RE: Official HPI Savage Flux XS thread...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: Official HPI Savage Flux XS thread...
Page: <<   < prev  125 126 [127] 128 129 130 131 132 133 134   next >   >>
Login
RE: Official HPI Savage Flux XS thread... - 8/11/2012 12:35 AM
xDIRTYSOUTHx
Score: 113
Last Login: 9/27/2012
Status: offline
Was going to wait to get new shocks until the stock ones broke.. well, the rear shocks are broken after 2 packs of light bashing. The bottom plastic snapped.
Can anyone suggest some decent upgrade shocks for the XS? Was looking at some proline shock from tower but they are $50 for rear set..
I'm looking to spend around $20 or so.
_____________________________
Savage XS Flux - Bullet MT Flux
Bullet ST 3.0 - Savage X 4.6
Hide Signatures
(in reply to chasehq)
       Post #: 3151
RE: Official HPI Savage Flux XS thread... - 8/13/2012 8:02 AM
X32garrick
Score: 100
Last Login: 5/10/2013
Status: offline
 Hi everyone  I just picked up my new Savage XS ss and I need advice...
I plan to use a spare Novak Kinetic ESC & Speed Passion 4 turn sensored motor in the XS. Do you guys think this is ok?
Somebody advised me not to use the 4 turn and if so, would an LRP X12 13.5 turn be adequate?
Or if still no, could I buy an appropriate motor but use the Kinetic anyway? I'd rather not spend if I don't have to
Thank you very much in advance for all your recommendations, positive or otherwise!
Hide Signatures
(in reply to xDIRTYSOUTHx)
       Post #: 3152
RE: Official HPI Savage Flux XS thread... - 8/13/2012 5:48 PM
Thiagooo
Score: 100
Last Login: 12/12/2012
Status: offline
Estou pensando em comprar + 4 amortecedor, e instalar os mesmos. Totalizando 8 amortecedores. Será que fica bom?
De aluminio mais baratos tem os da GPM e da HOTRACING...
quote:
ORIGINAL: xDIRTYSOUTHx
Hide Signatures
       Post #: 3153
RE: Official HPI Savage Flux XS thread... - 8/13/2012 8:29 PM
xDIRTYSOUTHx
Score: 113
Status: offline
quote:
ORIGINAL: Thiagooo
Os absorvedores de choque não é o que eu estou olhando para fazer. Eu preciso 4 novos choques que são baratos. Não tenho idéia do que você está falando de
Hide Signatures
(in reply to Thiagooo)
       Post #: 3154
RE: Official HPI Savage Flux XS thread... - 8/14/2012 6:55 PM
Thiagooo
Score: 100
Status: offline
I'm talking about who has this shocks HOTRACING:
However, anyone know if it's worth putting more 4 stock shocks? Original HPI? Totaling 8 shocks?
Thank you.
quote:
ORIGINAL: Thiagooo
Hide Signatures
       Post #: 3155
RE: Official HPI Savage Flux XS thread... - 8/14/2012 8:01 PM
cumminspower5.9
Score: 211
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: Thiagooo
Thank you.
quote:
ORIGINAL: Thiagooo
I doubt its going to be worth it. The truck is light. Hell, the 1/8 Flux HP has 4 shocks and that does just fine.
-Aerodynamics and turbos are for people who can''''t build motors.
Hide Signatures
       Post #: 3156
RE: Official HPI Savage Flux XS thread... - 8/15/2012 1:18 AM
xDIRTYSOUTHx
Score: 113
Status: offline
quote:
ORIGINAL: cumminspower5.9
Hide Signatures
(in reply to cumminspower5.9)
       Post #: 3157
RE: Official HPI Savage Flux XS thread... - 8/15/2012 3:04 PM
Thiagooo
Score: 100
Status: offline
I am to make a purchase on liquidrc.com and was wondering if there is any oil or grease should I buy. For any further maintenance? In differential or engine?
thank you
Hide Signatures
       Post #: 3158
RE: Official HPI Savage Flux XS thread... - 8/16/2012 8:51 PM
Thiagooo
Score: 100
Status: offline
The difference comes bout what? grease?
Someone already switched to oil? What?
Do I need to buy the grease and go again? Never grease or changed or differentials of the motor housing ...
Hide Signatures
       Post #: 3159
RE: Official HPI Savage Flux XS thread... - 8/18/2012 10:13 PM
Asch74
Score: 100
Last Login: 8/29/2012
Status: offline
Just spent the last couple of days reading this forum when i had the time.  I own a RTR flux XS, Chase I had the exact same thing happen to me on the rear after about 5 or 6 packs truck was brand new. and found the exact same thing. all i had to replace was the bearing but when i rebuilt i put a small washer on top of the bearing before i put the pin and pinion gear back in, there previously was not a washer behind the pin. its been fine since. I actually just tore down my front diff to inspect for maintenance and the front diff had the washer behind the pin. it was put there during the build by HPI. I know my pinion shaft has a lot of slop in it. just wondering if the washer is not there, if the backside of the pinion or the pin itself is beating on the bearing causing the bearing to fail early in the diffs?
