RE: CDI gr8flyer55    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Page: <<   < prev  32 33 [34] 35 36 37 38 39 40 41   next >   >>
Login
RE: CDI gr8flyer55 - 11/16/2012 10:08 PM
jakestew
Score: 180
Last Login: 5/18/2013
Status: offline
v1.0 Release
v1.0 is now up on the website.
Changes/New features...
-Added Nyemi's code to turn interrupts on and off in a smarter way. This may reduce false interrupts which could cause the program to recalculate the delay multiple times if you have a dirty signal from your hall sensor.
-Put the code for both the 12F693 and 12F1840 in the same spreadsheet.
-Added buttons to copy the compiler command lines so that people don't have to install the IDE.
-Added instructions to help get people get things compiled.
I have been busy the last few weeks with school and work. The new changes are pretty minor, but hopefully everything is simplified a bit.
I can't find anything more to do to the program without getting into more advanced features. It runs very well and there seem to be no problems that I can find. I have plenty of ideas for more advanced features, but this seems to make a great v1.0 release point.
The code is as stable and accurate as it can be with the current table-driven system. There could possibly be some adjustments left to do in the table generation by the spreadsheet, but it already works as expected and I can only see the most minor gains being had.
I'm working on getting a video of the actual operation finished, and should have that added to the website soon. I've got good video captured of all the functions, but just need to edit, compress, and upload it.
Hopefully people will be willing to test all the various methods of compiling the code on the two processors. I wrote the instructions as I was upgrading my MPLAB and compiler, then I tested it on my engine for the video. Everything seems to work right, but I only tested the 1840 version on an actual engine, the 683 version was only tested in the simulator.
Be sure to let me know if you find any problems in the instructions or code. Email me first with problems, unless you think it's helpful for the thread.
-Jake
_____________________________
http://www.electrofunnel.com/CDI-2012/index.htm
Hide Signatures
(in reply to gr8flyer55)
       Post #: 826
RE: CDI gr8flyer55 - 11/17/2012 3:15 AM  1 votes
jakestew
Score: 180
Status: offline
Here's a video of v1.0 running on a Homelite 25cc engine...
Hide Signatures
(in reply to jakestew)
       Post #: 827
RE: CDI gr8flyer55 - 11/17/2012 5:42 AM
nyemi
Score: 210
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: jakestew
Hi Jake
Congratulations
I magnanimously helped you.
I think so. For you, bad for self-esteem.
But I did not breach you. Please.
You do not do it to me. Thank you.
Regards.
I am who I am just a simple manipulator hardware.
< Message edited by nyemi -- 11/17/2012 6:37 AM >
Regards nyemi.
Hide Signatures
       Post #: 828
RE: CDI gr8flyer55 - 11/17/2012 5:49 AM
lovefool
Score: 100
Last Login: 4/29/2013
Status: offline
quote:
ORIGINAL: jakestew
v1.0 Release
Congrats on your first official release !
Currently the server seems to be down tho.
Jay
Hide Signatures
       Post #: 829
RE: CDI gr8flyer55 - 11/17/2012 7:04 AM
jakestew
Score: 180
Status: offline
http://www.electrofunnel.com/CDI-2012/CDI-2012_v1.0.zip
Seems to work for me. Maybe it's just having intermittent problems, or only certain locations? Anyone who's having problems can email me and I'll send you the file.
Someone mentioned to me that the kill switch doesn't seem to work well in the video. That's because I was pushing it and letting off very quickly just to show that it was kicking in right. If you want to kill the engine you have to hold the kill switch until the engine stops. If you let off of it while the engine is still spinning the spark will return and it can start back up again.
It kills the spark in less than 1/4 sec, but only kills the spark while it is closed. If you don't like this behavior I suggest putting a toggle type switch on the kill switch. You could also use a normally closed momentary switch, which would work like a "deadman" switch.
