RE: CDI gr8flyer55    Gallery
Logged in as Guest
    Search This Thread
Printable Version
O.S. Engines O.S. FT-300 Twin
Seller:  thunderbolt-RCU
Details:   $600.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Page: <<   < prev  35 36 37 38 39 [40] 41 42 43 44   next >   >>
Login
RE: CDI gr8flyer55 - 12/8/2012 10:07 PM  1 votes
Gompy
Score: 460
Last Login: 5/18/2013
Status: offline
Adrian, it's very simple......heat is lost energie.
If you don't want to lost energie, you have to change your designe.
Don't make the component bigger, but find the ideal designe.
Sometimes the ideal designe have more components.
The designe I use for now have 95% effective power without heat and use less current.
But if I use the big componets the board will be as big like a greatingcard.
I have find differend components and can make a "small" board with a small transformer EF15.
The board (45x80mm) I have build can produce 130mJ at 10.000 rpm with a EF20 transformer.
Nice to use for my bike with twin cilinder, but I burn a hole into the piston of your modelengine.
One cilinder modelenigines use ~25mJ for 20.000 rpm, so the board can be smaller.
The boards you and John are using have less then 10mJ at 10.000 rpm.
You get a spark, but if the pressure will be a littlebit higher, the spark will be gone.
Same if the rpm will be higher or the Voltage lower, the spark will also be gone.
I don't say your system is wrong, but it don't use the power effective.
I have at high (15.000) rpm allmost the same HV-Voltage if I run low (1.000) rpm
Thats the differend between less or more components, but I have a more reable system.
_____________________________
CU, Rob
http://www.electronics.gompy.net
Hide Signatures
(in reply to CH Ignitions)
       Post #: 976
gr8flyer55
Score: 600
Last Login: 5/22/2013
Status: offline
RE: CDI gr8flyer55
Last posted software on electrofunnel works great for me as is. I'm not changing a thing except for the curves I just tried. If anyone decides to use it with the new "B" board, for everything to be operational, all 3 jumpers must be in place. If you are using switches, they must all be closed makin contact to ground. Just some info in case someone wondered how they are setup. Mine work.
John
Hide Signatures
(in reply to gr8flyer55)
       Post #: 977
RE: CDI gr8flyer55 - 12/8/2012 10:12 PM  1 votes
Gompy
Score: 460
Status: offline
quote:
ORIGINAL: gr8flyer55
All I will say about my board here will sum it up in one sentence.
I have been flying with it in a plane with a Clarence Lee built K&B .61 engine that turns in excess of 14,000 rpms without any misfire, NGK ME8 1/4-32 plug, 20 to 1 gas oil mix, Perry carb, for over 15 years and I couldn't be happier.
John
A nitro engine runs also without a bougie, petrol engines can do too.
If the engine is hot enough, make enough rpm and have enough pressure it can run without a spark.
The heat into the spark wil ignite the next rotation without a real spark.
The little spark you produce at 14.000 rpm is just enough to burn the petrol.
CU, Rob
Hide Signatures
       Post #: 978
RE: CDI gr8flyer55 - 12/8/2012 10:16 PM  1 votes
Gompy
Score: 460
Status: offline
RE: CDI gr8flyer55
Last posted software on electrofunnel works great for me as is. I'm not changing a thing except for the curves I just tried. If anyone decides to use it with the new ''B'' board, for everything to be operational, all 3 jumpers must be in place. If you are using switches, they must all be closed makin contact to ground. Just some info in case someone wondered how they are setup. Mine work.
John
And now your using with the B-timerboard PIC type ?
I have still see into the Exelsheet the MCLRE is OFF.
CU, Rob
Hide Signatures
       Post #: 979
RE: CDI gr8flyer55 - 12/8/2012 10:23 PM  1 votes
gr8flyer55
Score: 600
Status: offline
Rob, it is still off. I'm using it the way it is for now till Jake decides to change everything. I have no problems running it right now though.
John
Hide Signatures
(in reply to Gompy)
       Post #: 980
RE: CDI gr8flyer55 - 12/8/2012 11:10 PM  1 votes
CH Ignitions
Score: 420
Last Login: 5/6/2013
Status: offline
Rob ,John,
Your design is more complex and will work better no dealt about that with better efficienty.
Your design and John design ...both works and in 2 different ways of doing the job.
Beside you 2 and Niemy no one else come to the table with something different or with feedback...yes I did it and works let's go with this design or that.
That is what I tried to say, make both, get them on testing and the most relaiable, smaller and lighter...some of those criterias will win.
I have not looked to see the design A or B who made it, how it works...my plate is full as it is ...more to that... wify wanted... lighting decorations
on outside the hose and all around and funny thing...as I...since I know my self I never hang Christmas lights outside in shorts and no t-shirt and decorate
palm trees...funny as molases to me.....but I guess we all have to deal with changes if is hanging lights in Florida palms or what choice of PCB design.
