CDI gr8flyer55    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> CDI gr8flyer55
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
CDI gr8flyer55 - 8/9/2011 11:48 AM  1 votes
Fly42
Score: 105
Last Login: 10/7/2012
Status: offline
New post, now i will see new cdi.
http://www.rcuniverse.com/forum/m_4344316/mpage_58/tm.htm
It looks almost a a fairy tail to me.
Hide Signatures
       Post #: 1
RE: CDI gr8flyer55 - 8/10/2011 11:23 PM
jpanhalt
Score: 115
Last Login: 5/9/2013
Status: offline
I have been working with gr8flyer55 to make a presentable CDI schematic and board. Attached is a Zipped file with the timer schematic he developed and board design with a bill of materials. Those people using Eagle will be able to open the Eagle files and manipulate them. Non-Eagle users can open the png files. I strongly urge installing the free version of Eagle so you can manipulate and print the files as you need them.
Unfortunately, I cannot figure out how to post either Eagle files or zipped files here. Moreover, converting to jpg may introduce dimensional errors. If someone knows how to post the correct formats. let me know. Otherwise, we could start a thread on a forum that will support those formats.
John
Hide Signatures
(in reply to Fly42)
       Post #: 2
RE: CDI gr8flyer55 - 8/11/2011 1:08 AM  1 votes
jpanhalt
Score: 115
Status: offline
Here the images are in gif and the BOM in txt.
John
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click to see the file in new window.Attachment.txt
Hide Signatures
(in reply to jpanhalt)
       Post #: 3
RE: CDI gr8flyer55 - 8/11/2011 1:24 AM  1 votes
gr8flyer55
Score: 600
Last Login: 5/20/2013
Status: offline
Thanks John for the post! Here's a picture of the first prototype working board, designed to interface with a CH ignition and my Original CDI design which will be posted later. Also I am posting the PDF file for etching the board true to size. The second PDF is the parts layout for the board.
Enjoy!
John
Click for fullsize
Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf
< Message edited by gr8flyer55 -- 8/12/2011 12:21 AM >
Hide Signatures
       Post #: 4
RE: CDI gr8flyer55 - 8/11/2011 1:43 AM  1 votes
gr8flyer55
Score: 600
Status: offline
The Hex file was written by Nyemi. It has a generic curve which works well for all my conversion engines so far. Starts at 0 degrees for starting, at idle it is 6 degrees, and at around 4,000 RPM it starts increasing to a max of 28 degrees. Top end for this hex file is set at roughly 9,800 RPM. where it starts a decline proportional to RPM.
John
:020000001829BD
:08000800F000030E8301F1007A
:10001000A70A0B11710E8300F00E700E090000008C
:100020000034003400340034003400340034003430
:10003000003400340034003400340134013401341D
:100040000134013401340234023402340234023403
:1000500003340334033403340334043404340434E5
:1000600004340434043405340534053405340534CB
:1000700006340634063406340634073407340734AD
:1000800007340734073409340A340C340C340F3481
:1000900010341234133415341634183419341A3415
:1000A0001B341E34203421342334243425342734A3
:1000B00028342A342B342D342F3430343234323433
:1000C000343436343734393439343C343D343F34C5
:1000D0004034423444344534473449344A344B3450
:1000E0004D344E344F3451345234543455345734E3
:1000F00058345A345B345D345E3460346134633474
:1001000064346634673469346A346D346E346E3402
:1001100071347134743475347734783478347A3493
:100120007B347C347D347E347F348034813482343B
:1001300083348434853486348734883489348A34EB
:100140008B348C348D348E348F348F34903491349E
:100150009234933494349534963497349834993453
:100160009A349B349C349D349E349F34A034A13403
:10017000A234A334A434A534A634A734A834A934B3
:10018000AA34AB34AC34AD34AE34AF34B034B13463
:10019000B234B334B334B434B534B634B734B83419
:1001A000B934BA34BB34BC34BD34BE34BF34C034CB
:1001B000C134C234C334C434C534C634C734C8347B
:1001C000C934CA34CB34CC34CD34CE34CF34D0342B
:1001D000D134D134D334D434D534D634D734D734DD
:1001E000D734D834DA34DB34DC34DD34DE34DE3496
:1001F000DF34E134E234E334E434E534E534E63446
:10020000E834E934EA34EB34EC34EC34ED34EF34F4
:10021000F034F134F234F334F334F534F634F734A3
:1002200008000313831222088A00210882000800B4
:100230000313831661308F000F1D1C2903138312D3
:10024000850107309900031383169F010C30850048
:10025000073081000313831202308500A401A70137
:100260008101A0308B00051938290130A400332901
:10027000A408031933298B010108A500810101306D
:100280002702031C562900000000000000000000A7
:100290000000000000000000000000000000A508B1
:1002A00003195429A5034329FF30A5002508E83E7A
:1002B000031C87292508103EA10000300318013EC9
:1002C000A2000A08A0001121A30020088A00A308A8
:1002D00003197C290000000000000000000000005D
:1002E000000000000000000000000000000000000E
:1002F00000000000A30B6A2903308506D830A60051
:10030000000000000000A60B802903308506A40130
:0A031000A701A0308B003329182943
:02400E00C433B9
:00000001FF
Hide Signatures
       Post #: 5
RE: CDI gr8flyer55 - 8/11/2011 7:44 AM
Fly42
Score: 105
Status: offline
Wat advange is the pic have and how change advange.
