RE: CDI gr8flyer55    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Page: <<   < prev  34 35 [36] 37 38 39 40 41 42 43   next >   >>
Login
RE: CDI gr8flyer55 - 11/24/2012 11:06 AM
jpanhalt
Score: 115
Last Login: 5/9/2013
Status: offline
quote:
Rob and I have been talking about how best to do the switches. I'd like for the kill switch to work (kill the engine) both if the switch comes loose OR if the wires short out. If anyone knows a good way to do this feel free to chime in!
One way might be to put a signal on the switch circuit, say 10 KHz. Watch transitions. If transitions are not seen for 200 uS (or whatever period you chose), kill the ignition.
John
Hide Signatures
(in reply to jakestew)
       Post #: 876
RE: CDI gr8flyer55 - 11/24/2012 11:18 AM  1 votes
Gompy
Score: 460
Last Login: 5/18/2013
Status: offline
@Jake
With a resistant to ground and a jumper (killswitch) to power you can tackel few problems.
If the killswitch input have broken leads, the input will be allways low
The killswitch input will be low if batterie fails (low Voltage - PIC still working)
If I don't want some one start the engine I remove the jumper of the killswitch.
You can test the complete RC-model with batterie on and killswitch removed.
Most safetyswitches from store, like lost RC, are working with switches / signals to ground.
Thats why I want the killswitch input with a resistant to ground and a jumper to hold him high.
So high is no problem and low is shut off or kill PIC output.
The internal pullup resistants are to weak to hold the input stable high.
Disable them into the PIC and use the external resistants.
BTW1, disable the resistants will also open the way for other applications (see above).
BTW2, if people use two b atterie packs, much safer, and the batterie pack of the radiocontrol failed the CDI will still running !!!
The killswitch like it is now hold the killswitch input high with the internal pullup resistats.
If we all agree with this changes and the changes are made, I will draw and publish the schematic and PCB.
The timerboard get a optocoupler into the output to the HV-board protect the timerboard.
I publish at the same time the schematics and the PCB so there can't be a discussion about wat kind of soft- or hardware there will be used.
@Nyemi
I use a cascade, doubler, after the transformer.
The transformer is wind 1:40, with 4V8 the Voltage from teh transformer is far to low.
I have still test how much power the transformers can make, this is only a "is it work test"
I use both schematics you show and both work good, but I like the ZVS for the LC ocsilator (no heat)
Now I have to find out the components I want to use, they must be small but reable.
I want to know witch timerboard we gone use A or B ?
< Message edited by Gompy -- 11/24/2012 1:47 PM >
_____________________________
CU, Rob
http://www.electronics.gompy.net
Hide Signatures
       Post #: 877
RE: CDI gr8flyer55 - 11/24/2012 1:48 PM
Gompy
Score: 460
Status: offline
Gompy want - B
CU, Rob
Hide Signatures
(in reply to Gompy)
       Post #: 878
RE: CDI gr8flyer55 - 11/24/2012 8:42 PM
jakestew
Score: 180
Status: offline
B looks like the switch lines are pulled low. I think it will be better to pull them high, and that's how it's done right now so there's less change.
http://www.electrofunnel.com/CDI-2012/index.htm
Hide Signatures
(in reply to Gompy)
       Post #: 879
RE: CDI gr8flyer55 - 11/24/2012 9:17 PM  1 votes
Gompy
Score: 460
Status: offline
If you use the internal resistors, you pull the inputs high with a very high value resistor.
This is a problem if you want to kill fals pulses / dirt on the input.
With the external resistors to ground you pull them standaard low and make them hard high.
If you forget a jumper for the table, table one is allways activate.
If the wire is broken or the Voltage is low, table one is allways activate......the most important table.
If you forget a jumper for the killswitch, you never get the engine start.
If the wire is broken or low batterie, the killswitch will allways be activate by it selfs, it will be pull hard to ground.
If schematic A will be used and the broken lead connect to the engine, most likely with heat, the switch don't do anything.
If this happen in schematic B, first you get low batterie if the plus is connectect to ground but also the input will be pull low.
In both situations the CDI switch off.
With a two batteriepacks you connect the minus together and the plus of batteriepack two to the killswitch input.
If for some reason the lead will broken between batteriepack two and the (killswitch) input, the CDI stop.