Hide Signatures
       Post #: 3160
RE: Official HPI Savage Flux XS thread... - 8/19/2012 6:58 AM
chasehq
Score: 100
Last Login: 10/30/2012
Status: offline
quote:
ORIGINAL: Thiagooo
I want to try diff oil inside the differentials too, can we use silicone diff oil? I tried a heavier grease and it seems to be oozing out the bearings a little (I could have put a bit too much in there).
I am probably looking for somewhere between 50k and 100k weight
quote:
ORIGINAL: Asch74
Sorry to hear you'rs did the same mate. I wanted to put a couple of washers/spacers in there as there was quite a bit of play in the cup when I installed the new HR cups, but didn't have anything handy at the time.
I dont think mine had a washer in there either, the remains of my rear diff are posted in that pic a page or two back.
I think you are right. With no washer in the rear the pinion shaft could very well be sliding back and forth and the pin damaging the bearing shield and letting the bearing cage and balls collapse.
Cumminspower, did yours have a washer in there rear diff?
Nearly 30 RC''s from vintage to modern, electric to petrol.
Hide Signatures
       Post #: 3161
RE: Official HPI Savage Flux XS thread... - 8/20/2012 12:59 PM
cumminspower5.9
Score: 211
Status: offline
quote:
ORIGINAL: chasehq
quote:
ORIGINAL: Thiagooo
quote:
ORIGINAL: Asch74
Thinking back to when I took it apart, I don't remember seeing one. I threw some shims in their and it helped a little, but it needs more.
Hide Signatures
       Post #: 3162
RE: Official HPI Savage Flux XS thread... - 8/23/2012 8:33 PM
chasehq
Score: 100
Status: offline
 My rear diff started slipping in and out of gear yesterday too, so i chucked a couple of washers in there behind the pin, too many and it was binding, took one out and it seems ok now ...
Hide Signatures
       Post #: 3163
RE: Official HPI Savage Flux XS thread... - 8/23/2012 8:55 PM
cumminspower5.9
Score: 211
Status: offline
quote:
ORIGINAL: chasehq
Yep, I finally got mine to be shimmed just perfect. I had the same issue. I somehow also broke a tooth off the ring gear. they mesh fine tho oddly. haven't had a chance to try it all under battery power yet, just turning it feels ok.
Hide Signatures
       Post #: 3164
RE: Official HPI Savage Flux XS thread... - 8/24/2012 1:09 AM
chasehq
Score: 100
Status: offline
quote:
ORIGINAL: chasehq
Well I am glad it has hopefully worked out for you, I gave mine a quick buzz up and down the driveway, but yet to fully test it.
I went from 20c hyperion packs to 40-80c Turnigys the other day. Need tyres now, mine are practically bald lol, still cant pop a wheelie
on demand, and forget about a flip haha. Trying to keep it straight is entertaining though.
Hide Signatures
       Post #: 3165
RE: Official HPI Savage Flux XS thread... - 8/24/2012 1:11 AM
chasehq
Score: 100
Status: offline
quote:
ORIGINAL: chasehq
Hide Signatures
       Post #: 3166
RE: Official HPI Savage Flux XS thread... - 8/25/2012 6:12 AM
chasehq
Score: 100
Status: offline
quote:
ORIGINAL: chasehq
quote:
ORIGINAL: chasehq
Scrap what I said, it doesn't work and I now know why.
Take the shims out. The shims are moving the pinion AWAY from the pin. What is happening is because there is play in the pinion shaft/rear drivecup, the shaft backs out and the pin slips out the back of the pinion and looses
drive to the rear diff. The pin and the back of the pinion on mine are wearing because of this. that pin needs to be as far inside the pinion as possible so it doesn't slip out. Shims aren't the way to fix this (you should have seen what was left of the shim closest to the pin in my diff!).
It's very simple to fix and I should have thought of this before... While removing your shims unbolt the two big allen bolts on the back of your TVP's that hold your diff to the chassis. Remove the two bolts that hold on the esc.
Find/buy some of those little foam spacers that go in the drive cups for the front and rear dogbones and put one in each drive cup between the gearbox and the rear diff. OR what I used was Tamiya o-rings that are commonly used in their
oil filled shocks (and actually some of their drive cups). This will take up the play in between the gearbox and diff and stop the diff drivecup from backing out which in turn stops the pin inside the diff from slipping out of the pinion!