Right now the kill switch is just an extra feature. You should not rely on it completely, and should always have another way to kill your engine. If the switch becomes disconnected it will NOT work and the engine will NOT stop. For that reason alone it is not suitable for being your primary kill method. It is very easy for a wire to break or the switch connection vibrate off, or even for your switch to malfunction.
I take no responsibility for any injuries! The code is open source, so you are fully empowered to study it and decide if it is suitable for your application. You have full knowledge of ALL the workings of the code, so you take ALL responsibility for deciding weather or not it is safe to use, and anything that results from that use.
I should also point out that open source software is legally considered to be constitutionally protected free speech. Unless you can prove I intentionally incited a riot or somehow equate this to yelling "fire" in a movie theater... I have no liability for what I put in the code or how it gets used.
-Jake
Hide Signatures
(in reply to lovefool)
       Post #: 830
RE: CDI gr8flyer55 - 11/17/2012 7:51 AM
lovefool
Score: 100
Status: offline
I got this message, but when I hit BLUE BUTTON, it started downloading ....
Any restriction of access from Japan, or my browser is a problem?
Anyway I got your file.
Jay.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 831
RE: CDI gr8flyer55 - 11/17/2012 8:41 AM
jakestew
Score: 180
Status: offline
That's strange... I tried adding that Cloudflare thing since it was free and my host was pushing it. It's supposed to make things faster and MORE reliable! Guess it's just a bunch of crap.
I'm not aware of any location restrictions, except for India. I banned their country because they hacked me not too long ago. It's possible that some of the banned India IPs are blocking some people. If this happens you'll just have to email me for the file, I'm not going to let Indians hack me again.
If anyone else has trouble with it please email or PM me. If it causes more problems I'll have to get rid of Cloudflare or look over the banned IPs again.
Hide Signatures
       Post #: 832
RE: CDI gr8flyer55 - 11/17/2012 3:21 PM  1 votes
gr8flyer55
Score: 600
Last Login: 5/22/2013
Status: offline
Thanks Jake !!
As I am going thru the testing phase of editing curves and installing the new MPlab files, everything is working great.
I particularly like the link buttons added to copy command lines etc. Makes things much simpler.
The instruction readme file is a big help for those with limited experience also.
A big thanks also to Nyemi for researching the trouble spots in the source code. Without guys like you Nyemi, some of us would be lost!!
Job well done!
John
Hide Signatures
       Post #: 833
RE: CDI gr8flyer55 - 11/19/2012 4:18 PM  1 votes
jakestew
Score: 180
Status: offline
It's been pointed out to me several times that the kill switch feature needs to be better. The kill switch should kill the engine if it becomes disconnected.
The reason I implemented it the current way is that not everyone has switches hooked up, and the switch I used for testing is a normally open, momentary type.
In the next version the polarity of the switch will be reversed so that the switch circuit will have to be closed for the engine to run. This way if the switch wires break or come off the engine will stop. If you don't want to use the kill switch feature you'll have to ground the kill switch pin with a jumper or solder bridge.
Just thought I'd let people know so they don't waste time hooking up switches that won't work in the next version. If you're looking to hook up a switch now, I suggest using a toggle switch.
I'm working on some pretty fancy new features for the next version, so it will take awhile for the next release.
Notes on the video...
The switch labeled "M" is a Momentary switch tied between the ground and the kill switch pin. The "T" switch is a Toggle switch connected between ground and the table switch pin. The grounds for both switches are tied together. I hooked them up by soldering a servo connector to pins 2, 3, and 4. Pin 4 is grounded in the current design, so I used it as the ground.
Other notes...
I forgot to mention, but the v1.0 release puts your settings and table into the code. There's no need to separately cut-and-paste in the table data.
Target features for the next major release...
-Learning mode - the processor will learn the hall pulse and store it in EEPROM so that it can do instantaneous RPM calculation based on the pulse length. This will be used for starting since it will solve the first spark timing problem. No more estimating the starting speed.