Same with the batterie low or lost model, the modules are all switch to ground.
Simple low batterie controle, relais connected between + and -, if the Voltage fails, the relais switch allways off.
If some one want to use the killswitch for something else, he have first to switch off the internal resistors.......but he don't know nothing about programming and anything about electronics.
With some luck he blowup only the pullup resistor, but I think he blowup the complete PIC.
CU, Rob
Hide Signatures
       Post #: 880
RE: CDI gr8flyer55 - 11/24/2012 11:42 PM
bluejets
Score: 205
Last Login: 4/15/2013
Status: offline
Jake,
Is it possible to look at the kill switch input as a mid point voltage. i.e. if there were say 2 x 4K7 in series across the supply and let the program look at the mid-point. That way if someone wanted to use a low kill or a high kill or if the wires came off the switch or something shorted out, basically anything other than mid-point voltage, then ignition would be killed.
It can be done in other pic such as picaxe but not sure about in C.
Hide Signatures
(in reply to Gompy)
       Post #: 881
RE: CDI gr8flyer55 - 11/24/2012 11:52 PM
jpanhalt
Score: 115
Status: offline
That was one of my thoughts too, but it cannot be done with a simple comparator, absent a lot of hysteresis. If you add in an ADC, then you may end up changing a lot of things.
John
Hide Signatures
(in reply to bluejets)
       Post #: 882
RE: CDI gr8flyer55 - 11/25/2012 12:57 AM
Gompy
Score: 460
Status: offline
If there is in the connection not a real hard high or low, the input will see anything you like with something in the middle.
< Message edited by Gompy -- 11/25/2012 9:19 PM >
CU, Rob
Hide Signatures
(in reply to jpanhalt)
       Post #: 883
RE: CDI gr8flyer55 - 11/25/2012 6:50 AM
jakestew
Score: 180
Status: offline
Rob makes a good point... if low = run then if the switch or wires short out it will be stuck on. So design B seems like the best choice.
Sure, we could use the AD converter to sample the voltage. That way only the proper voltage will work and either high or low will kill the engine.
The AD converter can sample from pins 3,5,6,or 7. Looks like it would be no problem to pull samples pretty much as fast as we want.
I guess it's just a question of how much work the kill switch is worth. I'm up for doing the programming if it's something that sounds worthwhile.
The only problem I see is what to do if someone doesn't want to use the kill switch at all. They'd have to jumper it with a resistor I guess.
-Jake
Hide Signatures
(in reply to Gompy)
       Post #: 884
RE: CDI gr8flyer55 - 11/25/2012 9:13 AM  1 votes
nyemi
Score: 210
Last Login: 5/21/2013
Status: offline
Hi Rob
I will help you calculate secondary circuit capacitor.(C2-main Cap)
You, the main capacitor, what do you use (1uF-680nF-470nF/400V)?
I used a transformer, power.
See the picture.
(EE20-N27
material-air gap=0,09)=26W
The document is EPCOS.
FET push - pull inverter. Best choice: N87 ferrite material.
Hungary is not available.(EE20/10/6)
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by nyemi -- 11/26/2012 6:28 PM >
Regards nyemi.
Hide Signatures
(in reply to Gompy)
       Post #: 885
RE: CDI gr8flyer55 - 11/25/2012 1:41 PM  1 votes
Gompy
Score: 460
Status: offline
It's a example, but this will be board B (34x27mm).
500 - Internal server error.
There is a problem with the resource you are looking for, and it cannot be displayed.
< Message edited by Gompy -- 11/25/2012 9:09 PM >
CU, Rob
Hide Signatures
(in reply to nyemi)
       Post #: 886
RE: CDI gr8flyer55 - 11/25/2012 2:34 PM  1 votes
gr8flyer55
Score: 600
Last Login: 5/20/2013
Status: offline
I will etch both A and B versions today. When the software is finalized, I will be ready to test them.
Both boards are similar in size so that is good. When the HV board is ready, I can do an aluminum box pattern to put both inside for a small case size with everything inside it. Only external wiring and switches to be added of your choice.
John
Hide Signatures
(in reply to Gompy)
       Post #: 887
RE: CDI gr8flyer55 - 11/25/2012 4:59 PM  1 votes
Gompy
Score: 460
Status: offline
If we choose of version B, Jack have make the following changes.