I just done this to mine, in hindsight I should have taken photo's to explain, but hopefully you get the jist of it.
Hide Signatures
       Post #: 3167
RE: Official HPI Savage Flux XS thread... - 8/25/2012 9:07 PM
sparky 25
Score: 152
Last Login: 5/1/2013
Status: offline
Was running a toro 3900kv on 2s in my flux xs ss,
I was pleased with the performance but the motor got hot and would start to cut power back due to heat issues,
If I let it cool even for 1 minute it would come onto full power again, after a few packs runtime this became annoying,
Ive just bought a castle 3800kv motor but want to know if this is a down grade in speed and power to what I'm used to with the 3900kv toro motor,
I went with a lower kv rating than the stock xs flux rtr 4000kv with the toro 3900kv as I read about overheating issues on the stock rtr xs,
Is 3800kv castle motor too much of a step down in kv to have good torque and have some speed?
Its me is that you?
Hide Signatures
       Post #: 3168
RE: Official HPI Savage Flux XS thread... - 8/25/2012 10:16 PM
chasehq
Score: 100
Status: offline
I have no experience with toro motors, but i have heard lots of people choosing the castle 3800kv as the motor of choice
in the savage xs. I do know the castle has .2mm laminations compared to the toros .35  (same as vektor 4000) and the
castle has higher quality magnets which both keep the temps lower in the motor.
I also know the castle 3800 doesnt draw as much current on the esc as the vektor does, (being far more efficient and not wasting current as heat)
so this could be similar to the toro.
I honestly dont know how much of a drop you will feel, if any, with a 100kv difference, try it and find out
(and let us know your thoughts).
Hide Signatures
(in reply to sparky 25)
       Post #: 3169
RE: Official HPI Savage Flux XS thread... - 8/27/2012 1:11 AM
wyumez
Score: 101
Last Login: 10/16/2012
Status: offline
I got a GREAT deal on this little beast!
< Message edited by wyumez -- 9/1/2012 4:36 PM >
Hpi Savage, Hpi NitroMt2
Hpi Micro Rs4, Xray M18, MR-TC4 SD SSG, HPI Pro-4
Hide Signatures
       Post #: 3170
RE: Official HPI Savage Flux XS thread... - 8/27/2012 1:12 AM
wyumez
Score: 101
Status: offline
double post.. sorry.
< Message edited by wyumez -- 9/1/2012 4:38 PM >
Hide Signatures
       Post #: 3171
RE: Official HPI Savage Flux XS thread... - 8/27/2012 2:57 PM
cumminspower5.9
Score: 211
Status: offline
quote:
ORIGINAL: chasehq
quote:
ORIGINAL: chasehq
quote:
ORIGINAL: chasehq
I did the same thing with the shims. What you said makes sense tho that having the washers behind the pin won't let the pinion seat itself all the way on the pin. I did throw some of those foam spacers in each drive cup between the transmission and diff. So before you said this, I have he foam spacers and the shims in. I'll have to see how she runs. Thanks for the find!
Hide Signatures
       Post #: 3172
RE: Official HPI Savage Flux XS thread... - 8/29/2012 9:24 AM
chasehq
Score: 100
Status: offline
Yeah I would take the shims out, but let us know how you get on.
Just ordered some HPI geolandars, still an all terrain but stickier than the useless D compound stock GT2's, my GT-2s are pretty much bald after a month and a half.
I have some old tamiya king cab rims with Proline Dirt Paws on them that are good for the dirt and grass, just needed something to replace the stock ones
Hide Signatures
       Post #: 3173
RE: Official HPI Savage Flux XS thread... - 8/29/2012 12:56 PM
cumminspower5.9
Score: 211
Status: offline
quote:
ORIGINAL: chasehq
Ran it and everything is ok with it. The shims are thin and I believe that's why it is ok. Other than the clicking since my bevel/ring gear is missing a tooth, I think it all worked out after pulling the diff apart 10 times in the beginning lol.
I was thinking of getting geolanders as my next tire, but nothing grips like pins do. I run Badlands and have been for about 8 months now and they show little signs of wear.
Hide Signatures
       Post #: 3174
RE: Official HPI Savage Flux XS thread... - 8/31/2012 1:07 AM
Thiagooo
Score: 100
Status: offline
I installed another 4 bumpers, liked the end result ... seems to become more agile.
I drove about 20 minutes and stopped it, activated the protection of ESC because it was too hot.
This has nothing to do with the 100 grams more than the bumpers add right? or have?
I put a thermometer in the sink today and 10 minutes later the temperature reached 80 degrees Celsius / 175 ° Fahrenheit.
< Message edited by Thiagooo -- 9/1/2012 2:01 AM >
Hide Signatures
       Post #: 3175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.703RCU1
