flynboy-RCU
Joined: 4/5/2002 From: Caryville, TN, USA Status: offline
Well, finally had a chance to fly mine over the weekend. Overall, the plane flies very well. I only got in two 5 minute flights (I changed the rudder to pull-pull and was getting some centering and drift issues with the rudder, which were the result of my linkage and not the plane). Also, my flights were without the cowling so... Takeoff - piece o' cake, little, if any rudder needed. tracking - tracks very well, tends to climb under power application, may need some down thrust (will check next flight) stalls, slow flight - will slow down more than expected, will drop a wing at stall, but is not violent. loops - round and large, no tendency to snap rolls - fast, not axial, but may be related to my rudder centering issue spins - spins quickly, but can also flatten out. note, my recovery from upright flat spin took over two rotations. inverted flight - required quite a bit of down ele. may be helped with downthrust. landing - flies approach good, slows down well, but took me several tries to get a decent touchdown as it was sensitive in pitch. Added some more expo to elevator and this helped some, but will take some more landings to get smooth. Some info on my config: weight - ?? didn't have scale, several people remarked on how light it is though. cg - right in middle of suggested range engine/prop - new gms 47, with apc 11x5 throws - ailerons, +-15mm; ele +-15 mm; rudder - as much as possible (approx 40-45deg) Joe
_____________________________
Fly 'n' Boy