-Rising edge hall pulse timing (magnet leaving sensor). I liked timing the pulse as soon as possible, but in order to do instantaneous speed measurement we'll have to wait for the end of the pulse. I've also come to the conclusion that it's easier to just move the sensor forward or the magnet back in order to give the processor enough time to do the calculations.
This may cause some problems if we have dirty sensor input. Using the first pulse edge like I'm currently doing is pretty safe, but with switching to the trailing edge it's possible that noise at any point during the pulse could generate a false interrupt and start the spark timing at the wrong point. We need some basic filtering on the sensor input. I don't think it will be a problem for most people, but if even some setups have this problem it will cause some jitter in the timing and make the project look bad.
-Better kill switch setup. A normally closed switch will make it so that the engine dies if the switch comes off. This will also let the switch have a deadman function, since if something happens to you you'll pull the switch loose and the engine will stop.
That's all I can think of to make the 683 do. v2.0 will be the last joint 683/1840 release.
Target features for the 1840...
-On-the-fly calculation. This will replace the precalculated table with a smaller table of just the advance values and allow more precision of the spark timing. This will also let us change the table values easier, so I'll write an app to allow on-the-fly table changes without reflashing the firmware.
-Telemetry. The processor will send out RPM speeds and possibly processor temp readings. I've ordered a Frsky DJT TX module and RX unit with serial telemetry (~$53 at hobbyking). So telemetry options will be using wires, bluetooth, or through the Frsky module.
I use a Turnigy 9X type transmitter since it's amazingly cheap and powerful. It's the only one out there that I can work with the firmware to add cool stuff like this. I'll be working to get RPM displayed on the TX LCD. I've already got the serial port working on the 1840, but still need to work out how to display the data. I'd like to write a PC and Android phone app to display the data and figure out the best way to display things on the 9X screen. I also need to figure out the best protocol for the telemetry data. I had wanted the display app to do most of the calculations, but this would probably force the burden onto the 9X processor and we can't really risk bogging down the 9X.
If anyone knows about the Frsky system or wants to help writing the apps, please let me know.
Well, that's my roadmap for the software side of the project. If anyone has any other ideas please let me know.
< Message edited by jakestew -- 11/19/2012 10:23 PM >
Hide Signatures
       Post #: 834
RE: CDI gr8flyer55 - 11/19/2012 5:01 PM
gr8flyer55
Score: 600
Status: offline
That sounds like a better way to have the switch work. I'd probably use one of RadioShack's normally closed pushbutton switches. That way it only requires you to push and hold till the engine quits. With the safety feature implemented, it solves the broken wire problem.
John
Hide Signatures
       Post #: 835
RE: CDI gr8flyer55 - 11/19/2012 5:11 PM  1 votes
gr8flyer55
Score: 600
Status: offline
By the way, if you are changing curves in the Excel sheet, please don't forget to change the hall sensor position to match what you physically have it set at on your engine !!!!
The default in the Excel sheet is set at 49 degrees!!! This will never work for an engine with the hall sensor set to 28 degrees which is a normal setting for MOST engines in use today. I tried that default of 49 degrees and trust me, you will never get your engine started with that setting without losing a finger or two.
John
Hide Signatures
       Post #: 836
RE: CDI gr8flyer55 - 11/19/2012 11:49 PM
COM
Score: 100
Last Login: 3/13/2013
Status: offline
Jake,
That sounds really interesting. I look forward to the 1840s features that you will implement. Thanks.
Regards
Charlie M.
Hide Signatures
       Post #: 837
RE: CDI gr8flyer55 - 11/20/2012 3:06 AM  1 votes
gr8flyer55
Score: 600
Status: offline
Jake, can we use Rob's suggested filtering on the sensor input on the current timer board?
Rob, can you post that filter schematic so we can see where to add the parts?
I can change my etch pattern to accommodate a few parts if needed.
