RE: CDI gr8flyer55    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Page: <<   < prev  19 20 [21] 22 23 24 25 26 27 28   next >   >>
Login
RE: CDI gr8flyer55 - 10/12/2012 11:03 AM
COM
Score: 100
Last Login: 3/13/2013
Status: offline
quote:
The commercial units work this way
Well Not exactly. Looking with a scope at a few different boards what happens is at startup the pic is triggered at the rising edge if the input. at about 4 or 500 rpm the pic is then triggered at the falling edge of the input. I am not quite sure how this is done, but it works very well.
_____________________________
Regards
Charlie M.
Hide Signatures
(in reply to Gompy)
       Post #: 501
RE: CDI gr8flyer55 - 10/12/2012 2:40 PM
nyemi
Score: 210
Last Login: 6/17/2013
Status: offline
quote:
ORIGINAL: COM
Hi COM
Yes!
High-speed fixed-time of the algorithm.
The rising edge, falling edge time lapse between.
Ignition RCexl me this was my experience.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Regards nyemi.
Hide Signatures
(in reply to COM)
       Post #: 502
RE: CDI gr8flyer55 - 10/12/2012 4:16 PM
jakestew
Score: 180
Last Login: 6/4/2013
Status: offline
I don't think we can count on the magnet leaving as being a safety feature.
If a stray magnet goes by it will trigger the spark no matter what we do. Rising edge, falling edge, or even both will end up with the same effect. The only way to prevent accidental firing would be measuring the length of the activation and only firing if it fell within the proper range.
I don't think even that would work because transient magnetic fields would still set it off since they would likely be very short and fall within the timing range. If I can figure how to make the unit safer I certainly will. With the new 1840 chip we'll have the processing power to make more measurements and handle things in a smarter way.
-Jake
http://www.electrofunnel.com/CDI-2012/index.htm
Hide Signatures
(in reply to Gompy)
       Post #: 503
RE: CDI gr8flyer55 - 10/12/2012 8:44 PM
jakestew
Score: 180
Status: offline
I just posted Eagle schematics of the timer board and HV board to the website. There's no board files yet, I haven't laid anything out for the board files.
I went straight from the pictures when punching this in. The only thing I changed was organizing the connectors. +5V should always be in the center, GND on one side, and signal on the other.
-Jake
Hide Signatures
(in reply to jakestew)
       Post #: 504
RE: CDI gr8flyer55 - 10/13/2012 6:13 AM
gr8flyer55
Score: 600
Last Login: 6/19/2013
Status: offline
Jake,I'm trying to post a revision of the CDI HV board schematic which should be used in the kit version. It's a revision of what Nyemi posted from RCCDI RC Ignition. I think it finally worked. I built 10 more today, tested and all spark great. I also tested the kill feature on the timer board with a servo operated switch, no RFI interferrence, even using an old 72 MHz. radio ! I used the throttle servo with a micro lever switch, and worked perfect.
Rob, this is the circuit you'll be building and testing with the rest of us. I included a few of the kits in your box.
Seems Murphy's law prevails! Got ahead of myself yesterday and uploaded a picture before I checked it out! Disregard the photo on the left! Use the one on the right which has an added resistor, 680 ohm to the signal coupling to the SCR. Sorry to confuse everyone again..Maybe this one is correct. Let me know if I made any errors, since we want this to be what we are all going to be using.
John
Click for fullsize
Click for fullsize
< Message edited by gr8flyer55 -- 10/13/2012 6:36 PM >
Hide Signatures
       Post #: 505
RE: CDI gr8flyer55 - 10/13/2012 3:07 PM
COM
Score: 100
Status: offline
OK I did some testing on my engine and I see some things that I think need fixing. I have (in the spreadsheet) the multi spark turned off or at least set to 1 spark. I still multiple sparks at startup. I notice also that if the magnet stops at the hall sensor I get a continuous spark until I move the magnet off the HES. That could really hurt someone. The spark needs to be a one shot deal. Anyway these are just some things I have seen and I am just trying to help.
Regards
Charlie M.
Hide Signatures
(in reply to gr8flyer55)
       Post #: 506
RE: CDI gr8flyer55 - 10/13/2012 3:42 PM
gr8flyer55
Score: 600
Status: offline
Mine also started doing this same thing but still runs the engine fine.