If jumper is on killswitchjumper set - killswitch is not active
If jumper is on tablejumper set - table one is active
I don't know the jumper function on pin 4 - maybe can be used for low batterie detection ?
This can be the second batterie pack detectiopn of the receiver if used.
If high no problem, if low.......LED flash at pin 7 ?
@Nyemi, this week I will buy a 4K7 / 10W resistant to test the power of the HV-board.
I use a 470nF/400V capacitor for the moment, but everything can changed.
I try to use the 4V7 diode between Gate and Source, but the HV stop working
Also if I use the IRL540 FET, maybe need small FETs and not MTPE3055V (?)
BTW1, I have to add the schematics on my own server, RCuniverse picture server is down.
If the server is up again I'll upload anything to the RCuniverse server.
BTW2, I was forgotten to draw the 78L05 on the timerboard and into the schematic.
< Message edited by Gompy -- 11/25/2012 9:31 PM >
CU, Rob
Hide Signatures
(in reply to gr8flyer55)
       Post #: 888
RE: CDI gr8flyer55 - 11/25/2012 11:02 PM
bluejets
Score: 205
Status: offline
Rob,
Do you realise your output to the "signal output" is now reversed from the original..??
I did drawings to show what I mean but the site is having some internal error apparently.
( 2 drawings, jpg. about 160kb each...)
Hide Signatures
(in reply to Gompy)
       Post #: 889
RE: CDI gr8flyer55 - 11/25/2012 11:21 PM  1 votes
Gompy
Score: 460
Status: offline
I know, but thats how the inputs works normaly.
I was working in the automation and if there was a broken lead the inputs will pull low.
Why, there no power anymore and with pull high you need power.
It's also for safety, you have to place the junpers / hold the switches if you want to start the engine.
In trains, planes aso, there are switches into the seats, if the pilot leave the seat you make a short circuit to ground.
We use low Voltage, but IRL the Voltage can be high enough to kill, thats also a reason why to make a short circuit to ground.
Most simple killswitch will be a relais, relais is connected between power and ground and use a NC to kill the circuit.
No power relais quit, NC contact make short circuit........all safety circuit work like this principal.
I want to know, can the left circuit work with low batterie ?
CU, Rob
Hide Signatures
       Post #: 890
RE: CDI gr8flyer55 - 11/25/2012 11:23 PM  1 votes
jakestew
Score: 180
Status: offline
Now that I think about it more, I favor design B for the switch setup.
A couple changes will make this timer board better suited for future features though. Here are some changes I'd like to see...
- Jumpers use 3-pin connector for Jmp1,2,3 (Gnd, Signal, +5v)
This will give more flexibility if we want to change things up. Just make the pattern for this. You don't have to actually drill the hole or put in all three pins, but it will be useful later if needed. Leaving this space will also make sure that people using three pin connectors will have the space to plug them in.
- I don't think we need LED2. I have planned to make more LED modes for the next release. I will make the processor switch the LED according to the hall sensor when the engine is not running. Maybe LED2 can be a power LED instead? That would have saved me a couple drained batteries already!
- I don't think we need T1 on LED1. The PIC can source or sink 25mA from any GPIO pin. There is a total limit of 90mA for GPIO. So we should be able to drive 3 LEDs at 25mA (=75mA) safely. You'll have to check the current draw on the HV output transistor and make sure the LEDs are limited to under 25mA.
- It would be nice to have a jumper/header for connection to a timing light or flash bulb. No need to worry about the actual flash circuit yet, but having the connector will make it easy in the future.
- Pin 4 is input only, and I'd like to keep the hall sensor on pin 5. Otherwise anything can be moved around. Feel free to move things around if it makes things easier to lay out.
- I'd like to put the kill switch on Pin 4.
- I'd like the table switch on Pin 2. (This is also the RX pin)
- I'd like a 3-pin connector for serial comms. on pins 2+3. (GND,RX,TX)(GND,Pin2,Pin3) There should be a ~2k resistor in line with the TX,RX lines for protection (optional). This way I figure the PIC can always send data on the TX pin and if we want to use the serial RX we can just open the table switch. If the serial is hooked up we can use that to control the table setting.
- I'd like an ICP header on the board for programming. My PIC pins are about to start breaking off from swapping them around so much.