John
Hide Signatures
       Post #: 838
RE: CDI gr8flyer55 - 11/20/2012 8:40 AM  1 votes
jakestew
Score: 180
Status: offline
Dang forum lost my post...
That sounds good. While you're at it... the 1840 can put serial on pins 2/3 or 6/7. To have serial and table/kill switches you should pin out 2, 3, 6, and 7. For the switches we need ground and pins 2+3. The serial also needs ground and pins 6+7. If you can pin things out in this fashion it will make it easy to connect the switches and serial. I use regular 3-pin RC connectors for most things.
-Jake
Hide Signatures
       Post #: 839
RE: CDI gr8flyer55 - 11/20/2012 12:58 PM  1 votes
gr8flyer55
Score: 600
Status: offline
Jake, pins 2 and 3 for the switches are absolutely fine. However, for the serial port, pin 6 is our signal output to the ignition board for spark trigger. Pin 7 was the output to the led, which we can relinquish since I have a new more direct link to the signal input from the hall sensor. It is pin 6 that is the problem, without that one as ignition trigger, Houston , we have a problem!
The only other solution would require a satellite board , linking signals for the data. Getting complicated, but maybe using a different higher pin count chip with dedicated serial comunnications like we once had with the 16F628a. Food for thought here, I am not a programmer and haven't much insight as to what you have in mind. Split signals on pin 6 ?
John
Hide Signatures
       Post #: 840
RE: CDI gr8flyer55 - 11/20/2012 1:23 PM  1 votes
gr8flyer55
Score: 600
Status: offline
Maybe a better way to use pin 3 would be to eliminate the kill switch connection and move that switch to the ignition board itself with the deadman switch. I have a way that works to kill the signal to the SCR by opening the trigger connection for a positive kill of the spark output. That gives you back pin 3 for serial connections. Pin 2- table switch. Pin 3- and 7- and ground for serial dedicated communications. There you have it all. Just my thoughts but a solution to the missing signal output pin.
John
Hide Signatures
       Post #: 841
RE: CDI gr8flyer55 - 11/20/2012 1:33 PM  1 votes
Gompy
Score: 460
Status: offline
John, you need ONE TX and ONE RX......It doesn't work with two TX or two RX
Click for fullsize
CU, Rob
http://www.electronics.gompy.net
Hide Signatures
       Post #: 842
RE: CDI gr8flyer55 - 11/20/2012 2:34 PM  1 votes
gr8flyer55
Score: 600
Status: offline
Not too hard to figure out Rob. Pin 6 and 7 become tx and rx , change old kill pin3 to signal out to SCR trigger on ignition board, problem solved. Didn't look at the pinouts to see 6 & 7 were paired tx and rx pins. Most likely requires many source code lines changed but possible. I guess it makes it easier to place a 3 pin header also on the board layout great idea I think. Jake probably already has that location for connections figured out on his timer board to link up his serial connections.
John
Hide Signatures
(in reply to Gompy)
       Post #: 843
RE: CDI gr8flyer55 - 11/20/2012 10:47 PM
bluejets
Score: 205
Last Login: 4/15/2013
Status: offline
John,
Pin 3 is input only.....
EDit....... sorry....are you referring to the physical pin or the port number.???
Not used to having it referred to as the physical pin....
Forget it....too early in the morning here I think...
Just looked at data sheet ..RA0/tx (pin7) RA1/rx (pin6) RA4/tx (pin3) RA5/rx(pin2)
Hide Signatures
       Post #: 844
RE: CDI gr8flyer55 - 11/20/2012 11:35 PM  1 votes
Gompy
Score: 460
Status: offline
First of all, why don't we use LiPo batteries ?
They are light in weight, small, can be reloaded, more Voltage, more current and cheap.
It's also easyer to make more power if the Voltage will be higher.
Also the electronics is easyer to make if there is enough power.