John
Hide Signatures
(in reply to COM)
       Post #: 507
RE: CDI gr8flyer55 - 10/13/2012 6:50 PM
gr8flyer55
Score: 600
Status: offline
Charlie, I have the multispark feature enabled and it still does a steady fire at the plug, but not every time! Getting stuck in the loop somewhere when it recieves a signal to fire, definitly needs fixing!! It does a nice ignition spark test though! LOL
John
Hide Signatures
(in reply to COM)
       Post #: 508
RE: CDI gr8flyer55 - 10/13/2012 7:20 PM
Gompy
Score: 460
Last Login: 6/16/2013
Status: offline
Try it with the diode I drawing.
I think the SCR isn't closed after firing.
I'm also missing the SCR protection, 22nF/ 600V and 22R/0.5W
BTW, the Bosch schematic is only for inspiration.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Gompy -- 10/13/2012 8:57 PM >
CU, Rob
http://www.electronics.gompy.net
Hide Signatures
       Post #: 509
RE: CDI gr8flyer55 - 10/13/2012 9:12 PM
COM
Score: 100
Status: offline
Hello Everyone,
I am not sure who has tested the software on a actual engine, but I made some adjustments to mine and the software works super. Other then the constant sparking when the magnet is on the HES everything else perfect. Good Job Jake.
Regards
Charlie M.
Hide Signatures
(in reply to Gompy)
       Post #: 510
RE: CDI gr8flyer55 - 10/13/2012 9:18 PM
Gompy
Score: 460
Status: offline
And now you have all stop to with testing untill I can test too [>:] !!
CU, Rob
Hide Signatures
(in reply to COM)
       Post #: 511
RE: CDI gr8flyer55 - 10/13/2012 9:20 PM
gr8flyer55
Score: 600
Status: offline
Just as a test, I let it continue firing for about 15 seconds to see what damage it would do, well it heated up the transistor on the HV board and destroyed it!
This bug needs to be fixed for sure now. can't have things being destroyed that were working perfectly before.
John
Hide Signatures
(in reply to Gompy)
       Post #: 512
RE: CDI gr8flyer55 - 10/14/2012 12:10 AM
gr8flyer55
Score: 600
Status: offline
Rob, I hope you get your box soon! It should be going thru customs right now. Lots of good stuff in the box. I can't wait till you see everything I sent.
John
Hide Signatures
(in reply to Gompy)
       Post #: 513
RE: CDI gr8flyer55 - 10/14/2012 12:28 AM
Gompy
Score: 460
Status: offline
The Homy is ready for it, the garden not.....I missing a roof and it will be winter now.
I hope my son wil help me to welding the frame, it's also a winterplace for his (and mine) bike.
I buy a new prop 16x6 and the Homy is run now ~6000 rpm (28ccm)
For now I need a startrope, I hope it's over with the new CDI.
BTW, can / wil you test the CDI with the diode who I draw into the schematic ?
I think the SCR didn't close and open again if the voltage is enough to create a new spark.
A SCR is only closed if the Voltage is going true zero, reverse the HV-coil wil do this normaly.
The flaslight with xenontube is allmost ready, I just damage my last SCR.....broken lead.
Monday I can buy a new one and can test with my electronic engine ignition tetser
CU, Rob
Hide Signatures
       Post #: 514
RE: CDI gr8flyer55 - 10/14/2012 2:28 AM
bluejets
Score: 205
Last Login: 4/15/2013
Status: offline
quote:
ORIGINAL: COM
A small cap in the hall signal before the R1,R3 junction should give you just one pulse.
Hide Signatures
(in reply to COM)
       Post #: 515
RE: CDI gr8flyer55 - 10/14/2012 3:04 AM
gr8flyer55
Score: 600
Status: offline
Rob, just tried your 3 added parts and it still does the continous sparking. It's coming from the pic in the software.
Jeff, also tried the small cap at that juncton, also a no go. So it is in the software. Stuck somewhere in a loop until it sees a change of the hall signal because if you move the magnet away from the sensor, it then stops. Somewhere in that control loop lies the problem.
I replaced the burned out transistor and all is well with the HV board again. Ran the engine and it's fine. Just can't stop the magnet under the sensor or you get a buzz of sparks and the transistor heats up cause it is supplying too much current to the oscillator circuit.
Somewhere there's a problem with it, Maybe Jake can find it.
