RE: CDI gr8flyer55    Gallery
Logged in as Guest
Users viewing this topic: Atam
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Page: <<   < prev  31 32 [33] 34 35 36 37 38 39 40   next >   >>
Login
RE: CDI gr8flyer55 - 11/1/2012 4:59 AM
gr8flyer55
Score: 600
Last Login: 5/22/2013
Status: offline
I'm trying a new email.
gr8flyer55@yahoo.com
Hide Signatures
(in reply to Gompy)
       Post #: 801
RE: CDI gr8flyer55 - 11/2/2012 1:40 PM  1 votes
nyemi
Score: 210
Last Login: 5/21/2013
Status: offline
Hi John
I finished the 4T curves.
Link: docs.google.com/open
I am wondering what is the best version.(A-B-C-D)
Hall location:BTDC 30°-32°
Thanks in advance test.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by nyemi -- 11/2/2012 2:01 PM >
_____________________________
Regards nyemi.
Hide Signatures
(in reply to gr8flyer55)
       Post #: 802
RE: CDI gr8flyer55 - 11/2/2012 7:26 PM  1 votes
Muciek
Score: 103
Last Login: 2/12/2013
Status: offline
This looks like 2t curve...  http://i.imgur.com/C2JkB.jpg   here is one for a 2t.    A 4 stroke ignition should have curve like this low rpm few degrees higher rpm more deegrees here is a example  http://i.imgur.com/tvvsi.jpg  .
Hide Signatures
(in reply to nyemi)
       Post #: 803
RE: CDI gr8flyer55 - 11/2/2012 8:59 PM  1 votes
Gompy
Score: 460
Last Login: 5/18/2013
Status: offline
Differend between 2 and 4 stroke curve
Click for fullsize
CU, Rob
http://www.electronics.gompy.net
Hide Signatures
(in reply to Muciek)
       Post #: 804
RE: CDI gr8flyer55 - 11/2/2012 9:45 PM  1 votes
bluejets
Score: 205
Last Login: 4/15/2013
Status: offline
I've had a timing light on my car engine (four stroke) and it certainly doesn't jump from a low degree advance (5)to a high degree (20) with a low increase in RPM as shown above.
It will start at low degree and then advance in a linear fashion.
Hide Signatures
(in reply to Gompy)
       Post #: 805
RE: CDI gr8flyer55 - 11/2/2012 10:14 PM
Muciek
Score: 103
Status: offline
It's only painted to show how it works in 4t the degree of advance are different on each engine but it should look like this (raising with rpm)
Hide Signatures
(in reply to bluejets)
       Post #: 806
RE: CDI gr8flyer55 - 11/2/2012 10:17 PM  1 votes
Gompy
Score: 460
Status: offline
Cars don't need easystart of 5 degree timing, this is only for us to start the engine easy.
Cars have enough power out of the batterij and use a powerfull start engine to spin the engine around.
Modelengine have also low pressure, so the petrol don't burn very easy as do by high pressure engine.
BTW, race engines have a hole differend ignitioncurve then jigsaw / weedeaters have.
Most of the people don't use a start engine but start the engine by hand, thats why we need easystart.
CU, Rob
Hide Signatures
       Post #: 807
RE: CDI gr8flyer55 - 11/2/2012 11:41 PM  1 votes
Gompy
Score: 460
Status: offline
I think I have the overheated transistor solved.
When testing a new flashlight the current will be sometimes very high.
Lucky me, I don't have a HV-board with a transistor.
With the scope it show me the SCR stay open.
Why, the Voltage coming from the HV-board was to high for the SCR (400 Volt type).
Changing the SCR to a 800 Volt type solved the problem, current stay low.
The problem of high Voltage is also the misfiring of the CDI.
The SCR opens if the Voltage of the HV-board will be to high and that can be any time.
If you use a low Voltage SCR, change it to a high type, at least 800 Volt.
For example BT151-800R
< Message edited by Gompy -- 11/3/2012 12:13 AM >
CU, Rob
Hide Signatures
(in reply to Gompy)
       Post #: 808
RE: CDI gr8flyer55 - 11/7/2012 8:16 PM  1 votes
gr8flyer55
Score: 600
Status: offline
Nyemi, is your new fixed source code the same as the source code in jake's excel sheet so we can make new curves and copy & paste the 2 tables as we did before?
I just tested your new fixed source code with the Led & switches fixed and it works beautifully!!
Thanks again for fixing the software. I need to make a few new 2 stroke curves but it tested good on my engine with the stock curve in it. The LED is now nice and bright so we can use it for a timing light again. Tested both tables and kill switch and they work fine.
I will test your 4stroke curves by the weekend. So far, I think the "C" curve will be the best but still have to test on my 4 stroke engine, too cold right now with snow coming today.
