Dragon 1/6 RC jeep conversion
Has anyone Converted one of Dragon’s 1/6 Jeeps to RC, what parts did you use, this is a conversion I have on my list I very interested in what people have used and links to sites, I’m new to this so be jentle
IL
RE: Dragon 1/6 RC jeep conversion
ORIGINAL: rivetcounter
This one uses HPI wheely king axles
http://www.rccrawler.com/forum/showthread.php?t=305487
This one uses Tamiya TLT-1 axles with wideners.
http://www.rccrawler.com/forum/showthread.php?t=163242
Axial ax10 axles are a little narrower than wheely king ones and a little wider than tlt-1 ones(without wideners).
RC4wd also makes good axles.
http://store.rc4wd.com/Scale-Crawler-Axle_c_12.html
I've seen the ax10's transmission used in a 1/6 jeep successfully, but you'd want the upgrade steel output shafts(the stock aluminum ones would probably snap off immediately under the load of a 1/6 truck).
BTW, welcome to the cars and trucks section.
Thanks for the information I will look through this latter, I want to build the vehicle stock with standard size tyres, WWII style is more my inspiration as opposed to anything else
IL