No program to change advange ?>
Click for fullsize
Hide Signatures
(in reply to gr8flyer55)
       Post #: 6
RE: CDI gr8flyer55 - 8/11/2011 7:51 AM  1 votes
av8tor1977
Score: 665
Last Login: 5/19/2013
Status: offline
This is why I never followed the "new" CDI threads. Way over the heads of most people in this forum. I can build small do it yourself electronics projects, and usually figure out schematics, but I've never seen anything that a layman could understand, follow, nor build in your posts. If it ever becomes a simple, easily understandable by a layman/beginning electronics experimenter project, then I would be interested, as I imagine many more here in the forum might. Meanwhile, you are just "talking far over the heads" of most people here I would venture to say...
AV8TOR
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to Fly42)
       Post #: 7
RE: CDI gr8flyer55 - 8/11/2011 9:27 AM  1 votes
jpanhalt
Score: 115
Status: offline
quote:
ORIGINAL: av8tor1977
This is why I never followed the ''new'' CDI threads. Way over the heads of most people in this forum.
AV8TOR
You are right. It is not for everyone. The AMA is a very large group and includes a wide spectrum of interests.
That said, this timer includes 12 parts plus a pcb. If you eliminate the strobe LED, then there are only 7 parts. Most of those parts are for the power supply to filter noise in the ignition environment. In other words, without the power supply, you have the microcontroller, a resistor, and a very common transistor. The simplest project for flashing an LED for rank beginners with a microcontroller also has 3 parts plus the power supply, actually most have 5 parts excluding the power supply. It just can't get any simpler.
So, what you seem to be complaining about is building anything with a microcontroller in it. That is your choice. What stumps me is why you continue to read a thread that is obviously microcontroller related and criticize its complexity.
John
Edit: Considering the limitations of this site for posting electronic projects, e.g., it does not support png or zip files, maybe this this project should be moved to: http://www.rcgroups.com/diy-electronics-199/
< Message edited by jpanhalt -- 8/11/2011 10:24 AM >
Hide Signatures
(in reply to av8tor1977)
       Post #: 8
RE: CDI gr8flyer55 - 8/11/2011 12:53 PM
gr8flyer55
Score: 600
Status: offline
If you are wanting a prebuilt and tested board, PM me.
John
Hide Signatures
       Post #: 9
RE: CDI gr8flyer55 - 8/11/2011 12:55 PM
gr8flyer55
Score: 600
Status: offline
Read post #5..it is mentioned there.
John
Hide Signatures
(in reply to Fly42)
       Post #: 10
RE: CDI gr8flyer55 - 8/11/2011 1:14 PM
Fly42
Score: 105
Status: offline
Where place sensor on engine ?
You have fig2 for you engine ?
Hide Signatures
       Post #: 11
RE: CDI gr8flyer55 - 8/11/2011 5:13 PM
gr8flyer55
Score: 600
Status: offline
For most engines it gets positioned at 28 degrees BTDC.
John
Hide Signatures
(in reply to Fly42)
       Post #: 12
RE: CDI gr8flyer55 - 8/11/2011 8:32 PM
Fly42
Score: 105
Status: offline
I need a 2 stroke HEX, this HEX is for 4 stroke.
The engine have 36 degrees not 28.
Hide Signatures
       Post #: 13
RE: CDI gr8flyer55 - 8/11/2011 11:07 PM
gr8flyer55
Score: 600
Status: offline
If you require something different in your advance curve even after I just told you it works on conversion engines, then email your requests to Nyemi. I do not do programming for this project!
John
Hide Signatures
(in reply to Fly42)
       Post #: 14
RE: CDI gr8flyer55 - 8/11/2011 11:17 PM
Fly42
Score: 105
Status: offline
If you have fig2 advange, you have a hex for the 4stroke engine.
I have a 2stroke engine, I can not use this hex.
Wat do I need to change in post#5 to get the 2stroke advange ?
Hide Signatures
       Post #: 15
RE: CDI gr8flyer55 - 8/12/2011 5:39 PM  1 votes
nyemi
Score: 210
Last Login: 5/13/2013
Status: offline
Hi Fly42
I'll show you gr8flyer55 hex CDI ignition curve. Hall position 28 °.
Look at the picture.
I want my image of you. Ignition curve as you want.
I will send you a blank ignition curve.
Describe your idea.
Hall position 36 °. OK?
RPM limiter  9973. OK?
If you have other ideas to communicate.
I'll write you PIC12F683 hex.