John
Hide Signatures
(in reply to Gompy)
       Post #: 516
RE: CDI gr8flyer55 - 10/14/2012 3:11 AM
bluejets
Score: 205
Status: offline
I meant for you to place the cap in series with the incoming hall signal between there and the R1,R3 junction, not from junction to ground.
Hide Signatures
       Post #: 517
RE: CDI gr8flyer55 - 10/14/2012 3:22 AM
gr8flyer55
Score: 600
Status: offline
Jeff, I placed it inline and same thing, so it is getting a signal to fire multiple times until you remove the magnet and that stops the signal.. What a mess, thought we had it nailed, otherwise it works great as Charlie said. Both switches work fine, good starting and handling characteristics otherwise. One last glitch...
John
Hide Signatures
(in reply to bluejets)
       Post #: 518
RE: CDI gr8flyer55 - 10/14/2012 3:55 AM
bluejets
Score: 205
Status: offline
mmm...ok...just sent you an email with a mod for the input you can try. Should give you one, and only one , pulse as the magnet approaches the hall switch.
If it works like I think it should, I'll poke it in here.
Hide Signatures
       Post #: 519
RE: CDI gr8flyer55 - 10/14/2012 4:36 AM
gr8flyer55
Score: 600
Status: offline
Looks like it may work as a debounce circuit Jeff.
Will try in the morning and let you know. Going to play the slots tomorrow morning and hope to win something....never know.
John
Hide Signatures
       Post #: 520
RE: CDI gr8flyer55 - 10/14/2012 5:38 AM
bluejets
Score: 205
Status: offline
The way it works is, the cap normally has both ends at positive rail. When hall switch turns on, it pulls the one end of the cap to ground.
It gives a negative going pulse at R1,R3 junction as the cap begins it's charge, and then after tou time, the pulse at R1,R3 junction goes high.
It will stay in this state until another high to low transition of the hall switch.
Just have to select correct values of RC so that it doesn't interfere with other timing in the system. i.e. with 0.01uF and 4K7 should give approx. 32uSec.(if I'm not mistaken)
Hide Signatures
       Post #: 521
RE: CDI gr8flyer55 - 10/14/2012 6:44 AM
nyemi
Score: 210
Status: offline
Hi bluejets
I called Jake's attention.
  The bounce-free input.
This Software can be solved.
The hardware is not bad.
But not enough.
Find a good solution.
link:www.labbookpages.co.uk/electronics/debounce.html
I checked, Jake Code.
I'm curious. Jake, that solved the problem.
I compiled ASM.
I see everything.
< Message edited by nyemi -- 10/14/2012 7:15 AM >
Regards nyemi.
Hide Signatures
       Post #: 522
RE: CDI gr8flyer55 - 10/14/2012 7:59 AM
bluejets
Score: 205
Status: offline
Nyemi,
this is the change I sent to John to try out. It may need changing the new values to smaller sizes to change the pulse time though. in principle it should work.
Click for fullsize
Hide Signatures
(in reply to nyemi)
       Post #: 523
RE: CDI gr8flyer55 - 10/14/2012 8:33 AM
nyemi
Score: 210
Status: offline
Hi bluejets
Yes, the circuit is good.
Part solves the problem.
But this is not causing the problem.
The software does not turn off, the input pin (GP2) of the interrupt.
When the pin (GP2) of the signal is displayed.
I do not know. Jake, why do not you use IOC register (INTERRUPT-ON-CHANGE GPIO REGISTER).
The opportunity exists to separate interrupt handling pins.
I'm sorry. I now see GP4-5 pin interrupt is not used.
It seems to me that in this case the register INTCON, INTE bit is enough to delete it.
The task is waiting for him.
I was debugging and testing.
< Message edited by nyemi -- 10/14/2012 11:17 AM >
Regards nyemi.
Hide Signatures
       Post #: 524
RE: CDI gr8flyer55 - 10/14/2012 10:36 AM
COM
Score: 100
Status: offline
Jake this is why the pic needs to fire at start up( at least) on the low to high transition.After 500 rpm then you can have the pic trigger at the high to low transition. Then if the magnet stops on the HES it won't continuously fire the spark plug. No extra parts are needed for the HV board. the 680 resistor, .1 cap and the 220 resistor the way they are setup are designed are for a one- shot signal to the gate of the scr. the issue is in the software.
Regards
Charlie M.
Hide Signatures
(in reply to nyemi)
       Post #: 525
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.391RCU1