You can find details about the ICP header connections here...
http://www.piccircuit.com/shop/pic-code/120-diagram-01-icsp-wiring-pic-series.html
And look at this schematic...
- I'd like to see some filtering and protection on the hall sensor input.
I read this page, which seems to have pretty good info on this sort of stuff.
http://www.digikey.com/us/en/techzone/microcontroller/resources/articles/protecting-inputs-in-digital-electronics.html
Signal coming from long wires showing ringing...
Filtering circuit...
Filtered input...
I think if we make these changes we will have the best board possible for our PICs. I'll be etching some boards for another project hopefully sometime this week. If we figure out the best design I'll make some of these boards for testing. Everybody needs to look over these designs and double check all the values and circuits! If we can get it right this v2.0 board design should last us a good long time.
-Jake
Hide Signatures
(in reply to Gompy)
       Post #: 891
RE: CDI gr8flyer55 - 11/25/2012 11:42 PM
bluejets
Score: 205
Status: offline
Rob, you quote" I know, but thats how the inputs works normaly."
The 2 diagrams have the output to the signal output reversed. How can both be correct..??
Hide Signatures
       Post #: 892
RE: CDI gr8flyer55 - 11/25/2012 11:46 PM  1 votes
bluejets
Score: 205
Status: offline
Jake,
I think if you look back a couple of weeks, that filter arrangement was what I suggested back then but everyone said correct with software.
I was of the opinion that the micro should get what it is expecting to see.
Hide Signatures
       Post #: 893
RE: CDI gr8flyer55 - 11/25/2012 11:51 PM  1 votes
Gompy
Score: 460
Status: offline
LED 1 will be the timinglight.
LED 2 will be the degree LED and check the hallsensor.
On the PCB there are pins to plug-in the LED's.
If you can see there are allready 3 LED's into the schematic, LED 1, LED 2 and OPTO 1.
Pull LED 1 or 2 or both if you don't use them, they are on pins.
Plug a rotationmeter to the LED-place and you can see how fast your engine run.
The killswitch can't be used if you want to use pin 2 and 3 for communication.
Jumper 2 and 3 are allready on the PCB, so communication is possible to use the jumperplaces.
Move the table switch to pin 4, jumper is allready be avalible.
Changing the otherside of the PIC pin 5, 6, 7 and 8 is allmost impossible without making a complete new PCB-designe.
But there are two designes feel free to use A or B.
You have also thinking about the size of the board, we use normal size components.
Using on my bike it's no problem, but putt the same size into a model airplane can be a problem.
CU, Rob
Hide Signatures
       Post #: 894
RE: CDI gr8flyer55 - 11/25/2012 11:58 PM
Gompy
Score: 460
Status: offline
quote:
ORIGINAL: bluejets
Rob, you quote'' I know, but thats how the inputs works normaly.''
I'm confused.......wat diagram you mean......the low batterie schematics ?
CU, Rob
Hide Signatures
       Post #: 895
RE: CDI gr8flyer55 - 11/26/2012 12:17 AM  1 votes
Gompy
Score: 460
Status: offline
Why do you not use clips ?
And with his bigger brother
CU, Rob
Hide Signatures
(in reply to Gompy)
       Post #: 896
RE: CDI gr8flyer55 - 11/26/2012 8:11 AM
bluejets
Score: 205
Status: offline
I cannot post diagrams to show you because the site keeps saying 500...internal server error
Anyone know what that means..??
Hide Signatures
(in reply to Gompy)
       Post #: 897
RE: CDI gr8flyer55 - 11/26/2012 10:22 AM
w8ye
Score: 318
Status: online
There is a problem and the Internet Brands IT guys have been notified by Nathan about THE PROBLEM.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 898
RE: CDI gr8flyer55 - 11/26/2012 5:43 PM
Gompy
Score: 460
Status: offline
Email the schematics I will put them on my own server.
CU, Rob
Hide Signatures
(in reply to w8ye)
       Post #: 899
RE: CDI gr8flyer55 - 11/26/2012 6:26 PM  1 votes
nyemi
Score: 210
Status: offline
Sorry.
I delete my posts.
< Message edited by nyemi -- 11/27/2012 7:14 PM >
Regards nyemi.
Hide Signatures
(in reply to Gompy)
       Post #: 900
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