I am drawing a schematic and parts list for the HV board we will be using. Similar to an RCexl HV board but a different size. Almost all the parts except for the transformer can be bought from either Mouser or Digikey and I'll provide the part numbers for the parts.
Working on getting the transformers factory made and should have an answer back in a few days. The factory is close to where I live. I want to get them to make 50 at a time until I get orders from the forum users for kits. I do have the bare HV boards available already, etched and drilled, ready for parts.
John
Hide Signatures
(in reply to nyemi)
       Post #: 809
RE: CDI gr8flyer55 - 11/8/2012 3:52 AM
captinjohn
Score: 247
Status: offline
Just a note here, John this is sounding good. Keep up the good work!    Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 810
RE: CDI gr8flyer55 - 11/8/2012 4:32 AM
gr8flyer55
Score: 600
Status: offline
Capt'n , kits will be available shortly to build the complete project. I have sent out a few with preprogrammed Pic chips on pre built timer boards. This project was one of the best ideas to ever be made available to modelers. You can get either an assembled and tested set of boards ready for your choice of connectors, or as a complete kit with all parts or just the bare boards ready for assembly. Tomorrow ill post the part number list and where to buy them or just drop me an email with your address and I can send whatever is required. We still need a sort of building tutorial though.
Jake is working on part 2 of the project, picking up where this one left off. A new chip, new features, and only requiring a new timer board and some extra parts. I think it will be a fun to do addition to this project. Telemetry being added, basic sensors for temp and rpm and on the fly timing changes etc. for those with newer radios capable of using telemetry features, it will make using the features very basic and simple. We are approaching this technology cheaper than you can buy a ready made system, if you have some basic soldering experience.
It's taking some time but good things come to those who wait!!
John
Hide Signatures
(in reply to captinjohn)
       Post #: 811
RE: CDI gr8flyer55 - 11/8/2012 3:35 PM
captinjohn
Score: 247
Status: offline
John, this is sounding even better. The kits would make for a good winter project with time to get things right!  Good Idea too me.   Thanks    Capt,n
Hide Signatures
       Post #: 812
RE: CDI gr8flyer55 - 11/8/2012 8:32 PM
captinjohn
Score: 247
Status: offline
I forgot to ask, are the Syncro boards going to be available too?  Thanks   Capt,n
Hide Signatures
       Post #: 813
RE: CDI gr8flyer55 - 11/8/2012 10:17 PM
gr8flyer55
Score: 600
Status: offline
Yes, what you are calling the SyncroSpark boards are actually our timer boards. Everything will be available, in fact they can be used to upgrade the old non SyncroSpark fixed or mechanical timing linkage such as on the older original Brison 3.2 engines. Our timer will be a plugin upgrade between the hall sensor and the original ignition box like the old CH ignitions were. Deans connectors are standard on the upgrade to match the originals.
John
Hide Signatures
       Post #: 814
RE: CDI gr8flyer55 - 11/9/2012 8:55 PM
Gompy
Score: 460
Status: offline
Nobody home so I try the forum.
I redraw the schematics like they use to be after all the changes.
Hope some one can take a look at it and confirm me they are right.
Missing the winds of the transformer.
Red are changes I don't know.
Only if I get to confirm the schematics are OK I start to draw the PCB's.
BTW, the PIC for this schematic / board will be the 12F683.
Jack will you add the schematics to your site if they are OK ?
Schematics removed
It must be clear the schematics are not a copy from (name)
< Message edited by Gompy -- 11/10/2012 4:40 PM >
CU, Rob
Hide Signatures
       Post #: 815
RE: CDI gr8flyer55 - 11/9/2012 10:29 PM  1 votes
gr8flyer55
Score: 600
Status: offline
Rob, I will check both schematics. Been busy today fixing my crashed computer, and rebuilding my snow blower.
I see some resistor values on the hv board that need to be updated. I will make the changes and email them to you. I did get your email thru Yahoo. I printed it out so I can compare to my working boards.
The transformer windings are 400 secondary, #32 awg, 20 primary, #26 awg, and 10 feedback, #30 awg.
You can experiment but that's what worked best.
Now that my computer virus is gone, I hope to get back to work on this project!!
John
Hide Signatures
(in reply to Gompy)
       Post #: 816
RE: CDI gr8flyer55 - 11/9/2012 10:45 PM  1 votes
Gompy
Score: 460
Status: offline
I add the winds.
BTW, I add some componets to the timerboard to use it optimal.
I don't know if both LEDs will be used, but if you don't use one of them don't place it.
We start this week with hail, the rest of the week it rains.
Monday I get a hearing if it's allowed to start to build a barn in the garden so I can test dry.