Second, don't try to use the same board for two differend types of CDI.
One of them or both don't work well with the same components.
Don't forget, it's high tech wat we are using and dangerous if it fails.
Third, first finish version 1 with the 12F683 befor start version 1 with a 12F1840.
I think a lot of people don't understand anymore wat we are doing or to use.
Wait for some time, atleast until some of us have test the version 1 of the 12F683 software.
Fourth, relase version 1 for the 12F1840 within a few months and not at the same time with the 12F683.
Lot of people don't undertsand wat they have to use or the possibillity of both PIC's.
Fifth, we need layouts and schematics to make it easy to the people who want build the CDI.
Jack was saying he will invert the killswitch and the table switch, but thats only possible if the PCB's are ready for this change.
If above isn't clear, we lost on all fronts.
Witch PIC software belongs to witch PCB and wat Exelsheet to use for witch version and ware can I find the hardware.....Even I'm lost sometimes
BTW Jack, you can write your new version for the 1840 but please lanuch it into a new topic - CDI 12F1840 ?
Now the differend versions are walking around into one topic and make it hard to know where people are talking about of.
If the topic will be longer it's also hard to find the sollutions for common errors of one version.
CU, Rob
Hide Signatures
(in reply to bluejets)
       Post #: 845
RE: CDI gr8flyer55 - 11/21/2012 12:20 AM
bluejets
Score: 205
Status: offline
Hi Rob,
What voltage level did you have in mind..??
2S or 3S ...??......capacity would have to be determined but probably 2200mAh would be sufficient, just carry an extra battery or two.
I guess easy(and also cheap) to connect a decent ubec to get the voltage down for the micro.
Hide Signatures
(in reply to Gompy)
       Post #: 846
RE: CDI gr8flyer55 - 11/21/2012 1:03 AM  1 votes
Gompy
Score: 460
Status: offline
I'm thinking of a 2 or 3S 2C pack and 1500 mA, the HV-board takes ~150 mA.
This must be enough for a day flying.
A normal PIC need 5 Volt or 3V3 for low Voltage type.
The four pennlights we use now are just enough to let the show go on, but it's not safe.
Batteries have also a differend unload then lipo's, batteries will be unload slowly and you equipment will be react strange.
Lipo's can hold there Voltage very long high, allmost untill their are empty.
CU, Rob
Hide Signatures
       Post #: 847
RE: CDI gr8flyer55 - 11/21/2012 1:15 AM  1 votes
gr8flyer55
Score: 600
Status: offline
Or, a 7805 regulator on the board. I've done that before. They hold up well at the less than 500 mah these circuits usually draw or higher for a new circuit, and can take up to 35 volts input. Cheap insurance for the timer pic and if you use Lipo cells, a 2 cell pack at 7.4 volts 2200 mah will last all day long. Very light weight also. Even a 1200 mah will go a whole day's flying. LiFE cells at 6.6 volts 2 cells are also good.
John
Hide Signatures
       Post #: 848
RE: CDI gr8flyer55 - 11/21/2012 3:43 AM  1 votes
bluejets
Score: 205
Status: offline
Yes, even the LP2950 that was used previously with the 16f628a micro would be ok. Maybe better if the LiFE was used.
Only 100mA but only driving the micro.
At 35 volts I think you'd want to try to reduce it a bit first. Poor old regulator will tend to get a bit hot under that condition.
Although I realise you were just quoting the max level John.
Hide Signatures
       Post #: 849
RE: CDI gr8flyer55 - 11/21/2012 4:55 AM  1 votes
gr8flyer55
Score: 600
Status: offline
Yup, that's the max rating. I use them on regulator boards on Harley's with my ignitions.
Put em' on a heat sink and forget they're in there.
I like the little 78L05 for the timing boards. Small TO-92 package style, add a few caps and it's ready.
John
Hide Signatures
       Post #: 850
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: CDI gr8flyer55
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