Here are couple of pictures and let's bring the Christmas spirit and be more forgiveing and tolerant one with another.
Life is short as it is and harmony is better than fight, Love is better than hate .
Adrian
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
www.ch-ignitions.com
Hide Signatures
       Post #: 981
RE: CDI gr8flyer55 - 12/8/2012 11:19 PM  1 votes
Gompy
Score: 460
Status: offline
Bikeboard.
Click for fullsize
Click for fullsize
Click for fullsize
CU, Rob
Hide Signatures
       Post #: 982
RE: CDI gr8flyer55 - 12/9/2012 2:59 AM
w8ye
Score: 318
Last Login: 5/24/2013
Status: offline
Adrian,
It doesn't feel like Christmas at first to me unless the snow is piled up on the sides of the driveway and side walk?
I've spent a few Christmases in Florida and I still enjoyed it.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to Gompy)
       Post #: 983
RE: CDI gr8flyer55 - 12/9/2012 3:48 AM
jakestew
Score: 180
Status: offline
Website had a bad link. Sorry everybody!
I fixed the link so that the new "B" board version will download right. Been busy with finals so I haven't had much free time.
Post edited by moderator
< Message edited by w8ye -- 12/9/2012 4:44 AM >
http://www.electrofunnel.com/CDI-2012/index.htm
Hide Signatures
(in reply to w8ye)
       Post #: 984
RE: CDI gr8flyer55 - 12/9/2012 11:37 AM
Gompy
Score: 460
Status: offline
Sometimes sh*t happen.
Click for fullsize
CU, Rob
Hide Signatures
(in reply to jakestew)
       Post #: 985
RE: CDI gr8flyer55 - 12/9/2012 9:29 PM
jakestew
Score: 180
Status: offline
http://www.electrofunnel.com/CDI-2012/CDI-2012_v1.0.zip
http://www.electrofunnel.com/CDI-2012/CDI-2012_v1.0_B.xlsm
are the links to the v1.0 and v1.0B files.
Part of this post has been removed by the moderator.
< Message edited by w8ye -- 12/10/2012 12:22 AM >
Hide Signatures
(in reply to Gompy)
       Post #: 986
RE: CDI gr8flyer55 - 12/9/2012 9:35 PM
captinjohn
Score: 247
Status: offline
Keep up the good work here ...very interesting !  Capt,n
< Message edited by captinjohn -- 12/11/2012 5:30 PM >
I never met a engine I did not like !
Hide Signatures
(in reply to Gompy)
       Post #: 987
RE: CDI gr8flyer55 - 12/9/2012 10:58 PM  1 votes
Gompy
Score: 460
Status: offline
Everybody is building timerboard version B, but no one is missing R9 on the board ?
Solution for the time be, if you remove LED2 you have to replace the LED2 with a resistant 3k9.
Click for fullsize
Click for fullsize
< Message edited by Gompy -- 12/10/2012 5:11 PM >
CU, Rob
Hide Signatures
(in reply to captinjohn)
       Post #: 988
RE: CDI gr8flyer55 - 12/10/2012 1:05 AM  1 votes
Nav-Aids
Score: 200
Last Login: 5/21/2013
Status: offline
Jake, I think Gompy was talking about this link.
"CDI-2012.zip This is the timer and HV board schematics.
These are preliminary schematics only! The board files are not included, as they don't exist yet."
This is the link that is bad, on your web page.
Ray
Everything is easy......Once you know how.
Hide Signatures
       Post #: 989
RE: CDI gr8flyer55 - 12/10/2012 2:16 AM  1 votes
gr8flyer55
Score: 600
Status: offline
Rob, I actually forgot I drilled extra holes in the boards for the 4.7k resistor and had added it when I was building them. Just figured it was a mistake and fixed it on the fly. Kind of like the extra 4.7 volt Zener that's missing from the board in this revision of the B board. I figured it wasn't needed and left it out, everything worked fine for me.
John
Hide Signatures
(in reply to Gompy)
       Post #: 990
RE: CDI gr8flyer55 - 12/10/2012 2:33 AM  1 votes
Nav-Aids
Score: 200
Status: offline
I'm sorry Gompy but, I can't remember how you are measuring / calculating the actual spark output?
Ray
Hide Signatures
       Post #: 991
RE: CDI gr8flyer55 - 12/10/2012 11:43 AM  1 votes
Gompy
Score: 460
Status: offline
I doit with this advance device.
Click for fullsize
CU, Rob
Hide Signatures
(in reply to Nav-Aids)
       Post #: 992
RE: CDI gr8flyer55 - 12/10/2012 12:09 PM  1 votes
Gompy
Score: 460
Status: offline
@Jack,
I don't can see wat you have change into version 1_B
We deside there are no other timerboards, we use timerboard B with a 12F683
If switch on pin 4 (GP3) will be closed, the PIC will be RESET.