CU, Rob
Hide Signatures
       Post #: 817
RE: CDI gr8flyer55 - 11/10/2012 1:07 AM  1 votes
CH Ignitions
Score: 420
Last Login: 5/6/2013
Status: offline
Well that schematic looks real good and I am sure will work...some way somehow it happens to be familiar with ...couple additions to it ...but should be OK.
As far as Original Syncrospark timing boards I am sure that no one will be able to have. The closes one but not close it was a limited try of rcxel with a 16f pic. and only one program.
The original SS had its unique features that no one will be able to duplicate them.
Syncrospark was part of CH brand name to its timing board and not available anymore...
I can still get them but for a real high price . Syncrospark had 4 curves preprogrammed and selectable via 3 pads.
CH change the sycrospark name to computer timing control after the new TB V1 that was developed and programmed by a friend of Bill Carpenter , after that V2 was done with external OSC,VR...
The TB currently used is a V1 and a LED added to it.
So... no matter how good the software is, hardware... this will never be a Syncrospark and do not create confusions.
Do not want to get anyone upset, I myself supported this project .
"Sky is big enough and can hold many stars"
Adrian
< Message edited by CH Ignitions -- 11/10/2012 5:07 AM >
www.ch-ignitions.com
Hide Signatures
(in reply to Gompy)
       Post #: 818
RE: CDI gr8flyer55 - 11/10/2012 2:41 AM
captinjohn
Score: 247
Status: offline
I cut & pasted this below.  I hope all of you guys and all RC People can work together.
Sometimes we wonder, 'What did I do to deserve this?' or 'Why did God have to do this to me?' Here is a wonderful explanation! A daughter is telling her Mother how everything is going wrong, she's failing algebra, her boyfriend broke up with her and her best friend is moving away.
Meanwhile, her Mother is baking a cake and asks her daughter if she would like a snack, and the daughter says, 'Absolutely Mom, I love your cake.'
'Here, have some cooking oil,' her Mother offers.
'Yuck' says her daughter.
'How about a couple raw eggs?' 'Gross, Mom!'
'Would you like some flour then? Or maybe baking soda?'
'Mom, those are all yucky!'
To which the mother replies: ‘Yes, all those things seem bad all by themselves. But when they are put together in the right way, they make a wonderfully delicious cake!
‘God works the same way. Many times we wonder why He would let us go through such bad and difficult times. But God knows that when He puts these things all in His order, they always work for good! We just have to trust Him and, eventually, they will all make something wonderful!
God is crazy about you. He sends you flowers every spring and a sunrise every morning. Whenever you want to talk, He'll listen. He can live anywhere in the universe, and He chose your heart.
Hide Signatures
(in reply to CH Ignitions)
       Post #: 819
RE: CDI gr8flyer55 - 11/10/2012 3:22 AM
bluejets
Score: 205
Status: offline
Think you have the wrong forum here captain, this is rcuniverse, jcuniverse is further on.
Hide Signatures
       Post #: 820
RE: CDI gr8flyer55 - 11/10/2012 4:52 AM
captinjohn
Score: 247
Status: offline
We are all in the same Universe...right!
Hide Signatures
       Post #: 821
RE: CDI gr8flyer55 - 11/11/2012 7:01 PM
gr8flyer55
Score: 600
Status: offline
This project will probably be abandoned as an orphan without anymore support from the programmer in about 2 weeks.
I still have kits and boards available for anyone interested.
PM me if you are interested.
There are still private developments taking place, but limited access to it seems the only way for it to survive since there have been comments made to stop our progress. It is a shame but it does happen. I have my end of this project working flawlessly, and will continue to keep making them for local club members and inquiries only.
The completed project is going commercial in a few months. Dates and availability will be posted.
I appreciate the help of everyone who participated in the project, whether it was information gathering, testing, or fresh new ideas for circuit changes or software implementation. You are all a really great group of people! Thank you for your support.
John :0(
Hide Signatures
       Post #: 822
RE: CDI gr8flyer55 - 11/11/2012 10:44 PM
Muciek
Score: 103
Status: offline
How can I compile a picf1840 version into hex?
Hide Signatures
       Post #: 823
RE: CDI gr8flyer55 - 11/11/2012 11:31 PM
gr8flyer55
Score: 600
Status: offline
Send your source code to me in email and I will compile it for you.
John
Hide Signatures
       Post #: 824
RE: CDI gr8flyer55 - 11/12/2012 3:57 PM
gr8flyer55
Score: 600
Status: offline
The information for downloading the software is at this link.
http://www.electrofunnel.com/CDI-2012/index.htm
Follow the instructions to get everything working. Remember to change your device to the 12F1840 in the setup to compile the source code.
John
Hide Signatures
       Post #: 825
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.188RCU1