Regards nyemi.
Click for fullsize
Click for fullsize
Regards nyemi.
Hide Signatures
(in reply to Fly42)
       Post #: 16
RE: CDI gr8flyer55 - 8/13/2011 3:22 AM  1 votes
gr8flyer55
Score: 600
Status: offline
Check out this video on YouTube:
http://www.youtube.com/watch?v=yQSChQWkams&feature=youtube_gdata_player
John
Hide Signatures
       Post #: 17
RE: CDI gr8flyer55 - 8/13/2011 7:56 AM
Fly42
Score: 105
Status: offline
I do not know wat advange I need for now for good engine runs.
Send every time program to you and wait is not good for try.
Why can we not make self the advange in program?
Hide Signatures
       Post #: 18
RE: CDI gr8flyer55 - 8/13/2011 9:07 PM  1 votes
gr8flyer55
Score: 600
Status: offline
The excel sheet will only work with Mikro C programs. This software is written in Assembly Language and Excel does not produce the ASM code. Nyemi offered to write a hex file with your curve in it. You have to know what curve you need first.
John
Hide Signatures
(in reply to Fly42)
       Post #: 19
RE: CDI gr8flyer55 - 8/13/2011 9:13 PM
gr8flyer55
Score: 600
Status: offline
What engine do you have that is making this curve so difficult to figure out? If you watch my YouTube video I posted, you will see this system was written for a 2 stroke airplane engine and not a 4 stroke. My airplane has a 2 stroke engine on it in the video, and it runs quite well.
John
Hide Signatures
(in reply to Fly42)
       Post #: 20
RE: CDI gr8flyer55 - 8/13/2011 9:43 PM
Fly42
Score: 105
Status: offline
Now the engine run also good without cdi, with universal cdi it run also good.
I can buy a real one for the same price with the same options - no options is not wat i want.
If the engine run not good, i must every time sent some-one a question to make new hex.
Maybe wait few day befor some-one sent the hex file and i get again not good hex for the engine.
How long it go take befor i have run a good engine in this way ?
Timebord gompy is ok, this one is smal and you say better but only if i can change to perfect and not almost to perfect.
I know micro c and exel too, no problem to work with i have also brains.
Hide Signatures
       Post #: 21
RE: CDI gr8flyer55 - 8/14/2011 7:58 AM  1 votes
nyemi
Score: 210
Status: offline
Hi Fly42
I have seen many ignition curve.
2T-4T much difference. I will show RCexl original ignition curve. This is a general curve which is not good 2T-4T. 2T much ignition advance. 4T little ignition advance.
The problem can be corrected by the Hall position. More or less success.
I show Walbro ignition curve supply. I have created. Walbro ignition curves, hex program.
Will soon be in touch.
Click for fullsize
< Message edited by nyemi -- 8/14/2011 8:57 AM >
Regards nyemi.
Hide Signatures
(in reply to Fly42)
       Post #: 22
RE: CDI gr8flyer55 - 8/14/2011 3:32 PM  1 votes
gr8flyer55
Score: 600
Status: offline
John, I am considering moving this whole project to the rc projects site you posted the link for.
It would eliminate the beginners problems and attract only seriously interested participants.
This is definitely NOT a beginners project ! Only those with experience in this area of electronics should be attempting to build it anyway in my opinion. I have done alot of work on this project and I don't want to see it fail miserably because of someone's inability to follow simple instructions and criticize my work on this project. You and others involved from it's inception have put too many hours of work into it, because you have felt the need to produce what I feel is an excellent addition to the original ignition project initiated by JMJ and Rob. I also have other ignition related projects which I am working on for those who want the satisfaction derived from a DIY standpoint. These won't be released until we have a suitable site to post them.
John
Hide Signatures
       Post #: 23
RE: CDI gr8flyer55 - 8/14/2011 4:17 PM
Fly42
Score: 105
Status: offline
Good idea, people on the rcgroup forum do not accept "it works,becourse  I say so" you have to explain why and how it works.
< Message edited by Fly42 -- 8/14/2011 8:06 PM >
Hide Signatures
       Post #: 24
RE: CDI gr8flyer55 - 8/14/2011 8:11 PM  1 votes
gr8flyer55
Score: 600
Status: offline
Well Mr. Fly42, as I see it, you are complaining about something not working that you haven't even built and tried!
If you need proof that it works, watch my video of it actually working before you say it doesn't work. As for the project itself, it is a "do it yourself" project. Which in turn means, you gather the parts, you make the circuit board, you program the chip with the provided hex file, then and ONLY then, you decide if it is not the project to fit your needs.
If free is not cheap enough for you, then I would strongly suggest that you go out and spend your money on a commercially available ignition that fills your needs. I know you can't get RcExel to change a curve for your engine because you think it won't work without ever trying it.
I stand my ground in defense of everyone participating in this DIY project.
John
Hide Signatures
(in reply to Fly42)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> CDI gr8flyer55
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.718RCU1