* Pin 4(GP3) = Tied low on some timer boards, no function assigned *
No pull-ups, if grounded table 1 must be active.
* Pin 2(GP5) = Table Switch, internal pull-up, ground for Table2 *
MCLRE is still OFF, pin 4 do not have the RESET funtion.
__CONFIG(FOSC_INTOSCIO & WDTE_OFF & PWRTE_ON & MCLRE_OFF & CP_OFF & CPD_OFF & BOREN_OFF & IESO_OFF & FCMEN_OFF);
This lines I don't understand, switch ON - switch OFF ?
WPU = 0b000100; // Internal pull-ups on GP2,4,5
OPTION_REG = 0b00000000; // pullups on, falling edge, Tmr0
There is also a delay of 100msec for the killswitch to reduce the noice.
It takes 16 turns befor the killswitch is gone work.
I reduce the noise allready with a capacitor, the delay for the killswitch can be removed.
< Message edited by Gompy -- 12/10/2012 12:49 PM >
CU, Rob
Hide Signatures
(in reply to Gompy)
       Post #: 993
RE: CDI gr8flyer55 - 12/10/2012 2:29 PM  1 votes
Nav-Aids
Score: 200
Status: offline
quote:
ORIGINAL: Gompy
Cute, I got one of those also but, it doesn't measure voltage or current. Ok I'll put it this way, where and how are you measuring the current and voltage  to get the milli-joules, spark power? What are you using to measure the current and voltage of the spark? Are you measuring the spark gap with the spark gap open or with a 1 ohm resistor shorting the spark gap or are you using a 25 to 50 Meg ohn resistor to simulate the gap?
Ray
Hide Signatures
(in reply to Gompy)
       Post #: 994
RE: CDI gr8flyer55 - 12/10/2012 2:38 PM  1 votes
Nav-Aids
Score: 200
Status: offline
What do we need a reset (MCLRE) on a simple circuit when we have a power switch? IMO we can use it for something else more important like; General purpose input, Slave Select input, Timer1 Gate input, or Programming voltage.
Ray
Hide Signatures
       Post #: 995
RE: CDI gr8flyer55 - 12/10/2012 2:49 PM  1 votes
gr8flyer55
Score: 600
Status: offline
Maybe in some situations the reset function would be of some use, but I have never had a problem with a pic requiring it to be reset to restart the program. If the engine stops for some reason like maybe lack if fuel, broken wire etc. , the program goes back to the main loop anyway. Anything under 2 revs per second tells the pic the engine is not running and it restarts anyway. If there would be some other condition that causes it, I have never run into it in the years of using it.
I would be in favor of leaving it turned off and use the pin for something else later.
John
Hide Signatures
       Post #: 996
RE: CDI gr8flyer55 - 12/10/2012 4:39 PM
captinjohn
Score: 247
Status: offline
anyone need a small 1/4x32 sparlplug???
https://www.google.com/search?sourceid=navclient&aq=hts&oq=&ie=UTF-8&rlz=1T4GZBN_enUS434US434&q=NGK+ME8+1%2F4-32+plug
Hide Signatures
       Post #: 997
RE: CDI gr8flyer55 - 12/10/2012 8:33 PM  1 votes
Gompy
Score: 460
Status: offline
THE PIC 12F683 DON'T GET OTHER FUNCTIONS ANYMORE.
Jack don't want spent more time to the 12F683 software !
The only thing I can think about to use pin4 will be a RESET-function.
Only a small piece of txt change with a funtion to pin 4.
CU, Rob
Hide Signatures
       Post #: 998
RE: CDI gr8flyer55 - 12/10/2012 9:20 PM  1 votes
gr8flyer55
Score: 600
Status: offline
Jake said he was very busy between work, school finals, and I guess the girlfriend too. If it would work, I'd just edit the source code myself in the excel sheet. You can view it, but not sure if you can edit it while viewing and still have it correct when you try to compile it. I've done it before, so if there's no further changes being made to the code I'll edit it and see what happens, if anything.
I know why you want the reset Rob. Not a problem either way for the rest of us I would think.
On my 3 boards it doesn't matter if the jumper is on or not as the software has it turned off right now as Rob pointed out. I guess now I have a 4th and final version B board to etch and build tonight. Might as well make a few while I'm at it in case this project really takes off. Well, I doubt it. The only person that requested a board so far was Jake. Maybe this isn't such a hot project after all eh?
The only thing I use the features on is my engine test stand. Once testing is over, no need for a second advance table. I already have a kill switch on my ignition board, so there goes that one too. Oh well. It starts, runs well, and it works, what more can I say.
John
Hide Signatures
(in reply to Gompy)
       Post #: 999
RE: CDI gr8flyer55 - 12/10/2012 10:00 PM  1 votes
Gompy
Score: 460
Status: offline
A specialy for you John......BUT i want to have my RESET if you accept.
Click for fullsize
CU, Rob
Hide Signatures
       Post #: 1000
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
