 12:02 AM
Gompy
Score: 460
Status: offline
He John, I hope the US-post-office will be fast [>:]
I think I'm the last one who can test the CDI this time.
Tomorrow I can buy some secondhand smaller props, maybe the engine wil run faster with it.
To day also the propholder was turn of the engine, my hart was stopped !
Inside there is also a cracklock, a small bold, they forgot to screw it tide.
I was lucky I hear something when I spin the engine by hand otherwise the engine was damaged.
CU, Rob
Hide Signatures
(in reply to COM)
       Post #: 488
RE: CDI gr8flyer55 - 10/9/2012 2:32 AM
jakestew
Score: 180
Status: offline
I updated the spreadsheet to fix the toggle problem with the ribbon. Before it was just toggling the ribbon minimize feature. Now it checks and only minimizes the ribbon if it is actually displayed.
Also made save and load update the preview curve chart. Code is the same, so no version increment.
I'll be busy until Wed, but post if there are any problems.
-Jake
Hide Signatures
(in reply to Gompy)
       Post #: 489
RE: CDI gr8flyer55 - 10/9/2012 1:58 PM
Gompy
Score: 460
Status: offline
Nothing todo , waiting for US-post
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Gompy -- 10/9/2012 5:02 PM >
CU, Rob
Hide Signatures
       Post #: 490
RE: CDI gr8flyer55 - 10/9/2012 11:02 PM
Gompy
Score: 460
Status: offline
John, can you test the changes I have make ?
The PIC is now protected agains flashback spikes from the HV coil / parts.
The PIC is now operated on 5 Volt.
The capacitor for the sparkcoil will be loaded faster with the extra diode, otherwise it has to load true the resistant of th sparkcoil.
Click for fullsize
CU, Rob
Hide Signatures
(in reply to Gompy)
       Post #: 491
RE: CDI gr8flyer55 - 10/10/2012 7:12 AM
iura
Score: 100
Last Login: 11/26/2012
Status: offline
5v maybe not so good for HV converter(current too much). I think better 8.2v (2 LiPo) and use 5v LM for PIC. And from my experience flyback converter better scheme for charging HV capacitor instead of self oscillator one.
BR Iura
Hide Signatures
(in reply to Gompy)
       Post #: 492
RE: CDI gr8flyer55 - 10/10/2012 7:59 AM
Gompy
Score: 460
Status: offline
Thats the first thing I want to know, how much current consum the CDI.
For my bike it isn't a problem, the generator will load the batteries.
Batteries into a plane don't have a generator for backup, empty is empty.
If the tank is full but the batteries are empty, we missing some point.
But befor I'll rebuild something else I want to know the specs from the board John haven make.
I think to build for test the schematic below, all factories are usuing this kind of schematics.
For John, is this the flashlight / strobe you are loooking for ?
BTW, If you want to use it, Jake have to change the program to get a extra LED-input to send a puls to the LED output.
Changing the C into this schematic will also change the lenght of the puls.
Click for fullsize
Click for fullsize
Click for fullsize
CU, Rob
Hide Signatures
(in reply to iura)
       Post #: 493
RE: CDI gr8flyer55 - 10/11/2012 4:47 PM
COM
Score: 100
Status: offline
Jake is there any way to change the input from falling edge to rising edge?
Regards
Charlie M.
Hide Signatures
(in reply to Gompy)
       Post #: 494
RE: CDI gr8flyer55 - 10/11/2012 7:31 PM
gr8flyer55
Score: 600
Status: offline
Charlie, check your email. I sent you the lines to edit to make the change.
John
Hide Signatures
(in reply to COM)
       Post #: 495
RE: CDI gr8flyer55 - 10/11/2012 7:45 PM
Gompy
Score: 460
Status: offline
Charlie, put the engine in reverse
CU, Rob
Hide Signatures
       Post #: 496
RE: CDI gr8flyer55 - 10/11/2012 9:05 PM
jakestew
Score: 180
Status: offline
quote:
ORIGINAL: jakestew
If you want to change this then change...
OPTION_REG = 0b00000000; // pullups on, falling edge, Tmr0
to
OPTION_REG = 0b01000000; // pullups on, rising edge, Tmr0
Also change...
else if(INTCONbits.INTF){  // ***** GP2 SENSOR INPUT *****
        if(GPIObits.GP2 == 0){
to
        if(GPIObits.GP2 == 1){
Remember that the hall switch is active low, so falling edge = magnet approaching and rising edge = magnet leaving.
I'm not sure why people want to trigger as the magnet leaves the sensor. When the magnet triggers the sensor we know the RPM and the position, that's all we need to know to calculate the delay before firing the spark.
The only thing I can see this change doing is wasting a couple degrees worth of time. If you want to use your existing sensor placement without moving anything it's easy enough to just change the Hall degree setting in the spreadsheet.
It's also not difficult to change the code if you want to trigger with the magnet leaving the sensor. If people really want the option I can write a setting to change this into the code.
The only problem is that in order to keep the timing the same I need to compile in as many variable options as I can, so I use defines to do this and the preprocessor figures out some of the settings at compile time. Because of this, I can't make the spreadsheet produce the hex for some settings because they're compiled in. I want to avoid making the spreadsheet too large and complicated because I have to change and test it for every code revision. Adding multiple hex files and code changing options is sure to result in more work, more errors, or probably both.
I just need to know what the reasoning is behind passing up the first opportunity (magnet triggering the hall) to time the spark in favor of the 2nd opportunity (magnet leaving hall)? It just doesn't seem to make sense to me.
-Jake
Hide Signatures
(in reply to COM)
       Post #: 497
RE: CDI gr8flyer55 - 10/11/2012 10:03 PM
Gompy
Score: 460
Status: offline
It's for safety, you know when the magnet leave the hallsensor.
You don't know and not want a puls if a magneticfeeld activate the hallsensor.
It (have to) act like a set / reset funtion.
The magnet activate the sensor, set ready ignition, leave hallsensor is ignition.
CU, Rob
Hide Signatures
       Post #: 498
RE: CDI gr8flyer55 - 10/11/2012 10:49 PM
COM
Score: 100
Status: offline
Hi Jake For Me its a matter of personal preference. The commercial units work this way. Its not a big deal.
Regards
Charlie M.
Hide Signatures
(in reply to Gompy)
       Post #: 499
RE: CDI gr8flyer55 - 10/11/2012 11:06 PM
Gompy
Score: 460
Status: offline
Be carfull Charlie, if the prop flips back you get also a spark, even if the prop don't goes true the TDC and the engine can be run reverse !
CU, Rob
Hide Signatures
(in reply to COM)
       Post #: 500
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.547RCU1
